[PATCH 28/52] m68k/mvme136/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning and clean up
Wed Oct 8 19:16:19 UTC 2014
 c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c | 15 +++++----------
 1 file changed, 5 insertions(+), 10 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c b/c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c
index 0d78452..04d073d 100644
--- a/c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c
+++ b/c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c
@@ -1,9 +1,8 @@
- *  This routine starts the application.  It includes application,
- *  board, and monitor specific initialization and configuration.
- *  The generic CPU dependent initialization has been performed
- *  before this routine is invoked.
+ *  This routine does the bulk of the system initialization.
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
@@ -13,13 +12,9 @@
 #include <bsp.h>
+#include <bsp/bootcard.h>
 #include <rtems/zilog/z8036.h>
- *  bsp_start
- *  This routine does the bulk of the system initialization.
 void bsp_start( void )
   rtems_isr_entry *monitors_vector_table;
1.9.3
