[PATCH 34/52] powerpc/ep1a/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning and clean up
Wed Oct 8 19:16:25 UTC 2014
 c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c b/c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c
index 92b466c..158d0dc 100644
--- a/c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c
@@ -3,7 +3,9 @@
  *  board, and monitor specific initialization and configuration.
  *  The generic CPU dependent initialization has been performed
  *  before this routine is invoked.
  *  COPYRIGHT (c) 1989-2007.
  *  On-Line Applications Research Corporation (OAR).
@@ -15,6 +17,7 @@
 #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
 #include <bsp/consoleIo.h>
+#include <bsp/bootcard.h>
 #include <libcpu/spr.h>
 #include <bsp/residual.h>
 #include <bsp/pci.h>
1.9.3
