[PATCH 44/52] sparc64/shared/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning and clean up
Wed Oct 8 19:16:35 UTC 2014
 c/src/lib/libbsp/sparc64/shared/startup/bspstart.c | 21 ++++++---------------
 1 file changed, 6 insertions(+), 15 deletions(-)
diff --git a/c/src/lib/libbsp/sparc64/shared/startup/bspstart.c b/c/src/lib/libbsp/sparc64/shared/startup/bspstart.c
index 25d4276..f6c190b 100644
--- a/c/src/lib/libbsp/sparc64/shared/startup/bspstart.c
+++ b/c/src/lib/libbsp/sparc64/shared/startup/bspstart.c
@@ -1,9 +1,8 @@
- *  This routine starts the application.  It includes application,
- *  board, and monitor specific initialization and configuration.
- *  The generic CPU dependent initialization has been performed
- *  before this routine is invoked.
+ *  This routine does the bulk of the system initialization.
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
@@ -12,20 +11,12 @@
  *  http://www.rtems.org/license/LICENSE.
-#include <string.h>
 #include <bsp.h>
+#include <bsp/bootcard.h>
 extern void sparc64_install_isr_entries(void);
- *  bsp_start
- *  This routine does the bulk of the system initialization.
 void bsp_start( void )
-/*	bootstrap(); */
-	sparc64_install_isr_entries();
+  sparc64_install_isr_entries();
1.9.3
