[PATCH 46/52] moxiertems/score/cpu.h: _CPU_Context_switch needed RTEMS_COMPILER_NO_RETURN_ATTRIBUTE plus fix warnings on unimplemented ISR enable/disable
Wed Oct 8 19:16:37 UTC 2014
 cpukit/score/cpu/moxie/rtems/score/cpu.h | 31 ++++++++++++++++++++++---------
 1 file changed, 22 insertions(+), 9 deletions(-)
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index cf22601..4b204cb 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -570,9 +570,12 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
  *  MOXIE Specific Information:
- *  XXX
+ *  TODO: As of 7 October 2014, this method is not implemented.
-#define _CPU_ISR_Disable( _isr_cookie ) (_isr_cookie) = 0
+#define _CPU_ISR_Disable( _isr_cookie ) \
+  do { \
+    (_isr_cookie) = 0; \
+  } while (0)
  *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
@@ -581,9 +584,12 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
- *  XXX
-#define _CPU_ISR_Enable( _isr_cookie )
+#define _CPU_ISR_Enable( _isr_cookie ) \
+  do { \
+    (_isr_cookie) = (_isr_cookie); \
+  } while (0)
  *  This temporarily restores the interrupt to _level before immediately
@@ -593,9 +599,13 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
- *  XXX
-#define _CPU_ISR_Flash( _isr_cookie )
+#define _CPU_ISR_Flash( _isr_cookie ) \
+  do { \
+    _CPU_ISR_Enable( _isr_cookie ); \
+    _CPU_ISR_Disable( _isr_cookie ); \
+  } while (0)
  *  Map interrupt level in task mode onto the hardware that the CPU
@@ -609,7 +619,7 @@ SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
- *  XXX
 #define _CPU_ISR_Set_level( _new_level )        \
@@ -645,7 +655,8 @@ uint32_t   _CPU_ISR_Get_level( void );
- *  XXX
+ *  TODO: As of 7 October 2014, this method does not ensure that the context
+ *  is set up with interrupts disabled/enabled as requested.
 #define CPU_CCR_INTERRUPTS_ON  0x80
 #define CPU_CCR_INTERRUPTS_OFF 0x00
@@ -656,6 +667,8 @@ uint32_t   _CPU_ISR_Get_level( void );
   do {                                                             \
     uintptr_t   _stack;                                            \
+    (void) _is_fp; /* avoid warning for being unused */            \
+    (void) _isr;   /* avoid warning for being unused */            \
     _stack = ((uintptr_t)(_stack_base)) + (_size) - 8;             \
     *((proc_ptr *)(_stack)) = (_entry_point);                      \
     _stack -= 4;                                                   \
@@ -948,7 +961,7 @@ void _CPU_Context_switch(
 void _CPU_Context_restore(
   Context_Control *new_context
+) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
  *  _CPU_Context_save_fp
1.9.3
