[PATCH 39/52] powerpc/mvme5500/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning and clean up
Wed Oct 8 20:31:46 UTC 2014
Done.
On 10/8/2014 3:22 PM, Gedare Bloom wrote:
> On Wed, Oct 8, 2014 at 3:16 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>>  c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c | 5 ++++-
>>  1 file changed, 4 insertions(+), 1 deletion(-)
>> diff --git a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
>> index 1db27a6..792d38f 100644
>> --- a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
>> +++ b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
>> @@ -3,7 +3,9 @@
>>   *  board, and monitor specific initialization and configuration.
>>   *  The generic CPU dependent initialization has been performed
>>   *  before this routine is invoked.
> Simplify comment?
>>   *  COPYRIGHT (c) 1989-2007.
>>   *  On-Line Applications Research Corporation (OAR).
>> @@ -31,6 +33,7 @@
>>  #include <libcpu/spr.h>   /* registers.h is included here */
>>  #include <bsp.h>
>> +#include <bsp/bootcard.h>
>>  #include <bsp/uart.h>
>>  #include <bsp/pci.h>
>>  #include <libcpu/bat.h>
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
