GCC 4.9.1 changes.
Wed Oct 8 21:31:45 UTC 2014
On 10/5/2014 1:23 AM, Chris Johns wrote:
> Hi,
> There are a few issues with 4.9.1 which need to be looked at. I have not
> attempted a Windows build yet.
> My question is:
>   Do we move the architectures that *do* build to 4.9.1 ?
I would lean to yes or wait for 4.9.2 to be released since it should be
close.
> If there are patches or known option required to build the failing
> architectures please let me know.
> Is anyone test builind gcc head on a regular basis ?
http://toolchain.lug-owl.de/buildbot/
I think between Sebastian starting and me piling on, every target
we have is built now. But.. I have issues with the website in that
it appears to take a long time to display them. So long you think
there aren't any results.
Sebastian.. any comments based on the gcc buildbot?
I personally have not been building the head recently. I have
enough cycles devoted to warning killing. :)
> This is the list of architectures do not build:
> bfin:
> ../../../gcc-4.9.1/libgcc/fp-bit.c: In function '__divsf3':
> ../../../gcc-4.9.1/libgcc/fp-bit.c:1082:1: internal compiler error: in
> cfg_layout_initialize, at cfgrtl.c:4233
> m32c:
> configure: error: unable to detect exception model
Is this trying C++? m32c does not support C++ at all. End of story.
> mips:
> xgcc: error: addsf3: No such file or directory
> moxie:
> We are using binutils-2.24. Is there a later release ?
> CC_TLS -DUSE_EMUTLS -o _gcov.o -MT _gcov.o -MD -MP -MF _gcov.dep
> -DL_gcov -c ../../../../gcc-4.9.1/libgcc/libgcov-driver.c
> /tmp//cc7Lxv5S.s: Assembler messages:
> /tmp//cc7Lxv5S.s:176: Error: unknown opcode sex.b $r0,$r0
>    [ AG, a rather interesting name for an instruction ]
> powerpc:
> ../../../../gcc-4.9.1/libgcc/fp-bit.c: In function '_fpadd_parts':
> ../../../../gcc-4.9.1/libgcc/fp-bit.c:738:1: internal compiler error: in
> dwf_regno, at dwarf2cfi.c:909
> Chris
> devel mailing list
> devel at rtems.org
