[PATCH 2/3 v2] LEON3 SMP: support static interrupt affinity
Thu Oct 9 09:43:17 UTC 2014
On 09/10/14 11:31, Daniel Hellstrom wrote:
> On 10/09/2014 11:13 AM, Sebastian Huber wrote:
>> On 08/10/14 15:49, Daniel Hellstrom wrote:
>>> +#ifdef RTEMS_SMP
>>> +/* Weak table used to implement static interrupt CPU affinity in a SMP
>>> + * configuration. The array index is the interrupt to be looked up, and
>>> + * the array[INTERRUPT] content is the CPU number relative to boot CPU
>>> + * index that will be servicing the interrupts from the IRQ source. The
>>> + * default is to let the first CPU (the boot cpu) to handle all
>>> + * interrupts (all zeros).
>>> +extern unsigned char sparc_irq_to_cpu[32];
>>> +#endif
>> I am not so fond of adding BSP specific solutions to deal with the interrupt
>> processor affinity.
>> I would rather enhance the interrupt manager extension API:
>> http://www.rtems.org/wiki/index.php?title=SMP#Interrupt_Support_2
>> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__interrupt__extension.html
> I see this as a first step for the BSP to support Interrupt affinity. The
> rtems_interrupt_{set,get}_affinity() will change the default IRQ2CPU mapping
> and move already installed interrupts to a specific CPU set. With this patch
> the default mapping does not have to route all IRQs to CPU0 from the start.
I am fine with adding this, but I am still not fond of it.
Since this is clearly LEON3 specific, can you please name this similar to the
LEON3_mp_irq directly above in bsp.h.
Why are these two variables not read-only?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
