[PATCH 2/8] Move Mongoose-V specific devices into BSP.
Thu Oct 9 18:39:53 UTC 2014
Putting the duart in libcpu was very optimistic and presumptuous.
It has never been used again on another SoC and is BSP specific.
 c/src/lib/libbsp/mips/genmongoosev/Makefile.am     |   7 +-
 c/src/lib/libbsp/mips/genmongoosev/README          |  54 +-
 .../libbsp/mips/genmongoosev/console/README.mguart | 100 +++
 .../lib/libbsp/mips/genmongoosev/console/conscfg.c |   2 +-
 .../lib/libbsp/mips/genmongoosev/console/mg5uart.c | 917 +++++++++++++++++++++
 .../lib/libbsp/mips/genmongoosev/console/mg5uart.h |  98 +++
 .../libbsp/mips/genmongoosev/console/mg5uart_reg.c |  58 ++
 c/src/lib/libbsp/mips/genmongoosev/include/bsp.h   |   2 +-
 .../libbsp/mips/genmongoosev/include/mongoose-v.h  | 306 +++++++
 .../lib/libbsp/mips/genmongoosev/irq/vectorisrs.c  |   2 +-
 c/src/lib/libbsp/mips/genmongoosev/preinstall.am   |  20 +
 .../libbsp/mips/genmongoosev/startup/bspstart.c    |   2 +-
 .../libbsp/mips/genmongoosev/startup/gdb-support.c |   2 +-
 c/src/lib/libcpu/mips/Makefile.am                  |  21 -
 .../lib/libcpu/mips/mongoosev/duart/README.mguart  | 101 ---
 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c    | 917 ---------------------
 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h    |  98 ---
 .../lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c  |  58 --
 .../lib/libcpu/mips/mongoosev/include/mongoose-v.h | 306 -------
 c/src/lib/libcpu/mips/preinstall.am                |  14 -
 20 files changed, 1562 insertions(+), 1523 deletions(-)
 create mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
 create mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
 create mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
 create mode 100644 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
 create mode 100644 c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
 delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duart/README.mguart
 delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c
 delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h
 delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c
 delete mode 100644 c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h
diff --git a/c/src/lib/libbsp/mips/genmongoosev/Makefile.am b/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
index fe21df4..a99fd56 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
+++ b/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
@@ -16,6 +16,11 @@ include_bsp_HEADERS += include/irq.h
 nodist_include_HEADERS = include/bspopts.h
 nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
+nodist_include_bsp_HEADERS += include/lr33000.h
+nodist_include_bsp_HEADERS += include/lr333x0.h
+nodist_include_bsp_HEADERS += include/mongoose-v.h
+nodist_include_bsp_HEADERS += include/r3000.h
+nodist_include_bsp_HEADERS += console/mg5uart.h
 DISTCLEANFILES = include/bspopts.h
 noinst_PROGRAMS =
@@ -47,6 +52,7 @@ libbsp_a_SOURCES += clock/clockdrv.c
 libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
 # console
 libbsp_a_SOURCES += console/conscfg.c
+libbsp_a_SOURCES += console/mg5uart.c
 libbsp_a_SOURCES += ../../shared/console.c
 libbsp_a_SOURCES += ../../shared/console_select.c
 libbsp_a_SOURCES += ../../shared/console_control.c
@@ -75,7 +81,6 @@ gdbstub_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 libbsp_a_LIBADD  = ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
 libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/interrupts.rel
-libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/mongoosev/duart.rel
 include $(srcdir)/preinstall.am
 include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/mips/genmongoosev/README b/c/src/lib/libbsp/mips/genmongoosev/README
index 97db696..87f57a9 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/README
+++ b/c/src/lib/libbsp/mips/genmongoosev/README
@@ -1,6 +1,56 @@
 BSP supporting the on-CPU capabilities of the Synova Mongoose-V.
-This BSP assumes that basic HW initialization is performed by
-PMON.
+The Synova Mongoose-V is a radiation hardened derivative of the
+LSI 33K with on-CPU peripherals.
+This BSP assumes that basic HW initialization is performed by PMON.
+Status
+Per-task floating point enable/disable is supported for both immediate
+and deferred FPU context swaps.
+Interrupt Levels are adapted reasonably well to the MIPS interrupt
+model. Bit 0 of the int level is a global enable/disable, corresponding
+to bit 0 of the processor's SR register.  Bits 1 thru 6 are configured
+as masks for the Int0 thru Int5 interrupts.  The 2 software interrupt
+bits are always enabled by default.  Each task maintains its own
+Interrupt Level setting, reconfiguring the SR register's interrupt bits
+whenever scheduled in.  The software ints, though not addressable via
+the various Interrupt Level functions, are maintained on a per-task
+basis, so if software manipulates them directly, things should behave as
+expected.  At the time of these udpates, the Interrupt Level was only 8
+bits, and completely supporting the global enable, software ints and the
+hardware ints would require 9 bits.  When more than 8 bits are
+available, there is no reason the software interrupts could not be added
+to the Interrupt Level.
+While supporting the Int0 thru Int5 bits in this way doesn't seem
+wonderfully useful, it does increase the level of compliance with the
+RTEMS spec.
+Interrupt Level 0 corresponds to interrupts globally enabled, software
+ints enabled and Int0 thru Int5 enabled.  If values other than 0 are
+supplied, they should be formulated to impose the desired bitmask.
+Interrupt priority is not a strong concept on this bsp, it is provided
+only by the order in which interrupts are checked.
+If during the vectoring of an interrupt, others arrive, they will all be
+processed in accordance with their ordering in SR & the peripheral
+register.  For example, if while we're vectoring Int4, Int3 and Int5 are
+asserted, Int3 will be serviced before Int5.  The peripheral interrupts
+are individually vectored as a consequence of Int5 being asserted,
+however Int5 is not itself vectored.  Within the set of peripheral
+interrupts, bit 0 is vectored first, 31 is last.
+Interrupts are not nested for MIPS1 or MIPS3 processors, but are
+processed serially as possible.  On an unloaded 50 task RTEMS program,
+runnning on a 12mhz MIPS1 processor, worst-case latencies of 100us were
+observed, the average being down at 60us or below.
+These features are principally a consequence of fixes and tweaks to the
+MIPS1 and MIPS3 processor support, and should be equally effective on
+both levels of MIPS processors for any of their bsp's.
 Address Map
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart b/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
new file mode 100644
index 0000000..7c6a290
--- /dev/null
+++ b/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
@@ -0,0 +1,100 @@
+Configuration Table Use
+sDeviceName
+   The name of this device.
+deviceType
+   This field must be SERIAL_MG5UART.
+pDeviceFns
+   The device interface control table.  This may be:
+      + mg5uart_fns for interrupt driven IO
+      + mg5uart_fns_polled for polled IO
+deviceProbe
+   This is the address of the routine which probes to see if the device
+   is present.
+pDeviceFlow
+   This field is ignored as hardware flow control is not currently supported.
+ulMargin
+    This is currently unused.
+ulHysteresis
+pDeviceParams
+    This is set to the default settings.
+ulCtrlPort1
+   This field is the address of the command register shared by both ports.
+ulCtrlPort2
+   This field is the address of the port being used.
+ulDataPort
+   This field is set to MG5UART_PORTA or MG5UART_PORTB.
+getRegister
+setRegister
+   These do NOT follow standard conventions and are ignored.
+   The register address routines are hard-coded as this is
+   an on-CPU part and assumed to provide a 32-bit wide interface.
+getData
+   This is address of the RX buffer register.
+setData
+   This is address of the TX buffer register.
+ulClock
+   baudRate Clock
+ulIntVector
+   This is the interrupt vector number associated with this chip.
+Example:
+#if (CONSOLE_USE_INTERRUPTS)
+#define MG5UART_FUNCTIONS &mg5uart_fns
+#else
+#define MG5UART_FUNCTIONS &mg5uart_fns_polled
+#endif
+  "/dev/com0",                            /* sDeviceName */
+  SERIAL_MG5UART,                         /* deviceType */
+  MG5UART_FUNCTIONS,                      /* pDeviceFns */
+  NULL,                                   /* deviceProbe, assume it is there */
+  NULL,                                   /* pDeviceFlow */
+  16,                                     /* ulMargin */
+  8,                                      /* ulHysteresis */
+  (void *) NULL,               /* NULL */ /* pDeviceParams */
+  MONGOOSEV_PERIPHERAL_COMMAND_REGISTER,  /* ulCtrlPort1 */
+  MONGOOSEV_UART0_BASE,                   /* ulCtrlPort2 */
+  MG5UART_UART0,                          /* ulDataPort */
+  mg5uart_get_register,                   /* getRegister */
+  mg5uart_set_register,                   /* setRegister */
+  NULL, /* unused */                      /* getData */
+  NULL, /* unused */                      /* setData */
+  12000000,                               /* ulClock */
+  MONGOOSEV_IRQ_UART0_RX_FRAME_ERROR      /* ulIntVector -- base for port */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c b/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
index 61ac56e..87df736 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
+++ b/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
@@ -21,7 +21,7 @@
 #include <bsp/irq.h>
 #include <libchip/serial.h>
-#include <libchip/mg5uart.h>
+#include <bsp/mg5uart.h>
 /* #define CONSOLE_USE_INTERRUPTS */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
index 0000000..8c4177a
--- /dev/null
+++ b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
@@ -0,0 +1,917 @@
+ *  @file
+ *  This file contains the termios TTY driver for the UART found
+ *  on the Synova Mongoose-V.
+ *  COPYRIGHT (c) 1989-2012.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <rtems.h>
+#include <rtems/libio.h>
+#include <rtems/score/sysstate.h>
+#include <stdlib.h>
+#include <libchip/serial.h>
+#include <libchip/sersupp.h>
+#include <bsp/mongoose-v.h>
+#include <bsp/irq.h>
+#include <bsp.h>
+ *  Indices of registers
+ *  Per chip context control
+typedef struct _mg5uart_context
+  int            mate;
+} mg5uart_context;
+ *  Define MG5UART_STATIC to nothing while debugging so the entry points
+ *  will show up in the symbol table.
+#define MG5UART_STATIC
+/* #define MG5UART_STATIC static */
+#define MG5UART_SETREG( _base, _register, _value ) \
+        MONGOOSEV_WRITE_REGISTER( _base, _register, _value )
+#define MG5UART_GETREG( _base, _register ) \
+        MONGOOSEV_READ_REGISTER( _base, _register )
+ *  Console Device Driver Support Functions
+MG5UART_STATIC int mg5uart_baud_rate(
+  int        minor,
+  uint32_t   baud,
+  uint32_t  *code
+MG5UART_STATIC void mg5uart_enable_interrupts(
+  int minor,
+  int mask
+ *  mg5uart_isr_XXX
+ *  This is the single interrupt entry point which parcels interrupts
+ *  out to the handlers for specific sources and makes sure that the
+ *  shared handler gets the right arguments.
+ *  NOTE: Yes .. this is ugly but it provides 5 interrupt source
+ *  wrappers which are nearly functionally identical.
+extern void mips_default_isr(int vector);
+#define __ISR(_TYPE, _OFFSET) \
+  MG5UART_STATIC void mg5uart_process_isr_ ## _TYPE ( \
+    int  minor \
+  MG5UART_STATIC rtems_isr mg5uart_isr_ ## _TYPE ( \
+    void *arg \
+    rtems_vector_number vector = (rtems_vector_number) arg; \
+    int   minor; \
+    for(minor=0 ; minor<Console_Port_Count ; minor++) { \
+      if( Console_Port_Tbl[minor]->deviceType == SERIAL_MG5UART && \
+          vector == Console_Port_Tbl[minor]->ulIntVector + _OFFSET ) { \
+        mg5uart_process_isr_ ## _TYPE (minor); \
+	return; \
+    mips_default_isr( vector ); \
+__ISR(rx_frame_error, MG5UART_IRQ_RX_FRAME_ERROR)
+__ISR(rx_overrun_error, MG5UART_IRQ_RX_OVERRUN_ERROR)
+__ISR(tx_empty, MG5UART_IRQ_TX_EMPTY)
+__ISR(tx_ready, MG5UART_IRQ_TX_READY)
+__ISR(rx_ready, MG5UART_IRQ_RX_READY)
+ *  mg5uart_set_attributes
+ *  This function sets the UART channel to reflect the requested termios
+ *  port settings.
+MG5UART_STATIC int mg5uart_set_attributes(
+  int minor,
+  const struct termios *t
+  uint32_t               pMG5UART_port;
+  uint32_t               pMG5UART;
+  uint32_t               cmd, cmdSave;
+  uint32_t               baudcmd;
+  uint32_t               shift;
+  rtems_interrupt_level  Irql;
+  pMG5UART      = Console_Port_Tbl[minor]->ulCtrlPort1;
+  pMG5UART_port = Console_Port_Tbl[minor]->ulCtrlPort2;
+   *  Set the baud rate
+  if (mg5uart_baud_rate( minor, t->c_cflag, &baudcmd ) == -1)
+    return -1;
+   *  Base settings
+   *  Base settings
+  cmd = MONGOOSEV_UART_CMD_RX_ENABLE | MONGOOSEV_UART_CMD_TX_ENABLE;
+   *  Parity
+  if (t->c_cflag & PARENB) {
+    cmd |= MONGOOSEV_UART_CMD_PARITY_ENABLE;
+    if (t->c_cflag & PARODD)
+      cmd |= MONGOOSEV_UART_CMD_PARITY_ODD;
+    else
+      cmd |= MONGOOSEV_UART_CMD_PARITY_EVEN;
+  } else {
+    cmd |= MONGOOSEV_UART_CMD_PARITY_DISABLE;
+   *  Character Size
+  if (t->c_cflag & CSIZE) {
+    switch (t->c_cflag & CSIZE) {
+      case CS5:
+      case CS6:
+      case CS7:
+        return -1;
+        break;
+      case CS8:
+        /* Mongoose-V only supports CS8 */
+        break;
+  } /* else default to CS8 */
+   *  Stop Bits
+#if 0
+  if (t->c_cflag & CSTOPB) {
+    /* 2 stop bits not supported by Mongoose-V uart */
+    return -1;
+#endif
+   *  XXX what about CTS/RTS
+  /* XXX */
+   *  Now write the registers
+  if ( Console_Port_Tbl[minor]->ulDataPort == MG5UART_UART0 )
+    shift = MONGOOSEV_UART0_CMD_SHIFT;
+  else
+    shift = MONGOOSEV_UART1_CMD_SHIFT;
+  rtems_interrupt_disable(Irql);
+  cmdSave = MG5UART_GETREG( pMG5UART, MG5UART_COMMAND_REGISTER );
+  MG5UART_SETREG( pMG5UART,
+		  MG5UART_COMMAND_REGISTER,
+		  (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (cmd << shift) );
+  MG5UART_SETREG( pMG5UART_port, MG5UART_BAUD_RATE, baudcmd );
+  rtems_interrupt_enable(Irql);
+  return 0;
+ *  mg5uart_initialize_context
+ *  This function sets the default values of the per port context structure.
+MG5UART_STATIC void mg5uart_initialize_context(
+  int               minor,
+  mg5uart_context  *pmg5uartContext
+  int          port;
+  unsigned int pMG5UART;
+  unsigned int pMG5UART_port;
+  pmg5uartContext->mate = -1;
+  for (port=0 ; port<Console_Port_Count ; port++ ) {
+    if ( Console_Port_Tbl[port]->ulCtrlPort1 == pMG5UART &&
+         Console_Port_Tbl[port]->ulCtrlPort2 != pMG5UART_port ) {
+      pmg5uartContext->mate = port;
+      break;
+ *  mg5uart_init
+ *  This function initializes the DUART to a quiecsent state.
+MG5UART_STATIC void mg5uart_init(int minor)
+  uint32_t  		cmdSave;
+  uint32_t  		shift;
+  mg5uart_context        *pmg5uartContext;
+  pmg5uartContext = (mg5uart_context *) malloc(sizeof(mg5uart_context));
+  Console_Port_Data[minor].pDeviceContext = (void *)pmg5uartContext;
+  mg5uart_initialize_context( minor, pmg5uartContext );
+  else
+   *  Disable the uart and leave this port disabled.
+  cmdSave = MG5UART_GETREG(pMG5UART, MG5UART_COMMAND_REGISTER) & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift);
+  MG5UART_SETREG( pMG5UART, MG5UART_COMMAND_REGISTER, cmdSave );
+   *  Disable interrupts on RX and TX for this port
+  mg5uart_enable_interrupts( minor, MG5UART_DISABLE_ALL );
+ *  mg5uart_open
+ *  This function opens a port for communication.
+ *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
+MG5UART_STATIC int mg5uart_open(
+  int      major,
+  int      minor,
+  void    *arg
+  uint32_t  	vector;
+  uint32_t      baudcmd;
+  uint32_t      shift;
+  vector        = Console_Port_Tbl[minor]->ulIntVector;
+  else
+  /* XXX default baud rate could be from configuration table */
+  (void) mg5uart_baud_rate( minor, B19200, &baudcmd );
+   *  Set the DUART channel to a default useable state
+   *  B19200, 8Nx since there is no stop bit control.
+  cmd = MONGOOSEV_UART_CMD_TX_ENABLE | MONGOOSEV_UART_CMD_RX_ENABLE;
+		  cmd = (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (cmd << shift) );
+  return RTEMS_SUCCESSFUL;
+ *  mg5uart_close
+ *  This function shuts down the requested port.
+MG5UART_STATIC int mg5uart_close(
+  int      major,
+  int      minor,
+  void    *arg
+  uint32_t      shift;
+   *  Disable interrupts from this channel and then disable it totally.
+  /* XXX interrupts */
+  cmd = MONGOOSEV_UART_CMD_TX_DISABLE | MONGOOSEV_UART_CMD_RX_DISABLE;
+  else
+  return(RTEMS_SUCCESSFUL);
+ *  mg5uart_write_polled
+ *  This routine polls out the requested character.
+MG5UART_STATIC void mg5uart_write_polled(
+  int   minor,
+  char  c
+  uint32_t                status;
+  int                     shift;
+  int                     timeout;
+    shift = MONGOOSEV_UART0_IRQ_SHIFT;
+  else
+    shift = MONGOOSEV_UART1_IRQ_SHIFT;
+   * wait for transmitter holding register to be empty
+  timeout = 2000;
+  while( --timeout )
+    status = MG5UART_GETREG(pMG5UART, MG5UART_STATUS_REGISTER) >> shift;
+    if ( (status & (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY)) ==
+            (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY) )
+      break;
+    if( (status & (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY)) )
+       break;
+     * Yield while we wait
+#if 0
+     if(_System_state_Is_up(_System_state_Get()))
+       rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
+#endif
+   * transmit character
+  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, c);
+MG5UART_STATIC void mg5uart_process_isr_rx_error(
+   int  minor,
+   uint32_t   mask
+  int                     shift;
+  else
+  /* now clear the error */
+  MG5UART_SETREG(
+     pMG5UART,
+     MG5UART_STATUS_REGISTER,
+     mask << shift );
+MG5UART_STATIC void mg5uart_process_isr_rx_frame_error(
+  int  minor
+   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_FRAME_ERROR );
+MG5UART_STATIC void mg5uart_process_isr_rx_overrun_error(
+  int  minor
+   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_OVERRUN_ERROR );
+MG5UART_STATIC void mg5uart_process_tx_isr(
+   int        minor,
+   uint32_t   source
+   int             shift;
+   mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX);
+   else
+   MG5UART_SETREG(
+      pMG5UART,
+      source << shift );
+   if( rtems_termios_dequeue_characters( Console_Port_Data[minor].termios_data, 1) )
+      mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL);
+      return;
+    *  There are no more characters to transmit.  The tx interrupts are be cleared
+    *  by writing data to the uart, so just disable the tx interrupt sources.
+   Console_Port_Data[minor].bActive = FALSE;
+   /* mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX); */
+MG5UART_STATIC void mg5uart_process_isr_tx_empty(
+  int  minor
+   /* mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_EMPTY ); */
+MG5UART_STATIC void mg5uart_process_isr_tx_ready(
+  int  minor
+   mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_READY );
+MG5UART_STATIC void mg5uart_process_isr_rx_ready(
+  int  minor
+  char       c;
+  /* reading the RX buffer automatically resets the interrupt flag */
+  c = (char) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
+  rtems_termios_enqueue_raw_characters(
+     Console_Port_Data[minor].termios_data,
+     &c, 1 );
+static rtems_irq_connect_data mg5uart_rx_frame_error_cd  = {  \
+  0,                             /* filled in at initialization */
+  mg5uart_isr_rx_frame_error,   /* filled in at initialization */
+  NULL,   /* (void *) minor */
+  NULL,
+  NULL,
+  NULL
+static rtems_irq_connect_data mg5uart_rx_overrun_error_cd  = {  \
+  mg5uart_isr_rx_overrun_error,   /* filled in at initialization */
+  NULL,
+  NULL,
+  NULL
+static rtems_irq_connect_data mg5uart_tx_empty_cd  = {  \
+  mg5uart_isr_tx_empty,   /* filled in at initialization */
+  NULL,
+  NULL,
+  NULL
+static rtems_irq_connect_data mg5uart_tx_ready_cd  = {  \
+  mg5uart_isr_tx_ready,   /* filled in at initialization */
+  NULL,
+  NULL,
+  NULL
+static rtems_irq_connect_data mg5uart_rx_ready_cd  = {  \
+  mg5uart_isr_rx_ready,   /* filled in at initialization */
+  NULL,
+  NULL,
+  NULL
+ *  mg5uart_initialize_interrupts
+ *  This routine initializes the console's receive and transmit
+ *  ring buffers and loads the appropriate vectors to handle the interrupts.
+MG5UART_STATIC void mg5uart_initialize_interrupts(int minor)
+  unsigned long v;
+  mg5uart_init(minor);
+  v = Console_Port_Tbl[minor]->ulIntVector;
+  mg5uart_rx_frame_error_cd.name    =  v + MG5UART_IRQ_RX_FRAME_ERROR;
+  mg5uart_rx_overrun_error_cd.name  =  v + MG5UART_IRQ_RX_OVERRUN_ERROR;
+  mg5uart_tx_empty_cd.name          =  v + MG5UART_IRQ_TX_EMPTY;
+  mg5uart_tx_ready_cd.name          =  v + MG5UART_IRQ_TX_READY;
+  mg5uart_rx_ready_cd.name          =  v + MG5UART_IRQ_RX_READY;
+  mg5uart_rx_frame_error_cd.handle    =  (void *)mg5uart_rx_frame_error_cd.name;
+  mg5uart_rx_overrun_error_cd.handle  =  (void *)mg5uart_rx_overrun_error_cd.name;
+  mg5uart_tx_empty_cd.handle          =  (void *)mg5uart_tx_empty_cd.name;
+  mg5uart_tx_ready_cd.handle          =  (void *)mg5uart_tx_ready_cd.name;
+  mg5uart_rx_ready_cd.handle          =  (void *)mg5uart_rx_ready_cd.name;
+  BSP_install_rtems_irq_handler( &mg5uart_rx_frame_error_cd );
+  BSP_install_rtems_irq_handler( &mg5uart_rx_overrun_error_cd );
+  BSP_install_rtems_irq_handler( &mg5uart_tx_empty_cd );
+  BSP_install_rtems_irq_handler( &mg5uart_tx_ready_cd );
+  BSP_install_rtems_irq_handler( &mg5uart_rx_ready_cd );
+ *  mg5uart_write_support_int
+ *  Console Termios output entry point when using interrupt driven output.
+MG5UART_STATIC int mg5uart_write_support_int(
+  int         minor,
+  const char *buf,
+  size_t      len
+   *  We are using interrupt driven output and termios only sends us
+   *  one character at a time.
+  if ( !len )
+     return 0;
+   *  Put the character out and enable interrupts if necessary.
+  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, *buf);
+  if( Console_Port_Data[minor].bActive == FALSE )
+     Console_Port_Data[minor].bActive = TRUE;
+  return 1;
+ *  mg5uart_write_support_polled
+ *  Console Termios output entry point when using polled output.
+MG5UART_STATIC ssize_t mg5uart_write_support_polled(
+  int         minor,
+  const char *buf,
+  size_t      len
+  int nwrite = 0;
+   * poll each byte in the string out of the port.
+  while (nwrite < len)
+    mg5uart_write_polled(minor, *buf++);
+    nwrite++;
+   * return the number of bytes written.
+  return nwrite;
+ *  mg5uart_inbyte_nonblocking_polled
+ *  Console Termios polling input entry point.
+MG5UART_STATIC int mg5uart_inbyte_nonblocking_polled(
+  int minor
+  uint32_t                status;
+  uint32_t                tmp,shift;
+  else
+  /* reset overrrun or framing errors */
+  if( (tmp = (status & 0x3)) )
+     MG5UART_SETREG(pMG5UART, MG5UART_STATUS_REGISTER, (tmp << shift) );
+  if ( status & MONGOOSEV_UART_RX_READY )
+     return (int) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
+  else
+     return -1;
+ *  mg5uart_baud_rate
+  int           minor,
+  uint32_t      baud,
+  uint32_t     *code
+  uint32_t   clock;
+  uint32_t   tmp_code;
+  uint32_t   baud_requested;
+  baud_requested = baud & CBAUD;
+  if (!baud_requested)
+    baud_requested = B9600;              /* default to 9600 baud */
+  baud_requested = rtems_termios_baud_to_number( baud_requested );
+  clock = (uint32_t) Console_Port_Tbl[minor]->ulClock;
+  if (!clock)
+    rtems_fatal_error_occurred(RTEMS_INVALID_NUMBER);
+   *  Formula is Code = round(ClockFrequency / Baud - 1).
+   *  Since this is integer math, we will divide by twice the baud and
+   *  check the remaining odd bit.
+  tmp_code = (clock / baud_requested) - 1;
+   *  From section 12.7, "Keep C>100 for best receiver operation."
+   *  That is 100 cycles which is not a lot of instructions.  It is
+   *  reasonable to think that the Mongoose-V could not keep
+   *  up with C < 100.
+  if ( tmp_code < 100 )
+    return RTEMS_INVALID_NUMBER;
+   *  upper word is receiver baud and lower word is transmitter baud
+  *code = (tmp_code << 16) | tmp_code;
+  return 0;
+ *  mg5uart_enable_interrupts
+ *  This function enables specific interrupt sources on the DUART.
+  int minor,
+  int mask
+  uint32_t  		maskSave;
+  uint32_t              shift;
+   *  Enable interrupts on RX and TX -- not break
+  else
+  maskSave = MG5UART_GETREG( pMG5UART, MG5UART_INTERRUPT_MASK_REGISTER );
+  MG5UART_SETREG(
+     pMG5UART,
+     MG5UART_INTERRUPT_MASK_REGISTER,
+     (maskSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (mask << shift) );
+ * Flow control is only supported when using interrupts
+const console_fns mg5uart_fns =
+  libchip_serial_default_probe,   /* deviceProbe */
+  mg5uart_open,                   /* deviceFirstOpen */
+  NULL,                           /* deviceLastClose */
+  NULL,                           /* deviceRead */
+  mg5uart_write_support_int,      /* deviceWrite */
+  mg5uart_initialize_interrupts,  /* deviceInitialize */
+  mg5uart_write_polled,           /* deviceWritePolled */
+  mg5uart_set_attributes,         /* deviceSetAttributes */
+  TRUE                            /* deviceOutputUsesInterrupts */
+const console_fns mg5uart_fns_polled =
+  mg5uart_close,                       /* deviceLastClose */
+  mg5uart_inbyte_nonblocking_polled,   /* deviceRead */
+  mg5uart_write_support_polled,        /* deviceWrite */
+  mg5uart_init,                        /* deviceInitialize */
+  FALSE,                               /* deviceOutputUsesInterrupts */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
index 0000000..fa7bed6
--- /dev/null
+++ b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
@@ -0,0 +1,98 @@
+ *  COPYRIGHT (c) 1989-1999.
+#ifndef _MG5UART_H_
+#define _MG5UART_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  This is the ASCII for "MG5U" which should be unique enough to
+ *  distinguish this type of serial device from others.
+#define SERIAL_MG5UART 0x474D5535
+#define MG5UART_UART0  0
+#define MG5UART_UART1  1
+ *  These are just used in the interface between this driver and
+ *  the read/write register routines when accessing the first
+ *  control port.  They are indices of registers from the bases.
+/* shared registers from peripheral base (i.e. from ulCtrlPort1) */
+#define MG5UART_COMMAND_REGISTER          0
+#define MG5UART_STATUS_REGISTER           1
+#define MG5UART_INTERRUPT_CAUSE_REGISTER  2
+#define MG5UART_INTERRUPT_MASK_REGISTER   3
+#define MG5UART_STATUS_REGISTER           0x04
+#define MG5UART_INTERRUPT_CAUSE_REGISTER  0x08
+#define MG5UART_INTERRUPT_MASK_REGISTER   0x0C
+/* port specific registers from uart base (i.e. from ulCtrlPort2) */
+#define MG5UART_RX_BUFFER  0
+#define MG5UART_TX_BUFFER  4
+#define MG5UART_BAUD_RATE  8
+ *  Interrupt mask values
+#define MG5UART_ENABLE_ALL_EXCEPT_TX MONGOOSEV_UART_ALL_RX_STATUS_BITS
+/* all rx ints on, but only tx ready.  no need to also int on tx empty */
+#define MG5UART_ENABLE_ALL           (MONGOOSEV_UART_ALL_STATUS_BITS & ~MONGOOSEV_UART_TX_EMPTY)
+#define MG5UART_DISABLE_ALL          0x0000
+ *  Assume vectors are sequential.
+#define MG5UART_IRQ_RX_FRAME_ERROR   0
+#define MG5UART_IRQ_RX_OVERRUN_ERROR 1
+#define MG5UART_IRQ_TX_EMPTY         2
+#define MG5UART_IRQ_TX_READY         3
+#define MG5UART_IRQ_RX_READY         4
+ * Driver function table
+extern const console_fns mg5uart_fns;
+extern const console_fns mg5uart_fns_polled;
+ * Default register access routines
+uint32_t   mg5uart_get_register(    /* registers are on 32-bit boundaries */
+  uint32_t    ulCtrlPort,           /*   and accessed as word             */
+  uint32_t    ucRegNum
+void  mg5uart_set_register(
+  uint32_t    ucRegNum,
+  uint32_t    ucData
+#ifdef __cplusplus
+#endif
+#endif /* _MG5UART_H_ */
diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
index 0000000..134695f
--- /dev/null
+++ b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
@@ -0,0 +1,58 @@
+ *  This file contains a typical set of register access routines which may be
+ *  used with the mg5uart chip if accesses to the chip are as follows:
+ *    + registers are accessed as uint32_t  's
+ *    + registers are only u32-aligned (no address gaps)
+ *  COPYRIGHT (c) 1989-2001.
+#include <rtems.h>
+#ifndef _MG5UART_MULTIPLIER
+#define _MG5UART_MULTIPLIER 1
+#define _MG5UART_NAME(_X) _X
+#define _MG5UART_TYPE uint32_t
+#endif
+#define CALCULATE_REGISTER_ADDRESS( _base, _reg ) \
+  (_MG5UART_TYPE *)((_base) + ((_reg) * _MG5UART_MULTIPLIER ))
+ *  MG5UART Get Register Routine
+uint8_t   _MG5UART_NAME(mg5uart_get_register)(
+  uint8_t     ucRegNum
+  _MG5UART_TYPE *port;
+  port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
+  return *port;
+ *  MG5UART Set Register Routine
+void  _MG5UART_NAME(mg5uart_set_register)(
+  uint8_t     ucRegNum,
+  uint8_t     ucData
+  *port = ucData;
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h b/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
index da4c198..5146b7f 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
+++ b/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
@@ -28,7 +28,7 @@ extern "C" {
 #include <rtems/iosupp.h>
 #include <rtems/console.h>
 #include <rtems/clockdrv.h>
-#include <libcpu/mongoose-v.h>
 #define BSP_FEATURE_IRQ_EXTENSION
 #define BSP_SHARED_HANDLER_SUPPORT      1
diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h b/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
index 0000000..e69d25a
--- /dev/null
+++ b/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
@@ -0,0 +1,306 @@
+ *  @file
+ *  MIPS Mongoose-V specific information
+#ifndef __MONGOOSEV_h
+#define __MONGOOSEV_h
+ *  Macros to assist in accessing memory mapped Mongoose registers
+#define MONGOOSEV_READ( _base ) \
+  ( *((volatile uint32_t*)(_base)) )
+#define MONGOOSEV_WRITE( _base, _value ) \
+  ( *((volatile uint32_t*)(_base)) = (_value) )
+#define MONGOOSEV_READ_REGISTER( _base, _register ) \
+  ( *((volatile uint32_t*)((_base) + (_register))) )
+#define MONGOOSEV_WRITE_REGISTER( _base, _register, _value ) \
+  ( *((volatile uint32_t*)((_base) + (_register))) = (_value) )
+ * Macros to read/write the Mongoose FPU control register.
+ *  BIU and DRAM Registers
+#define MONGOOSEV_BIU_CACHE_CONFIGURATION_REGISTER       0xFFFE0130
+#define MONGOOSEV_DRAM_CONFIGURATION_REGISTER            0xFFFE0120
+#define MONGOOSEV_REFRESH_TIMER_INITIAL_COUNTER_REGISTER 0xFFFE0010
+#define MONGOOSEV_WAIT_STATE_CONFIGURATION_REGISTER_BASE 0xFFFE0100
+ *  Peripheral Function Addresses
+ *  NOTE: Status and Interrupt Cause use the same bits
+#define MONGOOSEV_PERIPHERAL_COMMAND_REGISTER                   0xFFFE0180
+#define MONGOOSEV_PERIPHERAL_STATUS_REGISTER                    0xFFFE0184
+#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_CAUSE_REGISTER  0xFFFE0188
+#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_MASK_REGISTER   0xFFFE018C
+#define MONGOOSEV_WATCHDOG			0xBE000000
+/* UART Bits in Peripheral Command Register Bits (TX/RX tied together here) */
+#define MONGOOSEV_UART_CMD_RESET_BOTH_PORTS	0x0001
+#define MONGOOSEV_UART_CMD_LOOPBACK_CTSN	0x0002
+#define MONGOOSEV_UART_CMD_LOOPBACK_RXTX	0x0004
+#define MONGOOSEV_UART_CMD_RX_ENABLE		0x001
+#define MONGOOSEV_UART_CMD_RX_DISABLE		0x000
+#define MONGOOSEV_UART_CMD_TX_ENABLE		0x002
+#define MONGOOSEV_UART_CMD_TX_DISABLE		0x000
+#define MONGOOSEV_UART_CMD_TX_READY		0x004
+#define MONGOOSEV_UART_CMD_PARITY_ENABLE	0x008
+#define MONGOOSEV_UART_CMD_PARITY_DISABLE	0x000
+#define MONGOOSEV_UART_CMD_PARITY_EVEN		0x010
+#define MONGOOSEV_UART_CMD_PARITY_ODD		0x000
+#define MONGOOSEV_UART0_CMD_SHIFT 5
+#define MONGOOSEV_UART1_CMD_SHIFT 11
+#define MONGOOSEV_UART_CMD_TX_ENABLE_0 \
+        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_RX_ENABLE_0 \
+        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_TX_READY_0 \
+        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART0_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_ENABLE_0 \
+        (MONGOOSEV_UART_CMD_PARITY_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_DISABLE_0 \
+        (MONGOOSEV_UART_CMD_PARITY_DISABLE << MONGOOSEV_UART0_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_EVEN_0 \
+        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART0_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_ODD_0 \
+        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART0_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_TX_ENABLE_1 \
+        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_RX_ENABLE_1 \
+        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_TX_READY_1 \
+        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART1_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_ENABLE_1 \
+        (MONGOOSEV_UART_CMD_PARITY_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_DISABLE_1 \
+        (MONGOOSEV_UART_CMD_PARITY_DISABLE << MONGOOSEV_UART1_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_EVEN_1 \
+        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART1_CMD_SHIFT)
+#define MONGOOSEV_UART_CMD_PARITY_ODD_1 \
+        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART1_CMD_SHIFT)
+/* UART Bits in Peripheral Status and Interrupt Cause Register */
+#define MONGOOSEV_UART_RX_FRAME_ERROR              0x0001
+#define MONGOOSEV_UART_RX_OVERRUN_ERROR            0x0002
+#define MONGOOSEV_UART_TX_EMPTY                    0x0004
+#define MONGOOSEV_UART_TX_READY                    0x0008
+#define MONGOOSEV_UART_RX_READY                    0x0010
+#define MONGOOSEV_UART_ALL_RX_STATUS_BITS          0x0013
+#define MONGOOSEV_UART_ALL_STATUS_BITS             0x001F
+ *  The Peripheral Interrupt Status, Cause, and Mask registers have the
+ *  same bit assignments although some revisions of the document have
+ *  the Cause and Status registers incorrect.
+#define MONGOOSEV_UART0_IRQ_SHIFT 11
+#define MONGOOSEV_UART1_IRQ_SHIFT 17
+#define MONGOOSEV_UART_FRAME_ERROR_0 \
+        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
+#define MONGOOSEV_UART_RX_OVERRUN_ERROR_0 \
+        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
+#define MONGOOSEV_UART_TX_EMPTY_0 \
+        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART0_IRQ_SHIFT)
+#define MONGOOSEV_UART_TX_READY_0 \
+        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
+#define MONGOOSEV_UART_RX_READY_0 \
+        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
+#define MONGOOSEV_UART_FRAME_ERROR_1 \
+        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
+#define MONGOOSEV_UART_RX_OVERRUN_ERROR_1 \
+        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
+#define MONGOOSEV_UART_TX_EMPTY_1 \
+        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART1_IRQ_SHIFT)
+#define MONGOOSEV_UART_TX_READY_1 \
+        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
+#define MONGOOSEV_UART_RX_READY_1 \
+        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
+ *  Bits in the Peripheral Interrupt Mask Register
+** Interrupt Status/Cause/Mask register bits - from 31 to 0
+#define MONGOOSEV_EDAC_SERR_BIT          0x80000000
+#define MONGOOSEV_EDAC_MERR_BIT          0x40000000
+/* 29 - 24 reserved */
+#define MONGOOSEV_MAVN_WRITE_ACCESS      0x00800000
+#define MONGOOSEV_MAVN_READ_ACCESS       0x00400000
+#define MONGOOSEV_UART_1_RX_READY        0x00200000
+#define MONGOOSEV_UART_1_TX_READY        0x00100000
+#define MONGOOSEV_UART_1_TX_EMPTY        0x00080000
+#define MONGOOSEV_UART_1_RX_OVERRUN      0x00040000
+#define MONGOOSEV_UART_1_FRAME_ERROR     0x00020000
+#define MONGOOSEV_RESERVED_16            0x00010000
+#define MONGOOSEV_UART_0_RX_READY        0x00008000
+#define MONGOOSEV_UART_0_TX_READY        0x00004000
+#define MONGOOSEV_UART_0_TX_EMPTY        0x00002000
+#define MONGOOSEV_UART_0_RX_OVERRUN      0x00001000
+#define MONGOOSEV_UART_0_FRAME_ERROR     0x00000800
+#define MONGOOSEV_RESERVED_10            0x00000400
+#define MONGOOSEV_EXTERN_INT_9           0x00000200
+#define MONGOOSEV_EXTERN_INT_8           0x00000100
+#define MONGOOSEV_EXTERN_INT_7           0x00000080
+#define MONGOOSEV_EXTERN_INT_6           0x00000040
+#define MONGOOSEV_EXTERN_INT_5           0x00000020
+#define MONGOOSEV_EXTERN_INT_4           0x00000010
+#define MONGOOSEV_EXTERN_INT_3           0x00000008
+#define MONGOOSEV_EXTERN_INT_2           0x00000004
+#define MONGOOSEV_EXTERN_INT_1           0x00000002
+#define MONGOOSEV_EXTERN_INT_0           0x00000001
+** Peripheral Command bits (non-uart, those are defined above)
+#define MONGOOSEV_COMMAND_ENABLE_EDAC	MONGOOSEV_EDAC_SERR_BIT
+#define MONGOOSEV_COMMAND_OVERRIDE_EDAC MONGOOSEV_EDAC_MERR_BIT
+ *  EDAC Registers
+#define MONGOOSEV_EDAC_ERROR_ADDRESS_REGISTER       0xFFFE0190
+#define MONGOOSEV_EDAC_PARITY_TEST_MODE_REGISTER    0xFFFE0194
+ *  MAVN Registers
+#define MONGOOSEV_MAVN_TEST_REGISTER               0xFFFE01B4
+#define MONGOOSEV_MAVN_ACCESS_PRIVILEGE_REGISTER   0xFFFE01B8
+#define MONGOOSEV_MAVN_ACCESS_VIOLATION_REGISTER   0xFFFE01BC
+#define MONGOOSEV_MAVN_RANGE_0_REGISTER            0xFFFE01C0
+#define MONGOOSEV_MAVN_RANGE_1_REGISTER            0xFFFE01C4
+#define MONGOOSEV_MAVN_RANGE_2_REGISTER            0xFFFE01C8
+#define MONGOOSEV_MAVN_RANGE_3_REGISTER            0xFFFE01CC
+#define MONGOOSEV_MAVN_RANGE_4_REGISTER            0xFFFE01D0
+#define MONGOOSEV_MAVN_RANGE_5_REGISTER            0xFFFE01D4
+#define MONGOOSEV_MAVN_RANGE_6_REGISTER            0xFFFE01D8
+#define MONGOOSEV_MAVN_RANGE_7_REGISTER            0xFFFE01DC
+ *  Timer Base Addresses, Offsets, and Values
+#define MONGOOSEV_TIMER1_BASE    0xFFFE0000
+#define MONGOOSEV_TIMER2_BASE    0xFFFE0008
+#define MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER 0
+#define MONGOOSEV_TIMER_CONTROL_REGISTER         4
+/* Timer Control Register Constants */
+#define MONGOOSEV_TIMER_CONTROL_COUNTER_ENABLE    0x04
+#define MONGOOSEV_TIMER_CONTROL_INTERRUPT_ENABLE  0x02
+#define MONGOOSEV_TIMER_CONTROL_TIMEOUT           0x01
+ *  UART Base Addresses and Offsets
+ *  Many bits in the peripheral command register are UART related
+ *  and the bits are defined there.
+#define MONGOOSEV_UART0_BASE   0xFFFE01E8
+#define MONGOOSEV_UART1_BASE   0xFFFE01F4
+#define MONGOOSEV_RX_BUFFER    0
+#define MONGOOSEV_TX_BUFFER    4
+#define MONGOOSEV_BAUD_RATE    8
+ *  Status Register Bits
+#define SR_CUMASK	0xf0000000	/* coproc usable bits */
+#define SR_CU3		0x80000000	/* Coprocessor 3 usable */
+#define SR_CU2		0x40000000	/* Coprocessor 2 usable */
+#define SR_CU1		0x20000000	/* Coprocessor 1 usable */
+#define SR_CU0		0x10000000	/* Coprocessor 0 usable */
+#define SR_BEV		0x00400000	/* use boot exception vectors */
+#define SR_TS		0x00200000	/* TLB shutdown */
+#define SR_PE		0x00100000	/* cache parity error */
+#define SR_CM		0x00080000	/* cache miss */
+#define SR_PZ		0x00040000	/* cache parity zero */
+#define SR_SWC		0x00020000	/* swap cache */
+#define SR_ISC		0x00010000	/* Isolate data cache */
+#define SR_IMASK	0x0000ff00	/* Interrupt mask */
+#define SR_IMASK8	0x00000000	/* mask level 8 */
+#define SR_IMASK7	0x00008000	/* mask level 7 */
+#define SR_IMASK6	0x0000c000	/* mask level 6 */
+#define SR_IMASK5	0x0000e000	/* mask level 5 */
+#define SR_IMASK4	0x0000f000	/* mask level 4 */
+#define SR_IMASK3	0x0000f800	/* mask level 3 */
+#define SR_IMASK2	0x0000fc00	/* mask level 2 */
+#define SR_IMASK1	0x0000fe00	/* mask level 1 */
+#define SR_IMASK0	0x0000ff00	/* mask level 0 */
+#define SR_IBIT8	0x00008000	/* bit level 8 */
+#define SR_IBIT7	0x00004000	/* bit level 7 */
+#define SR_IBIT6	0x00002000	/* bit level 6 */
+#define SR_IBIT5	0x00001000	/* bit level 5 */
+#define SR_IBIT4	0x00000800	/* bit level 4 */
+#define SR_IBIT3	0x00000400	/* bit level 3 */
+#define SR_IBIT2	0x00000200	/* bit level 2 */
+#define SR_IBIT1	0x00000100	/* bit level 1 */
+#define SR_KUO		0x00000020	/* old kernel/user, 0 => k, 1 => u */
+#define SR_IEO		0x00000010	/* old interrupt enable, 1 => enable */
+#define SR_KUP		0x00000008	/* prev kernel/user, 0 => k, 1 => u */
+#define SR_IEP		0x00000004	/* prev interrupt enable, 1 => enable */
+#define SR_KUC		0x00000002	/* cur kernel/user, 0 => k, 1 => u */
+#define SR_IEC		0x00000001	/* cur interrupt enable, 1 => enable */
+#define SR_KUMSK	(SR_KUO|SR_IEO|SR_KUP|SR_IEP|SR_KUC|SR_IEC)
+#define SR_IMASKSHIFT	8
+#define MONGOOSEV_IC_SIZE	0x1000		/* instruction cache = 4Kbytes */
+#define MONGOOSEV_DC_SIZE	0x800		/* data cache 2Kbytes */
+#endif
diff --git a/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c b/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
index 8a23643..b7210f7 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
+++ b/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
@@ -15,7 +15,7 @@
 #include <rtems/mips/iregdef.h>
 #include <rtems/mips/idtcpu.h>
diff --git a/c/src/lib/libbsp/mips/genmongoosev/preinstall.am b/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
index f11c87a..e5988a4 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
+++ b/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
@@ -69,6 +69,26 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INC
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
+$(PROJECT_INCLUDE)/bsp/lr33000.h: include/lr33000.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lr33000.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lr33000.h
+$(PROJECT_INCLUDE)/bsp/lr333x0.h: include/lr333x0.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lr333x0.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lr333x0.h
+$(PROJECT_INCLUDE)/bsp/mongoose-v.h: include/mongoose-v.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mongoose-v.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mongoose-v.h
+$(PROJECT_INCLUDE)/bsp/r3000.h: include/r3000.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/r3000.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/r3000.h
+$(PROJECT_INCLUDE)/bsp/mg5uart.h: console/mg5uart.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mg5uart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mg5uart.h
 $(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
diff --git a/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c b/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
index 744dd69..a8dd2cb 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
+++ b/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
@@ -23,7 +23,7 @@
 #include <bsp.h>
 #include <libcpu/isr_entries.h>
 #include <bsp/irq-generic.h>
diff --git a/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c b/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
index 5f6ec0d..481774e 100644
--- a/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
+++ b/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
@@ -11,7 +11,7 @@
 #include <rtems/bspIo.h>
 #include "gdb_if.h"
diff --git a/c/src/lib/libcpu/mips/Makefile.am b/c/src/lib/libcpu/mips/Makefile.am
index 6dc6258..e4dd7ca 100644
--- a/c/src/lib/libcpu/mips/Makefile.am
+++ b/c/src/lib/libcpu/mips/Makefile.am
@@ -31,10 +31,6 @@ if tx49
 interrupts_CPPFLAGS = -DTX49
 endif
-if mongoosev
-interrupts_CPPFLAGS = -DMONGOOSEV
-endif
 noinst_PROGRAMS += shared/interrupts.rel
 shared_interrupts_rel_SOURCES = shared/interrupts/installisrentries.c \
     shared/interrupts/isr_entries.S shared/interrupts/isr_entries.h
@@ -42,23 +38,6 @@ shared_interrupts_rel_CPPFLAGS = $(AM_CPPFLAGS) $(interrupts_CPPFLAGS)
 shared_interrupts_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 include_libcpu_HEADERS += shared/interrupts/isr_entries.h
-EXTRA_DIST += mongoosev/README
-EXTRA_DIST += mongoosev/duart/README.mguart
-if mongoosev
-include_libcpu_HEADERS += mongoosev/include/mongoose-v.h
-## mongoosev/duart
-include_libchipdir = $(includedir)/libchip
-include_libchip_HEADERS = mongoosev/duart/mg5uart.h
-noinst_PROGRAMS += mongoosev/duart.rel
-mongoosev_duart_rel_SOURCES = mongoosev/duart/mg5uart.c \
-    mongoosev/duart/mg5uart.h mongoosev/duart/mg5uart_reg.c
-mongoosev_duart_rel_CPPFLAGS = $(AM_CPPFLAGS)
-mongoosev_duart_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-endif
 if tx39
 include_libcpu_HEADERS += tx39/include/tx3904.h
 endif
diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/README.mguart b/c/src/lib/libcpu/mips/mongoosev/duart/README.mguart
deleted file mode 100644
index 8073ab7..0000000
--- a/c/src/lib/libcpu/mips/mongoosev/duart/README.mguart
+++ /dev/null
@@ -1,101 +0,0 @@
-Configuration Table Use
-sDeviceName
-   The name of this device.
-deviceType
-   This field must be SERIAL_MG5UART.
-pDeviceFns
-   The device interface control table.  This may be:
-      + mg5uart_fns for interrupt driven IO
-      + mg5uart_fns_polled for polled IO
-deviceProbe
-   This is the address of the routine which probes to see if the device
-   is present.
-pDeviceFlow
-   This field is ignored as hardware flow control is not currently supported.
-ulMargin
-    This is currently unused.
-ulHysteresis
-pDeviceParams
-    This is set to the default settings.
-ulCtrlPort1
-   This field is the address of the command register shared by both ports.
-ulCtrlPort2
-   This field is the address of the port being used.
-ulDataPort
-   This field is set to MG5UART_PORTA or MG5UART_PORTB.
-getRegister
-setRegister
-   These do NOT follow standard conventions and are ignored.
-   The register address routines are hard-coded as this is
-   an on-CPU part and assumed to provide a 32-bit wide interface.
-getData
-   This is address of the RX buffer register.
-setData
-   This is address of the TX buffer register.
-ulClock
-   baudRate Clock
-ulIntVector
-   This is the interrupt vector number associated with this chip.
-Example:
-#if (CONSOLE_USE_INTERRUPTS)
-#define MG5UART_FUNCTIONS &mg5uart_fns
-#else
-#define MG5UART_FUNCTIONS &mg5uart_fns_polled
-#endif
-  "/dev/com0",                            /* sDeviceName */
-  SERIAL_MG5UART,                         /* deviceType */
-  MG5UART_FUNCTIONS,                      /* pDeviceFns */
-  NULL,                                   /* deviceProbe, assume it is there */
-  NULL,                                   /* pDeviceFlow */
-  16,                                     /* ulMargin */
-  8,                                      /* ulHysteresis */
-  (void *) NULL,               /* NULL */ /* pDeviceParams */
-  MONGOOSEV_PERIPHERAL_COMMAND_REGISTER,  /* ulCtrlPort1 */
-  MONGOOSEV_UART0_BASE,                   /* ulCtrlPort2 */
-  MG5UART_UART0,                          /* ulDataPort */
-  mg5uart_get_register,                   /* getRegister */
-  mg5uart_set_register,                   /* setRegister */
-  NULL, /* unused */                      /* getData */
-  NULL, /* unused */                      /* setData */
-  12000000,                               /* ulClock */
-  MONGOOSEV_IRQ_UART0_RX_FRAME_ERROR      /* ulIntVector -- base for port */
diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c b/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c
index 50f6586..0000000
--- a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c
+++ /dev/null
@@ -1,917 +0,0 @@
- *  @file
- *  This file contains the termios TTY driver for the UART found
- *  on the Synova Mongoose-V.
- *  COPYRIGHT (c) 1989-2012.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
-#include <rtems/libio.h>
-#include <rtems/score/sysstate.h>
-#include <stdlib.h>
-#include <libchip/serial.h>
-#include <libchip/sersupp.h>
-#include <bsp/irq.h>
-#include <bsp.h>
- *  Indices of registers
- *  Per chip context control
-typedef struct _mg5uart_context
-  int            mate;
-} mg5uart_context;
- *  Define MG5UART_STATIC to nothing while debugging so the entry points
- *  will show up in the symbol table.
-#define MG5UART_STATIC
-/* #define MG5UART_STATIC static */
-#define MG5UART_SETREG( _base, _register, _value ) \
-        MONGOOSEV_WRITE_REGISTER( _base, _register, _value )
-#define MG5UART_GETREG( _base, _register ) \
-        MONGOOSEV_READ_REGISTER( _base, _register )
- *  Console Device Driver Support Functions
-MG5UART_STATIC int mg5uart_baud_rate(
-  int        minor,
-  uint32_t   baud,
-  uint32_t  *code
-MG5UART_STATIC void mg5uart_enable_interrupts(
-  int minor,
-  int mask
- *  mg5uart_isr_XXX
- *  This is the single interrupt entry point which parcels interrupts
- *  out to the handlers for specific sources and makes sure that the
- *  shared handler gets the right arguments.
- *  NOTE: Yes .. this is ugly but it provides 5 interrupt source
- *  wrappers which are nearly functionally identical.
-extern void mips_default_isr(int vector);
-#define __ISR(_TYPE, _OFFSET) \
-  MG5UART_STATIC void mg5uart_process_isr_ ## _TYPE ( \
-    int  minor \
-  MG5UART_STATIC rtems_isr mg5uart_isr_ ## _TYPE ( \
-    void *arg \
-    rtems_vector_number vector = (rtems_vector_number) arg; \
-    int   minor; \
-    for(minor=0 ; minor<Console_Port_Count ; minor++) { \
-      if( Console_Port_Tbl[minor]->deviceType == SERIAL_MG5UART && \
-          vector == Console_Port_Tbl[minor]->ulIntVector + _OFFSET ) { \
-        mg5uart_process_isr_ ## _TYPE (minor); \
-	return; \
-    mips_default_isr( vector ); \
-__ISR(rx_frame_error, MG5UART_IRQ_RX_FRAME_ERROR)
-__ISR(rx_overrun_error, MG5UART_IRQ_RX_OVERRUN_ERROR)
-__ISR(tx_empty, MG5UART_IRQ_TX_EMPTY)
-__ISR(tx_ready, MG5UART_IRQ_TX_READY)
-__ISR(rx_ready, MG5UART_IRQ_RX_READY)
- *  mg5uart_set_attributes
- *  This function sets the UART channel to reflect the requested termios
- *  port settings.
-MG5UART_STATIC int mg5uart_set_attributes(
-  int minor,
-  const struct termios *t
-  uint32_t               pMG5UART_port;
-  uint32_t               pMG5UART;
-  uint32_t               cmd, cmdSave;
-  uint32_t               baudcmd;
-  uint32_t               shift;
-  rtems_interrupt_level  Irql;
-  pMG5UART      = Console_Port_Tbl[minor]->ulCtrlPort1;
-  pMG5UART_port = Console_Port_Tbl[minor]->ulCtrlPort2;
-   *  Set the baud rate
-  if (mg5uart_baud_rate( minor, t->c_cflag, &baudcmd ) == -1)
-    return -1;
-   *  Base settings
-   *  Base settings
-  cmd = MONGOOSEV_UART_CMD_RX_ENABLE | MONGOOSEV_UART_CMD_TX_ENABLE;
-   *  Parity
-  if (t->c_cflag & PARENB) {
-    cmd |= MONGOOSEV_UART_CMD_PARITY_ENABLE;
-    if (t->c_cflag & PARODD)
-      cmd |= MONGOOSEV_UART_CMD_PARITY_ODD;
-    else
-      cmd |= MONGOOSEV_UART_CMD_PARITY_EVEN;
-  } else {
-    cmd |= MONGOOSEV_UART_CMD_PARITY_DISABLE;
-   *  Character Size
-  if (t->c_cflag & CSIZE) {
-    switch (t->c_cflag & CSIZE) {
-      case CS5:
-      case CS6:
-      case CS7:
-        return -1;
-        break;
-      case CS8:
-        /* Mongoose-V only supports CS8 */
-        break;
-  } /* else default to CS8 */
-   *  Stop Bits
-#if 0
-  if (t->c_cflag & CSTOPB) {
-    /* 2 stop bits not supported by Mongoose-V uart */
-    return -1;
-#endif
-   *  XXX what about CTS/RTS
-  /* XXX */
-   *  Now write the registers
-  if ( Console_Port_Tbl[minor]->ulDataPort == MG5UART_UART0 )
-    shift = MONGOOSEV_UART0_CMD_SHIFT;
-  else
-    shift = MONGOOSEV_UART1_CMD_SHIFT;
-  rtems_interrupt_disable(Irql);
-  cmdSave = MG5UART_GETREG( pMG5UART, MG5UART_COMMAND_REGISTER );
-  MG5UART_SETREG( pMG5UART,
-		  MG5UART_COMMAND_REGISTER,
-		  (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (cmd << shift) );
-  MG5UART_SETREG( pMG5UART_port, MG5UART_BAUD_RATE, baudcmd );
-  rtems_interrupt_enable(Irql);
-  return 0;
- *  mg5uart_initialize_context
- *  This function sets the default values of the per port context structure.
-MG5UART_STATIC void mg5uart_initialize_context(
-  int               minor,
-  mg5uart_context  *pmg5uartContext
-  int          port;
-  unsigned int pMG5UART;
-  unsigned int pMG5UART_port;
-  pmg5uartContext->mate = -1;
-  for (port=0 ; port<Console_Port_Count ; port++ ) {
-    if ( Console_Port_Tbl[port]->ulCtrlPort1 == pMG5UART &&
-         Console_Port_Tbl[port]->ulCtrlPort2 != pMG5UART_port ) {
-      pmg5uartContext->mate = port;
-      break;
- *  mg5uart_init
- *  This function initializes the DUART to a quiecsent state.
-MG5UART_STATIC void mg5uart_init(int minor)
-  uint32_t  		cmdSave;
-  uint32_t  		shift;
-  mg5uart_context        *pmg5uartContext;
-  pmg5uartContext = (mg5uart_context *) malloc(sizeof(mg5uart_context));
-  Console_Port_Data[minor].pDeviceContext = (void *)pmg5uartContext;
-  mg5uart_initialize_context( minor, pmg5uartContext );
-  else
-   *  Disable the uart and leave this port disabled.
-  cmdSave = MG5UART_GETREG(pMG5UART, MG5UART_COMMAND_REGISTER) & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift);
-  MG5UART_SETREG( pMG5UART, MG5UART_COMMAND_REGISTER, cmdSave );
-   *  Disable interrupts on RX and TX for this port
-  mg5uart_enable_interrupts( minor, MG5UART_DISABLE_ALL );
- *  mg5uart_open
- *  This function opens a port for communication.
- *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
-MG5UART_STATIC int mg5uart_open(
-  int      major,
-  int      minor,
-  void    *arg
-  uint32_t  	vector;
-  uint32_t      baudcmd;
-  uint32_t      shift;
-  vector        = Console_Port_Tbl[minor]->ulIntVector;
-  else
-  /* XXX default baud rate could be from configuration table */
-  (void) mg5uart_baud_rate( minor, B19200, &baudcmd );
-   *  Set the DUART channel to a default useable state
-   *  B19200, 8Nx since there is no stop bit control.
-  cmd = MONGOOSEV_UART_CMD_TX_ENABLE | MONGOOSEV_UART_CMD_RX_ENABLE;
-		  cmd = (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (cmd << shift) );
-  return RTEMS_SUCCESSFUL;
- *  mg5uart_close
- *  This function shuts down the requested port.
-MG5UART_STATIC int mg5uart_close(
-  int      major,
-  int      minor,
-  void    *arg
-  uint32_t      shift;
-   *  Disable interrupts from this channel and then disable it totally.
-  /* XXX interrupts */
-  cmd = MONGOOSEV_UART_CMD_TX_DISABLE | MONGOOSEV_UART_CMD_RX_DISABLE;
-  else
-  return(RTEMS_SUCCESSFUL);
- *  mg5uart_write_polled
- *  This routine polls out the requested character.
-MG5UART_STATIC void mg5uart_write_polled(
-  int   minor,
-  char  c
-  uint32_t                status;
-  int                     shift;
-  int                     timeout;
-    shift = MONGOOSEV_UART0_IRQ_SHIFT;
-  else
-    shift = MONGOOSEV_UART1_IRQ_SHIFT;
-   * wait for transmitter holding register to be empty
-  timeout = 2000;
-  while( --timeout )
-    status = MG5UART_GETREG(pMG5UART, MG5UART_STATUS_REGISTER) >> shift;
-    if ( (status & (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY)) ==
-            (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY) )
-      break;
-    if( (status & (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY)) )
-       break;
-     * Yield while we wait
-#if 0
-     if(_System_state_Is_up(_System_state_Get()))
-       rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
-#endif
-   * transmit character
-  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, c);
-MG5UART_STATIC void mg5uart_process_isr_rx_error(
-   int  minor,
-   uint32_t   mask
-  int                     shift;
-  else
-  /* now clear the error */
-  MG5UART_SETREG(
-     pMG5UART,
-     MG5UART_STATUS_REGISTER,
-     mask << shift );
-MG5UART_STATIC void mg5uart_process_isr_rx_frame_error(
-  int  minor
-   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_FRAME_ERROR );
-MG5UART_STATIC void mg5uart_process_isr_rx_overrun_error(
-  int  minor
-   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_OVERRUN_ERROR );
-MG5UART_STATIC void mg5uart_process_tx_isr(
-   int        minor,
-   uint32_t   source
-   int             shift;
-   mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX);
-   else
-   MG5UART_SETREG(
-      pMG5UART,
-      source << shift );
-   if( rtems_termios_dequeue_characters( Console_Port_Data[minor].termios_data, 1) )
-      mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL);
-      return;
-    *  There are no more characters to transmit.  The tx interrupts are be cleared
-    *  by writing data to the uart, so just disable the tx interrupt sources.
-   Console_Port_Data[minor].bActive = FALSE;
-   /* mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX); */
-MG5UART_STATIC void mg5uart_process_isr_tx_empty(
-  int  minor
-   /* mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_EMPTY ); */
-MG5UART_STATIC void mg5uart_process_isr_tx_ready(
-  int  minor
-   mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_READY );
-MG5UART_STATIC void mg5uart_process_isr_rx_ready(
-  int  minor
-  char       c;
-  /* reading the RX buffer automatically resets the interrupt flag */
-  c = (char) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
-  rtems_termios_enqueue_raw_characters(
-     Console_Port_Data[minor].termios_data,
-     &c, 1 );
-static rtems_irq_connect_data mg5uart_rx_frame_error_cd  = {  \
-  0,                             /* filled in at initialization */
-  mg5uart_isr_rx_frame_error,   /* filled in at initialization */
-  NULL,   /* (void *) minor */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_rx_overrun_error_cd  = {  \
-  mg5uart_isr_rx_overrun_error,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_tx_empty_cd  = {  \
-  mg5uart_isr_tx_empty,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_tx_ready_cd  = {  \
-  mg5uart_isr_tx_ready,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
-static rtems_irq_connect_data mg5uart_rx_ready_cd  = {  \
-  mg5uart_isr_rx_ready,   /* filled in at initialization */
-  NULL,
-  NULL,
-  NULL
- *  mg5uart_initialize_interrupts
- *  This routine initializes the console's receive and transmit
- *  ring buffers and loads the appropriate vectors to handle the interrupts.
-MG5UART_STATIC void mg5uart_initialize_interrupts(int minor)
-  unsigned long v;
-  mg5uart_init(minor);
-  v = Console_Port_Tbl[minor]->ulIntVector;
-  mg5uart_rx_frame_error_cd.name    =  v + MG5UART_IRQ_RX_FRAME_ERROR;
-  mg5uart_rx_overrun_error_cd.name  =  v + MG5UART_IRQ_RX_OVERRUN_ERROR;
-  mg5uart_tx_empty_cd.name          =  v + MG5UART_IRQ_TX_EMPTY;
-  mg5uart_tx_ready_cd.name          =  v + MG5UART_IRQ_TX_READY;
-  mg5uart_rx_ready_cd.name          =  v + MG5UART_IRQ_RX_READY;
-  mg5uart_rx_frame_error_cd.handle    =  (void *)mg5uart_rx_frame_error_cd.name;
-  mg5uart_rx_overrun_error_cd.handle  =  (void *)mg5uart_rx_overrun_error_cd.name;
-  mg5uart_tx_empty_cd.handle          =  (void *)mg5uart_tx_empty_cd.name;
-  mg5uart_tx_ready_cd.handle          =  (void *)mg5uart_tx_ready_cd.name;
-  mg5uart_rx_ready_cd.handle          =  (void *)mg5uart_rx_ready_cd.name;
-  BSP_install_rtems_irq_handler( &mg5uart_rx_frame_error_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_rx_overrun_error_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_tx_empty_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_tx_ready_cd );
-  BSP_install_rtems_irq_handler( &mg5uart_rx_ready_cd );
- *  mg5uart_write_support_int
- *  Console Termios output entry point when using interrupt driven output.
-MG5UART_STATIC int mg5uart_write_support_int(
-  int         minor,
-  const char *buf,
-  size_t      len
-   *  We are using interrupt driven output and termios only sends us
-   *  one character at a time.
-  if ( !len )
-     return 0;
-   *  Put the character out and enable interrupts if necessary.
-  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, *buf);
-  if( Console_Port_Data[minor].bActive == FALSE )
-     Console_Port_Data[minor].bActive = TRUE;
-  return 1;
- *  mg5uart_write_support_polled
- *  Console Termios output entry point when using polled output.
-MG5UART_STATIC ssize_t mg5uart_write_support_polled(
-  int         minor,
-  const char *buf,
-  size_t      len
-  int nwrite = 0;
-   * poll each byte in the string out of the port.
-  while (nwrite < len)
-    mg5uart_write_polled(minor, *buf++);
-    nwrite++;
-   * return the number of bytes written.
-  return nwrite;
- *  mg5uart_inbyte_nonblocking_polled
- *  Console Termios polling input entry point.
-MG5UART_STATIC int mg5uart_inbyte_nonblocking_polled(
-  int minor
-  uint32_t                status;
-  uint32_t                tmp,shift;
-  else
-  /* reset overrrun or framing errors */
-  if( (tmp = (status & 0x3)) )
-     MG5UART_SETREG(pMG5UART, MG5UART_STATUS_REGISTER, (tmp << shift) );
-  if ( status & MONGOOSEV_UART_RX_READY )
-     return (int) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
-  else
-     return -1;
- *  mg5uart_baud_rate
-  int           minor,
-  uint32_t      baud,
-  uint32_t     *code
-  uint32_t   clock;
-  uint32_t   tmp_code;
-  uint32_t   baud_requested;
-  baud_requested = baud & CBAUD;
-  if (!baud_requested)
-    baud_requested = B9600;              /* default to 9600 baud */
-  baud_requested = rtems_termios_baud_to_number( baud_requested );
-  clock = (uint32_t) Console_Port_Tbl[minor]->ulClock;
-  if (!clock)
-    rtems_fatal_error_occurred(RTEMS_INVALID_NUMBER);
-   *  Formula is Code = round(ClockFrequency / Baud - 1).
-   *  Since this is integer math, we will divide by twice the baud and
-   *  check the remaining odd bit.
-  tmp_code = (clock / baud_requested) - 1;
-   *  From section 12.7, "Keep C>100 for best receiver operation."
-   *  That is 100 cycles which is not a lot of instructions.  It is
-   *  reasonable to think that the Mongoose-V could not keep
-   *  up with C < 100.
-  if ( tmp_code < 100 )
-    return RTEMS_INVALID_NUMBER;
-   *  upper word is receiver baud and lower word is transmitter baud
-  *code = (tmp_code << 16) | tmp_code;
-  return 0;
- *  mg5uart_enable_interrupts
- *  This function enables specific interrupt sources on the DUART.
-  int minor,
-  int mask
-  uint32_t  		maskSave;
-  uint32_t              shift;
-   *  Enable interrupts on RX and TX -- not break
-  else
-  maskSave = MG5UART_GETREG( pMG5UART, MG5UART_INTERRUPT_MASK_REGISTER );
-  MG5UART_SETREG(
-     pMG5UART,
-     MG5UART_INTERRUPT_MASK_REGISTER,
-     (maskSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (mask << shift) );
- * Flow control is only supported when using interrupts
-const console_fns mg5uart_fns =
-  libchip_serial_default_probe,   /* deviceProbe */
-  mg5uart_open,                   /* deviceFirstOpen */
-  NULL,                           /* deviceLastClose */
-  NULL,                           /* deviceRead */
-  mg5uart_write_support_int,      /* deviceWrite */
-  mg5uart_initialize_interrupts,  /* deviceInitialize */
-  mg5uart_write_polled,           /* deviceWritePolled */
-  mg5uart_set_attributes,         /* deviceSetAttributes */
-  TRUE                            /* deviceOutputUsesInterrupts */
-const console_fns mg5uart_fns_polled =
-  mg5uart_close,                       /* deviceLastClose */
-  mg5uart_inbyte_nonblocking_polled,   /* deviceRead */
-  mg5uart_write_support_polled,        /* deviceWrite */
-  mg5uart_init,                        /* deviceInitialize */
-  FALSE,                               /* deviceOutputUsesInterrupts */
diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h b/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h
index fa7bed6..0000000
--- a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h
+++ /dev/null
@@ -1,98 +0,0 @@
- *  COPYRIGHT (c) 1989-1999.
-#ifndef _MG5UART_H_
-#define _MG5UART_H_
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This is the ASCII for "MG5U" which should be unique enough to
- *  distinguish this type of serial device from others.
-#define SERIAL_MG5UART 0x474D5535
-#define MG5UART_UART0  0
-#define MG5UART_UART1  1
- *  These are just used in the interface between this driver and
- *  the read/write register routines when accessing the first
- *  control port.  They are indices of registers from the bases.
-/* shared registers from peripheral base (i.e. from ulCtrlPort1) */
-#define MG5UART_COMMAND_REGISTER          0
-#define MG5UART_STATUS_REGISTER           1
-#define MG5UART_INTERRUPT_CAUSE_REGISTER  2
-#define MG5UART_INTERRUPT_MASK_REGISTER   3
-#define MG5UART_STATUS_REGISTER           0x04
-#define MG5UART_INTERRUPT_CAUSE_REGISTER  0x08
-#define MG5UART_INTERRUPT_MASK_REGISTER   0x0C
-/* port specific registers from uart base (i.e. from ulCtrlPort2) */
-#define MG5UART_RX_BUFFER  0
-#define MG5UART_TX_BUFFER  4
-#define MG5UART_BAUD_RATE  8
- *  Interrupt mask values
-#define MG5UART_ENABLE_ALL_EXCEPT_TX MONGOOSEV_UART_ALL_RX_STATUS_BITS
-/* all rx ints on, but only tx ready.  no need to also int on tx empty */
-#define MG5UART_ENABLE_ALL           (MONGOOSEV_UART_ALL_STATUS_BITS & ~MONGOOSEV_UART_TX_EMPTY)
-#define MG5UART_DISABLE_ALL          0x0000
- *  Assume vectors are sequential.
-#define MG5UART_IRQ_RX_FRAME_ERROR   0
-#define MG5UART_IRQ_RX_OVERRUN_ERROR 1
-#define MG5UART_IRQ_TX_EMPTY         2
-#define MG5UART_IRQ_TX_READY         3
-#define MG5UART_IRQ_RX_READY         4
- * Driver function table
-extern const console_fns mg5uart_fns;
-extern const console_fns mg5uart_fns_polled;
- * Default register access routines
-uint32_t   mg5uart_get_register(    /* registers are on 32-bit boundaries */
-  uint32_t    ulCtrlPort,           /*   and accessed as word             */
-  uint32_t    ucRegNum
-void  mg5uart_set_register(
-  uint32_t    ucRegNum,
-  uint32_t    ucData
-#ifdef __cplusplus
-#endif
-#endif /* _MG5UART_H_ */
diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c b/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c
index 134695f..0000000
--- a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c
+++ /dev/null
@@ -1,58 +0,0 @@
- *  This file contains a typical set of register access routines which may be
- *  used with the mg5uart chip if accesses to the chip are as follows:
- *    + registers are accessed as uint32_t  's
- *    + registers are only u32-aligned (no address gaps)
- *  COPYRIGHT (c) 1989-2001.
-#include <rtems.h>
-#ifndef _MG5UART_MULTIPLIER
-#define _MG5UART_MULTIPLIER 1
-#define _MG5UART_NAME(_X) _X
-#define _MG5UART_TYPE uint32_t
-#endif
-#define CALCULATE_REGISTER_ADDRESS( _base, _reg ) \
-  (_MG5UART_TYPE *)((_base) + ((_reg) * _MG5UART_MULTIPLIER ))
- *  MG5UART Get Register Routine
-uint8_t   _MG5UART_NAME(mg5uart_get_register)(
-  uint8_t     ucRegNum
-  _MG5UART_TYPE *port;
-  port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
-  return *port;
- *  MG5UART Set Register Routine
-void  _MG5UART_NAME(mg5uart_set_register)(
-  uint8_t     ucRegNum,
-  uint8_t     ucData
-  *port = ucData;
diff --git a/c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h b/c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h
index b8ded3d..0000000
--- a/c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h
+++ /dev/null
@@ -1,306 +0,0 @@
- *  @file
- *  MIPS Mongoose-V specific information
-#ifndef __MONGOOSEV_h
-#define __MONGOOSEV_h
- *  Macros to assist in accessing memory mapped Mongoose registers
-#define MONGOOSEV_READ( _base ) \
-  ( *((volatile uint32_t*)(_base)) )
-#define MONGOOSEV_WRITE( _base, _value ) \
-  ( *((volatile uint32_t*)(_base)) = (_value) )
-#define MONGOOSEV_READ_REGISTER( _base, _register ) \
-  ( *((volatile uint32_t*)((_base) + (_register))) )
-#define MONGOOSEV_WRITE_REGISTER( _base, _register, _value ) \
-  ( *((volatile uint32_t*)((_base) + (_register))) = (_value) )
- * Macros to read/write the Mongoose FPU control register.
- *  BIU and DRAM Registers
-#define MONGOOSEV_BIU_CACHE_CONFIGURATION_REGISTER       0xFFFE0130
-#define MONGOOSEV_DRAM_CONFIGURATION_REGISTER            0xFFFE0120
-#define MONGOOSEV_REFRESH_TIMER_INITIAL_COUNTER_REGISTER 0xFFFE0010
-#define MONGOOSEV_WAIT_STATE_CONFIGURATION_REGISTER_BASE 0xFFFE0100
- *  Peripheral Function Addresses
- *  NOTE: Status and Interrupt Cause use the same bits
-#define MONGOOSEV_PERIPHERAL_COMMAND_REGISTER                   0xFFFE0180
-#define MONGOOSEV_PERIPHERAL_STATUS_REGISTER                    0xFFFE0184
-#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_CAUSE_REGISTER  0xFFFE0188
-#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_MASK_REGISTER   0xFFFE018C
-#define MONGOOSEV_WATCHDOG			0xBE000000
-/* UART Bits in Peripheral Command Register Bits (TX/RX tied together here) */
-#define MONGOOSEV_UART_CMD_RESET_BOTH_PORTS	0x0001
-#define MONGOOSEV_UART_CMD_LOOPBACK_CTSN	0x0002
-#define MONGOOSEV_UART_CMD_LOOPBACK_RXTX	0x0004
-#define MONGOOSEV_UART_CMD_RX_ENABLE		0x001
-#define MONGOOSEV_UART_CMD_RX_DISABLE		0x000
-#define MONGOOSEV_UART_CMD_TX_ENABLE		0x002
-#define MONGOOSEV_UART_CMD_TX_DISABLE		0x000
-#define MONGOOSEV_UART_CMD_TX_READY		0x004
-#define MONGOOSEV_UART_CMD_PARITY_ENABLE	0x008
-#define MONGOOSEV_UART_CMD_PARITY_DISABLE	0x000
-#define MONGOOSEV_UART_CMD_PARITY_EVEN		0x010
-#define MONGOOSEV_UART_CMD_PARITY_ODD		0x000
-#define MONGOOSEV_UART0_CMD_SHIFT 5
-#define MONGOOSEV_UART1_CMD_SHIFT 11
-#define MONGOOSEV_UART_CMD_TX_ENABLE_0 \
-        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_RX_ENABLE_0 \
-        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_TX_READY_0 \
-        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ENABLE_0 \
-        (MONGOOSEV_UART_CMD_PARITY_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_DISABLE_0 \
-        (MONGOOSEV_UART_CMD_PARITY_DISABLE << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_EVEN_0 \
-        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ODD_0 \
-        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART0_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_TX_ENABLE_1 \
-        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_RX_ENABLE_1 \
-        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_TX_READY_1 \
-        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ENABLE_1 \
-        (MONGOOSEV_UART_CMD_PARITY_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_DISABLE_1 \
-        (MONGOOSEV_UART_CMD_PARITY_DISABLE << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_EVEN_1 \
-        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART1_CMD_SHIFT)
-#define MONGOOSEV_UART_CMD_PARITY_ODD_1 \
-        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART1_CMD_SHIFT)
-/* UART Bits in Peripheral Status and Interrupt Cause Register */
-#define MONGOOSEV_UART_RX_FRAME_ERROR              0x0001
-#define MONGOOSEV_UART_RX_OVERRUN_ERROR            0x0002
-#define MONGOOSEV_UART_TX_EMPTY                    0x0004
-#define MONGOOSEV_UART_TX_READY                    0x0008
-#define MONGOOSEV_UART_RX_READY                    0x0010
-#define MONGOOSEV_UART_ALL_RX_STATUS_BITS          0x0013
-#define MONGOOSEV_UART_ALL_STATUS_BITS             0x001F
- *  The Peripheral Interrupt Status, Cause, and Mask registers have the
- *  same bit assignments although some revisions of the document have
- *  the Cause and Status registers incorrect.
-#define MONGOOSEV_UART0_IRQ_SHIFT 11
-#define MONGOOSEV_UART1_IRQ_SHIFT 17
-#define MONGOOSEV_UART_FRAME_ERROR_0 \
-        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_OVERRUN_ERROR_0 \
-        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_EMPTY_0 \
-        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_READY_0 \
-        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_READY_0 \
-        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
-#define MONGOOSEV_UART_FRAME_ERROR_1 \
-        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_OVERRUN_ERROR_1 \
-        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_EMPTY_1 \
-        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_TX_READY_1 \
-        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
-#define MONGOOSEV_UART_RX_READY_1 \
-        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
- *  Bits in the Peripheral Interrupt Mask Register
-** Interrupt Status/Cause/Mask register bits - from 31 to 0
-#define MONGOOSEV_EDAC_SERR_BIT          0x80000000
-#define MONGOOSEV_EDAC_MERR_BIT          0x40000000
-/* 29 - 24 reserved */
-#define MONGOOSEV_MAVN_WRITE_ACCESS      0x00800000
-#define MONGOOSEV_MAVN_READ_ACCESS       0x00400000
-#define MONGOOSEV_UART_1_RX_READY        0x00200000
-#define MONGOOSEV_UART_1_TX_READY        0x00100000
-#define MONGOOSEV_UART_1_TX_EMPTY        0x00080000
-#define MONGOOSEV_UART_1_RX_OVERRUN      0x00040000
-#define MONGOOSEV_UART_1_FRAME_ERROR     0x00020000
-#define MONGOOSEV_RESERVED_16            0x00010000
-#define MONGOOSEV_UART_0_RX_READY        0x00008000
-#define MONGOOSEV_UART_0_TX_READY        0x00004000
-#define MONGOOSEV_UART_0_TX_EMPTY        0x00002000
-#define MONGOOSEV_UART_0_RX_OVERRUN      0x00001000
-#define MONGOOSEV_UART_0_FRAME_ERROR     0x00000800
-#define MONGOOSEV_RESERVED_10            0x00000400
-#define MONGOOSEV_EXTERN_INT_9           0x00000200
-#define MONGOOSEV_EXTERN_INT_8           0x00000100
-#define MONGOOSEV_EXTERN_INT_7           0x00000080
-#define MONGOOSEV_EXTERN_INT_6           0x00000040
-#define MONGOOSEV_EXTERN_INT_5           0x00000020
-#define MONGOOSEV_EXTERN_INT_4           0x00000010
-#define MONGOOSEV_EXTERN_INT_3           0x00000008
-#define MONGOOSEV_EXTERN_INT_2           0x00000004
-#define MONGOOSEV_EXTERN_INT_1           0x00000002
-#define MONGOOSEV_EXTERN_INT_0           0x00000001
-** Peripheral Command bits (non-uart, those are defined above)
-#define MONGOOSEV_COMMAND_ENABLE_EDAC	MONGOOSEV_EDAC_SERR_BIT
-#define MONGOOSEV_COMMAND_OVERRIDE_EDAC MONGOOSEV_EDAC_MERR_BIT
- *  EDAC Registers
-#define MONGOOSEV_EDAC_ERROR_ADDRESS_REGISTER       0xFFFE0190
-#define MONGOOSEV_EDAC_PARITY_TEST_MODE_REGISTER    0xFFFE0194
- *  MAVN Registers
-#define MONGOOSEV_MAVN_TEST_REGISTER               0xFFFE01B4
-#define MONGOOSEV_MAVN_ACCESS_PRIVILEGE_REGISTER   0xFFFE01B8
-#define MONGOOSEV_MAVN_ACCESS_VIOLATION_REGISTER   0xFFFE01BC
-#define MONGOOSEV_MAVN_RANGE_0_REGISTER            0xFFFE01C0
-#define MONGOOSEV_MAVN_RANGE_1_REGISTER            0xFFFE01C4
-#define MONGOOSEV_MAVN_RANGE_2_REGISTER            0xFFFE01C8
-#define MONGOOSEV_MAVN_RANGE_3_REGISTER            0xFFFE01CC
-#define MONGOOSEV_MAVN_RANGE_4_REGISTER            0xFFFE01D0
-#define MONGOOSEV_MAVN_RANGE_5_REGISTER            0xFFFE01D4
-#define MONGOOSEV_MAVN_RANGE_6_REGISTER            0xFFFE01D8
-#define MONGOOSEV_MAVN_RANGE_7_REGISTER            0xFFFE01DC
- *  Timer Base Addresses, Offsets, and Values
-#define MONGOOSEV_TIMER1_BASE    0xFFFE0000
-#define MONGOOSEV_TIMER2_BASE    0xFFFE0008
-#define MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER 0
-#define MONGOOSEV_TIMER_CONTROL_REGISTER         4
-/* Timer Control Register Constants */
-#define MONGOOSEV_TIMER_CONTROL_COUNTER_ENABLE    0x04
-#define MONGOOSEV_TIMER_CONTROL_INTERRUPT_ENABLE  0x02
-#define MONGOOSEV_TIMER_CONTROL_TIMEOUT           0x01
- *  UART Base Addresses and Offsets
- *  Many bits in the peripheral command register are UART related
- *  and the bits are defined there.
-#define MONGOOSEV_UART0_BASE   0xFFFE01E8
-#define MONGOOSEV_UART1_BASE   0xFFFE01F4
-#define MONGOOSEV_RX_BUFFER    0
-#define MONGOOSEV_TX_BUFFER    4
-#define MONGOOSEV_BAUD_RATE    8
- *  Status Register Bits
-#define SR_CUMASK	0xf0000000	/* coproc usable bits */
-#define SR_CU3		0x80000000	/* Coprocessor 3 usable */
-#define SR_CU2		0x40000000	/* Coprocessor 2 usable */
-#define SR_CU1		0x20000000	/* Coprocessor 1 usable */
-#define SR_CU0		0x10000000	/* Coprocessor 0 usable */
-#define SR_BEV		0x00400000	/* use boot exception vectors */
-#define SR_TS		0x00200000	/* TLB shutdown */
-#define SR_PE		0x00100000	/* cache parity error */
-#define SR_CM		0x00080000	/* cache miss */
-#define SR_PZ		0x00040000	/* cache parity zero */
-#define SR_SWC		0x00020000	/* swap cache */
-#define SR_ISC		0x00010000	/* Isolate data cache */
-#define SR_IMASK	0x0000ff00	/* Interrupt mask */
-#define SR_IMASK8	0x00000000	/* mask level 8 */
-#define SR_IMASK7	0x00008000	/* mask level 7 */
-#define SR_IMASK6	0x0000c000	/* mask level 6 */
-#define SR_IMASK5	0x0000e000	/* mask level 5 */
-#define SR_IMASK4	0x0000f000	/* mask level 4 */
-#define SR_IMASK3	0x0000f800	/* mask level 3 */
-#define SR_IMASK2	0x0000fc00	/* mask level 2 */
-#define SR_IMASK1	0x0000fe00	/* mask level 1 */
-#define SR_IMASK0	0x0000ff00	/* mask level 0 */
-#define SR_IBIT8	0x00008000	/* bit level 8 */
-#define SR_IBIT7	0x00004000	/* bit level 7 */
-#define SR_IBIT6	0x00002000	/* bit level 6 */
-#define SR_IBIT5	0x00001000	/* bit level 5 */
-#define SR_IBIT4	0x00000800	/* bit level 4 */
-#define SR_IBIT3	0x00000400	/* bit level 3 */
-#define SR_IBIT2	0x00000200	/* bit level 2 */
-#define SR_IBIT1	0x00000100	/* bit level 1 */
-#define SR_KUO		0x00000020	/* old kernel/user, 0 => k, 1 => u */
-#define SR_IEO		0x00000010	/* old interrupt enable, 1 => enable */
-#define SR_KUP		0x00000008	/* prev kernel/user, 0 => k, 1 => u */
-#define SR_IEP		0x00000004	/* prev interrupt enable, 1 => enable */
-#define SR_KUC		0x00000002	/* cur kernel/user, 0 => k, 1 => u */
-#define SR_IEC		0x00000001	/* cur interrupt enable, 1 => enable */
-#define SR_KUMSK	(SR_KUO|SR_IEO|SR_KUP|SR_IEP|SR_KUC|SR_IEC)
-#define SR_IMASKSHIFT	8
-#define MONGOOSEV_IC_SIZE	0x1000		/* instruction cache = 4Kbytes */
-#define MONGOOSEV_DC_SIZE	0x800		/* data cache 2Kbytes */
-#endif
diff --git a/c/src/lib/libcpu/mips/preinstall.am b/c/src/lib/libcpu/mips/preinstall.am
index 4a83d60..85aec82 100644
--- a/c/src/lib/libcpu/mips/preinstall.am
+++ b/c/src/lib/libcpu/mips/preinstall.am
@@ -26,20 +26,6 @@ $(PROJECT_INCLUDE)/libcpu/isr_entries.h: shared/interrupts/isr_entries.h $(PROJE
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/isr_entries.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/isr_entries.h
-if mongoosev
-$(PROJECT_INCLUDE)/libcpu/mongoose-v.h: mongoosev/include/mongoose-v.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/mongoose-v.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/mongoose-v.h
-$(PROJECT_INCLUDE)/libchip/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_INCLUDE)/libchip
-	@: > $(PROJECT_INCLUDE)/libchip/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/$(dirstamp)
-$(PROJECT_INCLUDE)/libchip/mg5uart.h: mongoosev/duart/mg5uart.h $(PROJECT_INCLUDE)/libchip/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/mg5uart.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/mg5uart.h
-endif
 if tx39
 $(PROJECT_INCLUDE)/libcpu/tx3904.h: tx39/include/tx3904.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/tx3904.h
1.9.3
