Updated Warnings Report
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Oct 9 18:48:07 UTC 2014
Hi
Building all BSPs with POSIX enabled and sample tests only,
there are now 1326 unique warnings across the build.
This is down from 1737 unique warnings earlier in the week.
These results are with the patches I just posted.
I am attaching two reports. One is the list of unique warnings
and count of BSPs where it occurs. The other is the number of
warnings per BSP.
At this point the gen5200 and motorola_powerpc BSPs
dominate the top of the list with > 50 warnings and multiple
variants.
The sparc-leon2 has 60 which is surprising.
The arm-nds is the winner with 118 though.
I am asking again for some help in reducing these. Please
pick a BSP and knock the set of warnings down.
2 arm-lm3s3749
2 arm-lm3s6965
2 arm-lm3s6965_qemu
2 arm-lm4f120
2 mips-jmr3904
3 arm-altcycv_devkit
3 arm-altcycv_devkit_smp
3 arm-lpc17xx_ea_ram
3 arm-lpc17xx_ea_rom_int
3 arm-lpc17xx_plx800_ram
3 arm-lpc17xx_plx800_rom_int
3 arm-lpc40xx_ea_ram
3 arm-lpc40xx_ea_rom_int
3 arm-realview_pbx_a9_qemu
3 arm-realview_pbx_a9_qemu_smp
3 arm-stm32f105rc
3 arm-stm32f4
3 arm-tms570ls3137_hdk
3 arm-tms570ls3137_hdk_intram
3 arm-tms570ls3137_hdk_sdram
3 arm-xilinx_zynq_a9_qemu
3 arm-xilinx_zynq_zc702
3 arm-xilinx_zynq_zc706
3 arm-xilinx_zynq_zedboard
3 avr-avrtest
4 arm-arm1136jfs
4 arm-arm1136js
4 arm-arm7tdmi
4 arm-arm920
4 arm-armcortexa9
4 arm-lpc24xx_ea
4 arm-lpc24xx_ncs_ram
4 arm-lpc24xx_ncs_rom_ext
4 arm-lpc24xx_ncs_rom_int
4 arm-lpc24xx_plx800_ram
4 arm-lpc24xx_plx800_rom_int
4 arm-lpc32xx_mzx
4 arm-lpc32xx_mzx_stage_1
4 arm-lpc32xx_mzx_stage_2
4 arm-lpc32xx_phycore
4 mips-csb350
5 v850-v850e1sim
5 v850-v850e2sim
5 v850-v850e2v3sim
5 v850-v850esim
5 v850-v850essim
5 v850-v850sim
6 arm-csb336
6 arm-edb7312
6 arm-lpc2362
6 arm-lpc23xx_tli800
8 arm-raspberrypi
8 mips-hurricane
8 sparc-leon3
8 sparc-ngmp
9 arm-lpc1768_mbed
9 arm-lpc1768_mbed_ahb_ram
9 arm-lpc1768_mbed_ahb_ram_eth
9 lm32-milkymist
9 mips-rbtx4925
9 mips-rbtx4938
9 powerpc-gwlcfm
9 powerpc-mpc5668g
10 powerpc-mpc5566evb
10 powerpc-mpc5566evb_spe
10 powerpc-mpc5674f_ecu508_app
10 powerpc-mpc5674f_ecu508_boot
10 powerpc-mpc5674fevb
10 powerpc-mpc5674fevb_spe
10 powerpc-mpc5674f_rsm6
10 powerpc-phycore_mpc5554
10 sh-simsh1
10 sh-simsh2
10 sh-simsh2e
10 sh-simsh4
11 arm-gba
11 m32r-m32rsim
12 h8300-h8sim
12 nios2-nios2_iss
12 powerpc-mpc5643l_dpu
12 powerpc-mpc5643l_evb
12 powerpc-t32mppc
12 sh-gensh1
13 powerpc-virtex5
14 mips-malta
14 moxie-moxiesim
14 sparc-erc32
14 sparc-sis
15 arm-gp32
15 arm-smdk2410
15 m68k-csb360
15 sh-gensh4
16 m68k-gen68360
16 m68k-gen68360_040
16 powerpc-psim
16 powerpc-qemuppc
16 powerpc-qoriq_p1020rdb
17 arm-gumstix
17 arm-rtl22xx_t
17 lm32-lm32_evr
17 m68k-COBRA5475
17 m68k-m5484FireEngine
17 m68k-mrm332
17 m68k-pgh360
17 powerpc-hsc_cm01
17 powerpc-mpc8349eamds
18 arm-rtl22xx
18 powerpc-qoriq_core_0
18 powerpc-qoriq_core_1
19 m68k-gen68302
20 bfin-TLL6527M
20 m68k-mvme147s
20 powerpc-mpc8309som
21 m68k-sim68000
21 m68k-simcpu32
21 powerpc-mpc8313erdb
22 bfin-eZKit533
22 m68k-idp
22 m68k-mvme147
23 m68k-mcf5206elite
23 m68k-mvme162
23 m68k-mvme162lx
23 m68k-mvme167
23 powerpc-br_uid
23 sh-gensh2
24 bfin-bf537Stamp
26 arm-csb337
26 arm-kit637_v6
27 powerpc-mpc8260ads
28 arm-csb637
28 m68k-mvme136
29 m68k-mcf52235
30 m68k-gen68340
30 m68k-mcf5225x
31 m68k-av5282
31 m68k-mcf5235
31 m68k-ods68302
31 mips-genmongoosev
32 m68k-mcf5329
32 powerpc-mbx821_001
32 powerpc-mbx821_002
32 powerpc-mbx821_002b
32 powerpc-mbx860_001b
32 powerpc-mbx860_002
32 powerpc-mbx860_1b
32 powerpc-virtex
32 powerpc-virtex4
35 powerpc-pghplus
35 powerpc-tqm8xx_stk8xx
36 powerpc-ss555
37 m68k-uC5282
37 powerpc-mbx860_005b
37 powerpc-score603e
42 powerpc-mvme3100
46 i386-pc386
46 i386-pc486
46 i386-pc586
46 i386-pc586-sse
46 i386-pc686
46 i386-pcp4
46 powerpc-ep1a
47 powerpc-beatnik
47 sparc64-usiii
48 powerpc-haleakala
48 sparc64-niagara
51 h8300-h8sxsim
54 powerpc-mvme5500
55 powerpc-brs5l
55 powerpc-brs6l
56 or1k-or1ksim
56 powerpc-dp2
56 powerpc-icecube
56 powerpc-pm520_cr825
56 powerpc-pm520_ze30
60 sparc-leon2
62 m32c-m32csim
69 powerpc-mvme2100
71 powerpc-qemuprep
71 powerpc-qemuprep-altivec
78 powerpc-mtx603e
80 powerpc-mcp750
80 powerpc-mvme2307
118 arm-nds
200 c/src/../../cpukit/libmisc/shell/hexdump-conv.c:145:4: warning: format '%lc' expects argument of type 'wint_t', but argument 4 has type 'wchar_t' [-Wformat=]
182 c/src/../../cpukit/libmisc/shell/main_cp.c:108:1: warning: 'rtems_shell_cp_exit' defined but not used [-Wunused-function]
179 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:19: warning: assignment makes integer from pointer without a cast [enabled by default]
78 c/src/../../cpukit/libmisc/capture/capture-cli.c:1424:18: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:61:17: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:55:7: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c:72:13: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
63 c/src/libchip/serial/ns16550.c:135:21: warning: 'ns16550_isr' declared 'static' but never defined [-Wunused-function]
56 c/src/lib/libcpu/powerpc/shared/src/cache_.h:203:2: warning: #warning Most cache functions are not implemented [-Wcpp]
54 c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_alignment.c:27:22: warning: initialization from incompatible pointer type [enabled by default]
41 c/src/../../cpukit/score/cpu/arm/arm_exc_handler_high.c:91:6: warning: no previous prototype for 'rtems_exception_init_mngt' [-Wmissing-prototypes]
40 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:83:20: warning: no previous prototype for 'Read_long_timer' [-Wmissing-prototypes]
40 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:34:5: warning: no previous prototype for 'Timer_get_clicks_overhead' [-Wmissing-prototypes]
34 c/src/../../cpukit/libfs/src/jffs2/src/os-rtems.h:47:3: warning: right shift count >= width of type [enabled by default]
34 c/src/../../cpukit/libfs/src/jffs2/src/nodelist.h:294:86: warning: integer overflow in expression [-Woverflow]
23 c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c:729:1: warning: no previous prototype for 'triv121PgTblConsistency' [-Wmissing-prototypes]
23 c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c:307:23: warning: variable 'api' set but not used [-Wunused-but-set-variable]
23 c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c:1082:1: warning: no previous prototype for 'triv121PgTblDump' [-Wmissing-prototypes]
20 c/src/../../cpukit/libfs/src/jffs2/include/linux/kernel.h:12:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:870:5: warning: no previous prototype for 'm8xx_smc_isOn' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:854:6: warning: no previous prototype for 'm8xx_smc_disable' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:838:6: warning: no previous prototype for 'm8xx_smc_enable' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:625:5: warning: no previous prototype for 'm8xx_scc_isOn' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:601:6: warning: no previous prototype for 'm8xx_scc_disable' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:577:6: warning: no previous prototype for 'm8xx_scc_enable' [-Wmissing-prototypes]
8 c/src/lib/libbsp/arm/lpc24xx/misc/restart.c:31:27: warning: variable 'level' set but not used [-Wunused-but-set-variable]
8 c/src/../../cpukit/score/src/threadloadenv.c:28:8: warning: variable 'is_fp' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libcpu/arm/shared/arm920/mmu.c:128:6: warning: no previous prototype for 'mmu_set_cpu_async_mode' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:47:19: warning: 'upmaTable' defined but not used [-Wunused-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:159:6: warning: no previous prototype for '_InitMBX8xx' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c:86:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c:85:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:79:5: warning: no previous prototype for 'BSP_irq_disable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:66:5: warning: no previous prototype for 'BSP_irq_enable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:271:1: warning: no previous prototype for 'BSP_CPM_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:252:6: warning: no previous prototype for 'BSP_SIU_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:149:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:42:6: warning: no previous prototype for 'mbx8xx_pcmciaide_probe' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:351:19: warning: no previous prototype for 'mbx8xx_pcmciaide_config_io_speed' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:328:5: warning: no previous prototype for 'mbx8xx_pcmciaide_control' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:270:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:213:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:175:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:137:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:111:6: warning: no previous prototype for 'mbx8xx_pcmciaide_initialize' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:714:1: warning: no previous prototype for 'serial_tstc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:693:1: warning: no previous prototype for 'serial_getc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:529:1: warning: no previous prototype for 'serial_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:1102:5: warning: no previous prototype for 'mbx8xx_console_get_configuration' [-Wmissing-prototypes]
7 c/src/../../cpukit/score/cpu/sh/context.c:171:6: warning: no previous prototype for '__CPU_Context_switch' [-Wmissing-prototypes]
6 c/src/lib/libcpu/i386/displayCpu.c:185:6: warning: no previous prototype for 'printCpuInfo' [-Wmissing-prototypes]
6 c/src/lib/libcpu/i386/cache.c:9:6: warning: no previous prototype for '_CPU_disable_cache' [-Wmissing-prototypes]
6 c/src/lib/libcpu/i386/cache.c:23:6: warning: no previous prototype for '_CPU_enable_cache' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspreset.c:12:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../shared/vmeUniverse/vmeUniverse.c:316:1: warning: no previous prototype for 'vmeUniverseFindPciBase' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../shared/vmeUniverse/bspVmeDmaList.c:322:1: warning: no previous prototype for 'BSP_VMEDmaListDump' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../shared/vmeUniverse/bspVmeDmaList.c:286:1: warning: no previous prototype for 'BSP_VMEDmaDescriptorPrev' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/vme/vmeconfig.c:75:1: warning: no previous prototype for '__BSP_default_vme_config' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/pretaskinghook.c:39:6: warning: no previous prototype for 'bsp_pretasking_hook' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/pgtbl_setup.c:73:1: warning: no previous prototype for '__BSP_default_pgtbl_setup' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/pgtbl_activate.c:59:1: warning: no previous prototype for '__BSP_default_pgtbl_activate' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/bspstart.c:103:8: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/showbats.c:41:6: warning: no previous prototype for 'ShowBATS' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/showbats.c:18:6: warning: no previous prototype for 'printBAT' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/motorola/motorola.c:363:15: warning: no previous prototype for 'getMotorolaBoard' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/uart.c:139:17: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/uart.c:115:13: warning: no previous prototype for 'uartError' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:564:5: warning: no previous prototype for 'serial_tstc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:558:5: warning: no previous prototype for 'serial_getc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:552:6: warning: no previous prototype for 'serial_putc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:499:6: warning: no previous prototype for 'log_putc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:454:5: warning: no previous prototype for 'vacuum_tstc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:450:5: warning: no previous prototype for 'vacuum_getc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:446:6: warning: no previous prototype for 'vacuum_putc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/console.c:178:12: warning: 'console_last_close' defined but not used [-Wunused-function]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/console.c:151:12: warning: 'console_first_open' defined but not used [-Wunused-function]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:892:6: warning: variable 'i' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:564:5: warning: no previous prototype for 'serial_tstc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:558:5: warning: no previous prototype for 'serial_getc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:552:6: warning: no previous prototype for 'serial_putc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:499:6: warning: no previous prototype for 'log_putc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:454:5: warning: no previous prototype for 'vacuum_tstc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:450:5: warning: no previous prototype for 'vacuum_getc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:446:6: warning: no previous prototype for 'vacuum_putc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/pci.c:801:7: warning: no previous prototype for 'pci_scan_bus' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/pci.c:716:6: warning: no previous prototype for 'pci_read_bases' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/mm.c:718:6: warning: no previous prototype for 'mm_init' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/mm.c:471:5: warning: no previous prototype for 'early_setup' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/mm.c:428:1: warning: no previous prototype for 'fix_residual' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/mm.c:133:6: warning: no previous prototype for '_handler' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/misc.c:99:6: warning: no previous prototype for 'zfree' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/misc.c:89:7: warning: no previous prototype for 'zalloc' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/misc.c:255:22: warning: variable 'indic' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/misc.c:247:1: warning: no previous prototype for 'setup_hw' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/misc.c:235:1: warning: no previous prototype for 'boot_udelay' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/misc.c:159:6: warning: no previous prototype for 'decompress_kernel' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/lib.c:43:5: warning: no previous prototype for 'strlen' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/lib.c:32:7: warning: no previous prototype for 'strcat' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/lib.c:23:7: warning: no previous prototype for 'memcpy' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/lib.c:16:7: warning: no previous prototype for 'memset' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86.c:312:5: warning: no previous prototype for 'em86_trap' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86.c:243:5: warning: no previous prototype for 'process_softint' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86.c:207:5: warning: no previous prototype for 'int10h' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86.c:200:10: warning: no previous prototype for 'pop2' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86.c:193:6: warning: no previous prototype for 'push2' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/bootloader/em86.c:135:5: warning: no previous prototype for 'bios86pci' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c:62:1: warning: no previous prototype for 'pcf8563_initialize' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c:174:1: warning: no previous prototype for 'pcf8563_set_time' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c:107:1: warning: no previous prototype for 'pcf8563_get_time' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c:130:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c:129:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c:268:5: warning: no previous prototype for 'sltIsOn' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c:251:6: warning: no previous prototype for 'sltOff' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c:233:6: warning: no previous prototype for 'sltOn' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/../shared/uboot_getenv.c:39:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/../shared/showbats.c:41:6: warning: no previous prototype for 'ShowBATS' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/../shared/showbats.c:18:6: warning: no previous prototype for 'printBAT' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:915:17: warning: variable 'mscan_hdl' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:832:30: warning: variable 'chan' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:494:6: warning: no previous prototype for 'mpc5200_mscan_perform_initialization_mode_settings' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:423:5: warning: no previous prototype for 'mpc5200_mscan_b_isOn' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:410:6: warning: no previous prototype for 'mpc5200_mscan_b_off' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:397:6: warning: no previous prototype for 'mpc5200_mscan_b_on' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:381:5: warning: no previous prototype for 'mpc5200_mscan_a_isOn' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:368:6: warning: no previous prototype for 'mpc5200_mscan_a_off' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c:355:6: warning: no previous prototype for 'mpc5200_mscan_a_on' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/irq/irq.c:672:6: warning: no previous prototype for 'BSP_SIU_irq_init' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/irq/irq.c:625:6: warning: no previous prototype for 'setup_irqMaskTable' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/irq/irq.c:506:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:643:6: warning: no previous prototype for 'mpc5200_pcmciaide_initialize' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:638:5: warning: no previous prototype for 'mpc5200_pcmciaide_control' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:546:6: warning: no previous prototype for 'mpc5200_pcmciaide_write_block' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:468:6: warning: no previous prototype for 'mpc5200_pcmciaide_read_block' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:235:6: warning: no previous prototype for 'mpc5200_pcmciaide_write_reg' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:224:6: warning: no previous prototype for 'mpc5200_pcmciaide_read_reg' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:184:19: warning: no previous prototype for 'mpc5200_pcmciaide_config_io_speed' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.c:141:6: warning: no previous prototype for 'mpc5200_pcmciaide_probe' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c:481:5: warning: no previous prototype for 'mpc5200mbus_irq_isOn' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c:470:6: warning: no previous prototype for 'mpc5200mbus_irq_disable' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c:459:6: warning: no previous prototype for 'mpc5200mbus_irq_enable' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/i2c/mpc5200mbus.c:441:6: warning: no previous prototype for 'mpc5200mbus_interrupt_handler' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:578:9: warning: no previous prototype for 'mpc5200_uart_write' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:552:9: warning: no previous prototype for 'mpc5200_uart_pollWrite' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:535:5: warning: no previous prototype for 'mpc5200_uart_pollRead' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:411:6: warning: no previous prototype for 'mpc5200_uart_psc_initialize' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:393:5: warning: no previous prototype for 'mpc5200_psc_isOn' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:379:6: warning: no previous prototype for 'mpc5200_psc_disable' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:364:6: warning: no previous prototype for 'mpc5200_psc_enable' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:267:5: warning: no previous prototype for 'mpc5200_uart_setAttributes' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/console/console.c:183:5: warning: no previous prototype for 'mpc5200_psc_setAttributes' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/gen5200/bestcomm/bestcomm_glue.c:130:6: warning: no previous prototype for 'bestcomm_glue_irq_dispatcher' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/startup/bspstart.c:48:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/pci/pcibios.c:269:1: warning: no previous prototype for 'BSP_pciFindDevice' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/irq/irq_init.c:101:6: warning: no previous prototype for 'raw_idt_notify' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/irq/irq.c:35:1: warning: no previous prototype for 'BSP_irq_count_dump' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/irq/irq.c:237:6: warning: no previous prototype for 'C_dispatch_isr' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/uart.c:85:13: warning: no previous prototype for 'uartError' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/uart.c:733:1: warning: no previous prototype for 'BSP_uart_termios_isr_com2' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/uart.c:637:1: warning: no previous prototype for 'BSP_uart_termios_isr_com1' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/uart.c:458:6: warning: no previous prototype for 'uart_set_driver_handler' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub-glue.c:62:5: warning: no previous prototype for 'BSP_uart_isOn' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub-glue.c:57:6: warning: no previous prototype for 'BSP_uart_off' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub-glue.c:52:6: warning: no previous prototype for 'BSP_uart_on' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:969:1: warning: no previous prototype for 'breakpoint' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:935:1: warning: no previous prototype for 'set_debug_traps' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:756:7: warning: variable 'newPC' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:635:1: warning: no previous prototype for 'hex2mem' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:601:1: warning: no previous prototype for 'set_char' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:585:1: warning: no previous prototype for 'set_mem_err' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:568:1: warning: no previous prototype for 'debug_error' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:533:1: warning: no previous prototype for 'putpacket' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:469:1: warning: no previous prototype for 'getpacket' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:456:1: warning: no previous prototype for 'hex' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:450:1: warning: no previous prototype for '_returnFromException' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/gdb_glue.c:25:6: warning: no previous prototype for 'init_remote_gdb' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/serial_mouse_config.c:29:6: warning: no previous prototype for 'bsp_get_serial_mouse_device' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/pc_keyb.c:450:6: warning: no previous prototype for 'kbd_reset_setup' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/keyboard.c:790:6: warning: no previous prototype for 'register_leds' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/inch.c:287:6: warning: no previous prototype for 'add_to_queue' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/inch.c:274:5: warning: no previous prototype for 'getch' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/inch.c:260:5: warning: no previous prototype for 'rtems_kbpoll' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/inch.c:247:1: warning: no previous prototype for 'BSP_wait_polled_input' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/clock/ckinit.c:325:0: warning: "Clock_driver_support_shutdown_hardware" redefined [enabled by default]
6 c/src/lib/libbsp/arm/lpc24xx/misc/restart.c:43:27: warning: variable 'level' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libfs/src/jffs2/src/fs-rtems.c:367:21: warning: unused variable 'sc' [-Wunused-variable]
6 c/src/../../cpukit/libfs/src/jffs2/src/fs-rtems.c:325:20: warning: unused variable 'sc' [-Wunused-variable]
6 c/src/../../cpukit/libfs/src/jffs2/src/fs-rtems.c:319:20: warning: unused variable 'sc' [-Wunused-variable]
6 c/src/../../cpukit/libfs/src/dosfs/msdos_conv_utf8.c:255:31: warning: variable 'rv' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media-server.c:47:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media.c:80:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
5 log/sparc64-usiii.log:../../cpukit/../../../usiii/lib/include/rtems/score/sparc64.h:324:25: warning: variable '_ignored' set but not used [-Wunused-but-set-variable]
5 log/sparc64-niagara.log:../../cpukit/../../../niagara/lib/include/rtems/score/sparc64.h:324:25: warning: variable '_ignored' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c:170:27: warning: iteration 474ul invokes undefined behavior [-Waggressive-loop-optimizations]
5 c/src/lib/libcpu/powerpc/e500/mmu/mmu.c:202:24: warning: variable 'mas0' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/pci/detect_raven_bridge.c:101:6: warning: no previous prototype for 'detect_host_bridge' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/startup/bsprestart.c:22:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libbsp/powerpc/gen83xx/../shared/uboot_getenv.c:39:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:563:5: warning: no previous prototype for 'mpc83xx_exception_handler' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:508:19: warning: no previous prototype for 'mpc83xx_ipic_initialize' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:495:19: warning: no previous prototype for 'mpc83xx_ipic_calc_prio2mask' [-Wmissing-prototypes]
5 c/src/../../cpukit/score/cpu/sparc/sparcv8-atomic.c:111:6: warning: conflicting types for built-in function '__atomic_compare_exchange_4' [enabled by default]
4 c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c:29:6: warning: no previous prototype for '__ISR_Handler' [-Wmissing-prototypes]
4 c/src/lib/libbsp/sh/shsim/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
4 c/src/lib/libbsp/sh/shsim/console/console-io.c:70:5: warning: no previous prototype for '_sys_exit' [-Wmissing-prototypes]
4 c/src/lib/libbsp/sh/shsim/console/console-debugio.c:30:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
4 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c:43:3: warning: initialization from incompatible pointer type [enabled by default]
4 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/irq/irq_init.c:167:6: warning: no previous prototype for 'VIA_isa_bridge_interrupts_setup' [-Wmissing-prototypes]
4 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:299:21: warning: unused variable 'sc' [-Wunused-variable]
4 c/src/lib/libbsp/powerpc/gen5200/../shared/uboot_dump_bdinfo.c:23:6: warning: no previous prototype for 'dumpUBootBDInfo' [-Wmissing-prototypes]
4 c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc.c:206:6: warning: no previous prototype for 'is_word_aligned' [-Wmissing-prototypes]
4 c/src/../../cpukit/libmisc/shell/main_lsof.c:64:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
4 c/src/../../cpukit/libmisc/shell/main_lsof.c:63:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
4 c/src/../../cpukit/libmisc/shell/main_lsof.c:49:7: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
4 c/src/../../cpukit/libmisc/shell/main_lsof.c:48:7: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 5 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:105:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 6 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 5 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 3 has type 'uint32_t' [-Wformat=]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:556:21: warning: no previous prototype for 'tty0_control' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:543:21: warning: no previous prototype for 'tty0_write' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:530:21: warning: no previous prototype for 'tty0_read' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:517:21: warning: no previous prototype for 'tty0_close' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:464:21: warning: no previous prototype for 'tty0_open' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:430:21: warning: no previous prototype for 'tty0_initialize' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:352:17: warning: variable '_tmp' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:351:17: warning: variable '_ier' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:347:1: warning: no previous prototype for 'tty0Initialize' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:327:1: warning: no previous prototype for 'tty0DeInit' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:158:1: warning: no previous prototype for 'tty0BaudSet' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/tty_drv/tty_drv.c:152:5: warning: no previous prototype for 'tty0_round' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:545:21: warning: no previous prototype for 'console_control' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:532:21: warning: no previous prototype for 'console_write' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:519:21: warning: no previous prototype for 'console_read' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:506:21: warning: no previous prototype for 'console_close' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:462:21: warning: no previous prototype for 'console_open' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:430:21: warning: no previous prototype for 'console_initialize' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:357:1: warning: no previous prototype for 'spiInitialize' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:336:1: warning: no previous prototype for 'spiDeInit' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:195:1: warning: no previous prototype for 'spiBaudSet' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/clock/clock.c:257:6: warning: no previous prototype for 'ReInstall_clock' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/clock/clock.c:231:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:80:3: warning: nested extern declaration of 'BSP_Convert_decrementer' [-Wnested-externs]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:80:3: warning: implicit declaration of function 'BSP_Convert_decrementer' [-Wimplicit-function-declaration]
3 c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c:496:9: warning: passing argument 1 of 'rtems_cache_flush_multiple_data_lines' discards 'volatile' qualifier from pointer target type [enabled by default]
3 c/src/lib/libcpu/bfin/serial/uart.c:93:6: warning: no previous prototype for 'debug_write_byte' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:87:6: warning: no previous prototype for 'debug_write_nybble' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:81:6: warning: no previous prototype for 'debug_write_crlf' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:72:6: warning: no previous prototype for 'debug_write_string' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:68:6: warning: no previous prototype for 'debug_write_char' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:505:6: warning: no previous prototype for 'uart_exit' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:107:6: warning: no previous prototype for 'debug_write_word' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:100:6: warning: no previous prototype for 'debug_write_half' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/clock/rtc.c:31:6: warning: no previous prototype for 'Init_RTC' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/usart/usart.c:270:5: warning: no previous prototype for 'usart_poll_read' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:220:5: warning: no previous prototype for '_BSP_poll_char' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:201:5: warning: no previous prototype for 'dbgu_poll_read' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/clock/clock.c:81:12: warning: variable 'st_str' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libcpu/arm/at91rm9200/clock/clock.c:79:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/clock/clock.c:120:6: warning: no previous prototype for 'Clock_driver_support_shutdown_hardware' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/clock/clock.c:114:14: warning: variable 'st_str' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libcpu/arm/at91rm9200/clock/clock.c:100:10: warning: no previous prototype for 'bsp_clock_nanoseconds_since_last_tick' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/uboot_getenv.c:39:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/uboot_dump_bdinfo.c:23:6: warning: no previous prototype for 'dumpUBootBDInfo' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/clock/../../../shared/clockdrv_shell.h:154:21: warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:814:5: warning: no previous prototype for 'kbd_tstc' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/polled_io.c:596:1: warning: no previous prototype for 'vga_putc' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:77:1: warning: no previous prototype for '_IBMPC_scankey' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:275:1: warning: no previous prototype for '_IBMPC_inch_sleep' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:257:1: warning: no previous prototype for 'BSP_wait_polled_input' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:243:1: warning: no previous prototype for '_IBMPC_inch' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:221:1: warning: no previous prototype for '_IBMPC_chrdy' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:198:6: warning: no previous prototype for '_IBMPC_keyboard_isr' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:814:5: warning: no previous prototype for 'kbd_tstc' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/../../../powerpc/shared/console/polled_io.c:596:1: warning: no previous prototype for 'vga_putc' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c:40:7: warning: initialization from incompatible pointer type [enabled by default]
3 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c:54:3: warning: initialization from incompatible pointer type [enabled by default]
3 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:43:6: warning: no previous prototype for '_Init68360' [-Wmissing-prototypes]
3 c/src/lib/libbsp/m68k/gen68360/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
3 c/src/lib/libbsp/m68k/gen68360/console/console.c:200:20: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libbsp/arm/lpc176x/misc/restart.c:28:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libbsp/arm/csb337/startup/bspstart.c:41:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/startup/bspreset.c:18:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libbsp/arm/csb337/startup/bspreset.c:16:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/umoncons.c:126:5: warning: no previous prototype for 'umoncons_poll_read' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/tfsDriver.c:671:3: warning: (near initialization for 'rtems_tfs_handlers.write_h') [enabled by default]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/tfsDriver.c:671:3: warning: initialization from incompatible pointer type [enabled by default]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/tfsDriver.c:670:3: warning: (near initialization for 'rtems_tfs_handlers.read_h') [enabled by default]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/tfsDriver.c:670:3: warning: initialization from incompatible pointer type [enabled by default]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/monlib.c:901:1: warning: no previous prototype for 'mon_memtrace' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/monlib.c:454:1: warning: no previous prototype for 'mon_sprintf' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/monlib.c:439:1: warning: no previous prototype for 'mon_cprintf' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/monlib.c:424:1: warning: no previous prototype for 'mon_printf' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/monlib.c:321:1: warning: 'EnableMonLock' defined but not used [-Wunused-function]
3 c/src/lib/libbsp/arm/csb337/../../shared/umon/monlib.c:315:1: warning: 'DisableMonLock' defined but not used [-Wunused-function]
3 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:19: warning: assignment makes integer from pointer without a cast
3 c/src/../../cpukit/libcsupport/src/__assert.c:52:43: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/powerpc-virtex.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex5.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex4.log: #warning Most cache functions are not implemented
2 log/powerpc-t32mppc.log: #warning Most cache functions are not implemented
2 log/powerpc-ss555.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_p1020rdb.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_1.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_0.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep-altivec.log: #warning Most cache functions are not implemented
2 log/powerpc-phycore_mpc5554.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme5500.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme3100.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme2307.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_rsm6.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_boot.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_app.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5668g.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_dpu.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mcp750.log: #warning Most cache functions are not implemented
2 log/powerpc-haleakala.log: #warning Most cache functions are not implemented
2 log/powerpc-gwlcfm.log: #warning Most cache functions are not implemented
2 log/powerpc-beatnik.log: #warning Most cache functions are not implemented
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:125:5: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:51: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:120:49: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 c/src/lib/libcpu/sparc64/shared/interrupts/installisrentries.c:18:6: warning: no previous prototype for 'sparc64_install_isr_entries' [-Wmissing-prototypes]
2 c/src/lib/libcpu/bfin/clock/clock.c:45:9: warning: comparison of distinct pointer types lacks a cast [enabled by default]
2 c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c:34:10: warning: no previous prototype for 'clock_driver_get_nanoseconds_since_last_tick' [-Wmissing-prototypes]
2 c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c:132:1: warning: no return statement in function returning non-void [-Wreturn-type]
2 c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c:106:10: warning: no previous prototype for 'bsp_clock_nanoseconds_since_last_tick' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/leon3/startup/bspdelay.c:18:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/leon3/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c:19:6: warning: no previous prototype for 'bsp_predriver_hook' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/startup/bspdelay.c:14:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:86:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:45:5: warning: no previous prototype for 'console_inbyte_nonblocking' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:24:6: warning: no previous prototype for 'console_outbyte_polled' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/clock/ckinit.c:48:10: warning: no previous prototype for 'bsp_clock_nanoseconds_since_last_tick' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:22:6: warning: no previous prototype for '_InitTQM8xx' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:129:6: warning: no previous prototype for 'cpu_init' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:85:13: warning: no previous prototype for 'bsp_tqm_get_cib_string' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:74:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:61:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:134:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:133:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:115:20: warning: no previous prototype for 'bsp_tqm_get_cib_uint32' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:906:19: warning: no previous prototype for 'bsp_register_spi' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:59:19: warning: no previous prototype for 'bsp_irq_enable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:52:19: warning: no previous prototype for 'bsp_irq_disable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:45:19: warning: no previous prototype for 'bsp_irq_enable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:38:19: warning: no previous prototype for 'bsp_irq_disable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:217:5: warning: no previous prototype for 'mpc8xx_exception_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:207:19: warning: no previous prototype for 'mpc8xx_siu_int_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:187:19: warning: no previous prototype for 'mpc8xx_cpic_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:51:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:37:5: warning: no previous prototype for 'BSP_disconnect_clock_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:28:5: warning: no previous prototype for 'BSP_get_clock_irq_level' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:23:6: warning: no previous prototype for 'BSP_clock_hdl' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: initialization from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c:69:6: warning: no previous prototype for 'enter_sleep_mode' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c:61:6: warning: no previous prototype for 'enter_active_mode' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c:53:6: warning: no previous prototype for 'enter_init_mode' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/../../../powerpc/shared/bootloader/qemu_fakeres.c:146:1: warning: no previous prototype for 'res_copy' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/../../../powerpc/shared/bootloader/qemu_fakeres.c:123:1: warning: no previous prototype for 'nvram_rdl_be' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:40:2: warning: #warning No SPI configuration available [-Wcpp]
2 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:301:12: warning: variable 'spi_busno' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:420:24: warning: unused variable 'level' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:419:11: warning: unused variable 'msr' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:418:29: warning: unused variable 'mask_ptr' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:417:22: warning: unused variable 'mask_save' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c:102:7: warning: variable 'i2c_busno' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c:21:6: warning: no previous prototype for 'bsp_spurious_handler_assistant' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/m68000spurious.c:34:9: warning: variable 's' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/m68000spurious.c:29:11: warning: no previous prototype for 'bsp_spurious_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/bspspuriousinit.c:29:6: warning: no previous prototype for 'bsp_spurious_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/console/debugio.c:20:6: warning: no previous prototype for 'debug_putc' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c:44:6: warning: no previous prototype for 'Clock_driver_support_shutdown_hardware' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c:37:6: warning: no previous prototype for 'Clock_driver_support_at_tick' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c:27:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/timer/timer.c:34:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c:55:18: warning: assignment from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c:26:6: warning: no previous prototype for 'bsp_return_to_monitor_trap' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:87:5: warning: implicit declaration of function 'putchar' [-Wimplicit-function-declaration]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:39:11: warning: no previous prototype for 'C_Receive_ISR' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:184:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:171:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c:64:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c:50:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/genmcf548x/console/console.c:849:6: warning: no previous prototype for 'DEBUG_OUTNUM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/genmcf548x/console/console.c:844:6: warning: no previous prototype for 'DEBUG_OUTSTR' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/genmcf548x/console/console.c:837:5: warning: no previous prototype for 'DEBUG_OUTCHAR' [-Wmissing-prototypes]
2 c/src/lib/libbsp/h8300/h8sim/startup/__main.c:9:6: warning: no previous prototype for '__main' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/stm32f4/i2c/i2c.c:211:21: warning: unused variable 'sc' [-Wunused-variable]
2 c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c:34:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c:12:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/console/uart.c:329:7: warning: no previous prototype for 'UART0_SendStr' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/console/uart.c:318:7: warning: no previous prototype for 'UART0_SendByte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/console/uart.c:297:7: warning: no previous prototype for 'UART0_Ini' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c:30:6: warning: no previous prototype for 'irqDummy' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c:70:12: warning: comparison between pointer and integer [enabled by default]
2 c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c:69:12: warning: comparison between pointer and integer [enabled by default]
2 c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c:68:12: warning: comparison between pointer and integer [enabled by default]
2 c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c:67:12: warning: comparison between pointer and integer [enabled by default]
2 c/src/lib/libbsp/arm/nds/libnds/source/common/card.c:170:15: warning: variable 'c03' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c:60:5: warning: passing argument 4 of '_Heap_Extend' makes integer from pointer without a cast [enabled by default]
2 c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c:54:5: warning: passing argument 4 of '_Heap_Extend' makes integer from pointer without a cast [enabled by default]
2 c/src/../../cpukit/score/src/threadstartmultitasking.c:82:1: warning: 'noreturn' function does return [enabled by default]
2 c/src/../../cpukit/score/src/threadloadenv.c:29:12: warning: variable 'isr_level' set but not used [-Wunused-but-set-variable]
2 c/src/../../cpukit/score/cpu/sparc64/cpu.c:74:18: warning: variable 'the_size' set but not used [-Wunused-but-set-variable]
2 c/src/../../cpukit/score/cpu/m68k/cpu_asm.S:75:2: warning: #warning "_CPU_Context_Restart_self restoring FPU context not implemented" [-Wcpp]
2 c/src/../../cpukit/score/cpu/lm32/irq.c:32:6: warning: no previous prototype for '__ISR_Handler' [-Wmissing-prototypes]
2 c/src/../../cpukit/libmisc/redirector/stdio-redirect.c:262:18: warning: integer overflow in expression [-Woverflow]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:80:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:33:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
1 tools/cpu/nios2/ptf.c:92:26: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:77:9: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:166:31: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:156:29: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 log/sh-gensh2.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/sh-gensh1.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/powerpc-ss555.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/powerpc-mpc8309som.log: #warning No SPI configuration available
1 log/powerpc-ep1a.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/powerpc-br_uid.log: #warning No SPI configuration available
1 log/or1k-or1ksim.log:/users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/../../../../or1k-rtems4.11/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000000000
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: (near initialization for 'Configuration.idle_task') [enabled by default]
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: initialization from incompatible pointer type [enabled by default]
1 log/m68k-m5484FireEngine.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 log/m68k-COBRA5475.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 c/src/../../testsuites/samples/paranoia/paranoia.c:195:0: warning: "POW" redefined [enabled by default]
1 c/src/../../testsuites/samples/nsecs/init.c:125:12: warning: iteration 3u invokes undefined behavior [-Waggressive-loop-optimizations]
1 c/src/../../testsuites/samples/fileio/init.c:420:7: warning: large integer implicitly truncated to unsigned type [-Woverflow]
1 c/src/../../testsuites/samples/fileio/init.c:354:9: warning: left shift count >= width of type [enabled by default]
1 c/src/../../testsuites/samples/capture/system.h:49:41: warning: integer overflow in expression [-Woverflow]
1 c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c:81:1: warning: no previous prototype for 'sh4uart_get_Pph' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c:454:7: warning: variable 'error_occured' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c:422:1: warning: no previous prototype for 'sh4uart_handle_error' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7750/clock/ckinit.c:267:1: warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7750/clock/ckinit.c:107:1: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c:154:11: warning: no previous prototype for 'sh_sci_tx_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c:127:11: warning: no previous prototype for 'sh_sci_rx_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:309:5: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:266:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:254:6: warning: no previous prototype for 'sh_sci_inbyte_polled' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:228:6: warning: no previous prototype for 'rdSCI1' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:204:6: warning: no previous prototype for 'rdSCI0' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:197:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:184:6: warning: no previous prototype for 'sh_sci_outbyte_polled' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:167:6: warning: no previous prototype for 'wrtSCI1' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:151:6: warning: no previous prototype for 'wrtSCI0' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/clock/ckinit.c:250:21: warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/clock/ckinit.c:147:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7032/clock/ckinit.c:307:21: warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7032/clock/ckinit.c:194:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/cpm/brg.c:59:3: warning: nested extern declaration of 'bsp_serial_per_sec' [-Wnested-externs]
1 c/src/lib/libcpu/powerpc/mpc8260/cpm/brg.c:157:6: warning: no previous prototype for 'm8xx_dump_brgs' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:877:17: warning: variable 'brg' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:868:5: warning: no previous prototype for 'm8xx_smc_isOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:852:6: warning: no previous prototype for 'm8xx_smc_disable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:836:6: warning: no previous prototype for 'm8xx_smc_enable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:655:5: warning: no previous prototype for 'm8xx_scc_isOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:633:6: warning: no previous prototype for 'm8xx_scc_disable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:607:6: warning: no previous prototype for 'm8xx_scc_enable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c:96:11: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:96:6: warning: no previous prototype for 'initialize_exceptions' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:91:5: warning: no previous prototype for 'except_always_enabled' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:87:6: warning: no previous prototype for 'nop_except_enable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:30:6: warning: no previous prototype for 'C_default_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c:92:6: warning: no previous prototype for 'CPU_USIU_irq_init' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c:110:1: warning: no previous prototype for 'CPU_UIMB_irq_init' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:410:6: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:400:5: warning: no previous prototype for 'CPU_rtems_irq_mngt_get' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:328:5: warning: no previous prototype for 'CPU_rtems_irq_mngt_set' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:271:5: warning: no previous prototype for 'CPU_remove_rtems_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:262:5: warning: no previous prototype for 'CPU_get_current_rtems_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:205:5: warning: no previous prototype for 'CPU_install_rtems_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:190:5: warning: no previous prototype for 'CPU_irq_enabled_at_usiu' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:176:5: warning: no previous prototype for 'CPU_irq_disable_at_usiu' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:162:5: warning: no previous prototype for 'CPU_irq_enable_at_usiu' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:155:5: warning: no previous prototype for 'CPU_irq_enabled_at_uimb' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:148:5: warning: no previous prototype for 'CPU_irq_disable_at_uimb' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:141:5: warning: no previous prototype for 'CPU_irq_enable_at_uimb' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c:273:5: warning: no previous prototype for 'm5xx_sci_isOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c:269:6: warning: no previous prototype for 'm5xx_sci_nop' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:77:6: warning: no previous prototype for 'clockOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:67:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:145:1: warning: no previous prototype for 'ReInstall_clock' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:136:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:119:5: warning: no previous prototype for 'clockIsOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:111:1: warning: no previous prototype for 'clockOff' [-Wmissing-prototypes]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:586:3: warning: nested extern declaration of '_CPU_cache_disable_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:586:3: warning: implicit declaration of function '_CPU_cache_disable_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:576:3: warning: nested extern declaration of '_CPU_cache_enable_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:576:3: warning: implicit declaration of function '_CPU_cache_enable_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:566:3: warning: nested extern declaration of '_CPU_cache_unfreeze_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:566:3: warning: implicit declaration of function '_CPU_cache_unfreeze_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:555:3: warning: nested extern declaration of '_CPU_cache_freeze_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:555:3: warning: implicit declaration of function '_CPU_cache_freeze_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:516:2: warning: nested extern declaration of '_CPU_cache_invalidate_entire_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:516:2: warning: implicit declaration of function '_CPU_cache_invalidate_entire_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:461:5: warning: nested extern declaration of '_CPU_cache_invalidate_1_instruction_line' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:461:5: warning: implicit declaration of function '_CPU_cache_invalidate_1_instruction_line' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:420:3: warning: nested extern declaration of '_CPU_cache_disable_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:420:3: warning: implicit declaration of function '_CPU_cache_disable_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:410:3: warning: nested extern declaration of '_CPU_cache_enable_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:410:3: warning: implicit declaration of function '_CPU_cache_enable_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:400:3: warning: nested extern declaration of '_CPU_cache_unfreeze_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:400:3: warning: implicit declaration of function '_CPU_cache_unfreeze_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:389:3: warning: nested extern declaration of '_CPU_cache_freeze_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:389:3: warning: implicit declaration of function '_CPU_cache_freeze_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:352:2: warning: nested extern declaration of '_CPU_cache_invalidate_entire_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:352:2: warning: implicit declaration of function '_CPU_cache_invalidate_entire_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:335:4: warning: nested extern declaration of '_CPU_cache_flush_entire_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:335:4: warning: implicit declaration of function '_CPU_cache_flush_entire_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:316:5: warning: nested extern declaration of '_CPU_cache_invalidate_1_data_line' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:316:5: warning: implicit declaration of function '_CPU_cache_invalidate_1_data_line' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:280:5: warning: nested extern declaration of '_CPU_cache_flush_1_data_line' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:280:5: warning: implicit declaration of function '_CPU_cache_flush_1_data_line' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:94:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:84:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:74:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:147:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:136:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:125:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:114:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:104:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:95:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:82:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:69:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:53:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:40:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:36:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:32:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:28:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:24:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:136:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:131:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:122:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:113:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:100:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c:57:1: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:91:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:86:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:76:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:66:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:57:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:52:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:42:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:32:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:30:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:29:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:24:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:23:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:22:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:21:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:35:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:34:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:33:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:32:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:30:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:29:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:28:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:27:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:25:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:24:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:19:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:18:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:17:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:16:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:568:23: warning: assignment makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:417:1: warning: no previous prototype for 'mcfmbus_interrupt_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:190:25: warning: passing argument 1 of 'bus->done' makes pointer from integer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c:524:22: warning: pointer targets in assignment differ in signedness [-Wpointer-sign]
1 c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c:53:1: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:93:6: warning: no previous prototype for 'xscale_pmc_disable_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:86:6: warning: no previous prototype for 'xscale_pmc_enable_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:51:6: warning: no previous prototype for 'xscale_write_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:13:14: warning: no previous prototype for 'xscale_read_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:117:6: warning: no previous prototype for 'xscale_pmc_setevent' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:109:6: warning: no previous prototype for 'xscale_pmc_reset_ccnt' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:101:6: warning: no previous prototype for 'xscale_pmc_reset_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c:207:5: warning: no previous prototype for 'ffuart_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/clock/clock.c:31:10: warning: no previous prototype for 'clock_driver_get_nanoseconds_since_last_tick' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/clock/clock.c:121:6: warning: no previous prototype for 'Clock_driver_support_shutdown_hardware' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/clock/clock.c:103:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c:44:18: warning: variable 'reg' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c:25:6: warning: no previous prototype for 'bsp_predriver_hook' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/startup/bspdelay.c:18:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/uart/apbuart_rasta.c:26:5: warning: no previous prototype for 'apbuart_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/spw/grspw_rasta.c:90:5: warning: no previous prototype for 'grspw_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:79:5: warning: no previous prototype for 'grcan_rasta_ram_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:41:28: warning: no previous prototype for 'grcan_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:41:28: warning: no previous prototype for 'grcan_rasta_register_abs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/1553/b1553brm_rasta.c:84:5: warning: no previous prototype for 'b1553brm_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c:298:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c:261:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c:260:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c:204:5: warning: no previous prototype for 'rasta_get_gpio' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c:129:6: warning: no previous prototype for 'rasta_interrrupt_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:702:41: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:687:41: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:664:37: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:614:25: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:605:17: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:601:13: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:575:9: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:517:21: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:507:13: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:502:13: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:482:9: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:440:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:430:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:330:5: warning: no previous prototype for 'dma_to_pci_1k' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:298:5: warning: no previous prototype for 'dma_from_pci_1k' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:263:1: warning: (near initialization for 'pci_access_functions.write_config_dword') [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:263:1: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:259:5: warning: (near initialization for 'pci_access_functions.read_config_dword') [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:259:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:247:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:234:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:190:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/pci/pci.c:178:5: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/console/debugputs.c:52:5: warning: no previous prototype for 'console_inbyte_nonblocking' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/console/debugputs.c:31:6: warning: no previous prototype for 'console_outbyte_polled' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/console/console.c:341:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/sparc/leon2/console/console.c:277:9: warning: no previous prototype for 'console_write_support' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:244:5: warning: no previous prototype for 'cchip1_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:205:5: warning: no previous prototype for 'init_onboard_sram' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:191:4: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:188:4: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:163:3: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:160:3: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:133:3: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:132:3: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:131:3: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:130:3: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:129:3: warning: passing argument 5 of 'pci_read_config_dword' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:111:5: warning: no previous prototype for 'init_pcif' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/helenos/boot/genarch/ofw.c:217:6: warning: no previous prototype for 'ofw_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:41:6: warning: no previous prototype for 'sun4v_console_deviceProbe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:32:5: warning: no previous prototype for 'sun4v_console_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:27:6: warning: no previous prototype for 'sun4v_console_deviceInitialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:16:5: warning: no previous prototype for 'sun4v_console_device_first_open' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/clock/ckinit.c:88:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/clock/ckinit.c:49:6: warning: no previous prototype for 'Clock_driver_support_at_tick' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/startup/m5op.h:46:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/helenos/boot/genarch/ofw.c:217:6: warning: no previous prototype for 'ofw_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:41:6: warning: no previous prototype for 'sun4v_console_deviceProbe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:32:5: warning: no previous prototype for 'sun4v_console_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:27:6: warning: no previous prototype for 'sun4v_console_deviceInitialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:16:5: warning: no previous prototype for 'sun4v_console_device_first_open' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/clock/ckinit.c:88:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/clock/ckinit.c:49:6: warning: no previous prototype for 'Clock_driver_support_at_tick' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh4/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh4/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c:36:1: warning: no previous prototype for 'early_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c:270:6: warning: no previous prototype for 'bsp_cache_on' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh2/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/sh/gensh2/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh2/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh1/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh1/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/sh/gensh1/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh1/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c:86:20: warning: unused variable 'c' [-Wunused-variable]
1 c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c:86:17: warning: unused variable 'i' [-Wunused-variable]
1 c/src/lib/libbsp/powerpc/virtex5/../shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/virtex5/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/virtex5/../../powerpc/shared/clock/p_clock.c:32:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/virtex4/../shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/virtex4/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:848:26: warning: 'bsp_dummy_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:773:26: warning: 'bsp_pghplus_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:743:26: warning: 'bsp_pghplus_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:694:26: warning: 'bsp_pghplus_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:673:26: warning: 'bsp_dummy_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:629:26: warning: 'bsp_dummy_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:51:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:38:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_write.c:36:21: warning: no previous prototype for 'console_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_read.c:36:21: warning: no previous prototype for 'console_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_control.c:37:21: warning: no previous prototype for 'console_control' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ss555/startup/iss555.c:34:6: warning: no previous prototype for '_InitSS555' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:82:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:81:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:22:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:86:6: warning: no previous prototype for 'init_PCI' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:77:6: warning: no previous prototype for 'init_RTC' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:129:6: warning: no previous prototype for 'data_cache_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:114:6: warning: no previous prototype for 'instruction_cache_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/../../powerpc/shared/showbats.c:41:6: warning: no previous prototype for 'ShowBATS' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/../../powerpc/shared/showbats.c:18:6: warning: no previous prototype for 'printBAT' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/../../powerpc/shared/clock/p_clock.c:32:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:252:6: warning: no previous prototype for 'set_vme_slave_size' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:239:18: warning: no previous prototype for 'get_vme_slave_size' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:230:18: warning: no previous prototype for 'get_vme_base_address' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:197:6: warning: no previous prototype for 'set_vme_base_address' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:157:6: warning: no previous prototype for 'initialize_universe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:85:7: warning: no previous prototype for 'Write_pci_device_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:61:18: warning: no previous prototype for 'Read_pci_device_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:46:18: warning: no previous prototype for 'PCI_bus_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:37:6: warning: no previous prototype for 'PCI_bus_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:28:6: warning: no previous prototype for 'PCI_bus_delay' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c:63:14: warning: no previous prototype for 'SCORE603e_FLASH_pci_reset_reg' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c:35:14: warning: no previous prototype for 'SCORE603e_FLASH_verify_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:42:10: warning: no previous prototype for 'get_irq_mask' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:24:6: warning: no previous prototype for 'initialize_PCI_bridge' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:162:18: warning: no previous prototype for 'read_and_clear_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:106:6: warning: no previous prototype for 'init_irq_data_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:46:5: warning: no previous prototype for 'console_inbyte_nonblocking' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:404:1: warning: no previous prototype for 'debug_putc_onlcr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:255:9: warning: no previous prototype for 'console_write_support' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:181:36: warning: variable 'chip' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: (near initialization for 'console_device_table[2].context') [enabled by default]
1 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: (near initialization for 'console_device_table[0].context') [enabled by default]
1 c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c:37:6: warning: no previous prototype for 'cmain' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c:10:1: warning: '__inb' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:49:19: warning: no previous prototype for 'bsp_interrupt_facility_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:43:19: warning: no previous prototype for 'bsp_interrupt_vector_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:37:19: warning: no previous prototype for 'bsp_interrupt_vector_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:28:5: warning: no previous prototype for 'qemuppc_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/../shared/clock/p_clock.c:32:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:91:5: warning: no previous prototype for 'psim_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:112:19: warning: no previous prototype for 'bsp_interrupt_facility_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:106:19: warning: no previous prototype for 'bsp_interrupt_vector_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:100:19: warning: no previous prototype for 'bsp_interrupt_vector_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c:18:1: warning: no previous prototype for '__BSP_default_pgtbl_activate' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c:200:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c:199:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c:163:1: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../shared/vme/vmeconfig.c:75:1: warning: no previous prototype for '__BSP_default_vme_config' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../shared/vmeUniverse/vmeUniverse.c:316:1: warning: no previous prototype for 'vmeUniverseFindPciBase' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../shared/vmeUniverse/bspVmeDmaList.c:322:1: warning: no previous prototype for 'BSP_VMEDmaListDump' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../shared/vmeUniverse/bspVmeDmaList.c:286:1: warning: no previous prototype for 'BSP_VMEDmaDescriptorPrev' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/probeMemEnd.c:168:1: warning: no previous prototype for 'probeMemoryEnd' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/probeMemEnd.c:120:1: warning: no previous prototype for 'CPU_lockUnlockCaches' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/pretaskinghook.c:39:6: warning: no previous prototype for 'bsp_pretasking_hook' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/pgtbl_setup.c:73:1: warning: no previous prototype for '__BSP_default_pgtbl_setup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/console/uart.c:139:17: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/console/uart.c:115:13: warning: no previous prototype for 'uartError' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/console/console.c:178:12: warning: 'console_last_close' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/console/console.c:151:12: warning: 'console_first_open' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci_interface.c:69:6: warning: no previous prototype for 'pci_interface' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c:22:7: warning: variable 'x' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c:19:5: warning: no previous prototype for 'BSP_pciFindDevicePrint' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c:219:18: warning: no previous prototype for 'BSP_getVMEchipType' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c:214:22: warning: no previous prototype for 'BSP_getDiscoveryChipVersion' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c:26:15: warning: no previous prototype for '_BSP_clear_hostbridge_errors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c:43:3: warning: (near initialization for 'defaultIrq.on') [enabled by default]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c:43:3: warning: (near initialization for 'defaultIrq.off') [enabled by default]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c:43:3: warning: (near initialization for 'defaultIrq.isOn') [enabled by default]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c:43:3: warning: (near initialization for 'defaultIrq.hdl') [enabled by default]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c:35:12: warning: 'connected' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/irq_init.c:100:25: warning: variable 'l' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:482:6: warning: no previous prototype for 'BSP_printPicIsrTbl' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:357:6: warning: no previous prototype for 'BSP_disable_pic_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:322:6: warning: no previous prototype for 'BSP_enable_pic_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c:30:5: warning: no previous prototype for 'I2Cread_eeprom' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c:23:15: warning: no previous prototype for 'I2cDevByteAddr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c:19:15: warning: no previous prototype for 'I2cAddrPack' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c:61:5: warning: no previous prototype for 'GT64260TWSIintFlag' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c:53:1: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c:125:1: warning: no previous prototype for 'BSP_eeprom_write_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c:116:1: warning: no previous prototype for 'BSP_eeprom_write_protect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c:128:8: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:691:1: warning: no previous prototype for 'am2imode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:577:1: warning: no previous prototype for 'am2omode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1238:1: warning: no previous prototype for 'vmeTsi148InboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1184:1: warning: no previous prototype for 'vmeTsi148InboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1178:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1114:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/bspVmeDmaList.c:322:1: warning: no previous prototype for 'BSP_VMEDmaListDump' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/bspVmeDmaList.c:286:1: warning: no previous prototype for 'BSP_VMEDmaDescriptorPrev' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/vme/vmeconfig.c:75:1: warning: no previous prototype for '__BSP_default_vme_config' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/startup/pretaskinghook.c:39:6: warning: no previous prototype for 'bsp_pretasking_hook' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/console/uart.c:139:17: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/console/uart.c:115:13: warning: no previous prototype for 'uartError' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/console/console.c:178:12: warning: 'console_last_close' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/console/console.c:151:12: warning: 'console_first_open' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c:76:6: warning: no previous prototype for 'detect_host_bridge' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c:71:6: warning: no previous prototype for 'BSP_motload_pci_fixup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c:109:1: warning: no previous prototype for 'BSP_pciConfigDump_early' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:430:1: warning: no previous prototype for 'i2c_write_bytes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:424:1: warning: no previous prototype for 'i2c_read_bytes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:381:1: warning: no previous prototype for 'i2c_send_addr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:365:1: warning: no previous prototype for 'i2c_stop' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:336:1: warning: no previous prototype for 'i2c_start' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:291:1: warning: no previous prototype for 'i2c_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:205:1: warning: no previous prototype for 'i2c_xfer' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/i2c_init.c:85:1: warning: no previous prototype for 'BSP_i2c_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/cpuinit.c:15:6: warning: no previous prototype for 'cpu_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:98:6: warning: no previous prototype for '_BSP_GPLED0_off' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:151:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:150:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:140:6: warning: no previous prototype for '_BSP_Uart2_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:133:6: warning: no previous prototype for '_BSP_Uart2_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:126:6: warning: no previous prototype for '_BSP_Uart1_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:119:6: warning: no previous prototype for '_BSP_Uart1_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:112:6: warning: no previous prototype for '_BSP_GPLED1_off' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c:314:1: warning: no previous prototype for 'BSP_CPM_irq_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c:214:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/console/console.c:455:5: warning: no previous prototype for 'mbx8xx_console_get_configuration' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/bspstart.c:125:14: warning: no previous prototype for 'get_eumbbar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/pci/detect_raven_bridge.c:39:6: warning: no previous prototype for 'detect_host_bridge' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:162:12: warning: unused variable 'i' [-Wunused-variable]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:411:26: warning: 'do_poll_write' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:347:26: warning: 'do_poll_read' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:219:16: warning: '_EPPCBug_pollWrite' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:114:12: warning: '_EPPCBug_pollRead' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c:208:6: warning: no previous prototype for 'BSP_ask_for_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c:165:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c:164:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c:127:6: warning: no previous prototype for 'Init_FPGA' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c:108:6: warning: no previous prototype for 'GPIO_AlternateSelect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/haleakala/../../powerpc/shared/console/uart.c:139:17: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/haleakala/../../powerpc/shared/console/uart.c:115:13: warning: no previous prototype for 'uartError' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/haleakala/../../powerpc/shared/console/console.c:178:12: warning: 'console_last_close' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/haleakala/../../powerpc/shared/console/console.c:151:12: warning: 'console_first_open' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c:41:1: warning: (near initialization for 'defaultIrq.isOn') [enabled by default]
1 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c:41:1: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c:40:7: warning: (near initialization for 'defaultIrq.on') [enabled by default]
1 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c:40:7: warning: (near initialization for 'defaultIrq.off') [enabled by default]
1 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c:40:7: warning: (near initialization for 'defaultIrq.hdl') [enabled by default]
1 c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c:14:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/powerpc/ep1a/../shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../shared/vme/vmeconfig.c:75:1: warning: no previous prototype for '__BSP_default_vme_config' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../../shared/vmeUniverse/vmeUniverse.c:316:1: warning: no previous prototype for 'vmeUniverseFindPciBase' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../../shared/vmeUniverse/bspVmeDmaList.c:322:1: warning: no previous prototype for 'BSP_VMEDmaListDump' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../../shared/vmeUniverse/bspVmeDmaList.c:286:1: warning: no previous prototype for 'BSP_VMEDmaDescriptorPrev' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../../powerpc/shared/startup/pgtbl_setup.c:73:1: warning: no previous prototype for '__BSP_default_pgtbl_setup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../../powerpc/shared/startup/pgtbl_activate.c:59:1: warning: no previous prototype for '__BSP_default_pgtbl_activate' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../../powerpc/shared/showbats.c:41:6: warning: no previous prototype for 'ShowBATS' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/../../powerpc/shared/showbats.c:18:6: warning: no previous prototype for 'printBAT' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c:26:6: warning: no previous prototype for 'detect_host_bridge' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c:77:13: warning: 'compute_i8259_masks_from_prio' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c:55:1: warning: (near initialization for 'defaultIrq.isOn') [enabled by default]
1 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c:55:1: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c:54:3: warning: (near initialization for 'defaultIrq.on') [enabled by default]
1 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c:54:3: warning: (near initialization for 'defaultIrq.off') [enabled by default]
1 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c:54:3: warning: (near initialization for 'defaultIrq.hdl') [enabled by default]
1 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c:48:12: warning: 'connected' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c:23:1: warning: no previous prototype for 'debug_putc_onlcr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:971:3: warning: passing argument 4 of 'rsPMCQ1QuiccIntConnect' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:891:6: warning: no previous prototype for 'mc68360_scc_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:874:9: warning: no previous prototype for 'mc68360_scc_write_support_polled' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:860:5: warning: no previous prototype for 'mc68360_scc_inbyte_nonblocking_polled' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:845:5: warning: no previous prototype for 'mc68360_scc_close' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:751:28: warning: variable 'm360' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:745:5: warning: no previous prototype for 'mc68360_scc_set_attributes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:728:6: warning: no previous prototype for 'mc68360_scc_write_polled' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:670:9: warning: no previous prototype for 'mc68360_scc_write_support_int' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:407:6: warning: no previous prototype for 'mc68360_scc_initialize_interrupts' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:381:10: warning: no previous prototype for 'mc68360_scc_calculate_pbdat' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:350:26: warning: variable 'm360' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c:255:6: warning: no previous prototype for 'mc68360_sccInterruptHandler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/startup/i2c_init.c:60:1: warning: no previous prototype for 'BSP_i2c_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:162:1: warning: no previous prototype for 'BSP_getBoardType' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:147:1: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../shared/vme/vmeconfig.c:75:1: warning: no previous prototype for '__BSP_default_vme_config' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeUniverse.c:316:1: warning: no previous prototype for 'vmeUniverseFindPciBase' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:691:1: warning: no previous prototype for 'am2imode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:577:1: warning: no previous prototype for 'am2omode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1238:1: warning: no previous prototype for 'vmeTsi148InboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1184:1: warning: no previous prototype for 'vmeTsi148InboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1178:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1114:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/bspVmeDmaList.c:322:1: warning: no previous prototype for 'BSP_VMEDmaListDump' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/bspVmeDmaList.c:286:1: warning: no previous prototype for 'BSP_VMEDmaDescriptorPrev' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/probeMemEnd.c:168:1: warning: no previous prototype for 'probeMemoryEnd' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/probeMemEnd.c:120:1: warning: no previous prototype for 'CPU_lockUnlockCaches' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/pretaskinghook.c:39:6: warning: no previous prototype for 'bsp_pretasking_hook' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/pgtbl_setup.c:73:1: warning: no previous prototype for '__BSP_default_pgtbl_setup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/pgtbl_activate.c:59:1: warning: no previous prototype for '__BSP_default_pgtbl_activate' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/panic.c:31:17: warning: variable 'flags' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/console/uart.c:139:17: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/console/uart.c:115:13: warning: no previous prototype for 'uartError' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/console/console.c:178:12: warning: 'console_last_close' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/console/console.c:151:12: warning: 'console_first_open' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c:76:1: warning: no previous prototype for 'rtems_pci_io_remap' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c:72:6: warning: no previous prototype for 'BSP_motload_pci_fixup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c:47:6: warning: no previous prototype for 'detect_host_bridge' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c:170:1: warning: no previous prototype for 'BSP_pci_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c:258:6: warning: no previous prototype for 'BSP_timer_test_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c:212:1: warning: no previous prototype for 'BSP_timers_uninstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:971:1: warning: no previous prototype for 'discovery_pic_set_debug_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:924:1: warning: no previous prototype for 'discovery_pic_install_debug_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:199:6: warning: no previous prototype for 'discovery_dump_picregs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:92:8: warning: unused variable 'c' [-Wunused-variable]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:29:17: warning: 'uart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:24:28: warning: 'uart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:147:3: warning: (near initialization for 'or1ksim_uart_fns.deviceRead') [enabled by default]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:147:3: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c:140:34: warning: 'Old_ticker' is used uninitialized in this function [-Wuninitialized]
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:45:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:33:6: warning: no previous prototype for 'timerisr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c:24:6: warning: no previous prototype for 'bsp_start' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/console/console.c:38:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c:34:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/startup/moxiebdinstallirq.c:15:6: warning: no previous prototype for 'MOXIEBD_Install_IRQ' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/startup/__main.c:10:6: warning: no previous prototype for '__main' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/../../shared/bspclean.c:14:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c:9:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/start/start.S:24:1: warning: "/*" within comment [-Wcomment]
1 c/src/lib/libbsp/mips/rbtx4938/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:93:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:272:6: warning: no previous prototype for 'RBTX4938_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:138:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:113:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/startup/inittlb.c:9:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/start/start.S:24:1: warning: "/*" within comment [-Wcomment]
1 c/src/lib/libbsp/mips/rbtx4925/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:91:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:266:6: warning: no previous prototype for 'RBTX4925_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:134:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:111:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:145:5: warning: (near initialization for 'Console_Configuration_Ports[2].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:145:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:144:5: warning: (near initialization for 'Console_Configuration_Ports[2].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:144:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:126:5: warning: (near initialization for 'Console_Configuration_Ports[1].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:126:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:125:5: warning: (near initialization for 'Console_Configuration_Ports[1].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:125:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:107:5: warning: (near initialization for 'Console_Configuration_Ports[0].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:107:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:106:5: warning: (near initialization for 'Console_Configuration_Ports[0].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:106:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/hurricane/startup/inittlb.c:5:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:80:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:254:6: warning: no previous prototype for 'hurricane_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:123:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:100:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c:97:6: warning: no previous prototype for 'getDebugChar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c:91:6: warning: no previous prototype for 'mg5rdbgCloseGDBuart' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c:40:5: warning: no previous prototype for 'mg5rdbgOpenGDBuart' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c:110:6: warning: no previous prototype for 'putDebugChar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:933:6: warning: no previous prototype for 'handle_exception' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:874:6: warning: no previous prototype for 'gdb_stub_report_exception_info' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:1573:7: warning: nested extern declaration of 'rtems_interrupt_catch' [-Wnested-externs]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:1573:7: warning: implicit declaration of function 'rtems_interrupt_catch' [-Wimplicit-function-declaration]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:95:28: warning: no previous prototype for 'mg5uart_isr_tx_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:95:28: warning: no previous prototype for 'mg5uart_isr_tx_empty' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:95:28: warning: no previous prototype for 'mg5uart_isr_rx_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:95:28: warning: no previous prototype for 'mg5uart_isr_rx_overrun_error' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:95:28: warning: no previous prototype for 'mg5uart_isr_rx_frame_error' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:756:20: warning: no previous prototype for 'mg5uart_inbyte_nonblocking_polled' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:727:24: warning: no previous prototype for 'mg5uart_write_support_polled' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:684:20: warning: no previous prototype for 'mg5uart_write_support_int' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:648:21: warning: no previous prototype for 'mg5uart_initialize_interrupts' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:519:21: warning: no previous prototype for 'mg5uart_process_tx_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:474:21: warning: no previous prototype for 'mg5uart_process_isr_rx_error' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:418:21: warning: no previous prototype for 'mg5uart_write_polled' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:376:17: warning: variable 'pMG5UART_port' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:369:20: warning: no previous prototype for 'mg5uart_close' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:320:14: warning: variable 'vector' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:312:20: warning: no previous prototype for 'mg5uart_open' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:269:25: warning: variable 'pMG5UART_port' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:267:21: warning: no previous prototype for 'mg5uart_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:237:21: warning: no previous prototype for 'mg5uart_initialize_context' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c:125:20: warning: no previous prototype for 'mg5uart_set_attributes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c:89:6: warning: no previous prototype for 'GENMG5_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/csb350/startup/bspreset.c:12:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/csb350/console/console-io.c:76:6: warning: no previous prototype for 'csb250_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/init5282.c:28:6: warning: no previous prototype for 'Init5282' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:759:1: warning: no previous prototype for 'rtems_bsp_reset_cause' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:635:1: warning: no previous prototype for 'BSP_irq_is_enabled_at_pic' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:625:1: warning: no previous prototype for 'BSP_disable_irq_at_pic' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:615:1: warning: no previous prototype for 'BSP_enable_irq_at_pic' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:414:6: warning: no previous prototype for 'bsp_setbenv' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:178:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:171:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:159:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:147:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:138:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:133:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:123:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:113:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:111:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:110:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:105:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:104:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:103:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:102:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/console/console.c:784:6: warning: no previous prototype for 'DEBUG_OUTNUM' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/console/console.c:779:6: warning: no previous prototype for 'DEBUG_OUTSTR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/console/console.c:772:5: warning: no previous prototype for 'DEBUG_OUTCHAR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/clock/clock.c:131:5: warning: no previous prototype for 'rtems_bsp_cpu_load_percentage' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/trace.c:66:6: warning: no previous prototype for 'trace_exception' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:29:1: warning: no previous prototype for 'partial_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:24:1: warning: no previous prototype for 'reset_partial_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:19:1: warning: no previous prototype for 'boot_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:14:1: warning: no previous prototype for 'production_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c:540:6: warning: no previous prototype for '_returnFromException' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c:62:6: warning: no previous prototype for 'exceptionHandler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c:25:6: warning: no previous prototype for 'getDebugChar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c:14:6: warning: no previous prototype for 'putDebugChar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c:95:6: warning: no previous prototype for 'boot_phase_2' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c:51:6: warning: no previous prototype for 'boot_phase_1' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c:124:6: warning: no previous prototype for 'boot_phase_3' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/console/console.c:88:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/console/console.c:65:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/console/console.c:108:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c:78:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c:61:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/timer/timer.c:78:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:585:52: warning: variable 'final_ier' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:585:39: warning: variable 'initial_ier' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:540:8: warning: variable 'buffer' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:539:42: warning: variable 'total' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:232:18: warning: variable 'ticks_per_second' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:1374:19: warning: no previous prototype for 'do_poll_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:1336:19: warning: no previous prototype for 'do_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c:93:11: warning: no previous prototype for 'VMEchip2_T2_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c:146:6: warning: no previous prototype for 'VMEchip2_T2_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/timer/timer.c:30:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c:43:18: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c:21:6: warning: no previous prototype for 'bsp_return_to_monitor_trap' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/timer/timer.c:30:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:94:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:66:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:120:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/clock/ckinit.c:60:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/clock/ckinit.c:47:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:94:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:66:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:120:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c:60:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c:47:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme136/timer/timer.c:23:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c:44:18: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c:18:6: warning: no previous prototype for 'bsp_return_to_monitor_trap' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme136/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme136/console/console.c:88:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme136/console/console.c:65:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme136/console/console.c:105:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c:72:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c:57:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c:31:11: warning: no previous prototype for 'Spurious_Isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mrm332/console/sci.c:1150:16: warning: variable 'unused' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mrm332/console/sci.c:1041:16: warning: variable 'length' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c:40:13: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c:25:6: warning: no previous prototype for 'Init5329' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5329/console/console.c:680:6: warning: no previous prototype for 'DEBUG_OUTNUM' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5329/console/console.c:675:6: warning: no previous prototype for 'DEBUG_OUTSTR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5329/console/console.c:668:5: warning: no previous prototype for 'DEBUG_OUTCHAR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5235/startup/init5235.c:29:6: warning: no previous prototype for 'Init5235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5235/console/console.c:757:6: warning: no previous prototype for 'DEBUG_OUTNUM' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5235/console/console.c:752:6: warning: no previous prototype for 'DEBUG_OUTSTR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5235/console/console.c:745:5: warning: no previous prototype for 'DEBUG_OUTCHAR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c:40:13: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c:30:6: warning: no previous prototype for 'Init5225x' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:43:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:42:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:41:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:40:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:38:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:37:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:36:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:35:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:33:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:32:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:27:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:26:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:25:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:24:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/console/console.c:483:5: warning: no previous prototype for 'IntUartPollRead' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c:40:13: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c:25:6: warning: no previous prototype for 'Init52235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:91:1: warning: no previous prototype for 'ds1307_get_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:47:1: warning: no previous prototype for 'ds1307_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:172:1: warning: no previous prototype for 'ds1307_set_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c:66:1: warning: no previous prototype for 'Init5206e' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/timer/timer.c:26:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/idp/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/mc68ec.c:12:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:86:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:157:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:132:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:110:6: warning: no previous prototype for 'quick_char_check' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/clock/ckinit.c:88:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/clock/ckinit.c:60:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:48:26: warning: variable 'RamBase_p' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:88:6: warning: no previous prototype for '__Restart_Check_Timer' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:72:6: warning: no previous prototype for '__Restart_Fifo_Full_Timer' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:188:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:105:6: warning: no previous prototype for '__do_nothing' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/startup/init68340.c:21:6: warning: no previous prototype for '_Init68340' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c:129:6: warning: no previous prototype for '_dbug_dumpanic' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c:109:6: warning: no previous prototype for '_dbug_dump' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/m340uart.c:302:6: warning: no previous prototype for 'RAW_FMT' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/m340uart.c:288:6: warning: no previous prototype for 'RAW_GETC' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/m340uart.c:127:1: warning: no previous prototype for 'Find_Right_m340_UART_Channel_Config' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:382:23: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:298:23: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:232:5: warning: no previous prototype for 'dbug_char_present' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:214:5: warning: no previous prototype for 'dbug_in_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:196:6: warning: no previous prototype for 'dbug_out_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c:59:1: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/../../shared/dummy_printk_support.c:25:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:166:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:134:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:105:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c:78:6: warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c:61:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/csb360/startup/init5272.c:84:1: warning: no previous prototype for 'init5272' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/init5282.c:23:6: warning: no previous prototype for 'Init5282' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:95:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:86:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:81:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:71:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:61:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:59:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:58:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:53:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:52:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:51:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:50:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:121:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:116:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:105:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/console/console.c:728:6: warning: no previous prototype for 'DEBUG_OUTNUM' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/console/console.c:723:6: warning: no previous prototype for 'DEBUG_OUTSTR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/console/console.c:716:5: warning: no previous prototype for 'DEBUG_OUTCHAR' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c:27:1: warning: no previous prototype for 'timer_ra_interrupt' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c:48:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/milkymist/../../lm32/shared/milkymist_clock/ckinit.c:42:6: warning: no previous prototype for 'Clock_driver_support_shutdown_hardware' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/milkymist/../../lm32/shared/milkymist_clock/ckinit.c:33:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../shared/setvec.c:29:17: warning: no previous prototype for 'set_vector' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:61:6: warning: no previous prototype for 'BSP_uart_is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:54:6: warning: no previous prototype for 'BSP_uart_polled_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:44:6: warning: no previous prototype for 'BSP_uart_polled_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/console.c:88:5: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/console.c:69:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/console.c:108:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/clock/../../../shared/clockdrv_shell.h:173:3: warning: nested extern declaration of 'set_vector' [-Wnested-externs]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/clock/../../../shared/clockdrv_shell.h:173:3: warning: implicit declaration of function 'set_vector' [-Wimplicit-function-declaration]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/clock/ckinit.c:70:6: warning: no previous prototype for 'Clock_driver_support_shutdown_hardware' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/clock/ckinit.c:55:6: warning: no previous prototype for 'Clock_driver_support_initialize_hardware' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c:173:6: warning: no previous prototype for 'initCPLB' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c:225:9: warning: no previous prototype for 'getButtons' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c:218:9: warning: no previous prototype for 'getLEDs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c:207:6: warning: no previous prototype for 'setLEDs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/startup/bspreset.c:11:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/startup/bspstart.c:29:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:355:5: warning: no previous prototype for 'sm_ECCEncode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:326:6: warning: no previous prototype for 'smc_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:291:6: warning: no previous prototype for 'smc_detect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:242:6: warning: no previous prototype for 'smc_make_l2p' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:210:6: warning: no previous prototype for 'smc_read_spare' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:163:9: warning: no previous prototype for 'smc_read_page' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:136:6: warning: no previous prototype for 'smc_read_id' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../../shared/bspclean.c:14:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:37:17: warning: 'usart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:32:28: warning: 'usart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/nds/touchscreen/reco.c:72:6: warning: no previous prototype for 'PA_StylusLine' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/reco.c:63:6: warning: no previous prototype for 'PA_AddStylusPos' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/reco.c:209:6: warning: no previous prototype for 'PA_CheckLetter' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/reco.c:133:6: warning: no previous prototype for 'PA_AnalyzeShape' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/parser.c:58:1: warning: no previous prototype for 'update_touchscreen' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/parser.c:194:1: warning: no previous prototype for 'touchscreen_sethand' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/parser.c:184:1: warning: no previous prototype for 'unregister_kbd_msg_queue' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/parser.c:166:1: warning: no previous prototype for 'register_kbd_msg_queue' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/parser.c:156:1: warning: no previous prototype for 'unregister_mou_msg_queue' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/touchscreen/parser.c:136:1: warning: no previous prototype for 'register_mou_msg_queue' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/startup/bspstart.c:53:1: warning: no previous prototype for 'bss_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/startup/bspstart.c:17:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
1 c/src/lib/libbsp/arm/nds/rtc/rtc.c:66:1: warning: no previous prototype for 'nds_rtc_set_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/rtc/rtc.c:47:1: warning: no previous prototype for 'nds_rtc_get_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/rtc/rtc.c:35:1: warning: no previous prototype for 'nds_rtc_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/rtc/rtc.c:25:1: warning: no previous prototype for 'nds_rtc_probe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c:327:9: warning: no previous prototype for 'getNextTextureSlot' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c:295:5: warning: no previous prototype for 'vramIsTextureBank' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c:272:9: warning: no previous prototype for 'vramGetBank' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c:255:5: warning: no previous prototype for 'getNextPaletteSlot' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c:250:15: warning: no previous prototype for 'alignVal' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/video.c:51:6: warning: no previous prototype for 'vramRestorMainBanks' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:98:5: warning: no previous prototype for 'motion_pak_is_inserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:81:6: warning: no previous prototype for 'motion_MK6_EEPROM_mode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:65:6: warning: no previous prototype for 'motion_MK6_sensor_mode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:55:15: warning: no previous prototype for 'motion_spi' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:457:16: warning: variable 'return_byte' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:450:16: warning: variable 'return_byte' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:133:5: warning: no previous prototype for 'motion_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c:117:5: warning: no previous prototype for 'motion_card_is_inserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/initSystem.c:44:6: warning: no previous prototype for 'initSystem' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c:124:20: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c:80:5: warning: no previous prototype for 'getExceptionAddress' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c:38:15: warning: no previous prototype for 'ARMShift' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c:176:5: warning: no previous prototype for 'con_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c:81:5: warning: no previous prototype for 'BoxTestf' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c:64:5: warning: no previous prototype for 'BoxTest' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c:55:5: warning: no previous prototype for 'BoxTestResult' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c:47:6: warning: no previous prototype for 'BoxTestf_Asynch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c:34:6: warning: no previous prototype for 'BoxTest_Asynch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c:43:4: warning: no previous prototype for 'CheckStylus' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c:227:6: warning: no previous prototype for 'UpdateRange' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c:136:7: warning: no previous prototype for 'readTouchValue' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:383:6: warning: no previous prototype for '_SCSD_shutdown' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:379:6: warning: no previous prototype for '_SCSD_clearStatus' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:335:6: warning: no previous prototype for '_SCSD_writeSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:299:6: warning: no previous prototype for '_SCSD_readSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:281:6: warning: no previous prototype for '_SCSD_isInserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:276:6: warning: no previous prototype for '_SCSD_startUp' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:206:6: warning: no previous prototype for '_SCSD_cmd_17byte_response' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:201:6: warning: no previous prototype for '_SCSD_cmd_6byte_response' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c:195:6: warning: variable 'temp' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.c:68:6: warning: no previous prototype for '_SCCF_startup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c:305:6: warning: no previous prototype for '_NMMC_readSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c:258:6: warning: no previous prototype for '_NMMC_writeSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c:213:6: warning: no previous prototype for '_NMMC_startUp' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c:209:6: warning: no previous prototype for '_NMMC_shutdown' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c:186:6: warning: no previous prototype for '_NMMC_clearStatus' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c:164:6: warning: no previous prototype for '_NMMC_isInserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:464:6: warning: no previous prototype for '_NJSD_readSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:446:6: warning: no previous prototype for '_NJSD_writeSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:435:6: warning: no previous prototype for '_NJSD_startup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:431:6: warning: no previous prototype for '_NJSD_shutdown' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:427:6: warning: no previous prototype for '_NJSD_clearStatus' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:416:6: warning: no previous prototype for '_NJSD_isInserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:391:6: warning: no previous prototype for '_NJSD_cmd_17byte_response' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c:387:6: warning: no previous prototype for '_NJSD_cmd_6byte_response' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.c:84:6: warning: no previous prototype for '_MPCF_startup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:502:6: warning: no previous prototype for '_M3SD_shutdown' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:498:6: warning: no previous prototype for '_M3SD_clearStatus' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:450:6: warning: no previous prototype for '_M3SD_writeSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:414:6: warning: no previous prototype for '_M3SD_readSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:397:6: warning: no previous prototype for '_M3SD_isInserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:392:6: warning: no previous prototype for '_M3SD_startUp' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:246:6: warning: no previous prototype for '_M3SD_cmd_17byte_response' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c:241:6: warning: no previous prototype for '_M3SD_cmd_6byte_response' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.c:81:6: warning: no previous prototype for '_M3CF_startup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c:76:6: warning: no previous prototype for '_FCSR_isInserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c:248:6: warning: no previous prototype for '_FCSR_startUp' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c:226:6: warning: no previous prototype for '_FCSR_shutdown' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c:187:6: warning: no previous prototype for '_FCSR_writeSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c:119:6: warning: no previous prototype for '_FCSR_readSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c:104:6: warning: no previous prototype for '_FCSR_clearStatus' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c:289:6: warning: no previous prototype for '_EFA2_startUp' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c:279:6: warning: no previous prototype for '_EFA2_shutdown' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c:268:6: warning: no previous prototype for '_EFA2_writeSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c:194:6: warning: no previous prototype for '_EFA2_readSectors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c:179:6: warning: no previous prototype for '_EFA2_isInserted' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c:167:6: warning: no previous prototype for '_EFA2_clearStatus' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/irq/irq.c:33:1: warning: no previous prototype for 'BSP_rtems_irq_mngt_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/coproc/coproc.c:120:6: warning: passing argument 1 of 'StartRecording' discards 'volatile' qualifier from pointer target type [enabled by default]
1 c/src/lib/libbsp/arm/nds/console/console.c:53:1: warning: no previous prototype for 'nds_getch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/console/console.c:47:1: warning: no previous prototype for 'console_push' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/console/console.c:36:1: warning: no previous prototype for 'nds_putch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:82:1: warning: no previous prototype for 'nds_flash_io_speed' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:75:1: warning: no previous prototype for 'nds_flash_control' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:67:1: warning: no previous prototype for 'nds_flash_write_block' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:59:1: warning: no previous prototype for 'nds_flash_read_block' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:53:1: warning: no previous prototype for 'nds_flash_write_reg' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:47:1: warning: no previous prototype for 'nds_flash_read_reg' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:27:1: warning: no previous prototype for 'nds_flash_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/nds/block/block.c:21:1: warning: no previous prototype for 'nds_flash_probe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gumstix/startup/bspstart.c:32:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gumstix/startup/bspreset.c:15:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/startup/bspstart.c:29:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/startup/bspreset.c:9:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:355:5: warning: no previous prototype for 'sm_ECCEncode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:326:6: warning: no previous prototype for 'smc_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:291:6: warning: no previous prototype for 'smc_detect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:242:6: warning: no previous prototype for 'smc_make_l2p' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:210:6: warning: no previous prototype for 'smc_read_spare' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:163:9: warning: no previous prototype for 'smc_read_page' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:136:6: warning: no previous prototype for 'smc_read_id' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/startup/bspstart.c:37:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/startup/bspreset.c:10:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/console/conio.c:353:6: warning: no previous prototype for 'delay_loop' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/console/conio.c:302:6: warning: no previous prototype for 'gba_initconio' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/console/conio.c:229:6: warning: no previous prototype for 'gba_put' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/console/conio.c:197:6: warning: no previous prototype for 'gba_nextline' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/console/conio.c:182:6: warning: no previous prototype for 'gba_clearline' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/console/conio.c:121:6: warning: no previous prototype for 'gba_putchar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/edb7312/startup/bspstart.c:32:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/edb7312/startup/bspreset.c:12:6: warning: no previous prototype for 'bsp_reset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/edb7312/irq/irq.c:23:6: warning: no previous prototype for 'edb7312_interrupt_dispatch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb337/console/sed1356.c:362:6: warning: no previous prototype for 'sed_update_fb_offset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb337/console/fbcons.c:135:5: warning: no previous prototype for 'fbcons_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb336/startup/bspstart.c:33:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/../../cpukit/score/src/objectextendinformation.c:159:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/score/src/objectextendinformation.c:154:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/score/cpu/m32c/cpu_asm.c:48:6: warning: no previous prototype for '_ISR_Handler' [-Wmissing-prototypes]
1 c/src/../../cpukit/libmisc/utf8proc/utf8proc.c:148:5: warning: left shift count >= width of type [enabled by default]
1 c/src/../../cpukit/libfs/src/dosfs/msdos_conv.c:452:48: warning: 'c' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 c/src/../../cpukit/libcsupport/src/vprintk.c:199:41: warning: 'num' may be used uninitialized in this function [-Wmaybe-uninitialized]
