[PATCH 2/8] Move Mongoose-V specific devices into BSP.
Cudmore, Alan P. (GSFC-5820) alan.p.cudmore at nasa.gov
Fri Oct 10 12:26:39 UTC 2014
If it helps, I have not heard of anyone using the Mongoose V in years.
If it's still around and being used in a new project, I'm not aware of it .
Alan
On 10/9/14 3:50 PM, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>On 10/9/2014 2:47 PM, Gedare Bloom wrote:
>> I didn't read this, but you should consider doing some style cleanup
>> too (as a separate commit)
>Noted.
>FWIW I didn't change any code file contents except to note that a .h
>file moved from libcpu/ to bsp/.
>The big problem here is that when we did the BSP, we thought the
>Mongoose-V on-CPU IP modules might show up again. They haven't
>and moving them makes it clear they were specific to this single case.
>--joel
>> On Thu, Oct 9, 2014 at 2:39 PM, Joel Sherrill
>>> Putting the duart in libcpu was very optimistic and presumptuous.
>>> It has never been used again on another SoC and is BSP specific.
>>>  c/src/lib/libbsp/mips/genmongoosev/Makefile.am     |   7 +-
>>>  c/src/lib/libbsp/mips/genmongoosev/README          |  54 +-
>>>  .../libbsp/mips/genmongoosev/consoe/README.mguart | 100 +++
>>>  .../lib/libbsp/mips/genmongoosev/console/conscfg.c |   2 +-
>>>  .../lib/libbsp/mips/genmongoosev/console/mg5uart.c | 917
>>>  .../lib/libbsp/mips/genmongoosev/console/mg5uart.h |  98 +++
>>>  .../libbsp/mips/genmongoosev/console/mg5uart_reg.c |  58 ++
>>>  c/src/lib/libbsp/mips/genmongoosev/include/bsp.h   |   2 +-
>>>  .../libbsp/mips/genmongoosev/include/mongoose-v.h  | 306 +++++++
>>>  .../lib/libbsp/mips/genmongoosev/irq/vectorisrs.c  |   2 +-
>>>  c/src/lib/libbsp/mips/genmongoosev/preinstall.am   |  20 +
>>>  .../libbsp/mips/genmongoosev/startup/bspstart.c    |   2 +-
>>>  .../libbsp/mips/genmongoosev/startup/gdb-support.c |   2 +-
>>>  c/src/lib/libcpu/mips/Makefile.am                  |  21 -
>>>  .../lib/libcpu/mips/mongoosev/duart/README.mguart  | 101 ---
>>>  c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c    | 917
>>>  c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h    |  98 ---
>>>  .../lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c  |  58 --
>>>  .../lib/libcpu/mips/mongoosev/include/mongoose-v.h | 306 -------
>>>  c/src/lib/libcpu/mips/preinstall.am                |  14 -
>>>  20 files changed, 1562 insertions(+), 1523 deletions(-)
>>>  create mode 100644
>>>c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
>>>  create mode 100644
>>>c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
>>>  create mode 100644
>>>c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
>>>  create mode 100644
>>>c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
>>>  create mode 100644
>>>c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
>>>  delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duar/README.mguart
>>>  delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c
>>>  delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h
>>>  delete mode 100644 c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c
>>>  delete mode 100644
>>>c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
>>>b/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
>>> index fe21df4..a99fd56 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
>>> ++ b/c/src/lib/libbsp/mips/genmongoosev/Makefile.am
>>> @@ -16,6 +16,11 @@ include_bsp_HEADERS += include/irq.h
>>>  nodist_include_HEADERS = include/bspopts.h
>>>  nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>>> +nodist_include_bsp_HEADERS += include/lr33000.h
>>> +nodist_include_bsp_HEADERS += include/lr333x0.h
>>> +nodist_include_bsp_HEADERS += include/mongoose-v.h
>>> +nodist_include_bsp_HEADERS += include/r3000.h
>>> +nodist_include_bsp_HEADERS += console/mg5uart.h
>>>  DISTCLEANFILES = include/bspopts.h
>>>  noinst_PROGRAMS =
>>> @@ -47,6 +52,7 @@ libbsp_a_SOURCES += clock/clockdrv.c
>>>  libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
>>>  # console
>>>  libbsp_a_SOURCES += console/conscfg.c
>>> +libbsp_a_SOURCES += console/mg5uart.c
>>>  libbsp_a_SOURCES += ../../shared/console.c
>>>  libbsp_a_SOURCES += ../../shared/console_select.c
>>>  libbsp_a_SOURCES += ../../shared/console_control.c
>>> @@ -75,7 +81,6 @@ gdbstub_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>  libbsp_a_LIBADD  = ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
>>>  libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/interrupts.rel
>>> -libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/mongoosev/duart.rel
>>>  include $(srcdir)/preinstall.am
>>>  include $(top_srcdir)/../../../../automake/local.am
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/README
>>>b/c/src/lib/libbsp/mips/genmongoosev/README
>>> index 97db696..87f57a9 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/README
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/README
>>> @@ -1,6 +1,56 @@
>>>  BSP supporting the on-CPU capabilities of the Synova Mongoose-V.
>>> -This BSP assumes that basic HW initialization is performed by
>>> -PMON.
>>> +The Synova Mongoose-V is a radiation hardened derivative of the
>>> +LSI 33K with on-CPU peripherals.
>>> +This BSP assumes that basic HW initialization is performed by PMON.
>>> +Status
>>> +Per-task floating point enable/disable is supported for both immediate
>>> +and deferred FPU context swaps.
>>> +Interrupt Levels are adapted reasonably well to the MIPS interrupt
>>> +model. Bit 0 of the int level is a global enable/disable,
>>>corresponding
>>> +to bit 0 of the processor's SR register.  Bits 1 thru 6 are configured
>>> +as masks for the Int0 thru Int5 interrupts.  The 2 software interrupt
>>> +bits are always enabled by default. Each task maintains its own
>>> +Interrupt Level setting, reconfiguring the SR register's interrupt
>>>bits
>>> +whenever scheduled in.  The software ints, though not addressable via
>>> +the various Interrupt Level functions, are maintained on a per-task
>>> +basis, so if software manipulates them drectly, things should behave
>>>as
>>> +expected.  At the time of these udpates, the Interrupt Level was only
>>>8
>>> +bits, and completely supporting the global enable, software ints and
>>>the
>>> +hardware ints would require 9 bits.  When more than 8 bits are
>>> +available, there is no reason the software interrupts could not be
>>>added
>>> +to the Interrupt Level.
>>> +While supporting the Int0 thru Int5 bits in this way doesn't seem
>>> +wonderfully useful, it does increase the level of compliance with the
>>> +RTEMS spec.
>>> +Interrupt Level 0 corresponds to interrupts globally enabled, software
>>> +ints enabled and Int0 thru Int5 enabled.  If values other than 0 are
>>> +supplied, they should be formulated to impose the desired bitmask.
>>> +Interrupt priority is not a strong concept on this bsp, it is provided
>>> +only by the order in which interrupts are checked.
>>> +If during the vectoring of an interrupt, others arrive, they will all
>>>be
>>> +processed in accordance with their ordering in SR & the peripheral
>>> +register.  For example, if while we're vectoring Int4, Int3 and Int5
>>>are
>>> +asserted, Int3 ill be serviced before Int5.  The peripheral
>>>interrupts
>>> +are individually vectored as a consequence of Int5 being asserted,
>>> +however Int5 is not itself vectored.  Within the set of peripheral
>>> +interrupts, bit 0 is vectored first, 31 is last.
>>> +Interrupts are not nested for MIPS1 or MIPS3 processors, but are
>>> +processed serially as possible.  On an unloaded 50 task RTEMS program,
>>> +runnning on a 12mhz MIPS1 processor, worst-case latencies of 100us
>>>were
>>> +observed, the average being down at 60us or below.
>>> +These features are principally a consequence of fixes and tweaks to
>>>the
>>> +MIPS1and MIPS3 processor support, and should be equally effective on
>>> +both levels of MIPS processors for any of their bsp's.
>>>  Address Map
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
>>>b/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
>>> new file mode 100644
>>> index 0000000..7c6a290
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/console/README.mguart
>>> @@ -0,0 +1,100 @@
>>> +Configuration Table Use
>>> +sDeviceName
>>> +   The name of this device.
>>> +deviceType
>>> +   This field must be SERIAL_MG5UART.
>>> +pDeviceFns
>>> +   The device interface control table.  This may be:
>>> +      + mg5uart_fns for interrupt driven IO
>>> +      + mg5uart_fns_polled for polled IO
>>> +deviceProbe
>>> +   This is the address of the routine which probes to see if the
>>>device
>>> +   is present.
>>> +pDeviceFlow
>>> +   This field is ignored as hardware flow control is not currently
>>>supported.
>>> +ulMargin
>>> +    This is currently unused.
>>> +ulHysteresis
>>> +pDeviceParams
>>> +    This is set to the default settings.
>>> +ulCtrlPort1
>>> +   This field is the address of the command register shared by both
>>>ports.
>>> +ulCtrlPort2
>>> +   This field is the address of the port being used.
>>> +ulDataPort
>>> +   This field is set to MG5UART_PORTA or MG5UART_PORTB.
>>> +getRegister
>>> +setRegister
>>> +   These do NOT follow standard conventions and are ignored.
>>> +   The register address routines are hard-coded as this is
>>> +   an on-CPU part and assumed to provide a 32-bit wide interface.
>>> +getData
>>> +   This is address of the RX buffer register.
>>> +setData
>> +   This is address of the TX buffer register.
>>> +ulClock
>>> +   baudRate Clock
>>> +ulIntVector
>>> +   This is the interrupt vector number associated with this chip.
>>> +Example:
>>> +#if (CONSOLE_USE_INTERRUPTS)
>>> +#define MG5UART_FUNCTIONS &mg5uart_fns
>>> +#else
>>> +#define MG5UART_FUNCTIONS &mg5uart_fns_polled
>>> +#endif
>>> +  "/dev/com0",                            /* sDeviceName */
>>> +  SERIAL_MG5UART,                         /* deviceType */
>>> +  MG5UART_FUNCTIONS,                      /* pDeviceFns */
>>> +  NULL,                                   /* deviceProbe, assume it
>>>is there */
>>> +  NULL,                                   /* pDeviceFlw */
>>> +  16,                                     /* ulMargin */
>>> +  8,                                      /* ulHysteresis */
>>> +  (void *) NULL,               /* NULL */ /* pDeviceParams */
>>> +  MONGOOSEV_PERIPHERAL_COMMAND_REGISTER,  /* ulCtrlPort1 */
>>> +  MONGOOSEV_UART0_BASE,                   /* ulCtrlPort2 */
>>> +  MG5UART_UART0,                          /* ulDataPort */
>>> +  mg5uart_get_register,                   /* getRegister */
>>> +  mg5uart_set_register,                   /* setRegister */
>>> +  NULL, /* unused */                      /* getData */
>>>   NULL, /* unused */                      /* setData */
>>> +  12000000,                               /* ulClock */
>>> +  MONGOOSEV_IRQ_UART0_RX_FRAME_ERROR      /* ulIntVector -- base for
>>>port */
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
>>>b/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
>>> index 61ac56e..87df736 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/console/conscfg.c
>>> @@ -21,7 +21,7 @@
>>>  #include <bsp/irq.h>
>>>  #include <libchip/serial.h>
>>> -#include <libchip/mg5uart.h>
>>> +#include <bsp/mg5uart.h>
>>>  /* #define CONSOLE_USE_INTERRUPTS */
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
>>>b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
>>> index 0000000..8c4177a
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.c
>>> @@ -0,0 +1,917 @@
>>> + *  @file
>>> + *  This file contains the termios TTY driver for the UART foun
>>> + *  on the Synova Mongoose-V.
>>> + *  COPYRIGHT () 1989-2012.
>>> + *  On-Line Applications Research Corporation (OAR).
>>> + *  The license and distribution terms for this file may be
>>> + *  found in the file LICENSE in this ditribution or at
>>> + *  http://www.rtems.org/license/LICENSE.
>>> +#include <rtems.h>
>>> +#include <rtems/libio.h>
>>> +#include <rtems/score/sysstate.h>
>>> +#include <stdlib.h>
>>> +#include <libchip/serial.h>
>>> +#include <libchip/sersupp.h>
>>> +#include <bsp/mongoose-v.h>
>>> +#include <bsp/irq.h>
>>> +#include <bsp.h>
>>> + *  Indices of registers
>>> + *  Per chip context control
>>> +typedef struct _mg5uart_context
>>> +  int            mate;
>>> +} mg5uart_context;
>>> + *  Define MG5UART_STATIC to nothing while debugging so the entry
>>>points
>>> + *  will show up in the symbol table.
>>> +#define MG5UART_STATIC
>>> +/* #define MG5UART_STATIC static */
>>> +#define MG5UART_SETREG( _base, _register, _value ) \
>>> +        MONGOOSEV_WRITE_REGISTER( _base, _register, _value )
>>> +#define MG5UART_GETREG( _base, _register ) \
>>> +        MONGOOSEV_READ_REGISTER( _base, _register )
>>> + *  Console Device Driver Support Functions
>>> +MG5UART_STATIC int mg5art_baud_rate(
>>> +  int        minor,
>>> +  uint32_t   baud,
>>> +  uint32_t  *code
>>> +MG5UART_STATIC void mg5uart_enable_interrupts(
>>> + int minor,
>>> +  int mask
>>> + *  mg5uart_isr_XXX
>>> + *  This is the single interrupt entry point which parcels interrupts
>>> + *  out to the handlers for specific sources and makes sure that the
>>> + *  shared handler gets the right arguments.
>>> + *  NOTE: Yes .. this is ugly but it provides 5 interrupt source
>>> + *  wrappers which are nearly functionally identical.
>>> +extern void mips_default_isr(int vector);
>>> +#define __ISR(_TYPE, _OFFSET) \
>>> +  MG5UART_STATIC void mg5uart_process_isr_ ## _TYPE ( \
>>> +    int  minor \
>>> +  MG5UART_STATIC rtems_isr mg5uart_isr_ ## _TYPE ( \
>>> +    void *arg \
>>> +    rtems_vector_number vectr = (rtems_vector_number) arg; \
>>> +    int   minor; \
>>> +    for(minor=0 ; minor<Console_Port_Count ; minor++) { \
>>> +      if( Console_Port_Tbl[minor]->deviceType == SERIAL_MG5UART && \
>>> +          vector == Console_Por_Tbl[minor]->ulIntVector + _OFFSET )
>>> +        mg5uart_process_isr_ ## _TYPE (mino); \
>>> +       return; \
>>> +    mips_default_isr( vector ); \
>>> +__ISR(rx_frame_error, MG5UART_IRQ_RX_FRAME_ERRO)
>>> +__ISR(rx_overrun_error, MG5UART_IRQ_RX_OVERRUN_ERROR)
>>> +__ISR(tx_empty, MG5UART_IRQ_TX_EMPTY)
>>> +__ISR(tx_ready, MG5UART_IRQ_TX_READY)
>>> +__ISR(rx_ready, MG5UART_IRQ_RX_READY)
>>> + *  mg5uart_set_attributes
>>> + *  This function sets the UART channel to reflect the requested
>>>termios
>>> + *  port settings.
>>> +MG5UART_STATIC int mg5uart_set_attributes(
>>> +  int minor,
>>> +  const struct termios *t
>>> +  uint32_t               pMG5UART_port;
>>> +  uint32_t               pMG5UART;
>>> +  uint32_t               cmd, cmdSave;
>>> +  uint32_t               baudcmd;
>>> +  uint32_t               shift;
>>> +  rtems_interrupt_level  Irql;
>>> +  pMG5UART      = Console_Port_Tbl[minor]->ulCtrlPort1;
>>> +  pMG5UART_port = Console_Port_Tbl[minor]->ulCtrlPort2;
>>> +   *  Set the baud rate
>>> +  if (mg5uart_baud_rate( minor, t->c_cflag, &baudcmd ) == -1)
>>> +    return -1;
>>> +   *  Base settings
>>> +   *  Base settings
>>> +  cmd = MONGOOSEV_UART_CMD_RX_ENABLE | MONGOOSEV_UART_CMD_TX_ENABLE;
>>> +   *  Parity
>>> +  if (t->c_cflag & PARENB) {
>>> +    cmd |= MONGOOSEV_UART_CMD_PARITY_ENABLE;
>>> +    if (t->c_cflag & PARODD)
>>> +      cmd |= MONGOOSEV_UART_CMD_PARITY_ODD;
>>> +    else
>>> +      cmd |= MONGOOSEV_UART_CMD_PARITY_EVEN;
>>> +  } else {
>>> +    cmd |= MONGOOSEV_UART_CMD_PARITY_DISABLE;
>>> +   *  Character Size
>>> +  if (t->c_cflag & CSIZE) {
>>> +    switch (t->c_cflag & CSIZE) {
>>> +      case CS5:
>>> +      case CS6:
>>> +      case CS7:
>>> +        return -1;
>>> +        break;
>>> +      case CS8:
>>> +        /* Mongoose-V only supports CS8 */
>>> +        break;
>>> +  } /* else default to CS8 */
>>> +   *  Stop Bits
>>> +#if 0
>>> +  if (t->c_cflag & CSTOPB) {
>>> +    /* 2 stop bits not supported by Mongoose-V uart */
>>> +    return -1;
>>> +#endif
>>> +   *  XXX what about CTS/RTS
>>> +  /* XXX */
>>> +   *  Now write the registers
>>> +  if ( Console_Port_Tbl[minor]->ulDataPort == MG5UART_UART0 )
>>> +    shift = MONGOOSEV_UART0_CMD_SHIFT;
>>> +  else
>>> +    shift = MONGOOSEV_UART1_CMD_SHIFT;
>>> +  rtems_interrupt_disable(Irql);
>>> +  cmdSave = MG5UART_GETREG( pMG5UART, MG5UART_COMMAND_REISTER );
>>> +  MG5UART_SETREG( pMG5UART,
>>> +                 MG5UART_COMMAND_REGISTER,
>>> +                 (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS <<
>>>shift)) | (cmd << shift) );
>>> +  MG5UART_SETREG( pMG5UART_port, MG5UART_BAUD_RATE, baudcmd );
>>> +  rtems_interrupt_enable(Irql);
>>> +  return 0;
>>> + *  mg5uart_initialize_context
>>> + *  This function sets the default values of the per port context
>>>structure.
>>> +MG5UART_STATIC void mg5uart_initialize_context(
>>> +  int               minor,
>>> +  mg5uart_context  *pmg5uartContext
>>> +  int          port;
>>> +  unsigned int pMG5UART;
>> +  unsigned int pMG5UART_port;
>>> +  pMG5UART      = Console_Port_Tbl[minor]->uCtrlPort1;
>>> +  pmg5uatContext->mate = -1;
>>> +  for (port=0 ; port<Console_Port_Count ; port++ )
>>> +    if ( Console_Port_Tbl[port]->ulCtrlPort1 == pMG5UART &&
>>> +         Conole_Port_Tbl[port]->ulCtrlPort2 != pMG5UART_port ) {
>>> +      pmg5uartContext->mate = port;
>>> +      break;
>>> + *  mg5uart_init
>>> + *  This function initializes the DUART to a quiecsent state.
>>> +MG5UART_STATIC void mg5uart_init(int minor)
>>> +  uint32_t             cmdSave;
>>> +  uint32_t             shift;
>>> +  mg5uart_context        *pmg5uartContext;
>>> +  pmg5uartContext = (mg5uart_contxt *)
>>>malloc(sizeof(mg5uart_context));
>>> +  Console_Port_Data[minor].pDeviceContext = (void *)pmg5uartContext;
>>> +  mg5uart_initialize_context( minor, pmg5uartContext );
>>> +  else
>>> +   *  Disable the uart and leave this port disabled.
>>> +  cmdSave = MG5UART_GETREG(pMG5UART, MG5UART_COMMAND_REGISTER) &
>>>~(MONGOOSEV_UART_ALL_STATUS_BITS << shift);
>>> +  MG5UART_SETREG( pMG5UART, MG5UART_COMMAND_REGISTER, cmdSave );
>>> +   *  Disable interrupts on RX and TX for this port
>>> +  mg5uart_enable_interrupts( minor, MG5UART_DISABLE_ALL );
>>> + *  mg5uart_open
>>> + *  This function opens a port for communication.
>>> + *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>>> +MG5UART_STATIC int mg5uart_open(
>>> +  int      major,
>>> +  int      minor,
>>> +  void    *arg
>>> +  uint32_t     vector;
>>> +  uint32_t      baudcmd;
>>> +  uint32_t      shift;
>>> +  vector        = Console_Port_Tbl[minor]->ulIntVector;
>>> +  else
>>> +  /* XXX default baud rate could be from configuration table */
>>> +  (void) mg5uart_baud_rate( minor, B19200, &baudcmd );
>>> +   *  Set the DUART channel to a default useable state
>>> +   *  B19200, 8Nx since there is no stop bit control.
>>> +  cmd = MONGOOSEV_UART_CMD_TX_ENABLE | MONGOOSEV_UART_CMD_RX_ENABLE;
>>> +  cmdSave = MG5UART_GETREG( pMG5UART, MG5UART_COMMAND_REGISTER );
>>> +  MG5URT_SETREG( pMG5UART,
>>> +                cmd = (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS <<
>>> +  return RTEMS_SUCCESSFUL;
>>> + *  mg5uart_close
>>> + *  This function shuts down the requested port.
>>> +MG5UART_STATIC int mg5uart_close(
>>> +  int      major,
>>> +  int      minor,
>>> +  void    *arg
>>> +  uint32_t      shift;
>>> +   *  Disable interrupts from this channel and then disable it
>>>totally.
>>> +  /* XXX interrupts */
>>> +  cmd = MONGOOSEV_UART_CMD_TX_DISABLE | MONGOOSEV_UART_CMD_RX_DISABLE;
>>> +  else
>>> +  return(RTEMS_SUCCESSFUL);
>>> + *  mg5uart_write_polled
>>> + *  This routine polls out the requested character.
>>> +MG5UART_STATIC void mg5uart_write_polled(
>>> +  int   minor,
>>> +  char  c
>>> +  uint32_t                status;
>>> +  int                     shift;
>>> +  int                     timeout;
>>> +    shift = MONGOOSEV_UART0_IRQ_SHIFT;
>>> +  else
>>> +    shift = MONGOOSEV_UART1_IRQ_SHIFT;
>>> +   * wait for transmitter holding register to be empty
>>> +  timeout = 2000;
>>> +  while( --timeout )
>>> +    status = MG5UART_GETREG(pMG5UART, MG5UART_STATUS_REGISTER) >>
>>>shift;
>>> +    if ( (status & (MONGOOSEV_UART_TX_READY |
>>>MONGOOSEV_UART_TX_EMPTY)) ==
>>> +            (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY) )
>>> +      break;
>>> +    if((status & (MONGOOSEV_UART_TX_READY |
>>>MONGOOSEV_UART_TX_EMPTY)) )
>>> +       break;
>>> +     * Yield while we wait
>>> +#if 0
>>> +     if(_System_state_Is_up(_System_state_Get()))
>>> +       rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
>>> +#endif
>>> +   * transmit character
>>> +  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, c);
>>> +MG5UART_STATIC void mg5uart_process_isr_rx_error(
>>> +   int  minor,
>>> +   uint32_t   mask
>>> +  int                     shift;
>>> +  else
>>> +  /* now clear the error */
>>> +  MG5UART_SETREG(
>>> +     pMG5UART,
>>> +     MG5UART_STATUS_REGISTER,
>>> +     mask << shift );
>>> +MG5UART_STATIC void mg5uart_process_isr_rx_frame_error(
>>> +  int  minor
>>> +   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_FRAME_ERROR
>>> +MG5UART_STATIC void mg5uart_process_isr_rx_overrun_error(
>>> +  int  minor
>>>MONGOOSEV_UART_RX_OVERRUN_ERROR );
>>> +MG5UART_STATIC void m5uart_process_tx_isr(
>>> +   int        minor,
>>> +   uint32_t   source
>>> +   int             shift;
>>> +   mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX);
>>> +   else
>>> +   MG5UART_SETREG(
>>> +      pMG5UART,
>>> +      source << shift );
>>> +   if( rtems_termios_dequeue_characters(
>>>Console_Port_Data[minor].termios_data, 1) )
>>> +      mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL);
>>> +      return;
>>> +    *  There are no more characters to transmit.  The tx interrupts
>>>are be cleared
>>> +    *  by writing data to the uart, so just disable the tx interrupt
>>>sources.
>>> +   Console_Port_Data[minor].bActive = FALSE;
>>> +   /* mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX);
>>> +MG5UART_STATIC void mg5uart_process_isr_tx_empty(
>>> +  int  minor
>>> +   /* mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_EMPTY ); */
>>> +MG5UART_STATIC void mg5uart_process_isr_tx_ready(
>>> +  int  minor
>>> +   mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_READY );
>>> +MG5UART_STATIC void mg5uart_process_isr_rx_ready(
>>> +  int  minor
>>> +  char       c;
>>> +  /* reading the RX buffer automatically resets the interrupt flag */
>>> +  c = (char) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
>>> +  rtems_termios_enqueue_raw_characters(
>>> +     Console_Port_Data[minor].termios_data,
>>> +     &c, 1 ;
>>> +static rtems_irq_connect_data mg5uart_rx_frame_error_cd  = {  \
>> +  0,                             /* filled in at initialization */
>>> +  mg5uart_isr_rx_frame_error,   /* filled in at initialization */
>>> +  NULL,   /* (void *) minor */
>>> +  NULL,
>>> +  NULL,
>>> +  NULL
>>> +static rtems_irq_connect_data mg5uart_rx_overrun_error_cd  = {  \
>>> +  mg5uart_isr_rx_overrun_error,   /* filled in at initialization */
>>> +  NULL,
>>> +  NULL,
>>> +  NULL
>>> +static rtems_irq_connect_data mg5uart_tx_empty_cd  = {  \
>>> +  0,                             /* filled in at initializaion */
>>> +  mg5uart_isr_tx_empty,   /* filled in at initialization */
>>> +  NULL,id *) minor */
>>> +  NULL,
>>> +  NULL,
>>> +  NULL
>>> +static rtems_irq_connect_data mg5uart_tx_ready_cd  = {  \
>>> +  mg5uart_isr_tx_ready,   /* filled in at initialization */
>>> +  NULL,
>>> +  NULL,
>>>   NULL
>>> +static rtems_irq_connect_data mg5uart_rx_ready_cd  = {  \
>>> +  mg5uart_isr_rx_ready,   /* filled in at initialization */
>>> +  NULL,
>>> +  NULL,
>>> +  NUL
>>> + *  mg5uart_initialize_interrupts
>>> + *  This routine initializes the console's receive and transmit
>>> + *  ring buffers and loads the appropriate vectors to handle the
>>>interrupts.
>>> +MG5UART_STATIC void mg5uart_initialize_interrupts(int minor)
>>> +  unsigned long v;
>>> +  mg5uart_init(minor);
>>> +  v = Console_Port_Tbl[minor]->ulIntVector;
>>> +  mg5uart_rx_frame_error_cd.name    =  v + MG5UART_IRQ_RX_FRAME_ERROR;
>>> +  mg5uart_rx_overrun_error_cd.name  =  v +
>>>MG5UART_IRQ_RX_OVERRUN_ERROR;
>>> +  mg5uart_tx_empty_cd.name          =  v + MG5UART_IRQ_TX_EMPTY;
>>> +  mg5uart_tx_ready_cd.name          =  v + MG5UART_IRQ_TX_READY;
>>> +  mg5uart_rx_ready_cd.name          =  v + MG5UART_IRQ_RX_READY;
>>> +  mg5uart_rx_frame_error_cd.handle    =  (void
>>>*)mg5uart_rx_frame_error_cd.name;
>>> +  mg5uart_rx_overrun_error_cd.handle  =  (void
>>>*)mg5uart_rx_overrun_error_cd.name;
>>> +  mg5uart_tx_empty_cd.handle          =  (void
>>>*)mg5uart_tx_empty_cd.name;
>>> +  mg5uart_tx_ready_cd.handle          =  (void
>>>*)mg5uart_tx_ready_cd.name;
>>> +  mg5uart_rx_ready_cd.handle          =  (void
>>>*)mg5uart_rx_ready_cd.name;
>>> +  BSP_install_rtems_irq_handler( &mg5uart_rx_frame_error_cd );
>>> +  BSP_install_rtems_irq_handler( &mg5uart_rx_overrun_error_cd );
>>> +  BSP_install_rtems_irq_handler( &mg5uart_tx_empty_cd );
>>> +  BSP_install_rtems_irq_handler( &mg5uart_tx_ready_cd );
>>> +  BSP_istall_rtems_irq_handler( &mg5uart_rx_ready_cd );
>>> + *  mg5uart_write_support_int
>>> + *  Console Termios output entry point when using interrupt driven
>>>output.
>>> +MG5UART_STATIC int mg5uart_write_support_int(
>>> +  int         minor,
>>> +  const char *buf,
>>> +  size_t      len
>>> +   *  We are using interrupt driven output and termios only sends us
>>> +   *  one character at a time.
>>> +  if ( !len )
>>> +     return 0;
>>> +   *  Put the character out and enable interrupts if necessary.
>>> +  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, *buf);
>>> +  if( Console_Port_Data[minor].bActive == FALSE )
>>> +     Console_Port_Data[minor].bActive = TRUE;
>>> +  return 1;
>>> + *  mg5uart_write_support_polled
>>> + *  Console Termios output entry point when using polled output.
>>> +MG5UART_STATIC ssize_t mg5uart_write_support_polled(
>>> +  int         minor,
>>> +  const char *buf,
>>> +  size_t      len
>>> +  int nwrite = 0;
>>> +   * poll each byte in the string out of the port.
>>> +  while (nwrite < len)
>>> +    mg5uart_write_polled(minor, *buf++);
>>> +    nwrite++;
>>> +   * return the number of bytes written.
>>> +  return nwrite;
>>> + *  mg5uart_inbyte_nonblocking_polled
>>> + *  Console Termios polling input entry point.
>>> +MG5UART_STATIC int mg5uart_inbyte_nonblocking_polled(
>>> +  int minor
>>> +  uint32_t                status;
>>> +  uint32_t                tmp,shift;
>>> +  else
>>> +  /* reset overrrun or framing errors */
>>> +  status = MG5UART_GETREG(pMG5UART, MG5UART_STATUS_REGISTER) >> shift;
>>> +  if( (tmp = (status & 0x3)) )
>>> +     MG5UART_SETREG(pMG5UART, MG5UART_STATUS_REGISTER, (tmp << shift)
>>>shift;
>>> +  if ( status & MONGOOSEV_UART_RX_READY )
>>> +     return (int) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
>>> +  else
>>> +     return -1;
>>> + *  mg5uart_baud_rate
>>> +MG5UART_STATIC int mg5uart_baud_rate(
>>> +  int           minor,
>>> +  uint32_t      baud,
>>> +  uint32_t     *code
>>> +  uint32_t   clock;
>>> +  uint32_t   tmp_code;
>>> +  uint32_t   baud_requested;
>>> +  baud_requested = baud & CBAUD;
>>> +  if (!baud_requested)
>>> +    baud_requested = B9600;              /* default to 9600 baud */
>>> +  baud_requested = rtems_termios_baud_to_number( baud_requested );
>>> +  clock = (uint32_t) Console_Port_Tbl[minor]->ulClock;
>>> +  if (!clock)
>>> +    rtems_fatal_error_occurred(RTEMS_INVALID_NUMBER);
>>> +   *  Formula is Code = round(ClockFrequency / Baud - 1).
>>> +   *  Since this is integer math, we will divide by twice the baud and
>>> +   *  check the remaining odd bit.
>>> +  tmp_code = (clock / baud_requested) - 1;
>>> +   *  From section 12.7, "Keep C>100 for best receiver operation."
>>> +   *  That is 100 cycles which is not a lot of instructions.  It is
>>> +   *  reasonable to think that the Mongoose-V could not keep
>>> +   *  up with C < 100.
>>> +  if ( tmp_code < 100 )
>>> +    return RTEMS_INVALID_NUMBER;
>>> +   *  upper word is receiver baud and lower word is transmitter baud
>>> +  *code = (tmp_code << 16) | tmp_code;
>>> +  return 0;
>>> + *  mg5uart_enable_interrupts
>>> + *  This function enables specific interrupt sources on the DUART.
>>> +  int minor,
>>> +  int mask
>>> +  uint32_t             maskSave;
>>> +  uint32_t              shift;
>>> +   *  Enable interrupts on RX and TX -- not break
>>> +  else
>>> +  maskSave = MG5UART_GETREG( pMG5UART,
>>>MG5UART_INTERRUPT_MASK_REGISTER );
>>> +  MG5UART_SETREG(
>>> +     pMG5UART,
>>> +     MG5UART_INTERRUPT_MASK_REGISTER,
>>> +     (maskSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (mask
>>><< shift) );
>>> + * Flow control is only supported when using interrupts
>>> +const console_fns mg5uart_fns =
>>> +  libchip_serial_default_probe,   /* deviceProbe */
>>> +  mg5uart_open,                   /* deviceFirstOpen */
>>> +  NULL,                           /* deviceLastClose */
>>> +  NULL,                           /* deviceRead */
>>> +  mg5uart_write_support_int,      /* deviceWrite */
>>> +  mg5uart_initialize_interrupts,  /* deviceInitialize */
>>> +  mg5uart_write_polled,           /* deviceWritePolled */
>>> +  mg5uart_set_attributes,         /* deviceSetAttributes */
>>> +  TRUE                            /* deviceOutputUsesInterrupts */
>>> +const console_fns mg5uart_fns_polled =
>>> +  mg5uart_close,                       /* deviceLastClose */
>>> +  mg5uart_inbyte_nonblocking_polled,   /* deviceRead */
>>> +  mg5uart_write_support_polled,        /* deviceWrite */
>>> +  mg5uart_init,                        /* deviceInitialize */
>>> +  FALSE,                               /* deviceOutputUsesInterrupts
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
>>>b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
>>> index 0000000..fa7bed6
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart.h
>>> @@ -0,0 +1,98 @@
>>> + *  COPYRIGHT (c) 1989-1999.
>>> + *  found in the file LICENSE in this distribution or at
>>> +#ifndef _MG5UART_H_
>>> +#define _MG5UART_H_
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif
>>> + *  This is the ASCII for "MG5U" which should be unique enough to
>>> + *  distinguish this type of serial device from others.
>>> +#define SERIAL_MG5UART 0x474D5535
>>> +#define MG5UART_UART0  0
>>> +#define MG5UART_UART1  1
>>> + *  These are just used in the interface between this driver and
>>> + *  the read/write register routines when accessing the first
>>> + *  control port.  They are indices of registers from the bases.
>>> +/* shared registers from peripheral base (i.e. from ulCtrlPort1) */
>>> +#define MG5UART_COMMAND_REGISTER          0
>>> +#define MG5UART_STATUS_REGISTER           1
>>> +#define MG5UART_INTERRUPT_CAUSE_REGISTER  2
>>> +#define MG5UART_INTERRUPT_MASK_REGISTER   3
>>> +#define MG5UART_STATUS_REGISTER           0x04
>>> +#define MG5UART_INTERRUPT_CAUSE_REGISTER  0x08
>>> +#define MG5UART_INTERRUPT_MASK_REGISTER   0x0C
>>> +/* port specific registers from uart base (i.e. from ulCtrlPort2) */
>>> +#define MG5UART_RX_BUFFER  0
>>> +#define MG5UART_TX_BUFFER  4
>>> +#define MG5UART_BAUD_RATE  8
>>> + *  Interrupt mask values
>>> +#define MG5UART_ENABLE_ALL_EXCEPT_TX MONGOOSEV_UART_ALL_RX_STATUS_BITS
>>> +/* all rx ints on, but only tx ready.  no need to also int on tx
>>>empty */
>>> +#define MG5UART_ENABLE_ALL           (MONGOOSEV_UART_ALL_STATUS_BITS
>>>& ~MONGOOSEV_UART_TX_EMPTY)
>>> +#define MG5UART_DISABLE_ALL          0x0000
>>> + *  Assume vectors are sequential.
>>> +#define MG5UART_IRQ_RX_FRAME_ERROR   0
>>> +#define MG5UART_IRQ_RX_OVERRUN_ERROR 1
>>> +#define MG5UART_IRQ_TX_EMPTY         2
>>> +#define MG5UART_IRQ_TX_READY         3
>>> +#define MG5UART_IRQ_RX_READY         4
>>> + * Driver function table
>>> +extern const console_fns mg5uart_fns;
>>> +extern const console_fns mg5uart_fns_polled;
>>> + * Default register access routines
>>> +uint32_t   mg5uart_get_register(    /* registers are on 32-bit
>>>boundaries */
>>> +  uint32_t    ulCtrlPort,           /*   and accessed as word
>>> +  uint32_t    ucRegNum
>>> +void  mg5uart_set_register(
>>> +  uint32_t    ucRegNum,
>>> +  uint32_t    ucData
>>> +#ifdef __cplusplus
>>> +#endif
>>> +#endif /* _MG5UART_H_ */
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
>>>b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
>>> index 0000000..134695f
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/console/mg5uart_reg.c
>>> @@ -0,0 +1,58 @@
>>> + *  This file contains a typical set of register access routines
>>>which may be
>>> + *  used with the mg5uart chip if accesses to the chip are as follows:
>>> + *    + registers are accessed as uint32_t  's
>>> + *    + registers are only u32-aligned (no address gaps)
>>> + *  COPYRIGHT (c) 1989-2001.
>>> +#include <rtems.h>
>>> +#ifndef _MG5UART_MULTIPLIER
>>> +#define _MG5UART_MULTIPLIER 1
>>> +#define _MG5UART_NAME(_X) _X
>>> +#define _MG5UART_TYPE uint32_t
>>> +#endif
>>> +#define CALCULATE_REGISTER_ADDRESS( _base, _reg ) \
>>> +  (_MG5UART_TYPE *)((_base) + ((_reg) * _MG5UART_MULTIPLIER ))
>>> + *  MG5UART Get Register Routine
>>> +uint8_t   _MG5UART_NAME(mg5uart_get_register)(
>>> +  uint8_t     ucRegNum
>>> +  _MG5UART_TYPE *port;
>>> +  port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
>>> +  return *port;
>>> + *  MG5UART Set Register Routine
>>> +void  _MG5UART_NAME(mg5uart_set_register)(
>>> +  uint8_t     ucRegNum,
>>> +  uint8_t     ucData
>>> +  *port = ucData;
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
>>>b/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
>>> index da4c198..5146b7f 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/include/bsp.h
>>> @@ -28,7 +28,7 @@ extern "C" {
>>>  #include <rtems/iosupp.h>
>>>  #include <rtems/console.h>
>>>  #include <rtems/clockdrv.h>
>>> -#include <libcpu/mongoose-v.h>
>>>  #define BSP_FEATURE_IRQ_EXTENSION
>>>  #define BSP_SHARED_HANDLER_SUPPORT      1
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
>>>b/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
>>> index 0000000..e69d25a
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/include/mongoose-v.h
>>> @@ -0,0 +1,306 @@
>>> + *  @file
>>> + *  MIPS Mongoose-V specific information
>>> + *  COPYRIGHT (c) 1989-2012.
>>> +#ifndef __MONGOOSEV_h
>>> +#define __MONGOOSEV_h
>>> + *  Macros to assist in accessing memory mapped Mongoose registers
>>> +#define MONGOOSEV_READ( _base ) \
>>> +  ( *((volatile uint32_t*)(_base)) )
>>> +#define MONGOOSEV_WRITE( _base, _value ) \
>>> +  ( *((volatile uint32_t*)(_base)) = (_value) )
>>> +#define MONGOOSEV_READ_REGISTER( _base, _register ) \
>>> +  ( *((volatile uint32_t*)((_base) + (_register))) )
>>> +#define MONGOOSEV_WRITE_REGISTER( _base, _register, _value ) \
>>> +  ( *((volatile uint32_t*)((_base) + (_register))) = (_value) )
>>> + * Macros to read/write the Mongoose FPU control register.
>>> + *  BIU and DRAM Registers
>>> +#define MONGOOSEV_BIU_CACHE_CONFIGURATION_REGISTER       0xFFFE0130
>>> +#define MONGOOSEV_DRAM_CONFIGURATION_REGISTER            0xFFFE0120
>>> +#define MONGOOSEV_REFRESH_TIMER_INITIAL_COUNTER_REGISTER 0xFFFE0010
>>> +#define MONGOOSEV_WAIT_STATE_CONFIGURATION_REGISTER_BASE 0xFFFE0100
>>> + *  Peripheral Function Addresses
>>> + *  NOTE: Status and Interrupt Cause use the same bits
>>> +#define MONGOOSEV_PERIPHERAL_COMMAND_REGISTER
>>>0xFFFE0180
>>> +#define MONGOOSEV_PERIPHERAL_STATUS_REGISTER
>>>0xFFFE0184
>>> +#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_CAUSE_REGISTER
>>>0xFFFE0188
>>> +#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_MASK_REGISTER
>>>0xFFFE018C
>>> +#define MONGOOSEV_WATCHDOG                     0xBE000000
>>> +/* UART Bits in Peripheral Command Register Bits (TX/RX tied together
>>>here) */
>>> +#define MONGOOSEV_UART_CMD_RESET_BOTH_PORTS    0x0001
>>> +#define MONGOOSEV_UART_CMD_LOOPBACK_CTSN       0x0002
>>> +#define MONGOOSEV_UART_CMD_LOOPBACK_RXTX       0x0004
>>> +#define MONGOOSEV_UART_CMD_RX_ENABLE           0x001
>>> +#define MONGOOSEV_UART_CMD_RX_DISABLE          0x000
>>> +#define MONGOOSEV_UART_CMD_TX_ENABLE           0x002
>>> +#define MONGOOSEV_UART_CMD_TX_DISABLE          0x000
>>> +#define MONGOOSEV_UART_CMD_TX_READY            0x004
>>> +#define MONGOOSEV_UART_CMD_PARITY_ENABLE       0x008
>>> +#define MONGOOSEV_UART_CMD_PARITY_DISABLE      0x000
>>> +#define MONGOOSEV_UART_CMD_PARITY_EVEN         0x010
>>> +#define MONGOOSEV_UART_CMD_PARITY_ODD          0x000
>>> +#define MONGOOSEV_UART0_CMD_SHIFT 5
>>> +#define MONGOOSEV_UART1_CMD_SHIFT 11
>>> +#define MONGOOSEV_UART_CMD_TX_ENABLE_0 \
>>> +        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_RX_ENABLE_0 \
>>> +        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_TX_READY_0 \
>>> +        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART0_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_PARITY_ENABLE_0 \
>>> +        (MONGOOSEV_UART_CMD_PARITY_ENABLE <<
>>> +#define MONGOOSEV_UART_CMD_PARITY_DISABLE_0 \
>>> +        (MONGOOSEV_UART_CMD_PARITY_DISABLE <<
>>> +#define MONGOOSEV_UART_CMD_PARITY_EVEN_0 \
>>> +        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART0_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_PARITY_ODD_0 \
>>> +        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART0_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_TX_ENABLE_1 \
>>> +        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_RX_ENABLE_1 \
>>> +        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_TX_READY_1 \
>>> +        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART1_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_PARITY_ENABLE_1 \
>>> +#define MONGOOSEV_UART_CMD_PARITY_DISABLE_1 \
>>> +#define MONGOOSEV_UART_CMD_PARITY_EVEN_1 \
>>> +        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART1_CMD_SHIFT)
>>> +#define MONGOOSEV_UART_CMD_PARITY_ODD_1 \
>>> +        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART1_CMD_SHIFT)
>>> +/* UART Bits in Peripheral Status and Interrupt Cause Register */
>>> +#define MONGOOSEV_UART_RX_FRAME_ERROR              0x0001
>>> +#define MONGOOSEV_UART_RX_OVERRUN_ERROR            0x0002
>>> +#define MONGOOSEV_UART_TX_EMPTY                    0x0004
>>> +#define MONGOOSEV_UART_TX_READY                    0x0008
>>> +#define MONGOOSEV_UART_RX_READY                    0x0010
>>> +#define MONGOOSEV_UART_ALL_RX_STATUS_BITS          0x0013
>>> +#define MONGOOSEV_UART_ALL_STATUS_BITS             0x001F
>>> + *  The Peripheral Interrupt Status, Cause, and Mask registers have
>>>the
>>> + *  same bit assignments although some revisions of the document have
>>> + *  the Cause and Status registers incorrect.
>>> +#define MONGOOSEV_UART0_IRQ_SHIFT 11
>>> +#define MONGOOSEV_UART1_IRQ_SHIFT 17
>>> +#define MONGOOSEV_UART_FRAME_ERROR_0 \
>>> +        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_RX_OVERRUN_ERROR_0 \
>>> +        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_TX_EMPTY_0 \
>>> +        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART0_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_TX_READY_0 \
>>> +        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_RX_READY_0 \
>>> +        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_FRAME_ERROR_1 \
>>> +        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_RX_OVERRUN_ERROR_1 \
>>> +        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_TX_EMPTY_1 \
>>> +        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART1_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_TX_READY_1 \
>>> +        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
>>> +#define MONGOOSEV_UART_RX_READY_1 \
>>> +        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
>>> + *  Bits in the Peripheral Interrupt Mask Register
>>> +** Interrupt Status/Cause/Mask register bits - from 31 to 0
>>> +#define MONGOOSEV_EDAC_SERR_BIT          0x80000000
>>> +#define MONGOOSEV_EDAC_MERR_BIT          0x40000000
>>> +/* 29 - 24 reserved */
>>> +#define MONGOOSEV_MAVN_WRITE_ACCESS      0x00800000
>>> +#define MONGOOSEV_MAVN_READ_ACCESS       0x00400000
>>> +#define MONGOOSEV_UART_1_RX_READY        0x00200000
>>> +#define MONGOOSEV_UART_1_TX_READY        0x00100000
>>> +#define MONGOOSEV_UART_1_TX_EMPTY        0x00080000
>>> +#define MONGOOSEV_UART_1_RX_OVERRUN      0x00040000
>>> +#define MONGOOSEV_UART_1_FRAME_ERROR     0x00020000
>>> +#define MONGOOSEV_RESERVED_16            0x00010000
>>> +#define MONGOOSEV_UART_0_RX_READY        0x00008000
>>> +#define MONGOOSEV_UART_0_TX_READY        0x00004000
>>> +#define MONGOOSEV_UART_0_TX_EMPTY        0x00002000
>>> +#define MONGOOSEV_UART_0_RX_OVERRUN      0x00001000
>>> +#define MONGOOSEV_UART_0_FRAME_ERROR     0x00000800
>>> +#define MONGOOSEV_RESERVED_10            0x00000400
>>> +#define MONGOOSEV_EXTERN_INT_9           0x00000200
>>> +#define MONGOOSEV_EXTERN_INT_8           0x00000100
>>> +#define MONGOOSEV_EXTERN_INT_7           0x00000080
>>> +#define MONGOOSEV_EXTERN_INT_6           0x00000040
>>> +#define MONGOOSEV_EXTERN_INT_5           0x00000020
>>> +#define MONGOOSEV_EXTERN_INT_4           0x00000010
>>> +#define MONGOOSEV_EXTERN_INT_3           0x00000008
>>> +#define MONGOOSEV_EXTERN_INT_2           0x00000004
>>> +#define MONGOOSEV_EXTERN_INT_1           0x00000002
>>> +#define MONGOOSEV_EXTERN_INT_0           0x00000001
>>> +** Peripheral Command bits (non-uart, those are defined above)
>>> +#define MONGOOSEV_COMMAND_ENABLE_EDAC  MONGOOSEV_EDAC_SERR_BIT
>>> +#define MONGOOSEV_COMMAND_OVERRIDE_EDAC MONGOOSEV_EDAC_MERR_BIT
>>> + *  EDAC Registers
>>> +#define MONGOOSEV_EDAC_ERROR_ADDRESS_REGISTER       0xFFFE0190
>>> +#define MONGOOSEV_EDAC_PARITY_TEST_MODE_REGISTER    0xFFFE0194
>>> + *  MAVN Registers
>>> +#define MONGOOSEV_MAVN_TEST_REGISTER               0xFFFE01B4
>>> +#define MONGOOSEV_MAVN_ACCESS_PRIVILEGE_REGISTER   0xFFFE01B8
>>> +#define MONGOOSEV_MAVN_ACCESS_VIOLATION_REGISTER   0xFFFE01BC
>>> +#define MONGOOSEV_MAVN_RANGE_0_REGISTER            0xFFFE01C0
>>> +#define MONGOOSEV_MAVN_RANGE_1_REGISTER            0xFFFE01C4
>>> +#define MONGOOSEV_MAVN_RANGE_2_REGISTER            0xFFFE01C8
>>> +#define MONGOOSEV_MAVN_RANGE_3_REGISTER            0xFFFE01CC
>>> +#define MONGOOSEV_MAVN_RANGE_4_REGISTER            0xFFFE01D0
>>> +#define MONGOOSEV_MAVN_RANGE_5_REGISTER            0xFFFE01D4
>>> +#define MONGOOSEV_MAVN_RANGE_6_REGISTER            0xFFFE01D8
>>> +#define MONGOOSEV_MAVN_RANGE_7_REGISTER            0xFFFE01DC
>>> + *  Timer Base Addresses, Offsets, and Values
>>> +#define MONGOOSEV_TIMER1_BASE    0xFFFE0000
>>> +#define MONGOOSEV_TIMER2_BASE    0xFFFE0008
>>> +#define MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER 0
>>> +#define MONGOOSEV_TIMER_CONTROL_REGISTER         4
>>> +/* Timer Control Register Constants */
>>> +#define MONGOOSEV_TIMER_CONTROL_COUNTER_ENABLE    0x04
>>> +#define MONGOOSEV_TIMER_CONTROL_INTERRUPT_ENABLE  0x02
>>> +#define MONGOOSEV_TIMER_CONTROL_TIMEOUT           0x01
>>> + *  UART Base Addresses and Offsets
>>> + *  Many bits in the peripheral command register are UART related
>>> + *  and the bits are defined there.
>>> +#define MONGOOSEV_UART0_BASE   0xFFFE01E8
>>> +#define MONGOOSEV_UART1_BASE   0xFFFE01F4
>>> +#define MONGOOSEV_RX_BUFFER    0
>>> +#define MONGOOSEV_TX_BUFFER    4
>>> +#define MONGOOSEV_BAUD_RATE    8
>>> + *  Status Register Bits
>>> +#define SR_CUMASK      0xf0000000      /* coproc usable bits */
>>> +#define SR_CU3         0x80000000      /* Coprocessor 3 usable */
>>> +#define SR_CU2         0x40000000      /* Coprocessor 2 usable */
>>> +#define SR_CU1         0x20000000      /* Coprocessor 1 usable */
>>> +#define SR_CU0         0x10000000      /* Coprocessor 0 usable */
>>> +#define SR_BEV         0x00400000      /* use boot exception vectors
>>> +#define SR_TS          0x00200000      /* TLB shutdown */
>>> +#define SR_PE          0x00100000      /* cache parity error */
>>> +#define SR_CM          0x00080000      /* cache miss */
>>> +#define SR_PZ          0x00040000      /* cache parity zero */
>>> +#define SR_SWC         0x00020000      /* swap cache */
>>> +#define SR_ISC         0x00010000      /* Isolate data cache */
>>> +#define SR_IMASK       0x0000ff00      /* Interrupt mask */
>>> +#define SR_IMASK8      0x00000000      /* mask level 8 */
>>> +#define SR_IMASK7      0x00008000      /* mask level 7 */
>>> +#define SR_IMASK6      0x0000c000      /* mask level 6 */
>>> +#define SR_IMASK5      0x0000e000      /* mask level 5 */
>>> +#define SR_IMASK4      0x0000f000      /* mask level 4 */
>>> +#define SR_IMASK3      0x0000f800      /* mask level 3 */
>>> +#define SR_IMASK2      0x0000fc00      /* mask level 2 */
>>> +#define SR_IMASK1      0x0000fe00      /* mask level 1 */
>>> +#define SR_IMASK0      0x0000ff00      /* mask level 0 */
>>> +#define SR_IBIT8       0x00008000      /* bit level 8 */
>>> +#define SR_IBIT7       0x00004000      /* bit level 7 */
>>> +#define SR_IBIT6       0x00002000      /* bit level 6 */
>>> +#define SR_IBIT5       0x00001000      /* bit level 5 */
>>> +#define SR_IBIT4       0x00000800      /* bit level 4 */
>>> +#define SR_IBIT3       0x00000400      /* bit level 3 */
>>> +#define SR_IBIT2       0x00000200      /* bit level 2 */
>>> +#define SR_IBIT1       0x00000100      /* bit level 1 */
>>> +#define SR_KUO         0x00000020      /* old kernel/user, 0 => k, 1
>>>=> u */
>>> +#define SR_IEO         0x00000010      /* old interrupt enable, 1 =>
>>>enable */
>>> +#define SR_KUP         0x00000008      /* prev kernel/user, 0 => k, 1
>>>=> u */
>>> +#define SR_IEP         0x00000004      /* prev interrupt enable, 1 =>
>>>enable */
>>> +#define SR_KUC         0x00000002      /* cur kernel/user, 0 => k, 1
>>>=> u */
>>> +#define SR_IEC         0x00000001      /* cur interrupt enable, 1 =>
>>>enable */
>>> +#define SR_KUMSK       (SR_KUO|SR_IEO|SR_KUP|SR_IEP|SR_KUC|SR_IEC)
>>> +#define SR_IMASKSHIFT  8
>>> +#define MONGOOSEV_IC_SIZE      0x1000          /* instruction cache =
>>>4Kbytes */
>>> +#define MONGOOSEV_DC_SIZE      0x800           /* data cache 2Kbytes
>>> +#endif
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
>>>b/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
>>> index 8a23643..b7210f7 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
>>> @@ -15,7 +15,7 @@
>>>  #include <rtems.h>
>>>  #include <stdlib.h>
>>>  #include <rtems/mips/iregdef.h>
>>>  #include <rtems/mips/idtcpu.h>
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
>>>b/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
>>> index f11c87a..e5988a4 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/preinstall.am
>>> @@ -69,6 +69,26 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h:
>>>../../shared/include/bootcard.h $(PROJECT_INC
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
>>> +$(PROJECT_INCLUDE)/bsp/lr33000.h: include/lr33000.h
>>>$(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lr33000.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lr33000.h
>>> +$(PROJECT_INCLUDE)/bsp/lr333x0.h: include/lr333x0.h
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lr333x0.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lr333x0.h
>>> +$(PROJECT_INCLUDE)/bsp/mongoose-v.h: include/mongoose-v.h
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mongoose-v.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mongoose-v.h
>>> +$(PROJECT_INCLUDE)/bsp/r3000.h: include/r3000.h
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/r3000.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/r3000.h
>>> +$(PROJECT_INCLUDE)/bsp/mg5uart.h: console/mg5uart.h
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mg5uart.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mg5uart.h
>>>  $(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h
>>>$(PROJECT_INCLUDE)/$(dirstamp)
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
>>>b/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
>>> index 744dd69..a8dd2cb 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/startup/bspstart.c
>>> @@ -23,7 +23,7 @@
>>>  #include <string.h>
>>>  #include <bsp.h>
>>>  #include <libcpu/isr_entries.h>
>>>  #include <bsp/irq-generic.h>
>>> diff --git a/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
>>>b/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
>>> index 5f6ec0d..481774e 100644
>>> --- a/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
>>> +++ b/c/src/lib/libbsp/mips/genmongoosev/startup/gdb-support.c
>>> @@ -11,7 +11,7 @@
>>>  #include <rtems.h>
>>>  #include <rtems/bspIo.h>
>>>  #include "gdb_if.h"
>>> diff --git a/c/src/lib/libcpu/mips/Makefile.am
>>>b/c/src/lib/libcpu/mips/Makefile.am
>>> index 6dc6258..e4dd7ca 100644
>>> --- a/c/src/lib/libcpu/mips/Makefile.am
>>> +++ b/c/src/lib/libcpu/mips/Makefile.am
>>> @@ -31,10 +31,6 @@ if tx49
>>>  interrupts_CPPFLAGS = -DTX49
>>>  endif
>>> -if mongoosev
>>> -interrupts_CPPFLAGS = -DMONGOOSEV
>>> -endif
>>>  noinst_PROGRAMS += shared/interrupts.rel
>>>  shared_interrupts_rel_SOURCES = shared/interrupts/installisrentries.c
>>>      shared/interrupts/isr_entries.S shared/interrupts/isr_entries.h
>>> @@ -42,23 +38,6 @@ shared_interrupts_rel_CPPFLAGS = $(AM_CPPFLAGS)
>>>$(interrupts_CPPFLAGS)
>>>  shared_interrupts_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>  include_libcpu_HEADERS += shared/interrupts/isr_entries.h
>>> -EXTRA_DIST += mongoosev/README
>>> -EXTRA_DIST += mongoosev/duart/README.mguart
>>> -if mongoosev
>>> -include_libcpu_HEADERS += mongoosev/include/mongoose-v.h
>>> -## mongoosev/duart
>>> -include_libchipdir = $(includedir)/libchip
>>> -include_libchip_HEADERS = mongoosev/duart/mg5uart.h
>>> -noinst_PROGRAMS += mongoosev/duart.rel
>>> -mongoosev_duart_rel_SOURCES = mongoosev/duart/mg5uart.c \
>>> -    mongoosev/duart/mg5uart.h mongoosev/duart/mg5uart_reg.c
>>> -mongoosev_duart_rel_CPPFLAGS = $(AM_CPPFLAGS)
>>> -mongoosev_duart_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>> -endif
>>>  if tx39
>>>  include_libcpu_HEADERS += tx39/include/tx3904.h
>>>  endif
>>> diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/README.mguart
>>>b/c/src/lib/libcpu/mips/mongoosev/duart/README.mguart
>>> deleted file mode 100644
>>> index 8073ab7..0000000
>>> --- a/c/src/lib/libcpu/mips/mongoosev/duart/README.mguart
>>> +++ /dev/null
>>> @@ -1,101 +0,0 @@
>>> -Configuration Table Use
>>> -sDeviceName
>>> -   The name of this device.
>>> -deviceType
>>> -   This field must be SERIAL_MG5UART.
>>> -pDeviceFns
>>> -   The device interface control table.  This may be:
>>> -      + mg5uart_fns for interrupt driven IO
>>> -      + mg5uart_fns_polled for polled IO
>>> -deviceProbe
>>> -   This is the address of the routine which probes to see if the
>>>device
>>> -   is present.
>>> -pDeviceFlow
>>> -   This field is ignored as hardware flow control is not currently
>>>supported.
>>> -ulMargin
>>> -    This is currently unused.
>>> -ulHysteresis
>>> -pDeviceParams
>>> -    This is set to the default settings.
>>> -ulCtrlPort1
>>> -   This field is the address of the command register shared by both
>>>ports.
>>> -ulCtrlPort2
>>> -   This field is the address of the port being used.
>>> -ulDataPort
>>> -   This field is set to MG5UART_PORTA or MG5UART_PORTB.
>>> -getRegister
>>> -setRegister
>>> -   These do NOT follow standard conventions and are ignored.
>>> -   The register address routines are hard-coded as this is
>>> -   an on-CPU part and assumed to provide a 32-bit wide interface.
>>> -getData
>>> -   This is address of the RX buffer register.
>>> -setData
>>> -   This is address of the TX buffer register.
>>> -ulClock
>>> -   baudRate Clock
>>> -ulIntVector
>>> -   This is the interrupt vector number associated with this chip.
>>> -Example:
>>> -#if (CONSOLE_USE_INTERRUPTS)
>>> -#define MG5UART_FUNCTIONS &mg5uart_fns
>>> -#else
>>> -#define MG5UART_FUNCTIONS &mg5uart_fns_polled
>>> -#endif
>>> -  "/dev/com0",                            /* sDeviceName */
>>> -  SERIAL_MG5UART,                         /* deviceType */
>>> -  MG5UART_FUNCTIONS,                      /* pDeviceFns */
>>> -  NULL,                                   /* deviceProbe, assume it
>>>is there */
>>> -  NULL,                                   /* pDeviceFlow */
>>> -  16,                                     /* ulMargin */
>>> -  8,                                      /* ulHysteresis */
>>> -  (void *) NULL,               /* NULL */ /* pDeviceParams */
>>> -  MONGOOSEV_PERIPHERAL_COMMAND_REGISTER,  /* ulCtrlPort1 */
>>> -  MONGOOSEV_UART0_BASE,                   /* ulCtrlPort2 */
>>> -  MG5UART_UART0,                          /* ulDataPort */
>>> -  mg5uart_get_register,                   /* getRegister */
>>> -  mg5uart_set_register,                   /* setRegister */
>>> -  NULL, /* unused */                      /* getData */
>>> -  NULL, /* unused */                      /* setData */
>>> -  12000000,                               /* ulClock */
>>> -  MONGOOSEV_IRQ_UART0_RX_FRAME_ERROR      /* ulIntVector -- base for
>>>port */
>>> diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c
>>>b/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c
>>> index 50f6586..0000000
>>> --- a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.c
>>> +++ /dev/null
>>> @@ -1,917 +0,0 @@
>>> - *  @file
>>> - *  This file contains the termios TTY driver for the UART found
>>> - *  on the Synova Mongoose-V.
>>> - *  COPYRIGHT (c) 1989-2012.
>>> - *  On-Line Applications Research Corporation (OAR).
>>> - *  The license and distribution terms for this file may be
>>> - *  found in the file LICENSE in this distribution or at
>>> - *  http://www.rtems.org/license/LICENSE.
>>> -#include <rtems.h>
>>> -#include <rtems/libio.h>
>>> -#include <rtems/score/sysstate.h>
>>> -#include <stdlib.h>
>>> -#include <libchip/serial.h>
>>> -#include <libchip/sersupp.h>
>>> -#include <bsp/irq.h>
>>> -#include <bsp.h>
>>> - *  Indices of registers
>>> - *  Per chip context control
>>> -typedef struct _mg5uart_context
>>> -  int            mate;
>>> -} mg5uart_context;
>>> - *  Define MG5UART_STATIC to nothing while debugging so the entry
>>>points
>>> - *  will show up in the symbol table.
>>> -#define MG5UART_STATIC
>>> -/* #define MG5UART_STATIC static */
>>> -#define MG5UART_SETREG( _base, _register, _value ) \
>>> -        MONGOOSEV_WRITE_REGISTER( _base, _register, _value )
>>> -#define MG5UART_GETREG( _base, _register ) \
>>> -        MONGOOSEV_READ_REGISTER( _base, _register )
>>> - *  Console Device Driver Support Functions
>>> -MG5UART_STATIC int mg5uart_baud_rate(
>>> -  int        minor,
>>> -  uint32_t   baud,
>>> -  uint32_t  *code
>>> -MG5UART_STATIC void mg5uart_enable_interrupts(
>>> -  int minor,
>>> -  int mask
>>> - *  mg5uart_isr_XXX
>>> - *  This is the single interrupt entry point which parcels interrupts
>>> - *  out to the handlers for specific sources and makes sure that the
>>> - *  shared handler gets the right arguments.
>>> - *  NOTE: Yes .. this is ugly but it provides 5 interrupt source
>>> - *  wrappers which are nearly functionally identical.
>>> -extern void mips_default_isr(int vector);
>>> -#define __ISR(_TYPE, _OFFSET) \
>>> -  MG5UART_STATIC void mg5uart_process_isr_ ## _TYPE ( \
>>> -    int  minor \
>>> -  MG5UART_STATIC rtems_isr mg5uart_isr_ ## _TYPE ( \
>>> -    void *arg \
>>> -    rtems_vector_number vector = (rtems_vector_number) arg; \
>>> -    int   minor; \
>>> -    for(minor=0 ; minor<Console_Port_Count ; minor++) { \
>>> -      if( Console_Port_Tbl[minor]->deviceType == SERIAL_MG5UART && \
>>> -          vector == Console_Port_Tbl[minor]->ulIntVector + _OFFSET )
>>> -        mg5uart_process_isr_ ## _TYPE (minor); \
>>> -       return; \
>>> -    mips_default_isr( vector ); \
>>> -__ISR(rx_frame_error, MG5UART_IRQ_RX_FRAME_ERROR)
>>> -__ISR(rx_overrun_error, MG5UART_IRQ_RX_OVERRUN_ERROR)
>>> -__ISR(tx_empty, MG5UART_IRQ_TX_EMPTY)
>>> -__ISR(tx_ready, MG5UART_IRQ_TX_READY)
>>> -__ISR(rx_ready, MG5UART_IRQ_RX_READY)
>>> - *  mg5uart_set_attributes
>>> - *  This function sets the UART channel to reflect the requested
>>>termios
>>> - *  port settings.
>>> -MG5UART_STATIC int mg5uart_set_attributes(
>>> -  int minor,
>>> -  const struct termios *t
>>> -  uint32_t               pMG5UART_port;
>>> -  uint32_t               pMG5UART;
>>> -  uint32_t               cmd, cmdSave;
>>> -  uint32_t               baudcmd;
>>> -  uint32_t               shift;
>>> -  rtems_interrupt_level  Irql;
>>> -  pMG5UART      = Console_Port_Tbl[minor]->ulCtrlPort1;
>>> -  pMG5UART_port = Console_Port_Tbl[minor]->ulCtrlPort2;
>>> -   *  Set the baud rate
>>> -  if (mg5uart_baud_rate( minor, t->c_cflag, &baudcmd ) == -1)
>>> -    return -1;
>>> -   *  Base settings
>>> -   *  Base settings
>>> -  cmd = MONGOOSEV_UART_CMD_RX_ENABLE | MONGOOSEV_UART_CMD_TX_ENABLE;
>>> -   *  Parity
>>> -  if (t->c_cflag & PARENB) {
>>> -    cmd |= MONGOOSEV_UART_CMD_PARITY_ENABLE;
>>> -    if (t->c_cflag & PARODD)
>>> -      cmd |= MONGOOSEV_UART_CMD_PARITY_ODD;
>>> -    else
>>> -      cmd |= MONGOOSEV_UART_CMD_PARITY_EVEN;
>>> -  } else {
>>> -    cmd |= MONGOOSEV_UART_CMD_PARITY_DISABLE;
>>> -   *  Character Size
>>> -  if (t->c_cflag & CSIZE) {
>>> -    switch (t->c_cflag & CSIZE) {
>>> -      case CS5:
>>> -      case CS6:
>>> -      case CS7:
>>> -        return -1;
>>> -        break;
>>> -      case CS8:
>>> -        /* Mongoose-V only supports CS8 */
>>> -        break;
>>> -  } /* else default to CS8 */
>>> -   *  Stop Bits
>>> -#if 0
>>> -  if (t->c_cflag & CSTOPB) {
>>> -    /* 2 stop bits not supported by Mongoose-V uart */
>>> -    return -1;
>>> -#endif
>>> -   *  XXX what about CTS/RTS
>>> -  /* XXX */
>>> -   *  Now write the registers
>>> -  if ( Console_Port_Tbl[minor]->ulDataPort == MG5UART_UART0 )
>>> -    shift = MONGOOSEV_UART0_CMD_SHIFT;
>>> -  else
>>> -    shift = MONGOOSEV_UART1_CMD_SHIFT;
>>> -  rtems_interrupt_disable(Irql);
>>> -  cmdSave = MG5UART_GETREG( pMG5UART, MG5UART_COMMAND_REGISTER );
>>> -  MG5UART_SETREG( pMG5UART,
>>> -                 MG5UART_COMMAND_REGISTER,
>>> -                 (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS <<
>>> -  MG5UART_SETREG( pMG5UART_port, MG5UART_BAUD_RATE, baudcmd );
>>> -  rtems_interrupt_enable(Irql);
>>> -  return 0;
>>> - *  mg5uart_initialize_context
>>> - *  This function sets the default values of the per port context
>>>structure.
>>> -MG5UART_STATIC void mg5uart_initialize_context(
>>> -  int               minor,
>>> -  mg5uart_context  *pmg5uartContext
>>> -  int          port;
>>> -  unsigned int pMG5UART;
>>> -  unsigned int pMG5UART_port;
>>> -  pmg5uartContext->mate = -1;
>>> -  for (port=0 ; port<Console_Port_Count ; port++ ) {
>>> -    if ( Console_Port_Tbl[port]->ulCtrlPort1 == pMG5UART &&
>>> -         Console_Port_Tbl[port]->ulCtrlPort2 != pMG5UART_port ) {
>>> -      pmg5uartContext->mate = port;
>>> -      break;
>>> - *  mg5uart_init
>>> - *  This function initializes the DUART to a quiecsent state.
>>> -MG5UART_STATIC void mg5uart_init(int minor)
>>> -  uint32_t             cmdSave;
>>> -  uint32_t             shift;
>>> -  mg5uart_context        *pmg5uartContext;
>>> -  pmg5uartContext = (mg5uart_context *)
>>> -  Console_Port_Data[minor].pDeviceContext = (void *)pmg5uartContext;
>>> -  mg5uart_initialize_context( minor, pmg5uartContext );
>>> -  else
>>> -   *  Disable the uart and leave this port disabled.
>>> -  cmdSave = MG5UART_GETREG(pMG5UART, MG5UART_COMMAND_REGISTER) &
>>> -  MG5UART_SETREG( pMG5UART, MG5UART_COMMAND_REGISTER, cmdSave );
>>> -   *  Disable interrupts on RX and TX for this port
>>> -  mg5uart_enable_interrupts( minor, MG5UART_DISABLE_ALL );
>>> - *  mg5uart_open
>>> - *  This function opens a port for communication.
>>> - *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>>> -MG5UART_STATIC int mg5uart_open(
>>> -  int      major,
>>> -  int      minor,
>>> -  void    *arg
>>> -  uint32_t     vector;
>>> -  uint32_t      baudcmd;
>>> -  uint32_t      shift;
>>> -  vector        = Console_Port_Tbl[minor]->ulIntVector;
>>> -  else
>>> -  /* XXX default baud rate could be from configuration table */
>>> -  (void) mg5uart_baud_rate( minor, B19200, &baudcmd );
>>> -   *  Set the DUART channel to a default useable state
>>> -   *  B19200, 8Nx since there is no stop bit control.
>>> -  cmd = MONGOOSEV_UART_CMD_TX_ENABLE | MONGOOSEV_UART_CMD_RX_ENABLE;
>>> -                 cmd = (cmdSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS <<
>>> -  return RTEMS_SUCCESSFUL;
>>> - *  mg5uart_close
>>> - *  This function shuts down the requested port.
>>> -MG5UART_STATIC int mg5uart_close(
>>> -  int      major,
>>> -  int      minor,
>>> -  void    *arg
>>> -  uint32_t      shift;
>>> -   *  Disable interrupts from this channel and then disable it
>>>totally.
>>> -  /* XXX interrupts */
>>> -  cmd = MONGOOSEV_UART_CMD_TX_DISABLE | MONGOOSEV_UART_CMD_RX_DISABLE;
>>> -  else
>>> -  return(RTEMS_SUCCESSFUL);
>>> - *  mg5uart_write_polled
>>> - *  This routine polls out the requested character.
>>> -MG5UART_STATIC void mg5uart_write_polled(
>>> -  int   minor,
>>> -  char  c
>>> -  uint32_t                status;
>>> -  int                     shift;
>>> -  int                     timeout;
>>> -    shift = MONGOOSEV_UART0_IRQ_SHIFT;
>>> -  else
>>> -    shift = MONGOOSEV_UART1_IRQ_SHIFT;
>>> -   * wait for transmitter holding register to be empty
>>> -  timeout = 2000;
>>> -  while( --timeout )
>>> -    status = MG5UART_GETREG(pMG5UART, MG5UART_STATUS_REGISTER) >>
>>>shift;
>>> -    if ( (status & (MONGOOSEV_UART_TX_READY |
>>> -            (MONGOOSEV_UART_TX_READY | MONGOOSEV_UART_TX_EMPTY) )
>>> -      break;
>>> -    if( (status & (MONGOOSEV_UART_TX_READY |
>>> -       break;
>>> -     * Yield while we wait
>>> -#if 0
>>> -     if(_System_state_Is_up(_System_state_Get()))
>>> -       rtems_task_wake_after(RTEMS_YIELD_PROCESSOR);
>>> -#endif
>>> -   * transmit character
>>> -  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, c);
>>> -MG5UART_STATIC void mg5uart_process_isr_rx_error(
>>> -   int  minor,
>>> -   uint32_t   mask
>>> -  int                     shift;
>>> -  else
>>> -  /* now clear the error */
>>> -  MG5UART_SETREG(
>>> -     pMG5UART,
>>> -     MG5UART_STATUS_REGISTER,
>>> -     mask << shift );
>>> -MG5UART_STATIC void mg5uart_process_isr_rx_frame_error(
>>> -  int  minor
>>> -   mg5uart_process_isr_rx_error( minor, MONGOOSEV_UART_RX_FRAME_ERROR
>>> -MG5UART_STATIC void mg5uart_process_isr_rx_overrun_error(
>>> -  int  minor
>>> -MG5UART_STATIC void mg5uart_process_tx_isr(
>>> -   int        minor,
>>> -   uint32_t   source
>>> -   int             shift;
>>> -   mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX);
>>> -   else
>>> -   MG5UART_SETREG(
>>> -      pMG5UART,
>>> -      source << shift );
>>> -   if( rtems_termios_dequeue_characters(
>>> -      mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL);
>>> -      return;
>>> -    *  There are no more characters to transmit.  The tx interrupts
>>>are be cleared
>>> -    *  by writing data to the uart, so just disable the tx interrupt
>>>sources.
>>> -   Console_Port_Data[minor].bActive = FALSE;
>>> -   /* mg5uart_enable_interrupts(minor, MG5UART_ENABLE_ALL_EXCEPT_TX);
>>> -MG5UART_STATIC void mg5uart_process_isr_tx_empty(
>>> -  int  minor
>>> -   /* mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_EMPTY ); */
>>> -MG5UART_STATIC void mg5uart_process_isr_tx_ready(
>>> -  int  minor
>>> -   mg5uart_process_tx_isr( minor, MONGOOSEV_UART_TX_READY );
>>> -MG5UART_STATIC void mg5uart_process_isr_rx_ready(
>>> -  int  minor
>>> -  char       c;
>>> -  /* reading the RX buffer automatically resets the interrupt flag */
>>> -  c = (char) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
>>> -  rtems_termios_enqueue_raw_characters(
>>> -     Console_Port_Data[minor].termios_data,
>>> -     &c, 1 );
>>> -static rtems_irq_connect_data mg5uart_rx_frame_error_cd  = {  \
>>> -  0,                             /* filled in at initialization */
>>> -  mg5uart_isr_rx_frame_error,   /* filled in at initialization */
>>> -  NULL,   /* (void *) minor */
>>> -  NULL,
>>> -  NULL,
>>> -  NULL
>>> -static rtems_irq_connect_data mg5uart_rx_overrun_error_cd  = {  \
>>> -  mg5uart_isr_rx_overrun_error,   /* filled in at initialization */
>>> -  NULL,
>>> -  NULL,
>>> -  NULL
>>> -static rtems_irq_connect_data mg5uart_tx_empty_cd  = {  \
>>> -  mg5uart_isr_tx_empty,   /* filled in at initialization */
>>> -  NULL,
>>> -  NULL,
>>> -  NULL
>>> -static rtems_irq_connect_data mg5uart_tx_ready_cd  = {  \
>>> -  mg5uart_isr_tx_ready,   /* filled in at initialization */
>>> -  NULL,
>>> -  NULL,
>>> -  NULL
>>> -static rtems_irq_connect_data mg5uart_rx_ready_cd  = {  \
>>> -  mg5uart_isr_rx_ready,   /* filled in at initialization */
>>> -  NULL,
>>> -  NULL,
>>> -  NULL
>>> - *  mg5uart_initialize_interrupts
>>> - *  This routine initializes the console's receive and transmit
>>> - *  ring buffers and loads the appropriate vectors to handle the
>>>interrupts.
>>> -MG5UART_STATIC void mg5uart_initialize_interrupts(int minor)
>>> -  unsigned long v;
>>> -  mg5uart_init(minor);
>>> -  v = Console_Port_Tbl[minor]->ulIntVector;
>>> -  mg5uart_rx_frame_error_cd.name    =  v + MG5UART_IRQ_RX_FRAME_ERROR;
>>> -  mg5uart_rx_overrun_error_cd.name  =  v +
>>> -  mg5uart_tx_empty_cd.name          =  v + MG5UART_IRQ_TX_EMPTY;
>>> -  mg5uart_tx_ready_cd.name          =  v + MG5UART_IRQ_TX_READY;
>>> -  mg5uart_rx_ready_cd.name          =  v + MG5UART_IRQ_RX_READY;
>>> -  mg5uart_rx_frame_error_cd.handle    =  (void
>>> -  mg5uart_rx_overrun_error_cd.handle  =  (void
>>> -  mg5uart_tx_empty_cd.handle          =  (void
>>> -  mg5uart_tx_ready_cd.handle          =  (void
>>> -  mg5uart_rx_ready_cd.handle          =  (void
>>> -  BSP_install_rtems_irq_handler( &mg5uart_rx_frame_error_cd );
>>> -  BSP_install_rtems_irq_handler( &mg5uart_rx_overrun_error_cd );
>>> -  BSP_install_rtems_irq_handler( &mg5uart_tx_empty_cd );
>>> -  BSP_install_rtems_irq_handler( &mg5uart_tx_ready_cd );
>>> -  BSP_install_rtems_irq_handler( &mg5uart_rx_ready_cd );
>>> - *  mg5uart_write_support_int
>>> - *  Console Termios output entry point when using interrupt driven
>>>output.
>>> -MG5UART_STATIC int mg5uart_write_support_int(
>>> -  int         minor,
>>> -  const char *buf,
>>> -  size_t      len
>>> -   *  We are using interrupt driven output and termios only sends us
>>> -   *  one character at a time.
>>> -  if ( !len )
>>> -     return 0;
>>> -   *  Put the character out and enable interrupts if necessary.
>>> -  MG5UART_SETREG(pMG5UART_port, MG5UART_TX_BUFFER, *buf);
>>> -  if( Console_Port_Data[minor].bActive == FALSE )
>>> -     Console_Port_Data[minor].bActive = TRUE;
>>> -  return 1;
>>> - *  mg5uart_write_support_polled
>>> - *  Console Termios output entry point when using polled output.
>>> -MG5UART_STATIC ssize_t mg5uart_write_support_polled(
>>> -  int         minor,
>>> -  const char *buf,
>>> -  size_t      len
>>> -  int nwrite = 0;
>>> -   * poll each byte in the string out of the port.
>>> -  while (nwrite < len)
>>> -    mg5uart_write_polled(minor, *buf++);
>>> -    nwrite++;
>>> -   * return the number of bytes written.
>>> -  return nwrite;
>>> - *  mg5uart_inbyte_nonblocking_polled
>>> - *  Console Termios polling input entry point.
>>> -MG5UART_STATIC int mg5uart_inbyte_nonblocking_polled(
>>> -  int minor
>>> -  uint32_t                status;
>>> -  uint32_t                tmp,shift;
>>> -  else
>>> -  /* reset overrrun or framing errors */
>>> -  status = MG5UART_GETREG(pMG5UART, MG5UART_STATUS_REGISTER) >> shift;
>>> -  if( (tmp = (status & 0x3)) )
>>> -     MG5UART_SETREG(pMG5UART, MG5UART_STATUS_REGISTER, (tmp << shift)
>>>shift;
>>> -  if ( status & MONGOOSEV_UART_RX_READY )
>>> -     return (int) MG5UART_GETREG(pMG5UART_port, MG5UART_RX_BUFFER);
>>> -  else
>>> -     return -1;
>>> - *  mg5uart_baud_rate
>>> -  int           minor,
>>> -  uint32_t      baud,
>>> -  uint32_t     *code
>>> -  uint32_t   clock;
>>> -  uint32_t   tmp_code;
>>> -  uint32_t   baud_requested;
>>> -  baud_requested = baud & CBAUD;
>>> -  if (!baud_requested)
>>> -    baud_requested = B9600;              /* default to 9600 baud */
>>> -  baud_requested = rtems_termios_baud_to_number( baud_requested );
>>> -  clock = (uint32_t) Console_Port_Tbl[minor]->ulClock;
>>> -  if (!clock)
>>> -    rtems_fatal_error_occurred(RTEMS_INVALID_NUMBER);
>>> -   *  Formula is Code = round(ClockFrequency / Baud - 1).
>>> -   *  Since this is integer math, we will divide by twice the baud and
>>> -   *  check the remaining odd bit.
>>> -  tmp_code = (clock / baud_requested) - 1;
>>> -   *  From section 12.7, "Keep C>100 for best receiver operation."
>>> -   *  That is 100 cycles which is not a lot of instructions.  It is
>>> -   *  reasonable to think that the Mongoose-V could not keep
>>> -   *  up with C < 100.
>>> -  if ( tmp_code < 100 )
>>> -    return RTEMS_INVALID_NUMBER;
>>> -   *  upper word is receiver baud and lower word is transmitter baud
>>> -  *code = (tmp_code << 16) | tmp_code;
>>> -  return 0;
>>> - *  mg5uart_enable_interrupts
>>> - *  This function enables specific interrupt sources on the DUART.
>>> -  int minor,
>>> -  int mask
>>> -  uint32_t             maskSave;
>>> -  uint32_t              shift;
>>> -   *  Enable interrupts on RX and TX -- not break
>>> -  else
>>> -  maskSave = MG5UART_GETREG( pMG5UART,
>>> -  MG5UART_SETREG(
>>> -     pMG5UART,
>>> -     MG5UART_INTERRUPT_MASK_REGISTER,
>>> -     (maskSave & ~(MONGOOSEV_UART_ALL_STATUS_BITS << shift)) | (mask
>>><< shift) );
>>> - * Flow control is only supported when using interrupts
>>> -const console_fns mg5uart_fns =
>>> -  libchip_serial_default_probe,   /* deviceProbe */
>>> -  mg5uart_open,                   /* deviceFirstOpen */
>>> -  NULL,                           /* deviceLastClose */
>>> -  NULL,                           /* deviceRead */
>>> -  mg5uart_write_support_int,      /* deviceWrite */
>>> -  mg5uart_initialize_interrupts,  /* deviceInitialize */
>>> -  mg5uart_write_polled,           /* deviceWritePolled */
>>> -  mg5uart_set_attributes,         /* deviceSetAttributes */
>>> -  TRUE                            /* deviceOutputUsesInterrupts */
>>> -const console_fns mg5uart_fns_polled =
>>> -  mg5uart_close,                       /* deviceLastClose */
>>> -  mg5uart_inbyte_nonblocking_polled,   /* deviceRead */
>>> -  mg5uart_write_support_polled,        /* deviceWrite */
>>> -  mg5uart_init,                        /* deviceInitialize */
>>> -  FALSE,                               /* deviceOutputUsesInterrupts
>>> diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h
>>>b/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h
>>> index fa7bed6..0000000
>>> --- a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart.h
>>> +++ /dev/null
>>> @@ -1,98 +0,0 @@
>>> - *  COPYRIGHT (c) 1989-1999.
>>> -#ifndef _MG5UART_H_
>>> -#define _MG5UART_H_
>>> -#ifdef __cplusplus
>>> -extern "C" {
>>> -#endif
>>> - *  This is the ASCII for "MG5U" which should be unique enough to
>>> - *  distinguish this type of serial device from others.
>>> -#define SERIAL_MG5UART 0x474D5535
>>> -#define MG5UART_UART0  0
>>> -#define MG5UART_UART1  1
>>> - *  These are just used in the interface between this driver and
>>> - *  the read/write register routines when accessing the first
>>> - *  control port.  They are indices of registers from the bases.
>>> -/* shared registers from peripheral base (i.e. from ulCtrlPort1) */
>>> -#define MG5UART_COMMAND_REGISTER          0
>>> -#define MG5UART_STATUS_REGISTER           1
>>> -#define MG5UART_INTERRUPT_CAUSE_REGISTER  2
>>> -#define MG5UART_INTERRUPT_MASK_REGISTER   3
>>> -#define MG5UART_STATUS_REGISTER           0x04
>>> -#define MG5UART_INTERRUPT_CAUSE_REGISTER  0x08
>>> -#define MG5UART_INTERRUPT_MASK_REGISTER   0x0C
>>> -/* port specific registers from uart base (i.e. from ulCtrlPort2) */
>>> -#define MG5UART_RX_BUFFER  0
>>> -#define MG5UART_TX_BUFFER  4
>>> -#define MG5UART_BAUD_RATE  8
>>> - *  Interrupt mask values
>>> -#define MG5UART_ENABLE_ALL_EXCEPT_TX MONGOOSEV_UART_ALL_RX_STATUS_BITS
>>> -/* all rx ints on, but only tx ready.  no need to also int on tx
>>>empty */
>>> -#define MG5UART_ENABLE_ALL           (MONGOOSEV_UART_ALL_STATUS_BITS
>>> -#define MG5UART_DISABLE_ALL          0x0000
>>> - *  Assume vectors are sequential.
>>> -#define MG5UART_IRQ_RX_FRAME_ERROR   0
>>> -#define MG5UART_IRQ_RX_OVERRUN_ERROR 1
>>> -#define MG5UART_IRQ_TX_EMPTY         2
>>> -#define MG5UART_IRQ_TX_READY         3
>>> -#define MG5UART_IRQ_RX_READY         4
>>> - * Driver function table
>>> -extern const console_fns mg5uart_fns;
>>> -extern const console_fns mg5uart_fns_polled;
>>> - * Default register access routines
>>> -uint32_t   mg5uart_get_register(    /* registers are on 32-bit
>>>boundaries */
>>> -  uint32_t    ulCtrlPort,           /*   and accessed as word
>>> -  uint32_t    ucRegNum
>>> -void  mg5uart_set_register(
>>> -  uint32_t    ucRegNum,
>>> -  uint32_t    ucData
>>> -#ifdef __cplusplus
>>> -#endif
>>> -#endif /* _MG5UART_H_ */
>>> diff --git a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c
>>>b/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c
>>> index 134695f..0000000
>>> --- a/c/src/lib/libcpu/mips/mongoosev/duart/mg5uart_reg.c
>>> +++ /dev/null
>>> @@ -1,58 +0,0 @@
>>> - *  This file contains a typical set of register access routines
>>>which may be
>>> - *  used with the mg5uart chip if accesses to the chip are as follows:
>>> - *    + registers are accessed as uint32_t  's
>>> - *    + registers are only u32-aligned (no address gaps)
>>> - *  COPYRIGHT (c) 1989-2001.
>>> -#include <rtems.h>
>>> -#ifndef _MG5UART_MULTIPLIER
>>> -#define _MG5UART_MULTIPLIER 1
>>> -#define _MG5UART_NAME(_X) _X
>>> -#define _MG5UART_TYPE uint32_t
>>> -#endif
>>> -#define CALCULATE_REGISTER_ADDRESS( _base, _reg ) \
>>> -  (_MG5UART_TYPE *)((_base) + ((_reg) * _MG5UART_MULTIPLIER ))
>>> - *  MG5UART Get Register Routine
>>> -uint8_t   _MG5UART_NAME(mg5uart_get_register)(
>>> -  uint8_t     ucRegNum
>>> -  _MG5UART_TYPE *port;
>>> -  port = CALCULATE_REGISTER_ADDRESS( ulCtrlPort, ucRegNum );
>>> -  return *port;
>>> - *  MG5UART Set Register Routine
>>> -void  _MG5UART_NAME(mg5uart_set_register)(
>>> -  uint8_t     ucRegNum,
>>> -  uint8_t     ucData
>>> -  *port = ucData;
>>> diff --git a/c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h
>>>b/c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h
>>> index b8ded3d..0000000
>>> --- a/c/src/lib/libcpu/mips/mongoosev/include/mongoose-v.h
>>> +++ /dev/null
>>> @@ -1,306 +0,0 @@
>>> - *  @file
>>> - *  MIPS Mongoose-V specific information
>>> -#ifndef __MONGOOSEV_h
>>> -#define __MONGOOSEV_h
>>> - *  Macros to assist in accessing memory mapped Mongoose registers
>>> -#define MONGOOSEV_READ( _base ) \
>>> -  ( *((volatile uint32_t*)(_base)) )
>>> -#define MONGOOSEV_WRITE( _base, _value ) \
>>> -  ( *((volatile uint32_t*)(_base)) = (_value) )
>>> -#define MONGOOSEV_READ_REGISTER( _base, _register ) \
>>> -  ( *((volatile uint32_t*)((_base) + (_register))) )
>>> -#define MONGOOSEV_WRITE_REGISTER( _base, _register, _value ) \
>>> -  ( *((volatile uint32_t*)((_base) + (_register))) = (_value) )
>>> - * Macros to read/write the Mongoose FPU control register.
>>> - *  BIU and DRAM Registers
>>> -#define MONGOOSEV_BIU_CACHE_CONFIGURATION_REGISTER       0xFFFE0130
>>> -#define MONGOOSEV_DRAM_CONFIGURATION_REGISTER            0xFFFE0120
>>> -#define MONGOOSEV_REFRESH_TIMER_INITIAL_COUNTER_REGISTER 0xFFFE0010
>>> -#define MONGOOSEV_WAIT_STATE_CONFIGURATION_REGISTER_BASE 0xFFFE0100
>>> - *  Peripheral Function Addresses
>>> - *  NOTE: Status and Interrupt Cause use the same bits
>>> -#define MONGOOSEV_PERIPHERAL_COMMAND_REGISTER
>>>0xFFFE0180
>>> -#define MONGOOSEV_PERIPHERAL_STATUS_REGISTER
>>>0xFFFE0184
>>> -#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_CAUSE_REGISTER
>>>0xFFFE0188
>>> -#define MONGOOSEV_PERIPHERAL_FUNCTION_INTERRUPT_MASK_REGISTER
>>>0xFFFE018C
>>> -#define MONGOOSEV_WATCHDOG                     0xBE000000
>>> -/* UART Bits in Peripheral Command Register Bits (TX/RX tied together
>>>here) */
>>> -#define MONGOOSEV_UART_CMD_RESET_BOTH_PORTS    0x0001
>>> -#define MONGOOSEV_UART_CMD_LOOPBACK_CTSN       0x0002
>>> -#define MONGOOSEV_UART_CMD_LOOPBACK_RXTX       0x0004
>>> -#define MONGOOSEV_UART_CMD_RX_ENABLE           0x001
>>> -#define MONGOOSEV_UART_CMD_RX_DISABLE          0x000
>>> -#define MONGOOSEV_UART_CMD_TX_ENABLE           0x002
>>> -#define MONGOOSEV_UART_CMD_TX_DISABLE          0x000
>>> -#define MONGOOSEV_UART_CMD_TX_READY            0x004
>>> -#define MONGOOSEV_UART_CMD_PARITY_ENABLE       0x008
>>> -#define MONGOOSEV_UART_CMD_PARITY_DISABLE      0x000
>>> -#define MONGOOSEV_UART_CMD_PARITY_EVEN         0x010
>>> -#define MONGOOSEV_UART_CMD_PARITY_ODD          0x000
>>> -#define MONGOOSEV_UART0_CMD_SHIFT 5
>>> -#define MONGOOSEV_UART1_CMD_SHIFT 11
>>> -#define MONGOOSEV_UART_CMD_TX_ENABLE_0 \
>>> -        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_RX_ENABLE_0 \
>>> -        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART0_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_TX_READY_0 \
>>> -        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART0_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_PARITY_ENABLE_0 \
>>> -        (MONGOOSEV_UART_CMD_PARITY_ENABLE <<
>>> -#define MONGOOSEV_UART_CMD_PARITY_DISABLE_0 \
>>> -        (MONGOOSEV_UART_CMD_PARITY_DISABLE <<
>>> -#define MONGOOSEV_UART_CMD_PARITY_EVEN_0 \
>>> -        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART0_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_PARITY_ODD_0 \
>>> -        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART0_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_TX_ENABLE_1 \
>>> -        (MONGOOSEV_UART_CMD_TX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_RX_ENABLE_1 \
>>> -        (MONGOOSEV_UART_CMD_RX_ENABLE << MONGOOSEV_UART1_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_TX_READY_1 \
>>> -        (MONGOOSEV_UART_CMD_TX_READY << MONGOOSEV_UART1_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_PARITY_ENABLE_1 \
>>> -#define MONGOOSEV_UART_CMD_PARITY_DISABLE_1 \
>>> -#define MONGOOSEV_UART_CMD_PARITY_EVEN_1 \
>>> -        (MONGOOSEV_UART_CMD_PARITY_EVEN << MONGOOSEV_UART1_CMD_SHIFT)
>>> -#define MONGOOSEV_UART_CMD_PARITY_ODD_1 \
>>> -        (MONGOOSEV_UART_CMD_PARITY_ODD << MONGOOSEV_UART1_CMD_SHIFT)
>>> -/* UART Bits in Peripheral Status and Interrupt Cause Register */
>>> -#define MONGOOSEV_UART_RX_FRAME_ERROR              0x0001
>>> -#define MONGOOSEV_UART_RX_OVERRUN_ERROR            0x0002
>>> -#define MONGOOSEV_UART_TX_EMPTY                    0x0004
>>> -#define MONGOOSEV_UART_TX_READY                    0x0008
>>> -#define MONGOOSEV_UART_RX_READY                    0x0010
>>> -#define MONGOOSEV_UART_ALL_RX_STATUS_BITS          0x0013
>>> -#define MONGOOSEV_UART_ALL_STATUS_BITS             0x001F
>>> - *  The Peripheral Interrupt Status, Cause, and Mask registers have
>>>the
>>> - *  same bit assignments although some revisions of the document have
>>> - *  the Cause and Status registers incorrect.
>>> -#define MONGOOSEV_UART0_IRQ_SHIFT 11
>>> -#define MONGOOSEV_UART1_IRQ_SHIFT 17
>>> -#define MONGOOSEV_UART_FRAME_ERROR_0 \
>>> -        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_RX_OVERRUN_ERROR_0 \
>>> -        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART0_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_TX_EMPTY_0 \
>>> -        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART0_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_TX_READY_0 \
>>> -        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_RX_READY_0 \
>>> -        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART0_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_FRAME_ERROR_1 \
>>> -        (MONGOOSEV_UART_FRAME_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_RX_OVERRUN_ERROR_1 \
>>> -        (MONGOOSEV_UART_RX_OVERRUN_ERROR << MONGOOSEV_UART1_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_TX_EMPTY_1 \
>>> -        (MONGOOSEV_UART_TX_EMPTY << MONGOOSEV_UART1_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_TX_READY_1 \
>>> -        (MONGOOSEV_UART_TX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
>>> -#define MONGOOSEV_UART_RX_READY_1 \
>>> -        (MONGOOSEV_UART_RX_READY << MONGOOSEV_UART1_IRQ_SHIFT)
>>> - *  Bits in the Peripheral Interrupt Mask Register
>>> -** Interrupt Status/Cause/Mask register bits - from 31 to 0
>>> -#define MONGOOSEV_EDAC_SERR_BIT          0x80000000
>>> -#define MONGOOSEV_EDAC_MERR_BIT          0x40000000
>>> -/* 29 - 24 reserved */
>>> -#define MONGOOSEV_MAVN_WRITE_ACCESS      0x00800000
>>> -#define MONGOOSEV_MAVN_READ_ACCESS       0x00400000
>>> -#define MONGOOSEV_UART_1_RX_READY        0x00200000
>>> -#define MONGOOSEV_UART_1_TX_READY        0x00100000
>>> -#define MONGOOSEV_UART_1_TX_EMPTY        0x00080000
>>> -#define MONGOOSEV_UART_1_RX_OVERRUN      0x00040000
>>> -#define MONGOOSEV_UART_1_FRAME_ERROR     0x00020000
>>> -#define MONGOOSEV_RESERVED_16            0x00010000
>>> -#define MONGOOSEV_UART_0_RX_READY        0x00008000
>>> -#define MONGOOSEV_UART_0_TX_READY        0x00004000
>>> -#define MONGOOSEV_UART_0_TX_EMPTY        0x00002000
>>> -#define MONGOOSEV_UART_0_RX_OVERRUN      0x00001000
>>> -#define MONGOOSEV_UART_0_FRAME_ERROR     0x00000800
>>> -#define MONGOOSEV_RESERVED_10            0x00000400
>>> -#define MONGOOSEV_EXTERN_INT_9           0x00000200
>>> -#define MONGOOSEV_EXTERN_INT_8           0x00000100
>>> -#define MONGOOSEV_EXTERN_INT_7           0x00000080
>>> -#define MONGOOSEV_EXTERN_INT_6           0x00000040
>>> -#define MONGOOSEV_EXTERN_INT_5           0x00000020
>>> -#define MONGOOSEV_EXTERN_INT_4           0x00000010
>>> -#define MONGOOSEV_EXTERN_INT_3           0x00000008
>>> -#define MONGOOSEV_EXTERN_INT_2           0x00000004
>>> -#define MONGOOSEV_EXTERN_INT_1           0x00000002
>>> -#define MONGOOSEV_EXTERN_INT_0           0x00000001
>>> -** Peripheral Command bits (non-uart, those are defined above)
>>> -#define MONGOOSEV_COMMAND_ENABLE_EDAC  MONGOOSEV_EDAC_SERR_BIT
>>> -#define MONGOOSEV_COMMAND_OVERRIDE_EDAC MONGOOSEV_EDAC_MERR_BIT
>>> - *  EDAC Registers
>>> -#define MONGOOSEV_EDAC_ERROR_ADDRESS_REGISTER       0xFFFE0190
>>> -#define MONGOOSEV_EDAC_PARITY_TEST_MODE_REGISTER    0xFFFE0194
>>> - *  MAVN Registers
>>> -#define MONGOOSEV_MAVN_TEST_REGISTER               0xFFFE01B4
>>> -#define MONGOOSEV_MAVN_ACCESS_PRIVILEGE_REGISTER   0xFFFE01B8
>>> -#define MONGOOSEV_MAVN_ACCESS_VIOLATION_REGISTER   0xFFFE01BC
>>> -#define MONGOOSEV_MAVN_RANGE_0_REGISTER            0xFFFE01C0
>>> -#define MONGOOSEV_MAVN_RANGE_1_REGISTER            0xFFFE01C4
>>> -#define MONGOOSEV_MAVN_RANGE_2_REGISTER            0xFFFE01C8
>>> -#define MONGOOSEV_MAVN_RANGE_3_REGISTER            0xFFFE01CC
>>> -#define MONGOOSEV_MAVN_RANGE_4_REGISTER            0xFFFE01D0
>>> -#define MONGOOSEV_MAVN_RANGE_5_REGISTER            0xFFFE01D4
>>> -#define MONGOOSEV_MAVN_RANGE_6_REGISTER            0xFFFE01D8
>>> -#define MONGOOSEV_MAVN_RANGE_7_REGISTER            0xFFFE01DC
>>> - *  Timer Base Addresses, Offsets, and Values
>>> -#define MONGOOSEV_TIMER1_BASE    0xFFFE0000
>>> -#define MONGOOSEV_TIMER2_BASE    0xFFFE0008
>>> -#define MONGOOSEV_TIMER_INITIAL_COUNTER_REGISTER 0
>>> -#define MONGOOSEV_TIMER_CONTROL_REGISTER         4
>>> -/* Timer Control Register Constants */
>>> -#define MONGOOSEV_TIMER_CONTROL_COUNTER_ENABLE    0x04
>>> -#define MONGOOSEV_TIMER_CONTROL_INTERRUPT_ENABLE  0x02
>>> -#define MONGOOSEV_TIMER_CONTROL_TIMEOUT           0x01
>>> - *  UART Base Addresses and Offsets
>>> - *  Many bits in the peripheral command register are UART related
>>> - *  and the bits are defined there.
>>> -#define MONGOOSEV_UART0_BASE   0xFFFE01E8
>>> -#define MONGOOSEV_UART1_BASE   0xFFFE01F4
>>> -#define MONGOOSEV_RX_BUFFER    0
>>> -#define MONGOOSEV_TX_BUFFER    4
>>> -#define MONGOOSEV_BAUD_RATE    8
>>> - *  Status Register Bits
>>> -#define SR_CUMASK      0xf0000000      /* coproc usable bits */
>>> -#define SR_CU3         0x80000000      /* Coprocessor 3 usable */
>>> -#define SR_CU2         0x40000000      /* Coprocessor 2 usable */
>>> -#define SR_CU1         0x20000000      /* Coprocessor 1 usable */
>>> -#define SR_CU0         0x10000000      /* Coprocessor 0 usable */
>>> -#define SR_BEV         0x00400000      /* use boot exception vectors
>>> -#define SR_TS          0x00200000      /* TLB shutdown */
>>> -#define SR_PE          0x00100000      /* cache parity error */
>>> -#define SR_CM          0x00080000      /* cache miss */
>>> -#define SR_PZ          0x00040000      /* cache parity zero */
>>> -#define SR_SWC         0x00020000      /* swap cache */
>>> -#define SR_ISC         0x00010000      /* Isolate data cache */
>>> -#define SR_IMASK       0x0000ff00      /* Interrupt mask */
>>> -#define SR_IMASK8      0x00000000      /* mask level 8 */
>>> -#define SR_IMASK7      0x00008000      /* mask level 7 */
>>> -#define SR_IMASK6      0x0000c000      /* mask level 6 */
>>> -#define SR_IMASK5      0x0000e000      /* mask level 5 */
>>> -#define SR_IMASK4      0x0000f000      /* mask level 4 */
>>> -#define SR_IMASK3      0x0000f800      /* mask level 3 */
>>> -#define SR_IMASK2      0x0000fc00      /* mask level 2 */
>>> -#define SR_IMASK1      0x0000fe00      /* mask level 1 */
>>> -#define SR_IMASK0      0x0000ff00      /* mask level 0 */
>>> -#define SR_IBIT8       0x00008000      /* bit level 8 */
>>> -#define SR_IBIT7       0x00004000      /* bit level 7 */
>>> -#define SR_IBIT6       0x00002000      /* bit level 6 */
>>> -#define SR_IBIT5       0x00001000      /* bit level 5 */
>>> -#define SR_IBIT4       0x00000800      /* bit level 4 */
>>> -#define SR_IBIT3       0x00000400      /* bit level 3 */
>>> -#define SR_IBIT2       0x00000200      /* bit level 2 */
>>> -#define SR_IBIT1       0x00000100      /* bit level 1 */
>>> -#define SR_KUO         0x00000020      /* old kernel/user, 0 => k, 1
>>>=> u */
>>> -#define SR_IEO         0x00000010      /* old interrupt enable, 1 =>
>>>enable */
>>> -#define SR_KUP         0x00000008      /* prev kernel/user, 0 => k, 1
>>>=> u */
>>> -#define SR_IEP         0x00000004      /* prev interrupt enable, 1 =>
>>>enable */
>>> -#define SR_KUC         0x00000002      /* cur kernel/user, 0 => k, 1
>>>=> u */
>>> -#define SR_IEC         0x00000001      /* cur interrupt enable, 1 =>
>>>enable */
>>> -#define SR_KUMSK       (SR_KUO|SR_IEO|SR_KUP|SR_IEP|SR_KUC|SR_IEC)
>>> -#define SR_IMASKSHIFT  8
>>> -#define MONGOOSEV_IC_SIZE      0x1000          /* instruction cache =
>>>4Kbytes */
>>> -#define MONGOOSEV_DC_SIZE      0x800           /* data cache 2Kbytes
>>> -#endif
>>> diff --git a/c/src/lib/libcpu/mips/preinstall.am
>>>b/c/src/lib/libcpu/mips/preinstall.am
>>> index 4a83d60..85aec82 100644
>>> --- a/c/src/lib/libcpu/mips/preinstall.am
>>> +++ b/c/src/lib/libcpu/mips/preinstall.am
>>> @@ -26,20 +26,6 @@ $(PROJECT_INCLUDE)/libcpu/isr_entries.h:
>>>shared/interrupts/isr_entries.h $(PROJE
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/isr_entries.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/isr_entries.h
>>> -if mongoosev
>>> -$(PROJECT_INCLUDE)/libcpu/mongoose-v.h:
>>>mongoosev/include/mongoose-v.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>> -       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/mongoose-v.h
>>> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/mongoose-v.h
>>> -$(PROJECT_INCLUDE)/libchip/$(dirstamp):
>>> -       @$(MKDIR_P) $(PROJECT_INCLUDE)/libchip
>>> -       @: > $(PROJECT_INCLUDE)/libchip/$(dirstamp)
>>> -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libchip/$(dirstamp)
>>> -$(PROJECT_INCLUDE)/libchip/mg5uart.h: mongoosev/duart/mg5uart.h
>>> -       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libchip/mg5uart.h
>>> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/libchip/mg5uart.h
>>> -endif
>>>  if tx39
>>>  $(PROJECT_INCLUDE)/libcpu/tx3904.h: tx39/include/tx3904.h
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/tx3904.h
>>> 1.9.3
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel.sherrill at OARcorp.com        On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>Support Available                (256) 722-9985
>devel mailing list
>devel at rtems.org
