How to send a shutdown signal to QEMU from RTEMS?
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Oct 10 17:04:53 UTC 2014
On 10/10/2014 11:56 AM, Hesham Moustafa wrote:
> On Wed, Oct 8, 2014 at 4:20 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
> On 10/8/2014 12:15 AM, Sebastian Huber wrote:
> > On 07/10/14 15:53, Hesham Moustafa wrote:
> >> Hi,
> >> I want to send shutdown signal from RTEMS to qemu. Joel said that
> >> qemu-system-i386 does so; can anyone refers me to how to
> implement that for
> >> qemu-system-or32 (openrisc)?
> > This is target dependent. Some targets implement the registers
> of the reset
> > module. The easiest thing to figure this out is looking at the
> Qemu sources.
> We need to ask Christian. There is a command line option to qemu
> which turns on "exit on reset" (--no-reboot). If the simulated target
> hardware has a way to reset it from software, the target specific
> simulation
> can honor the command line option and just exit rather than start
> over.
> We use this on at least the pc386.
> Would you please provide the related QEMU code so that I can try to
> imitate for or1k?
Bring Christian in on this. There has to be defined a hardware way to
shutdown. It can be as simple as a new "IO device" which has a single
register. When you write to it, the simulator just does an orderly shutdown.
But if the or1k HW already has some defined HW mechanism to request
a reset, then we need to know that so that the simulator can exit or
restart when that is touched properly.
The qemu code is complex but it centers around qemu_system_reset_request()
as best I can tell.
> The questions for Christian are:
> + Does the or1ksim have a software reset capability? If not, can we
> add one?
> There is a single assembly instruction that shutdowns the whole
> or1ksim simulator process. We can use it from RTEMS. The question is
> where is the best place to put in this instruction? It's BSP related,
> and I was thinking of _CPU_Fatal_Halt, but it's not BSP related.
> However only or1ksim simulator recognizes this instruction, and it has
> no effect on other (future) target (QEMU, FPGA board, etc).
> + Can qemu be modified to support this?
> It should only be a few lines of code in qemu and one write to the
> magic location in the BSP.
> It will be of great value in speeding the testing procedure.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141010/145cfca4/attachment-0001.html>
