[PATCH 1/2] libcpu/or1k: Fix warnings.
Hesham ALMatary heshamelmatary at gmail.com
Fri Oct 10 17:23:08 UTC 2014
 c/src/lib/libcpu/or1k/shared/cache/cache.c  | 16 ++++++++--------
 c/src/lib/libcpu/or1k/shared/cache/cache_.h |  1 +
 2 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
index 039be36..afc8859 100644
--- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
+++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
@@ -71,7 +71,7 @@ static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
   _ISR_Disable (level);
-  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, (uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -81,7 +81,7 @@ static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
    ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -91,7 +91,7 @@ static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
    ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -101,7 +101,7 @@ static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
    ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, (uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -111,7 +111,7 @@ static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
    ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, (uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -122,7 +122,7 @@ static inline void _CPU_OR1K_Cache_instruction_block_prefetch
    ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, (uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -133,7 +133,7 @@ static inline void _CPU_OR1K_Cache_instruction_block_invalidate
    ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uintptr_t) d_addr);
   _ISR_Enable(level);
@@ -144,7 +144,7 @@ static inline void _CPU_OR1K_Cache_instruction_block_lock
    ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
+  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, (uintptr_t) d_addr);
   _ISR_Enable(level);
diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
index 5f08410..0ea939f 100644
--- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
+++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
@@ -6,6 +6,7 @@
 #define __OR1K_CACHE_H
 #include <bsp/cache_.h>
+#include <libcpu/cache.h>
 #endif
 /* end of include file */
1.9.3
