sis build failure with SMP enabled
Mon Oct 13 14:05:32 UTC 2014
On 10/13/2014 9:04 AM, Sebastian Huber wrote:
> On 13/10/14 15:56, Joel Sherrill wrote:
>> On 10/13/2014 3:08 AM, Sebastian Huber wrote:
>>>> On 10/10/14 21:52, Joel Sherrill wrote:
>>>>>> Hi
>>>>>> Any thoughts on how to address this?
>>>> http://lists.rtems.org/pipermail/devel/2014-September/008159.html
>> Why would one use an IPI on a single core system? I can see a stub
>> for the missing method being needed but not much more.
> I don't understand this question.
> The problem is this special purpose _Cache_manager_Send_smp_msg() that is only
> implemented in some BSPs breaking all other.
The question is why is this method even referenced in a non-SMP build?
