[PATCH 01/23] mips/clock/ckinit.c: Clean up (may be unused)
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Oct 13 14:18:08 UTC 2014
c/src/lib/libcpu/mips/clock/ckinit.c | 61 +++++++++---------------------------
1 file changed, 15 insertions(+), 46 deletions(-)
diff --git a/c/src/lib/libcpu/mips/clock/ckinit.c b/c/src/lib/libcpu/mips/clock/ckinit.c
index 711b41c..3152263 100644
--- a/c/src/lib/libcpu/mips/clock/ckinit.c
+++ b/c/src/lib/libcpu/mips/clock/ckinit.c
@@ -1,7 +1,8 @@
-/* ckinit.c
* This file contains the clock driver initialization for the IDT 4650.
* Author: Craig Lebakken <craigl at transition.com>
* COPYRIGHT (c) 1996 by Transition Networks Inc.
@@ -30,15 +31,12 @@
* Rather than deleting this, it is commented out to (hopefully) help
* the submitter send updates.
- * static char _sccsid[] = "@(#)ckinit.c 08/20/96 1.3\n";
-#include <rtems/libio.h>
+#include <rtems/clockdrv.h>
#define EXT_INT5 0x8000 /* external interrupt 5 */
@@ -49,15 +47,10 @@ extern uint32_t bsp_clicks_per_microsecond;
/* to avoid including the bsp */
mips_isr_entry set_vector( rtems_isr_entry, rtems_vector_number, int );
-void Clock_exit( void );
-rtems_isr Clock_isr( rtems_vector_number vector );
* The interrupt vector number associated with the clock tick device
* driver.
#define CLOCK_VECTOR_MASK EXT_INT5
#define CLOCK_VECTOR 0x7
@@ -65,7 +58,6 @@ rtems_isr Clock_isr( rtems_vector_number vector );
* Clock_driver_ticks is a monotonically increasing counter of the
* number of clock ticks since the driver was initialized.
volatile uint32_t Clock_driver_ticks;
@@ -75,42 +67,30 @@ volatile uint32_t Clock_driver_ticks;
* length of time between the user configured microseconds per tick
* has passed.
uint32_t Clock_isrs; /* ISRs until next tick */
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
* The previous ISR on this clock tick interrupt vector.
rtems_isr_entry Old_ticker;
static uint32_t mips_timer_rate = 0;
* Isr Handler
+static rtems_isr Clock_isr(
- * bump the number of clock driver ticks since initialization
- * determine if it is time to announce the passing of tick as configured
- * to RTEMS through the rtems_clock_tick directive
- * perform any timer dependent tasks
+ * bump the number of clock driver ticks since initialization
+ * determine if it is time to announce the passing of tick as configured
+ * to RTEMS through the rtems_clock_tick directive
+ * perform any timer dependent tasks
/* refresh the internal CPU timer */
mips_set_timer( mips_timer_rate );
@@ -140,8 +120,7 @@ rtems_isr User_Clock_isr(
* Install a clock tick handleR and reprograms the chip. This
* is used to initially establish the clock tick.
-void Install_clock(
+static void Install_clock(
rtems_isr_entry clock_isr
@@ -153,10 +132,10 @@ void Install_clock(
Clock_isrs = rtems_configuration_get_milliseconds_per_tick();
Old_ticker = (rtems_isr_entry) set_vector( clock_isr, CLOCK_VECTOR, 1 );
* Hardware specific initialize goes here
mips_timer_rate = rtems_configuration_get_microseconds_per_tick() *
@@ -165,14 +144,12 @@ void Install_clock(
* Schedule the clock cleanup routine to execute if the application exits.
atexit( Clock_exit );
* Clean up before the application exits
/* mips: turn off the timer interrupts */
@@ -184,7 +161,6 @@ void Clock_exit( void )
* Device driver entry point for clock tick driver initialization.
rtems_device_driver Clock_initialize(
rtems_device_major_number major,
rtems_device_minor_number minor,
@@ -193,12 +169,5 @@ rtems_device_driver Clock_initialize(
Install_clock( Clock_isr );
- * make major/minor avail to others such as shared memory driver
- rtems_clock_major = major;
- rtems_clock_minor = minor;
return RTEMS_SUCCESSFUL;
1.9.3
