[PATCH 19/23] m68k/av5282/console/console.c: Eliminate unused debug methods
Mon Oct 13 14:18:26 UTC 2014
 c/src/lib/libbsp/m68k/av5282/console/console.c | 23 -----------------------
 1 file changed, 23 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/av5282/console/console.c b/c/src/lib/libbsp/m68k/av5282/console/console.c
index 85ec37f..bc1d9e5 100644
--- a/c/src/lib/libbsp/m68k/av5282/console/console.c
+++ b/c/src/lib/libbsp/m68k/av5282/console/console.c
@@ -44,7 +44,6 @@ static void _BSP_null_char( char c )
 BSP_output_char_function_type     BSP_output_char = _BSP_null_char;
 BSP_polling_getchar_function_type BSP_poll_char = NULL;
 #define MAX_UART_INFO     3
 #define RX_BUFFER_SIZE    512
@@ -712,25 +711,3 @@ rtems_device_driver console_control(
   return rtems_termios_ioctl(arg);
-int DEBUG_OUTCHAR(int c)
-  if (c == '\n')
-    DEBUG_OUTCHAR('\r');
-  _BSP_null_char(c);
-  return c;
-void DEBUG_OUTSTR(const char *msg)
-  while (*msg)
-    DEBUG_OUTCHAR(*msg++);
-void DEBUG_OUTNUM(int i)
-  int n;
-  static const char map[] = "0123456789ABCDEF";
-  DEBUG_OUTCHAR(' ');
-  for (n = 28 ; n >= 0 ; n -= 4)
-      DEBUG_OUTCHAR(map[(i >> n) & 0xF]);
1.9.3
