[PATCH 01/54] m68k/mvme136: Fix warnings
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Oct 13 15:36:45 UTC 2014
c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c | 30 +++---------
c/src/lib/libbsp/m68k/mvme136/console/console.c | 60 +++---------------------
c/src/lib/libbsp/m68k/mvme136/include/bsp.h | 11 +++--
c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c | 12 ++---
c/src/lib/libbsp/m68k/mvme136/timer/timer.c | 2 +-
5 files changed, 25 insertions(+), 90 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c b/c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c
index febcb30..02115c4 100644
--- a/c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c
+++ b/c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c
@@ -1,12 +1,9 @@
-/* Clock_init()
* This routine initializes the Z80386 1 on the MVME136 board.
* The tick frequency is 1 millisecond.
- * Input parameters: NONE
- * Output parameters: NONE
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
@@ -44,17 +41,9 @@ rtems_isr_entry Old_ticker;
void Clock_exit( void );
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
* ISR Handler
-rtems_isr Clock_isr(
+static rtems_isr Clock_isr(
rtems_vector_number vector
@@ -69,7 +58,7 @@ rtems_isr Clock_isr(
Clock_isrs -= 1;
-void Install_clock(
+static void Install_clock(
rtems_isr_entry clock_isr
@@ -121,12 +110,5 @@ rtems_device_driver Clock_initialize(
Install_clock( Clock_isr );
- * make major/minor avail to others such as shared memory driver
- rtems_clock_major = major;
- rtems_clock_minor = minor;
return RTEMS_SUCCESSFUL;
diff --git a/c/src/lib/libbsp/m68k/mvme136/console/console.c b/c/src/lib/libbsp/m68k/mvme136/console/console.c
index 111fd7b..ce8fa8d 100644
--- a/c/src/lib/libbsp/m68k/mvme136/console/console.c
+++ b/c/src/lib/libbsp/m68k/mvme136/console/console.c
@@ -1,7 +1,9 @@
* This file contains the MVME136 console IO package.
- * COPYRIGHT (c) 1989-1999.
+ * COPYRIGHT (c) 1989-2014.
* The license and distribution terms for this file may be
@@ -15,19 +17,10 @@
volatile struct r_m681_info *_Read_m681; /* M68681 read registers */
volatile struct w_m681_info *_Write_m681; /* M68681 write registers */
/* console_initialize
* This routine initializes the console IO driver.
- * Return values:
rtems_device_driver console_initialize(
rtems_device_major_number major,
rtems_device_minor_number minor,
@@ -51,41 +44,11 @@ rtems_device_driver console_initialize(
-/* is_character_ready
- * This routine returns TRUE if a character is available.
- * Return values:
-bool is_character_ready(
- char *ch
- if ( !(_Read_m681->srb & RXRDYB) )
- return false;
- *ch = _Read_m681->rbb;
- return true;
/* inbyte
* This routine reads a character from the UART.
- * Return values:
- * character read from UART
-char inbyte( void )
+static char inbyte( void )
while ( !(_Read_m681->srb & RXRDYB) );
return _Read_m681->rbb;
@@ -95,14 +58,8 @@ char inbyte( void )
* This routine transmits a character out the M68681. It supports
* XON/XOFF flow control.
- * ch - character to be transmitted
-void outbyte(
+static void outbyte(
char ch
@@ -121,7 +78,6 @@ void outbyte(
* Open entry point
rtems_device_driver console_open(
@@ -134,7 +90,6 @@ rtems_device_driver console_open(
* Close entry point
rtems_device_driver console_close(
@@ -147,7 +102,6 @@ rtems_device_driver console_close(
* read bytes from the serial port. We only have stdin.
rtems_device_driver console_read(
@@ -179,7 +133,6 @@ rtems_device_driver console_read(
* write bytes to the serial port. Stdout and stderr are the same.
rtems_device_driver console_write(
@@ -210,7 +163,6 @@ rtems_device_driver console_write(
* IO Control entry point
rtems_device_driver console_control(
diff --git a/c/src/lib/libbsp/m68k/mvme136/include/bsp.h b/c/src/lib/libbsp/m68k/mvme136/include/bsp.h
index bbdc6c1..e699c09 100644
--- a/c/src/lib/libbsp/m68k/mvme136/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/mvme136/include/bsp.h
@@ -1,8 +1,9 @@
-/* bsp.h
* This include file contains all MVME136 board IO definitions.
@@ -68,7 +69,7 @@ extern rtems_isr_entry M68Kvec[]; /* vector table address */
/* functions */
rtems_isr_entry set_vector(
- rtems_isr_entry handler,
+ rtems_isr_entry handle,
rtems_vector_number vector,
int type
diff --git a/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c b/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
index c04a97d..5d968b8 100644
--- a/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c
@@ -13,16 +13,16 @@
#include <bsp/bootcard.h>
#include <rtems/zilog/z8036.h>
-extern void start( void );
+void start(void);
-void bsp_return_to_monitor_trap(void)
+static rtems_isr bsp_return_to_monitor_trap(rtems_vector_number ignored)
register volatile void *start_addr;
- m68k_set_vbr( 0 ); /* restore 135Bug vectors */
- __asm__ volatile( "trap #15" ); /* trap to 135Bug */
- __asm__ volatile( ".short 0x63" ); /* return to 135Bug (.RETURN) */
- /* restart program */
+ m68k_set_vbr( 0 ); /* restore 135Bug vectors */
+ __asm__ volatile( "trap #15" ); /* trap to 135Bug */
+ __asm__ volatile( ".short 0x63" ); /* return to 135Bug (.RETURN) */
+ /* restart program */
start_addr = start;
__asm__ volatile ( "jmp %0@" : "=a" (start_addr) : "0" (start_addr) );
diff --git a/c/src/lib/libbsp/m68k/mvme136/timer/timer.c b/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
index a445b71..a9bf322 100644
--- a/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mvme136/timer/timer.c
@@ -16,7 +16,7 @@
int Ttimer_val;
bool benchmark_timer_find_average_overhead;
-rtems_isr timerisr(void);
+rtems_isr timerisr(rtems_vector_number);
void benchmark_timer_initialize(void)
1.9.3
