[PATCH 09/54] gen68340/clock/ckinit.c: Fix warnings
Mon Oct 13 15:36:53 UTC 2014
 c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c | 125 +++++++++-----------------
 1 file changed, 41 insertions(+), 84 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c b/c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c
index d308531..de3df6e 100644
--- a/c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c
+++ b/c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c
@@ -1,6 +1,8 @@
  * This routine initializes the MC68340/349 Periodic Interval Timer
  * Based on the `gen68360' board support package, and covered by the
  * original distribution terms.
@@ -14,11 +16,7 @@
- * Input parameters:	NONE
- * Output parameters:	NONE
- * COPYRIGHT (c) 1989-1999.
+ * COPYRIGHT (c) 1989-2014.
  * On-Line Applications Research Corporation (OAR).
  * The license and distribution terms for this file may be
@@ -26,12 +24,12 @@
  * http://www.rtems.org/license/LICENSE.
-#include <stdlib.h>			/* for atexit() */
+#include <stdlib.h>       /* for atexit() */
 #include <bsp.h>
 #include <m68340.h>
-#define CLOCK_VECTOR	120		/* clock isr routine vector in the vbr */
-#define CLOCK_IRQ_LEVEL	6		/* clock isr level */
+#define CLOCK_VECTOR     120 /* clock isr routine vector in the vbr */
+#define CLOCK_IRQ_LEVEL  6   /* clock isr level */
  * Clock_driver_ticks is a monotonically increasing counter of the
@@ -40,107 +38,66 @@
 volatile uint32_t         Clock_driver_ticks;
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
  * Periodic interval timer interrupt handler
-  Name: Clock_isr
-  Input parameters: irq vector
-  Output parameters: none
-  Description: update # of clock ticks
-rtems_isr
+static rtems_isr
 Clock_isr (rtems_vector_number vector)
-	 * Announce the clock tick
-	Clock_driver_ticks++;
-	rtems_clock_tick();
+   * Announce the clock tick
+  Clock_driver_ticks++;
+  rtems_clock_tick();
-  Name: clock_exit
-  Input parameters: -
-  Output parameters: -
-  Description: turn off periodic time at shutdown
 void
 Clock_exit (void)
-	 * Turn off periodic interval timer
-	SIMPITR = 0;
+   * Turn off periodic interval timer
+  SIMPITR = 0;
-  Name: Install_clock
-  Input parameters: the Clock Interrupt Subroutine
-  Description: initialize the periodic interval ticker
-	       called by Clock_Initialize
 static void
 Install_clock (rtems_isr_entry clock_isr)
-	uint32_t   pitr_tmp;
-	uint32_t   usecs_per_tick;
-	Clock_driver_ticks = 0;
+  uint32_t   pitr_tmp;
+  uint32_t   usecs_per_tick;
-	set_vector (clock_isr, CLOCK_VECTOR, 1);
+  Clock_driver_ticks = 0;
-	/* sets the Periodic Interrupt Control Register PICR */
-	/* voir a quoi correspond exactement le Clock Vector */
+  set_vector (clock_isr, CLOCK_VECTOR, 1);
-	SIMPICR = ( CLOCK_IRQ_LEVEL << 8 ) | ( CLOCK_VECTOR );
+  /* sets the Periodic Interrupt Control Register PICR */
+  SIMPICR = ( CLOCK_IRQ_LEVEL << 8 ) | ( CLOCK_VECTOR );
-	/* sets the PITR count value */
-	/* this assumes a 32.765 kHz crystal */
+  /* sets the PITR count value */
+  /* this assumes a 32.765 kHz crystal */
-        usecs_per_tick = rtems_configuration_get_microseconds_per_tick();
-	/* find out whether prescaler should be enabled or not */
-	if ( usecs_per_tick <= 31128 ) {
-	   pitr_tmp = ( usecs_per_tick * 8192 ) / 1000000 ;
-	} else {
-	   pitr_tmp = ( usecs_per_tick / 1000000 ) * 16;
-	   /* enable it */
-	   pitr_tmp |= 0x100;
+  usecs_per_tick = rtems_configuration_get_microseconds_per_tick();
+  /* find out whether prescaler should be enabled or not */
+  if ( usecs_per_tick <= 31128 ) {
+     pitr_tmp = ( usecs_per_tick * 8192 ) / 1000000 ;
+  } else {
+     pitr_tmp = ( usecs_per_tick / 1000000 ) * 16;
+     /* enable it */
+     pitr_tmp |= 0x100;
-	SIMPITR = (unsigned char) pitr_tmp;
+  SIMPITR = (unsigned char) pitr_tmp;
-	atexit (Clock_exit);
+  atexit (Clock_exit);
-  Name: Clock_initialize
-  Input parameters: major & minor numbers
-  Description: main entry for clock initialization
-	       calls the bsp dependant routine
 rtems_device_driver
 Clock_initialize(
-	rtems_device_major_number major,
-	rtems_device_minor_number minor,
-	void *pargp
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *pargp
-	Install_clock (Clock_isr);
-	 * make major/minor avail to others such as shared memory driver
-	rtems_clock_major = major;
-	rtems_clock_minor = minor;
+  Install_clock (Clock_isr);
-	return RTEMS_SUCCESSFUL;
+  return RTEMS_SUCCESSFUL;
1.9.3
