[PATCH 11/54] mvme147/clock/ckinit.c: Fix warnings
Mon Oct 13 15:36:55 UTC 2014
 c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c | 30 ++++++----------------------
 1 file changed, 6 insertions(+), 24 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c b/c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c
index bfbb6da..2dae3a7 100644
--- a/c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c
+++ b/c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c
@@ -1,12 +1,9 @@
-/*  Clock_init()
  *  This routine initializes the Tick Timer 2 on the MVME147 board.
  *  The tick frequency is 1 millisecond.
- *  Input parameters:  NONE
- *  Output parameters:  NONE
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
@@ -34,17 +31,9 @@ rtems_isr_entry  Old_ticker;
 void Clock_exit( void );
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
  *  ISR Handler
-rtems_isr Clock_isr(rtems_vector_number vector)
+static rtems_isr Clock_isr(rtems_vector_number vector)
   Clock_driver_ticks += 1;
   pcc->timer2_int_control |= 0x80; /* Acknowledge interr. */
@@ -57,7 +46,7 @@ rtems_isr Clock_isr(rtems_vector_number vector)
     Clock_isrs -= 1;
-void Install_clock(rtems_isr_entry clock_isr )
+static void Install_clock(rtems_isr_entry clock_isr )
   Clock_driver_ticks = 0;
@@ -88,12 +77,5 @@ rtems_device_driver Clock_initialize(
   Install_clock( Clock_isr );
-   * make major/minor avail to others such as shared memory driver
-  rtems_clock_major = major;
-  rtems_clock_minor = minor;
   return RTEMS_SUCCESSFUL;
1.9.3
