[PATCH 16/54] powerpc/haleakala: Fix warnings
Mon Oct 13 15:37:00 UTC 2014
 c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c     | 11 +++++++++--
 c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c | 16 +++++++---------
 2 files changed, 16 insertions(+), 11 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c b/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c
index 06942ff..4165df1 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/haleakala/irq/irq_init.c
@@ -36,8 +36,15 @@ static int not_connected(void)
 static rtems_irq_connect_data      rtemsIrq[BSP_IRQ_NUMBER];
 static rtems_irq_global_settings   initial_config;
 static rtems_irq_connect_data      defaultIrq = {
-  /* name,     hdl   , handle  , on       , off      , isOn */
-      0,    nop_func , NULL    , nop_func , nop_func , not_connected
+  .name   = 0,
+  .hdl    = NULL,
+  .handle = NULL,
+  .on     = (rtems_irq_enable) nop_func,
+  .off    = (rtems_irq_disable) nop_func,
+  .isOn   = (rtems_irq_is_enabled) not_connected,
+#ifdef BSP_SHARED_HANDLER_SUPPORT
+  .next_handler = NULL
+#endif
 static rtems_irq_prio irqPrioTable[BSP_IRQ_NUMBER]={
diff --git a/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c b/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
index 443e454..4159d48 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c
@@ -105,7 +105,7 @@ InitUARTClock(void)
   mtsdr(SDR0_UART0,reg);
-void GPIO_AlternateSelect(int bitnum, int source)
+static void GPIO_AlternateSelect(int bitnum, int source)
 /* PPC405EX: select a GPIO function for the specified pin */
   int shift;
@@ -124,7 +124,7 @@ void GPIO_AlternateSelect(int bitnum, int source)
-void Init_FPGA(void)
+static void Init_FPGA(void)
   /* Have to write to the FPGA to enable the UART drivers */
   /* Have to enable CS2 as an output in GPIO to get the FPGA working */
@@ -161,9 +161,6 @@ BSP_polling_getchar_function_type BSP_poll_char = NULL;
 void bsp_start( void )
-  ppc_cpu_id_t myCpu;
-  ppc_cpu_revision_t myCpuRevision;
   /* Get the UART clock initialized first in case we call printk */
   InitUARTClock();
@@ -175,8 +172,8 @@ void bsp_start( void )
    * function store the result in global variables
    * so that it can be used later...
-  myCpu       = get_ppc_cpu_type();
-  myCpuRevision = get_ppc_cpu_revision();
+  get_ppc_cpu_type();
+  get_ppc_cpu_revision();
    *  initialize the device driver parameters
@@ -205,7 +202,7 @@ void bsp_start( void )
   BSP_rtems_irq_mng_init(0);
-void BSP_ask_for_reset(void)
+static void BSP_ask_for_reset(void)
   printk("system stopped, press RESET");
   while(1) {};
@@ -219,6 +216,7 @@ void BSP_panic(char *s)
 void _BSP_Fatal_error(unsigned int v)
-  printk("%s PANIC ERROR %x\n",_RTEMS_version, v);
+  printk("%s FATAL ERROR %x\n",_RTEMS_version, v);
   BSP_ask_for_reset();
1.9.3
