[PATCH 23/54] sparc/erc32/clock/ckinit.c: Fix warnings
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Mon Oct 13 15:37:07 UTC 2014
 c/src/lib/libbsp/sparc/erc32/clock/ckinit.c | 9 ++++-----
 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
index 25504f1..2afe770 100644
--- a/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
+++ b/c/src/lib/libbsp/sparc/erc32/clock/ckinit.c
@@ -1,12 +1,12 @@
- *  Clock Tick Device Driver
  *  This routine initializes the Real Time Clock Counter Timer which is
  *  part of the MEC on the ERC32 CPU.
  *  The tick frequency is directly programmed to the configured number of
  *  microseconds per tick.
  *  COPYRIGHT (c) 1989-2008.
  *  On-Line Applications Research Corporation (OAR).
@@ -33,7 +33,6 @@
  *  The Real Time Clock Counter Timer uses this trap type.
 #define CLOCK_VECTOR ERC32_TRAP_TYPE( ERC32_INTERRUPT_REAL_TIME_CLOCK )
 #define Clock_driver_support_at_tick()
@@ -45,7 +44,7 @@
 extern int CLOCK_SPEED;
-uint32_t bsp_clock_nanoseconds_since_last_tick(void)
+static uint32_t bsp_clock_nanoseconds_since_last_tick(void)
   uint32_t clicks;
   uint32_t usecs;
1.9.3
