[PATCH 38/54] libcpu/arm/lpc22xx/clock/clockdrv.c: Fix warnings
Mon Oct 13 15:37:22 UTC 2014
 c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c | 11 ++++++-----
 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c b/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c
index 459041e..02f5b8c 100644
--- a/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c
+++ b/c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c
@@ -1,10 +1,11 @@
  *  LPC22XX/LPC21xx clock specific using the System Timer
- *  Copyright (c) 2006 by Ray <rayx.cn at gmail.com>
- *  Set the Time0 to generate click for RTEMS
- *  This is hardware specific part of the clock driver. At the end of this
- *  file, the generic part of the driver is #included.
+ *  Set the Time0 to generate click for RTEMS
+ *  Copyright (c) 2006 by Ray <rayx.cn at gmail.com>
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -103,7 +104,7 @@ rtems_irq_connect_data clock_isr_data = {
     BSP_remove_rtems_irq_handler(&clock_isr_data);                  \
   } while (0)
-uint32_t bsp_clock_nanoseconds_since_last_tick(void)
+static uint32_t bsp_clock_nanoseconds_since_last_tick(void)
   uint32_t clicks;
   uint32_t microseconds;
1.9.3
