[PATCH 41/54] libcpu/arm/s3c24xx/clock/clockdrv.c: Fix warnings
Mon Oct 13 15:37:25 UTC 2014
 c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c b/c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c
index 4a32db7..519d3f8 100644
--- a/c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c
+++ b/c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c
@@ -1,9 +1,8 @@
  *  S3C2400 clock specific using the System Timer
- *  This is hardware specific part of the clock driver. At the end of this
- *  file, the generic part of the driver is #included.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.org/license/LICENSE.
@@ -31,7 +30,7 @@ rtems_irq_connect_data clock_isr_data = {
  *  Return the nanoseconds since last tick
-uint32_t clock_driver_get_nanoseconds_since_last_tick(void)
+static uint32_t clock_driver_get_nanoseconds_since_last_tick(void)
   return 0;
@@ -129,6 +128,7 @@ static void clock_isr_off(const rtems_irq_connect_data *unused)
 static int clock_isr_is_on(const rtems_irq_connect_data *irq)
+  return 1;
 /* Make sure to include this, and only at the end of the file */
1.9.3
