[PATCH 49/54] score/cpu/m32c: Fix warnings
Mon Oct 13 15:37:33 UTC 2014
 cpukit/score/cpu/m32c/cpu_asm.c         | 7 ++++---
 cpukit/score/cpu/m32c/rtems/score/cpu.h | 2 +-
 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/cpu/m32c/cpu_asm.c b/cpukit/score/cpu/m32c/cpu_asm.c
index 9515264..f992c57 100644
--- a/cpukit/score/cpu/m32c/cpu_asm.c
+++ b/cpukit/score/cpu/m32c/cpu_asm.c
@@ -36,15 +36,16 @@
 #include <rtems/score/cpu.h>
+void _ISR_Handler(void);
 /*  void __ISR_Handler()
  *  This routine provides the RTEMS interrupt management.
- *  NO_CPU Specific Information:
+ *  M32C Specific Information:
- *  XXX document implementation including references if appropriate
+ *  Interrupts are not currently supported.
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index 011fe48..55e9853 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -842,7 +842,7 @@ void _CPU_Context_Initialize(
 void _CPU_Context_Restart_self(
   Context_Control  *the_context
+) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
  * @ingroup CPUContext
1.9.3
