MPC55xx Warning for Undefined Behavior
Peter Dufault dufault at hda.com
Mon Oct 13 19:56:37 UTC 2014
On Oct 13, 2014, at 15:22 , Peter Dufault <dufault at hda.com> wrote:
> This looks like an issue in the header.  I downloaded the MPC5674F Reference Manual and it does specify 479 interrupt request sources.  See table 9-2, INTC Memory Map
> Base + (0x0040–0x0219)  INTC_PSRn—INTC priority select registers 2 0–479
Last posting on this, because it's confused and I'll defer to someone with the hardware who can puzzle this out.
The Freescale manual is inconsistent - there isn't space for 479 (1-byte) registers in the specified memory range 0x0040 through 0x0219 that I am quoting above.  That amount allows for the 474 registers in the Freescale header file and not the 479 in the RTEMS header file. So if I had to guess I'd guess the RTEMS header is wrong because someone read the Freescale manual and saw it clearly say there are 479 registers.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
