[PATCH] rfs: fix pointer conversion warnings
Tue Oct 14 04:03:31 UTC 2014
On Mon, Oct 13, 2014 at 10:54 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On October 13, 2014 9:46:50 PM CDT, Gedare Bloom <gedare at rtems.org> wrote:
>> cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c | 4 ++--
>> 1 file changed, 2 insertions(+), 2 deletions(-)
>>diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
>>b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
>>index 28e4739..48a6737 100644
>>--- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
>>+++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
>>@@ -30,7 +30,7 @@ rtems_rfs_rtems_device_get_major_and_minor ( const
>>rtems_libio_t       *iop,
>>                                      rtems_device_minor_number *minor)
>>   *major = iop->data0;
>>-  *minor = (rtems_device_minor_number) iop->data1;
>>+  *minor = (rtems_device_minor_number)(uintptr_t) iop->data1;
> Isn't the minor always 32 bits? Could this shorten the value?
Maybe on a target where unsigned int is 16 bits, but void* is 32 bits?
 Somehow I don't think such a target exists.
>>@@ -77,7 +77,7 @@ rtems_rfs_rtems_device_open ( rtems_libio_t *iop,
>>   rtems_rfs_rtems_unlock (fs);
>>   iop->data0 = major;
>>-  iop->data1 = (void *) minor;
>>+  iop->data1 = (void *)(uintptr_t) minor;
> This seems OK if the data value goes in OK.
>> return rtems_deviceio_open (iop, pathname, oflag, mode, minor, major);
