Batch of Patches from Joel
Tue Oct 14 06:29:50 UTC 2014
On 13/10/14 17:48, Joel Sherrill wrote:
> On 10/13/2014 10:43 AM, Sebastian Huber wrote:
>> On 10/13/2014 05:18 PM, Joel Sherrill wrote:
>>> NOTE: For defaults for weak symbols, I am just adding
>>> a prototype to the C file.
>> How do you then ensure that a non-weak implementation has the same
>> signature?
> Don't ask me. I didn't add any of these weak symbol options to any BSP.
> I am only fixing warnings on existing code. :)
Adding a prototype for a global function to the C file doesn't fix the warning.
  It just silences the warning and obscures things.
> On a more serious note, I would assume that only the linker can ensure
> this. In ELF, I think it can match the signature. I have no idea if it
> does or
> not. Create a test case and if it doesn't do check the signature, post it
> as a question to binutils.
> I don't think we have anyway to ensure the match inside our space.
Weak implementations are nothing special.  We need a declaration in a header
file (without the weak attribute).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
