Batch of Patches from Joel
Tue Oct 14 20:28:30 UTC 2014
On 14/10/2014 11:24 pm, Joel Sherrill wrote:
> On October 14, 2014 1:29:50 AM CDT, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 13/10/14 17:48, Joel Sherrill wrote:
>>> On 10/13/2014 10:43 AM, Sebastian Huber wrote:
>>>> On 10/13/2014 05:18 PM, Joel Sherrill wrote:
>>>>> NOTE: For defaults for weak symbols, I am just adding
>>>>> a prototype to the C file.
>>>> How do you then ensure that a non-weak implementation has the same
>>>> signature?
>>> Don't ask me. I didn't add any of these weak symbol options to any
>> BSP.
>>> I am only fixing warnings on existing code. :)
>> Adding a prototype for a global function to the C file doesn't fix the
>> warning.
>>   It just silences the warning and obscures things.
> Every case I have seen so far is for bsp_start() to have a weak default version. There is a prototype for that in BSP/bootcard.h and the default version can be static.
> I have started making the week default static. I will sweep to ensure they all are but if someone beats me to it, I won't complain.
Weak and static ? If so it does not make any sense to me.
