[PATCH 4/4] h8300/h8sim: Exit simulator cleanly
Wed Oct 15 14:34:52 UTC 2014
 c/src/lib/libbsp/h8300/h8sim/Makefile.am   | 23 +++++++++++++++--------
 c/src/lib/libbsp/h8300/h8sim/configure.ac  |  2 +-
 c/src/lib/libbsp/h8300/h8sim/start/start.S |  6 ++++--
 3 files changed, 20 insertions(+), 11 deletions(-)
diff --git a/c/src/lib/libbsp/h8300/h8sim/Makefile.am b/c/src/lib/libbsp/h8300/h8sim/Makefile.am
index 19f473a..3d36374 100644
--- a/c/src/lib/libbsp/h8300/h8sim/Makefile.am
+++ b/c/src/lib/libbsp/h8300/h8sim/Makefile.am
@@ -26,17 +26,24 @@ noinst_LIBRARIES += libbsp.a
 libbsp_a_SOURCES =
 # startup
-libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
-    ../../shared/bsppredriverhook.c ../../shared/bsppretaskinghook.c \
-    ../../shared/bspgetworkarea.c ../../shared/bsppost.c \
-    ../../shared/bspstart.c startup/h8bdinstallirq.c \
-    ../../shared/bootcard.c ../../shared/sbrk.c \
-    ../../shared/gnatinstallhandler.c startup/__main.c
+libbsp_a_SOURCES += ../../shared/bspclean.c
+libbsp_a_SOURCES += ../../shared/bsplibc.c
+libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
+libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
+libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
+libbsp_a_SOURCES += ../../shared/bsppost.c
+libbsp_a_SOURCES += ../../shared/bspstart.c
+libbsp_a_SOURCES += startup/h8bdinstallirq.c
+libbsp_a_SOURCES += ../../shared/bootcard.c
+libbsp_a_SOURCES += ../../shared/sbrk.c
+libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
 # clock
 libbsp_a_SOURCES += ../../shared/clock_driver_simidle.c
 # console
-libbsp_a_SOURCES += ../../shared/console-polled.c console/console-io.c \
-   console/syscalls.S
+libbsp_a_SOURCES += ../../shared/console-polled.c
+libbsp_a_SOURCES += console/console-io.c
+libbsp_a_SOURCES += console/syscalls.S
 # timer
 libbsp_a_SOURCES += ../../shared/timerstub.c
diff --git a/c/src/lib/libbsp/h8300/h8sim/configure.ac b/c/src/lib/libbsp/h8300/h8sim/configure.ac
index ae26342..4675d02 100644
--- a/c/src/lib/libbsp/h8300/h8sim/configure.ac
+++ b/c/src/lib/libbsp/h8300/h8sim/configure.ac
@@ -13,7 +13,7 @@ RTEMS_PROG_CC_FOR_TARGET
 RTEMS_CANONICALIZE_TOOLS
 RTEMS_PROG_CCAS
-RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
+RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 0)
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile])
diff --git a/c/src/lib/libbsp/h8300/h8sim/start/start.S b/c/src/lib/libbsp/h8300/h8sim/start/start.S
index 87daeb8..ca0fba2 100644
--- a/c/src/lib/libbsp/h8300/h8sim/start/start.S
+++ b/c/src/lib/libbsp/h8300/h8sim/start/start.S
@@ -13,9 +13,10 @@ _start:
 	adds	#2,r0
 	cmp	r1,r0
 	blo	.loop
-        ;       call __main
 	mov.w	#0,r0		; pass in NULL
 	jsr	@_boot_card
+	.global	_bsp_reset
+_bsp_reset:
 	mov.w	#0,r0		; indicate reason to exit
 	sleep
 	jmp	@_start 	; restart
@@ -37,8 +38,9 @@ _start:
 	adds	#2,er0
 	cmp.l	er1,er0
 	blo	.loop
-        ;       call __main
 	jsr	@_boot_card
+_bsp_reset:
 	sleep
1.9.3
