[PATCH 01/62] arm/gp32/smc/smc.c: Fix warnings and clean up
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Oct 15 19:59:51 UTC 2014
c/src/lib/libbsp/arm/gp32/smc/smc.c | 606 +++++++++++++++++-------------------
1 file changed, 287 insertions(+), 319 deletions(-)
diff --git a/c/src/lib/libbsp/arm/gp32/smc/smc.c b/c/src/lib/libbsp/arm/gp32/smc/smc.c
index 9cf460b..425a1df 100644
--- a/c/src/lib/libbsp/arm/gp32/smc/smc.c
+++ b/c/src/lib/libbsp/arm/gp32/smc/smc.c
@@ -1,9 +1,10 @@
-/* smc.c -- s3c2400 smc disk block device implementation
- Squidge's SMC Low-level access routines.
- Inspired and derived from routines provided by Samsung Electronics M/M R&D Center & FireFly.
+ * s3c2400 smc disk block device implementation
+ * Squidge's SMC Low-level access routines.
+ * Inspired and derived from routines provided by Samsung Electronics
+ * M/M R&D Center & FireFly.
#include <rtems/libio.h>
@@ -20,37 +21,36 @@
#include <s3c24xx.h>
#define SMC_DEVICE_NAME "/dev/smc"
-#define SMC_SAMSUNG_ID 0xEC
-#define SMC_TOSHIBA_ID 0x98
+#define SMC_SAMSUNG_ID 0xEC
+#define SMC_TOSHIBA_ID 0x98
-#define SMC_16MB 0x73
-#define SMC_32MB 0x75
-#define SMC_64MB 0x76
-#define SMC_128MB 0x79
+#define SMC_16MB 0x73
+#define SMC_32MB 0x75
+#define SMC_64MB 0x76
+#define SMC_128MB 0x79
-#define LBA_UNUSED 0x80000000
-#define LBA_RESERVED 0x80000001
+#define LBA_UNUSED 0x80000000
+#define LBA_RESERVED 0x80000001
-#define BLOCK_UNUSED 0x80000000
-#define BLOCK_RESERVED 0x80000001
+#define BLOCK_UNUSED 0x80000000
+#define BLOCK_RESERVED 0x80000001
/* SmartMedia Command */
-#define SEQ_DATA_INPUT_CMD 0x80
-#define READ1_CMD 0x00
-#define READ1_1_CMD 0x01
-#define READ2_CMD 0x50
-#define READ_ID_CMD 0x90
-#define RESET_CMD 0xFF
-#define PAGE_PROGRAM_CMD 0x10
-#define BLOCK_ERASE_CMD 0x60
-#define BLOCK_ERASE_CFM_CMD 0xD0
-#define READ_STATUS_CMD 0x70
-#define RESET_PTR_CMD 0x00
+#define SEQ_DATA_INPUT_CMD 0x80
+#define READ1_CMD 0x00
+#define READ1_1_CMD 0x01
+#define READ2_CMD 0x50
+#define READ_ID_CMD 0x90
+#define RESET_CMD 0xFF
+#define PAGE_PROGRAM_CMD 0x10
+#define BLOCK_ERASE_CMD 0x60
+#define BLOCK_ERASE_CFM_CMD 0xD0
+#define READ_STATUS_CMD 0x70
+#define RESET_PTR_CMD 0x00
/* Internal SMC disk descriptor */
-struct SMC_INFO
+struct SMC_INFO {
uint8_t id[3];
uint32_t bytes_per_page;
uint32_t pages_per_block;
@@ -112,7 +112,7 @@ static uint8_t sm_read(void)
returns 1 on success, 0 on fail
#if UNUSED
-static uint8_t sm_status()
+static static uint8_t sm_status()
uint8_t status;
@@ -133,9 +133,8 @@ static uint8_t sm_status()
#endif
-void smc_read_id( uint8_t* buf, uint32_t length)
+static void smc_read_id( uint8_t* buf, uint32_t length)
uint32_t i;
sm_chip_en();
@@ -160,58 +159,57 @@ void smc_read_id( uint8_t* buf, uint32_t length)
/* read an entire logical page of 512 bytes.*/
-uint8_t smc_read_page (uint32_t lpage, uint8_t* buf)
+static uint8_t smc_read_page (uint32_t lpage, uint8_t* buf)
- uint32_t block, page, i;
- /* convert logical block to physical block
- and then convert into page suitable for read1 command...
- block = lpage >> 5;
- if (smc_l2p[block] < LBA_UNUSED) {
- page = smc_l2p[block] << 5;
- page += (lpage & 0x1F);
- else
- return 0;
- sm_chip_en();
- sm_cle_en();
- sm_write_en();
- sm_write(READ1_CMD);
- sm_write_dis();
- sm_cle_dis();
- sm_ale_en();
- sm_write_en();
- sm_write( 0x00);
- sm_write( (uint8_t)(page >> 0));
- sm_write( (uint8_t)(page >> 8));
- if (smc_info.mb >= 64) sm_write( (uint8_t)(page >> 16));
- sm_write_dis();
- sm_ale_dis();
- sm_busy();
- sm_read_en();
- for (i = 0; i < 512; i++)
- *buf = sm_read();
- buf++;
- sm_read_dis();
- sm_chip_dis();
- sm_busy();
- return 1;
+ uint32_t block, page, i;
+ /* convert logical block to physical block
+ and then convert into page suitable for read1 command...
+ block = lpage >> 5;
+ if (smc_l2p[block] < LBA_UNUSED) {
+ page = smc_l2p[block] << 5;
+ page += (lpage & 0x1F);
+ else
+ return 0;
+ sm_chip_en();
+ sm_cle_en();
+ sm_write_en();
+ sm_write(READ1_CMD);
+ sm_write_dis();
+ sm_cle_dis();
+ sm_ale_en();
+ sm_write_en();
+ sm_write( 0x00);
+ sm_write( (uint8_t)(page >> 0));
+ sm_write( (uint8_t)(page >> 8));
+ if (smc_info.mb >= 64)
+ sm_write( (uint8_t)(page >> 16));
+ sm_write_dis();
+ sm_ale_dis();
+ sm_busy();
+ sm_read_en();
+ for (i = 0; i < 512; i++) {
+ *buf = sm_read();
+ buf++;
+ sm_read_dis();
+ sm_chip_dis();
+ sm_busy();
+ return 1;
-void smc_read_spare( uint32_t page, uint8_t* buf, uint8_t length)
+static void smc_read_spare( uint32_t page, uint8_t* buf, uint8_t length)
uint32_t i;
sm_chip_en();
sm_cle_en();
@@ -225,21 +223,23 @@ void smc_read_spare( uint32_t page, uint8_t* buf, uint8_t length)
sm_write( 0x00);
sm_read_en();
sm_ale_dis();
sm_busy();
sm_read_en();
- for (i=0;i<length;i++) *(buf+i) = sm_read();
+ for (i=0;i<length;i++)
+ *(buf+i) = sm_read();
sm_read_dis();
sm_chip_dis();
-void smc_make_l2p(void)
+static void smc_make_l2p(void)
uint32_t pblock, i, j, lblock, zone, count, cnt1, cnt2, cnt3;
uint8_t data[512];
@@ -248,47 +248,39 @@ void smc_make_l2p(void)
cnt2 = 0;
cnt3 = 0;
- for (i=0;i<0x2000;i++)
+ for (i=0;i<0x2000;i++) {
smc_l2p[i] = LBA_RESERVED;
smc_p2l[i] = BLOCK_RESERVED;
- for (pblock=0;pblock<smc_info.blocks;pblock++)
+ for (pblock=0;pblock<smc_info.blocks;pblock++) {
/* read physical block - first page */
smc_read_spare( pblock*smc_info.pages_per_block, (uint8_t*)&data, 16);
zone = pblock >> 10; /* divide by 1024 to get zone */
- if ((data[5] == 0xFF) && ((data[6]&0xF8) == 0x10))
+ if ((data[5] == 0xFF) && ((data[6]&0xF8) == 0x10)) {
lblock = ((((data[6]<<8)|(data[7]<<0)) >> 1) & 0x03FF) + (zone * 1000);
smc_l2p[lblock] = pblock;
smc_p2l[pblock] = lblock;
cnt1++;
- else
+ } else {
count = 0;
- for (j=0;j<16;j++)
+ for (j=0;j<16;j++) {
if (data[j] == 0xFF) count++;
- if (count == 16)
- smc_p2l[pblock] = BLOCK_UNUSED;
- cnt2++;
- else
- smc_p2l[pblock] = BLOCK_RESERVED;
- cnt3++;
+ if (count == 16) {
+ smc_p2l[pblock] = BLOCK_UNUSED;
+ cnt2++;
+ } else {
+ smc_p2l[pblock] = BLOCK_RESERVED;
+ cnt3++;
-void smc_detect( uint8_t id1, uint8_t id2, uint8_t id3)
+static void smc_detect( uint8_t id1, uint8_t id2, uint8_t id3)
smc_info.id[0] = id1;
smc_info.id[1] = id2;
@@ -298,13 +290,10 @@ void smc_detect( uint8_t id1, uint8_t id2, uint8_t id3)
smc_info.pages_per_block = 0;
smc_info.blocks = 0;
- switch (id1)
+ switch (id1) {
case SMC_SAMSUNG_ID:
- case SMC_TOSHIBA_ID:
- switch (id2)
+ case SMC_TOSHIBA_ID: {
+ switch (id2) {
case SMC_16MB : smc_info.mb = 16; break;
case SMC_32MB : smc_info.mb = 32; break;
case SMC_64MB : smc_info.mb = 64; break;
@@ -314,8 +303,7 @@ void smc_detect( uint8_t id1, uint8_t id2, uint8_t id3)
- switch (smc_info.mb)
+ switch (smc_info.mb) {
case 16 : smc_info.bytes_per_page = 512; smc_info.pages_per_block = 32; smc_info.blocks = 0x0400; break;
case 32 : smc_info.bytes_per_page = 512; smc_info.pages_per_block = 32; smc_info.blocks = 0x0800; break;
case 64 : smc_info.bytes_per_page = 512; smc_info.pages_per_block = 32; smc_info.blocks = 0x1000; break;
@@ -323,220 +311,200 @@ void smc_detect( uint8_t id1, uint8_t id2, uint8_t id3)
-void smc_init( void)
+static void smc_init( void)
- unsigned char buf[32];
- int i;
- /* reset smc */
- sm_chip_en();
- sm_cle_en();
- sm_write_en();
- sm_write(0xFF);
- sm_write_dis();
- sm_cle_dis();
- for(i=0;i<10;i++);
- sm_busy();
- sm_chip_dis();
- smc_read_id (buf, 4);
- smc_detect (buf[0], buf[1], buf[2]);
- printk ("SMC: [%02X-%02X-%02X-%02X]\n", buf[0], buf[1], buf[2], buf[3]);
- printk ("SMC size: %dMB detected\n",smc_info.mb);
- smc_make_l2p();
+ unsigned char buf[32];
+ int i;
+ /* reset smc */
+ sm_chip_en();
+ sm_cle_en();
+ sm_write_en();
+ sm_write(0xFF);
+ sm_write_dis();
+ sm_cle_dis();
+ for(i=0;i<10;i++);
+ sm_busy();
+ sm_chip_dis();
+ smc_read_id (buf, 4);
+ smc_detect (buf[0], buf[1], buf[2]);
+ printk ("SMC: [%02X-%02X-%02X-%02X]\n", buf[0], buf[1], buf[2], buf[3]);
+ printk ("SMC size: %dMB detected\n",smc_info.mb);
+ smc_make_l2p();
* Function: sm_ECCEncode (completely ripped, unaltered, from the samsung routines)
* Remark:
- * - adopted from "ECC Algorithm for SmartMedia V3.0"
- * by Memory Product & Technology, Samsung Electronics Co. (ecc30.pdf)
+ * - adopted from "ECC Algorithm for SmartMedia V3.0"
+ * by Memory Product & Technology, Samsung Electronics Co. (ecc30.pdf)
int sm_ECCEncode(const uint8_t * p_buf, uint8_t * p_ecc)
- uint32_t i, j;
- uint8_t paritr[256], tmp = 0, tmp2 = 0;
- uint8_t data_table0[16] = { 0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0 };
- uint8_t data_table1[16] = { 1, 0, 0, 1, 0, 1, 1, 0, 0, 1, 1, 0, 1, 0, 0, 1 };
- uint8_t sum = 0, paritc = 0;
- uint8_t parit0c = 0, parit1c = 0, parit2c = 0, parit3c = 0;
- uint8_t parit4c = 0, parit5c = 0, parit6c = 0, parit7c = 0;
- uint8_t parit1_1, parit1_2, parit2_1, parit2_2, parit4_1, parit4_2;
- uint8_t parit8_1 = 0, parit8_2 = 0, parit16_1 = 0, parit16_2 = 0, parit32_1 = 0, parit32_2 = 0;
- uint8_t parit64_1 = 0, parit64_2 = 0, parit128_1 = 0, parit128_2 = 0, parit256_1 = 0, parit256_2 = 0;
- uint8_t parit512_1 = 0, parit512_2 = 0, parit1024_1 = 0, parit1024_2 = 0;
- uint8_t* paritr_ptr;
- paritr_ptr = paritr;
- for (i = 0; i < 256; ++i, ++paritr_ptr, ++p_buf)
- paritc ^= *p_buf;
- tmp = (*p_buf & 0xf0) >> 4;
- tmp2 = *p_buf & 0x0f;
- switch (tmp)
- case 0:
- case 3:
- case 5:
- case 6:
- case 9:
- case 10:
- case 12:
- case 15:
- *paritr_ptr = *(data_table0 + tmp2);
- break;
- case 1:
- case 2:
- case 4:
- case 7:
- case 8:
- case 11:
- case 13:
- case 14:
- *paritr_ptr = *(data_table1 + tmp2);
- break;
- parit0c = (paritc & 0x01) ? 1 : 0;
- parit1c = (paritc & 0x02) ? 1 : 0;
- parit2c = (paritc & 0x04) ? 1 : 0;
- parit3c = (paritc & 0x08) ? 1 : 0;
- parit4c = (paritc & 0x10) ? 1 : 0;
- parit5c = (paritc & 0x20) ? 1 : 0;
- parit6c = (paritc & 0x40) ? 1 : 0;
- parit7c = (paritc & 0x80) ? 1 : 0;
- parit1_2 = parit6c ^ parit4c ^ parit2c ^ parit0c;
- parit1_1 = parit7c ^ parit5c ^ parit3c ^ parit1c;
- parit2_2 = parit5c ^ parit4c ^ parit1c ^ parit0c;
- parit2_1 = parit7c ^ parit6c ^ parit3c ^ parit2c;
- parit4_2 = parit3c ^ parit2c ^ parit1c ^ parit0c;
- parit4_1 = parit7c ^ parit6c ^ parit5c ^ parit4c;
- for (i = 0; i < 256; ++i, ++paritr_ptr)
- sum ^= *paritr_ptr;
- for (i = 0; i < 256; i += 2, paritr_ptr += 2)
- parit8_2 ^= *paritr_ptr;
- for (i = 0; i < 256; i += 4, paritr_ptr += 4)
- parit16_2 ^= *paritr_ptr;
- parit16_2 ^= *(paritr_ptr + 1);
- for (i = 0; i < 256; i += 8, paritr_ptr += 8)
- for (j = 0; j <= 3; ++j)
- parit32_2 ^= *(paritr_ptr + j);
- for (i = 0; i < 256; i += 16, paritr_ptr += 16)
- for (j = 0; j <= 7; ++j)
- parit64_2 ^= *(paritr_ptr + j);
- for (i = 0; i < 256; i += 32, paritr_ptr += 32)
- for (j = 0; j <= 15; ++j)
- parit128_2 ^= *(paritr_ptr + j);
- for (i = 0; i < 256; i += 64, paritr_ptr += 64)
- for (j = 0; j <= 31; ++j)
- parit256_2 ^= *(paritr_ptr + j);
- for (i = 0; i < 256; i += 128, paritr_ptr += 128)
- for (j = 0; j <= 63; ++j)
- parit512_2 ^= *(paritr_ptr + j);
- for (i = 0; i < 256; i += 256, paritr_ptr += 256)
- for (j = 0; j <= 127; ++j)
- parit1024_2 ^= *(paritr_ptr + j);
- if (sum==0)
- parit1024_1 = parit1024_2;
- parit512_1 = parit512_2;
- parit256_1 = parit256_2;
- parit128_1 = parit128_2;
- parit64_1 = parit64_2;
- parit32_1 = parit32_2;
- parit16_1 = parit16_2;
- parit8_1 = parit8_2;
- else
- parit1024_1 = parit1024_2 ? 0 : 1;
- parit512_1 = parit512_2 ? 0 : 1;
- parit256_1 = parit256_2 ? 0 : 1;
- parit128_1 = parit128_2 ? 0 : 1;
- parit64_1 = parit64_2 ? 0 : 1;
- parit32_1 = parit32_2 ? 0 : 1;
- parit16_1 = parit16_2 ? 0 : 1;
- parit8_1 = parit8_2 ? 0 : 1;
- parit1_2 <<= 2;
- parit1_1 <<= 3;
- parit2_2 <<= 4;
- parit2_1 <<= 5;
- parit4_2 <<= 6;
- parit4_1 <<= 7;
- parit128_1 <<= 1;
- parit256_2 <<= 2;
- parit256_1 <<= 3;
- parit512_2 <<= 4;
- parit512_1 <<= 5;
- parit1024_2 <<= 6;
- parit1024_1 <<= 7;
- parit8_1 <<= 1;
- parit16_2 <<= 2;
- parit16_1 <<= 3;
- parit32_2 <<= 4;
- parit32_1 <<= 5;
- parit64_2 <<= 6;
- parit64_1 <<= 7;
- p_ecc[0] = ~(parit64_1 | parit64_2 | parit32_1 | parit32_2 | parit16_1 | parit16_2 | parit8_1 | parit8_2);
- p_ecc[1] = ~(parit1024_1 |parit1024_2 | parit512_1 | parit512_2 | parit256_1 | parit256_2 | parit128_1 | parit128_2);
- p_ecc[2] = ~(parit4_1 | parit4_2 | parit2_1 | parit2_2 | parit1_1 | parit1_2);
- return 0;
+ uint32_t i, j;
+ uint8_t paritr[256], tmp = 0, tmp2 = 0;
+ uint8_t data_table0[16] = { 0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0 };
+ uint8_t data_table1[16] = { 1, 0, 0, 1, 0, 1, 1, 0, 0, 1, 1, 0, 1, 0, 0, 1 };
+ uint8_t sum = 0, paritc = 0;
+ uint8_t parit0c = 0, parit1c = 0, parit2c = 0, parit3c = 0;
+ uint8_t parit4c = 0, parit5c = 0, parit6c = 0, parit7c = 0;
+ uint8_t parit1_1, parit1_2, parit2_1, parit2_2, parit4_1, parit4_2;
+ uint8_t parit8_1 = 0, parit8_2 = 0, parit16_1 = 0, parit16_2 = 0, parit32_1 = 0, parit32_2 = 0;
+ uint8_t parit64_1 = 0, parit64_2 = 0, parit128_1 = 0, parit128_2 = 0, parit256_1 = 0, parit256_2 = 0;
+ uint8_t parit512_1 = 0, parit512_2 = 0, parit1024_1 = 0, parit1024_2 = 0;
+ uint8_t* paritr_ptr;
+ paritr_ptr = paritr;
+ for (i = 0; i < 256; ++i, ++paritr_ptr, ++p_buf) {
+ paritc ^= *p_buf;
+ tmp = (*p_buf & 0xf0) >> 4;
+ tmp2 = *p_buf & 0x0f;
+ switch (tmp) {
+ case 0:
+ case 3:
+ case 5:
+ case 6:
+ case 9:
+ case 10:
+ case 12:
+ case 15:
+ *paritr_ptr = *(data_table0 + tmp2);
+ break;
+ case 1:
+ case 2:
+ case 4:
+ case 7:
+ case 8:
+ case 11:
+ case 13:
+ case 14:
+ *paritr_ptr = *(data_table1 + tmp2);
+ break;
+ parit0c = (paritc & 0x01) ? 1 : 0;
+ parit1c = (paritc & 0x02) ? 1 : 0;
+ parit2c = (paritc & 0x04) ? 1 : 0;
+ parit3c = (paritc & 0x08) ? 1 : 0;
+ parit4c = (paritc & 0x10) ? 1 : 0;
+ parit5c = (paritc & 0x20) ? 1 : 0;
+ parit6c = (paritc & 0x40) ? 1 : 0;
+ parit7c = (paritc & 0x80) ? 1 : 0;
+ parit1_2 = parit6c ^ parit4c ^ parit2c ^ parit0c;
+ parit1_1 = parit7c ^ parit5c ^ parit3c ^ parit1c;
+ parit2_2 = parit5c ^ parit4c ^ parit1c ^ parit0c;
+ parit2_1 = parit7c ^ parit6c ^ parit3c ^ parit2c;
+ parit4_2 = parit3c ^ parit2c ^ parit1c ^ parit0c;
+ parit4_1 = parit7c ^ parit6c ^ parit5c ^ parit4c;
+ for (i = 0; i < 256; ++i, ++paritr_ptr) {
+ sum ^= *paritr_ptr;
+ for (i = 0; i < 256; i += 2, paritr_ptr += 2) {
+ parit8_2 ^= *paritr_ptr;
+ for (i = 0; i < 256; i += 4, paritr_ptr += 4) {
+ parit16_2 ^= *paritr_ptr;
+ parit16_2 ^= *(paritr_ptr + 1);
+ for (i = 0; i < 256; i += 8, paritr_ptr += 8) {
+ for (j = 0; j <= 3; ++j) {
+ parit32_2 ^= *(paritr_ptr + j);
+ for (i = 0; i < 256; i += 16, paritr_ptr += 16) {
+ for (j = 0; j <= 7; ++j) {
+ parit64_2 ^= *(paritr_ptr + j);
+ for (i = 0; i < 256; i += 32, paritr_ptr += 32) {
+ for (j = 0; j <= 15; ++j) {
+ parit128_2 ^= *(paritr_ptr + j);
+ for (i = 0; i < 256; i += 64, paritr_ptr += 64) {
+ for (j = 0; j <= 31; ++j) {
+ parit256_2 ^= *(paritr_ptr + j);
+ for (i = 0; i < 256; i += 128, paritr_ptr += 128) {
+ for (j = 0; j <= 63; ++j) {
+ parit512_2 ^= *(paritr_ptr + j);
+ for (i = 0; i < 256; i += 256, paritr_ptr += 256) {
+ for (j = 0; j <= 127; ++j) {
+ parit1024_2 ^= *(paritr_ptr + j);
+ if (sum==0) {
+ parit1024_1 = parit1024_2;
+ parit512_1 = parit512_2;
+ parit256_1 = parit256_2;
+ parit128_1 = parit128_2;
+ parit64_1 = parit64_2;
+ parit32_1 = parit32_2;
+ parit16_1 = parit16_2;
+ parit8_1 = parit8_2;
+ } else {
+ parit1024_1 = parit1024_2 ? 0 : 1;
+ parit512_1 = parit512_2 ? 0 : 1;
+ parit256_1 = parit256_2 ? 0 : 1;
+ parit128_1 = parit128_2 ? 0 : 1;
+ parit64_1 = parit64_2 ? 0 : 1;
+ parit32_1 = parit32_2 ? 0 : 1;
+ parit16_1 = parit16_2 ? 0 : 1;
+ parit8_1 = parit8_2 ? 0 : 1;
+ parit1_2 <<= 2;
+ parit1_1 <<= 3;
+ parit2_2 <<= 4;
+ parit2_1 <<= 5;
+ parit4_2 <<= 6;
+ parit4_1 <<= 7;
+ parit128_1 <<= 1;
+ parit256_2 <<= 2;
+ parit256_1 <<= 3;
+ parit512_2 <<= 4;
+ parit512_1 <<= 5;
+ parit1024_2 <<= 6;
+ parit1024_1 <<= 7;
+ parit8_1 <<= 1;
+ parit16_2 <<= 2;
+ parit16_1 <<= 3;
+ parit32_2 <<= 4;
+ parit32_1 <<= 5;
+ parit64_2 <<= 6;
+ parit64_1 <<= 7;
+ p_ecc[0] = ~(parit64_1 | parit64_2 | parit32_1 | parit32_2 | parit16_1 | parit16_2 | parit8_1 | parit8_2);
+ p_ecc[1] = ~(parit1024_1 |parit1024_2 | parit512_1 | parit512_2 | parit256_1 | parit256_2 | parit128_1 | parit128_2);
+ p_ecc[2] = ~(parit4_1 | parit4_2 | parit2_1 | parit2_2 | parit1_1 | parit1_2);
+ return 0;
/* smc_write --
@@ -544,8 +512,8 @@ int sm_ECCEncode(const uint8_t * p_buf, uint8_t * p_ecc)
static int smc_write(rtems_blkdev_request *req)
- rtems_blkdev_request_done(req, RTEMS_SUCCESSFUL);
- return 0;
+ rtems_blkdev_request_done(req, RTEMS_SUCCESSFUL);
+ return 0;
@@ -570,7 +538,7 @@ smc_read(rtems_blkdev_request *req)
int count = sg->length;
if (count > remains)
count = remains;
- smc_read_page(sg->block,sg->buffer);
+ smc_read_page(sg->block,sg->buffer);
remains -= count;
@@ -601,7 +569,7 @@ smc_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
case RTEMS_BLKDEV_REQ_READ:
return smc_read(r);
case RTEMS_BLKDEV_REQ_WRITE:
- return smc_write(r);
+ return smc_write(r);
default:
errno = EINVAL;
return -1;
1.9.3
