[PATCH 15/62] mbx8xx/startup/bspstart.c: Remove myCpu variables and clean up
Wed Oct 15 20:00:05 UTC 2014
 c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c | 12 +++++-------
 1 file changed, 5 insertions(+), 7 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c
index b67f0b9..9b63afb 100644
--- a/c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c
@@ -82,15 +82,13 @@ void _BSP_Fatal_error(unsigned int v)
 void bsp_start(void)
-  ppc_cpu_id_t myCpu;
-  ppc_cpu_revision_t myCpuRevision;
-   * Get CPU identification dynamically. Note that the get_ppc_cpu_type() function
-   * store the result in global variables so that it can be used latter...
+   * Get CPU identification dynamically. Note that the get_ppc_cpu_type()
+   * function stores the result in global variables so that it can be used
+   * later...
-  myCpu 	= get_ppc_cpu_type();
-  myCpuRevision = get_ppc_cpu_revision();
+  get_ppc_cpu_type();
+  get_ppc_cpu_revision();
   mmu_init();
1.9.3
