[PATCH 30/62] libcpu/i388: Fix warning i displayCpu.c
Wed Oct 15 20:00:20 UTC 2014
 c/src/lib/libcpu/i386/cpuModel.h   | 10 ++++++----
 c/src/lib/libcpu/i386/displayCpu.c |  7 ++++---
 2 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/c/src/lib/libcpu/i386/cpuModel.h b/c/src/lib/libcpu/i386/cpuModel.h
index 277edef..d17839b 100644
--- a/c/src/lib/libcpu/i386/cpuModel.h
+++ b/c/src/lib/libcpu/i386/cpuModel.h
@@ -1,9 +1,10 @@
-/*  cpuModel.h
  *  This file contains declaration for variables and code
  *  that may be used to get the Intel Cpu identification
  *  that has been performed by checkCPUtypeSetCr0 function.
  *  COPYRIGHT (c) 1998 valette at crf.canon.fr
  *  The license and distribution terms for this file may be
@@ -30,7 +31,8 @@ extern char x86_vendor_id[13];
 extern int have_cpuid;
 extern unsigned char Cx86_step; /* cyrix processor identification */
-extern void printCpuInfo(); /* Display this information on console in ascii form */
+/* Display this information on console in ascii form */
+extern void printCpuInfo(void);
 /* determine if the CPU has a TSC */
 #define x86_has_tsc() \
diff --git a/c/src/lib/libcpu/i386/displayCpu.c b/c/src/lib/libcpu/i386/displayCpu.c
index d784ae2..f8ab3b3 100644
--- a/c/src/lib/libcpu/i386/displayCpu.c
+++ b/c/src/lib/libcpu/i386/displayCpu.c
@@ -1,8 +1,9 @@
-/*  displayCpu.c
  *  This file contains code for displaying the Intel Cpu identification
  *  This file was updated by Joel Sherrill <joel.sherrill at oarcorp.com>
  *  to define more capability bits, pick up more CPU model information,
  *  and add more model strings. --joel (April 2010)
1.9.3
