[PATCH 35/62] mcf5282: Move cache to libcpu and update av5282 and uC5282 BSPs
Wed Oct 15 20:00:25 UTC 2014
 c/src/lib/libbsp/m68k/av5282/Makefile.am        |   1 +
 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c | 118 +++------------------
 c/src/lib/libbsp/m68k/uC5282/Makefile.am        |   1 +
 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c | 130 ++++--------------------
 c/src/lib/libcpu/m68k/Makefile.am               |   5 +
 c/src/lib/libcpu/m68k/mcf5282/cache/cachepd.c   | 123 ++++++++++++++++++++++
 c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h |   6 ++
 7 files changed, 170 insertions(+), 214 deletions(-)
 create mode 100644 c/src/lib/libcpu/m68k/mcf5282/cache/cachepd.c
diff --git a/c/src/lib/libbsp/m68k/av5282/Makefile.am b/c/src/lib/libbsp/m68k/av5282/Makefile.am
index 3c37eda..29993f0 100644
--- a/c/src/lib/libbsp/m68k/av5282/Makefile.am
+++ b/c/src/lib/libbsp/m68k/av5282/Makefile.am
@@ -50,6 +50,7 @@ endif
 libbsp_a_LIBADD = \
     ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
+    ../../../libcpu/@RTEMS_CPU@/mcf5282/cachepd.rel \
     ../../../libcpu/@RTEMS_CPU@/shared/misc.rel
 if HAS_NETWORKING
 libbsp_a_LIBADD += network.rel
diff --git a/c/src/lib/libbsp/m68k/av5282/startup/bspstart.c b/c/src/lib/libbsp/m68k/av5282/startup/bspstart.c
index e85ea4c..c2dd362 100644
--- a/c/src/lib/libbsp/m68k/av5282/startup/bspstart.c
+++ b/c/src/lib/libbsp/m68k/av5282/startup/bspstart.c
@@ -27,106 +27,6 @@
 #define FLASH_BASE      0xFF800000
 #define FLASH_SIZE      (8*1024*1024)
- * CPU-space access
-#define m68k_set_acr0(_acr0) __asm__ volatile ("movec %0,%%acr0" : : "d" (_acr0))
-#define m68k_set_acr1(_acr1) __asm__ volatile ("movec %0,%%acr1" : : "d" (_acr1))
- * Read/write copy of common cache
- *   Split I/D cache
- *   Allow CPUSHL to invalidate a cache line
- *   Enable buffered writes
- *   No burst transfers on non-cacheable accesses
- *   Default cache mode is *disabled* (cache only ACRx areas)
-static uint32_t cacr_mode = MCF5XXX_CACR_CENB |
-                              MCF5XXX_CACR_DBWE |
-                              MCF5XXX_CACR_DCM;
- * Cannot be frozen
-void _CPU_cache_freeze_data(void) {}
-void _CPU_cache_unfreeze_data(void) {}
-void _CPU_cache_freeze_instruction(void) {}
-void _CPU_cache_unfreeze_instruction(void) {}
- * Write-through data cache -- flushes are unnecessary
-void _CPU_cache_flush_1_data_line(const void *d_addr) {}
-void _CPU_cache_flush_entire_data(void) {}
-void _CPU_cache_enable_instruction(void)
-    rtems_interrupt_level level;
-    rtems_interrupt_disable(level);
-    cacr_mode &= ~MCF5XXX_CACR_DIDI;
-    m68k_set_cacr(cacr_mode);
-    rtems_interrupt_enable(level);
-void _CPU_cache_disable_instruction(void)
-    cacr_mode |= MCF5XXX_CACR_DIDI;
-void _CPU_cache_invalidate_entire_instruction(void)
-    m68k_set_cacr(cacr_mode | MCF5XXX_CACR_CINV | MCF5XXX_CACR_INVI);
-void _CPU_cache_invalidate_1_instruction_line(const void *addr)
-     * Top half of cache is I-space
-    addr = (void *)((int)addr | 0x400);
-    __asm__ volatile ("cpushl %%bc,(%0)" :: "a" (addr));
-void _CPU_cache_enable_data(void)
-    cacr_mode &= ~MCF5XXX_CACR_DISD;
-void _CPU_cache_disable_data(void)
-    cacr_mode |= MCF5XXX_CACR_DISD;
-void _CPU_cache_invalidate_entire_data(void)
-    m68k_set_cacr(cacr_mode | MCF5XXX_CACR_CINV | MCF5XXX_CACR_INVD);
-void _CPU_cache_invalidate_1_data_line(const void *addr)
-     * Bottom half of cache is D-space
-    addr = (void *)((int)addr & ~0x400);
 void bsp_start( void )
@@ -139,16 +39,22 @@ void bsp_start( void )
    * Cache SDRAM and FLASH
-  m68k_set_acr0(MCF5XXX_ACR_AB(SDRAM_BASE)    |
-                MCF5XXX_ACR_AM(SDRAM_SIZE-1)  |
-                MCF5XXX_ACR_EN                |
-                MCF5XXX_ACR_BWE               |
-                MCF5XXX_ACR_SM_IGNORE);
+  m68k_set_acr0(
+    MCF5XXX_ACR_AB(SDRAM_BASE)    |
+    MCF5XXX_ACR_AM(SDRAM_SIZE-1)  |
+    MCF5XXX_ACR_EN                |
+    MCF5XXX_ACR_BWE               |
+    MCF5XXX_ACR_SM_IGNORE
    * Enable the cache
+  mcf5xxx_initialize_cacr(
+    MCF5XXX_CACR_CENB |
+    MCF5XXX_CACR_DBWE |
+    MCF5XXX_CACR_DCM
 extern char _CPUClockSpeed[];
diff --git a/c/src/lib/libbsp/m68k/uC5282/Makefile.am b/c/src/lib/libbsp/m68k/uC5282/Makefile.am
index 6fe5787..a77785b 100644
--- a/c/src/lib/libbsp/m68k/uC5282/Makefile.am
+++ b/c/src/lib/libbsp/m68k/uC5282/Makefile.am
@@ -48,6 +48,7 @@ network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 endif
 libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
 if HAS_NETWORKING
diff --git a/c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c b/c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c
index 791913d..61444d7 100644
--- a/c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c
+++ b/c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c
@@ -36,6 +36,7 @@ extern char _PLLRefClockSpeed[];
 uint32_t BSP_sys_clk_speed = (uint32_t)_CPUClockSpeed;
 uint32_t BSP_pll_ref_clock = (uint32_t)_PLLRefClockSpeed;
  * CPU-space access
  * The NOP after writing the CACR is there to address the following issue as
@@ -76,115 +77,17 @@ uint32_t BSP_pll_ref_clock = (uint32_t)_PLLRefClockSpeed;
  *               ACRn[5] = BUFW (buffered write enable) must be 0
  *   Fix plan: Currently, there are no plans to fix this.
-#define m68k_set_cacr_nop(_cacr) __asm__ volatile ("movec %0,%%cacr\n\tnop" : : "d" (_cacr))
-#define m68k_set_cacr(_cacr) __asm__ volatile ("movec %0,%%cacr" : : "d" (_cacr))
+#define m68k_set_cacr_nop(_cacr) \
+  __asm__ volatile ("movec %0,%%cacr\n\tnop" : : "d" (_cacr))
+#define m68k_set_cacr(_cacr) \
+  __asm__ volatile ("movec %0,%%cacr" : : "d" (_cacr))
+#define m68k_set_acr0(_acr0) \
+  __asm__ volatile ("movec %0,%%acr0" : : "d" (_acr0))
+#define m68k_set_acr1(_acr1) \
+  __asm__ volatile ("movec %0,%%acr1" : : "d" (_acr1))
- * Read/write copy of cache registers
- *   Split instruction/data or instruction-only
- *   Disable buffered writes
-uint32_t mcf5282_cacr_mode = MCF5XXX_CACR_CENB |
-#ifndef RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
-                             MCF5XXX_CACR_DISD |
-#endif
-                             MCF5XXX_CACR_DCM;
 uint32_t mcf5282_acr0_mode = 0;
 uint32_t mcf5282_acr1_mode = 0;
-    mcf5282_cacr_mode &= ~MCF5XXX_CACR_DIDI;
-    m68k_set_cacr_nop(mcf5282_cacr_mode | MCF5XXX_CACR_CINV | MCF5XXX_CACR_INVI);
-    mcf5282_cacr_mode |= MCF5XXX_CACR_DIDI;
-    m68k_set_cacr(mcf5282_cacr_mode);
-#ifdef RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
-    mcf5282_cacr_mode &= ~MCF5XXX_CACR_DISD;
-    m68k_set_cacr_nop(mcf5282_cacr_mode | MCF5XXX_CACR_CINV | MCF5XXX_CACR_INVD);
-#endif
-    mcf5282_cacr_mode |= MCF5XXX_CACR_DISD;
-#endif
-#endif
-#endif
 extern void bsp_fake_syscall(int);
@@ -280,9 +183,20 @@ void bsp_start( void )
     *((void (**)(int))((32+2) * 4)) = bsp_fake_syscall;
-   * Enable the cache
+   * Read/write copy of cache registers
+   *   Split instruction/data or instruction-only
+   *   Allow CPUSHL to invalidate a cache line
+   *   Disable buffered writes
+   *   No burst transfers on non-cacheable accesses
+   *   Default cache mode is *disabled* (cache only ACRx areas)
+     #ifndef RTEMS_MCF5282_BSP_ENABLE_DATA_CACHE
+       MCF5XXX_CACR_DISD |
+     #endif
+     MCF5XXX_CACR_DCM
    * Set up CS* space (fake 'VME')
diff --git a/c/src/lib/libcpu/m68k/Makefile.am b/c/src/lib/libcpu/m68k/Makefile.am
index 2c46834..19f500f 100644
--- a/c/src/lib/libcpu/m68k/Makefile.am
+++ b/c/src/lib/libcpu/m68k/Makefile.am
@@ -176,6 +176,11 @@ if mcf5282
 ## mcf5282/include
 include_mcf5282dir = $(includedir)/mcf5282
 include_mcf5282_HEADERS = mcf5282/include/mcf5282.h
+noinst_PROGRAMS += mcf5282/cachepd.rel
+mcf5282_cachepd_rel_SOURCES = mcf5282/cache/cachepd.c
+mcf5282_cachepd_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/cache
+mcf5282_cachepd_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 endif
 if mcf548x
diff --git a/c/src/lib/libcpu/m68k/mcf5282/cache/cachepd.c b/c/src/lib/libcpu/m68k/mcf5282/cache/cachepd.c
new file mode 100644
index 0000000..709a3de
--- /dev/null
+++ b/c/src/lib/libcpu/m68k/mcf5282/cache/cachepd.c
@@ -0,0 +1,123 @@
+ *  @file
+ *  Cache Management Support Routines for the MCF5282
+#include <rtems.h>
+#include <mcf5282/mcf5282.h>   /* internal MCF5282 modules */
+#include "cache_.h"
+ * CPU-space access
+#define NOP __asm__ volatile ("nop");
+ * DEFAULT WHEN mcf5xxx_initialize_cacr not called
+ *   Read/write copy of common cache
+ *   Split I/D cache
+ *   Enable buffered writes
+static uint32_t cacr_mode = MCF5XXX_CACR_CENB |
+                            MCF5XXX_CACR_DCM;
+void mcf5xxx_initialize_cacr(uint32_t cacr)
+  cacr_mode = cacr;
+  m68k_set_cacr( cacr_mode );
+ * Cannot be frozen
+void _CPU_cache_freeze_data(void) {}
+void _CPU_cache_unfreeze_data(void) {}
+void _CPU_cache_freeze_instruction(void) {}
+void _CPU_cache_unfreeze_instruction(void) {}
+ * Write-through data cache -- flushes are unnecessary
+void _CPU_cache_flush_1_data_line(const void *d_addr) {}
+void _CPU_cache_flush_entire_data(void) {}
+void _CPU_cache_enable_instruction(void)
+  rtems_interrupt_level level;
+  rtems_interrupt_disable(level);
+    cacr_mode &= ~MCF5XXX_CACR_DIDI;
+    m68k_set_cacr(cacr_mode | MCF5XXX_CACR_CINV | MCF5XXX_CACR_INVI );
+    NOP;
+  rtems_interrupt_enable(level);
+void _CPU_cache_disable_instruction(void)
+    cacr_mode |= MCF5XXX_CACR_DIDI;
+    m68k_set_cacr(cacr_mode);
+void _CPU_cache_invalidate_entire_instruction(void)
+  m68k_set_cacr(cacr_mode | MCF5XXX_CACR_CINV | MCF5XXX_CACR_INVI);
+  NOP;
+void _CPU_cache_invalidate_1_instruction_line(const void *addr)
+   * Top half of cache is I-space
+  addr = (void *)((int)addr | 0x400);
+  __asm__ volatile ("cpushl %%bc,(%0)" :: "a" (addr));
+void _CPU_cache_enable_data(void)
+    cacr_mode &= ~MCF5XXX_CACR_DISD;
+    m68k_set_cacr(cacr_mode | MCF5XXX_CACR_CINV | MCF5XXX_CACR_INVD);
+void _CPU_cache_disable_data(void)
+    cacr_mode |= MCF5XXX_CACR_DISD;
+void _CPU_cache_invalidate_entire_data(void)
+void _CPU_cache_invalidate_1_data_line(const void *addr)
+   * Bottom half of cache is D-space
+  addr = (void *)((int)addr & ~0x400);
diff --git a/c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h b/c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h
index afe444c..3724f48 100644
--- a/c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h
+++ b/c/src/lib/libcpu/m68k/mcf5282/include/mcf5282.h
@@ -73,6 +73,12 @@ typedef volatile uint32		vuint32 __attribute__((__may_alias__)); /* 32 bits */
 #define MCF5XXX_SR_V		(0x0002)
 #define MCF5XXX_SR_C		(0x0001)
+ * Used to set the initialize the cacr register to the BSP's desired
+ * starting value.
+void mcf5xxx_initialize_cacr(uint32_t);
 #define MCF5XXX_CACR_CENB		(0x80000000)
 #define MCF5XXX_CACR_CPDI		(0x10000000)
 #define MCF5XXX_CACR_CPD		(0x10000000)
1.9.3
