[PATCH 43/62] c/src/lib/libbsp/arm/rtl22xx/console/uart.c
Wed Oct 15 20:00:33 UTC 2014
 c/src/lib/libbsp/arm/rtl22xx/console/uart.c     | 372 +++++++++++-------------
 c/src/lib/libbsp/arm/rtl22xx/include/bsp.h      |   5 +
 c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c |   7 -
 3 files changed, 167 insertions(+), 217 deletions(-)
diff --git a/c/src/lib/libbsp/arm/rtl22xx/console/uart.c b/c/src/lib/libbsp/arm/rtl22xx/console/uart.c
index fed3e37..91f7f32 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/console/uart.c
+++ b/c/src/lib/libbsp/arm/rtl22xx/console/uart.c
@@ -1,20 +1,19 @@
  *  console driver for RTL22xx UARTs
- *  This driver uses the shared console driver in
- *  ...../libbsp/shared/console.c
  *  If you want the driver to be interrupt driven, you
  *  need to write the ISR, and in the ISR insert the
  *  chars into termios's queue.
  *  Copyright (c) By ray <rayx.cn at gmail.com>
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.org/license/LICENSE.
 #include <bsp.h>                /* Must be before libio.h */
 #include <rtems/libio.h>
 #include <termios.h>
@@ -30,8 +29,6 @@
 /* How many serial ports? */
 #define NUM_DEVS       1
-int     uart_poll_read(int minor);
 int dbg_dly;
 /* static function prototypes */
@@ -47,17 +44,16 @@ static int     uart_set_attributes(int minor, const struct termios *t);
 unsigned long Console_Configuration_Count = NUM_DEVS;
 /* Pointers to functions for handling the UART. */
-const console_fns uart_fns =
-    libchip_serial_default_probe,
-    uart_first_open,
-    uart_last_close,
-    uart_read,
-    uart_write,
-    uart_init,
-    uart_write_polled,   /* not used in this driver */
-    uart_set_attributes,
-    FALSE      /* TRUE if interrupt driven, FALSE if not. */
+const console_fns uart_fns = {
+  libchip_serial_default_probe,
+  uart_first_open,
+  uart_last_close,
+  uart_read,
+  uart_write,
+  uart_init,
+  uart_write_polled,   /* not used in this driver */
+  uart_set_attributes,
+  FALSE                /* TRUE if interrupt driven, FALSE if not. */
@@ -65,55 +61,50 @@ const console_fns uart_fns =
  * Some of these fields are marked "NOT USED". They are not used
  * by console.c, but may be used by drivers in libchip
 console_tbl Console_Configuration_Ports[] = {
-        "/dev/com0",                      /* sDeviceName */
-        SERIAL_CUSTOM,                    /* deviceType */
-        &uart_fns,                        /* pDeviceFns */
-        NULL,                             /* deviceProbe */
-        NULL,                             /* pDeviceFlow */
-        0,                                /* ulMargin - NOT USED */
-        0,                                /* ulHysteresis - NOT USED */
-        NULL,                             /* pDeviceParams */
-        0,                                /* ulCtrlPort1  - NOT USED */
-        0,                                /* ulCtrlPort2  - NOT USED */
-        0,                                /* ulDataPort  - NOT USED */
-        NULL,                             /* getRegister - NOT USED */
-        NULL,                             /* setRegister - NOT USED */
-        NULL,                             /* getData - NOT USED */
-        NULL,                             /* setData - NOT USED */
-        0,                                /* ulClock - NOT USED */
-        0                                 /* ulIntVector - NOT USED */
-    #if 0
-        "/dev/com1",                      /* sDeviceName */
-    #endif
+    "/dev/com0",                      /* sDeviceName */
+    SERIAL_CUSTOM,                    /* deviceType */
+    &uart_fns,                        /* pDeviceFns */
+    NULL,                             /* deviceProbe */
+    NULL,                             /* pDeviceFlow */
+    0,                                /* ulMargin - NOT USED */
+    0,                                /* ulHysteresis - NOT USED */
+    NULL,                             /* pDeviceParams */
+    0,                                /* ulCtrlPort1  - NOT USED */
+    0,                                /* ulCtrlPort2  - NOT USED */
+    0,                                /* ulDataPort  - NOT USED */
+    NULL,                             /* getRegister - NOT USED */
+    NULL,                             /* setRegister - NOT USED */
+    NULL,                             /* getData - NOT USED */
+    NULL,                             /* setData - NOT USED */
+    0,                                /* ulClock - NOT USED */
+    0                                 /* ulIntVector - NOT USED */
+#if 0
+    "/dev/com1",                      /* sDeviceName */
+#endif
-/* Functions called via termios callbacks (i.e. the ones in uart_fns */
  * This is called the first time each device is opened. If the driver
  * is interrupt driven, you should enable interrupts here. Otherwise,
@@ -123,10 +114,9 @@ console_tbl Console_Configuration_Ports[] = {
 static int uart_first_open(int major, int minor, void *arg)
-    return 0;
+  return 0;
  * This is called the last time each device is closed. If the driver
  * is interrupt driven, you should disable interrupts here. Otherwise,
@@ -134,10 +124,9 @@ static int uart_first_open(int major, int minor, void *arg)
 static int uart_last_close(int major, int minor, void *arg)
-    return 0;
+  return 0;
  * Read one character from UART.
@@ -146,30 +135,28 @@ static int uart_last_close(int major, int minor, void *arg)
 static int uart_read(int minor)
-    char c;
-    if (minor == 0) {
-        if(U0LSR & ULSR_RDR) {
-            c = U0RBR;
-            return c;
-        } else {
-            return -1;
-    } else if (minor == 1) {
-        if (U1LSR & ULSR_RDR) {
-            c = U1RBR;
-            return c;
-        } else {
-            return -1;
-    } else {
-        printk("Unknown console minor number %d\n", minor);
-        return -1;
+  char c;
+  switch (minor) {
+    case 0:
+      if (U0LSR & ULSR_RDR) {
+        c = U0RBR;
+        return c;
+      return -1;
+    case 1:
+      if (U1LSR & ULSR_RDR) {
+        c = U1RBR;
+        return c;
+      return -1;
+    default:
+      break;
+  printk("Unknown console minor number %d\n", minor);
+  return -1;
  * Write buffer to UART
@@ -177,158 +164,123 @@ static int uart_read(int minor)
 static ssize_t uart_write(int minor, const char *buf, size_t len)
-    size_t i;
-    if (minor == 0) {
-        for (i = 0; i < len; i++) {
-            while(!(U0LSR & ULSR_THRE)) 	/* wait for TX buffer to empty*/
-                  continue;						/* also either WDOG() or swap()*/
-            U0THR = (char) buf[i];
-        } else {
-          return -1;
-    return 1;
+  size_t i;
+  switch (minor) {
+    case 0:
+      for (i = 0; i < len; i++) {
+        while (!(U0LSR & ULSR_THRE))   /* wait for TX buffer to empty*/
+          continue;                    /* also either WDOG() or swap()*/
+        U0THR = (char) buf[i];
+      break;
+    case 1:
+      break;
+    default:
+      return -1;
+  return len;
 /* Set up the UART. */
 static void uart_init(int minor)
 #if 0 //init will be done in bspstart.c
-	int baud=6;
-	int mode =0x03;
-	if(minor==0){
-		// set port pins for UART0
-		PINSEL0 =  (PINSEL0 & ~U0_PINMASK) | U0_PINSEL;
-		U0IER = 0x00;                         // disable all interrupts
-		// set the baudrate
-		U0LCR = 1<<7;             // select divisor latches
-		U0DLL = (uint8_t)baud;                // set for baud low byte
-		U0DLM = (uint8_t)(baud >> 8);         // set for baud high byte
-		// set the number of characters and other
-		// user specified operating parameters
-		U0LCR = (mode & ~ULCR_DLAB_ENABLE);
-		U0FCR = mode>>8; /*fifo mode*/
-		// set port pins for UART1
-		PINSEL0 = (PINSEL0 & ~U1_PINMASK) | U1_PINSEL;
-		U1IER = 0x00;						  // disable all interrupts
-	}else if(minor==1){
-		U1LCR = ULCR_DLAB_ENABLE;			  // select divisor latches
-		U1DLL = (uint8_t)baud;				  // set for baud low byte
-		U1DLM = (uint8_t)(baud >> 8);		  // set for baud high byte
-		U1LCR = (mode & ~ULCR_DLAB_ENABLE);
-		U1FCR = mode>>8;/*fifo mode*/
+  int baud=6;
+  int mode =0x03;
+  if(minor==0){
+    // set port pins for UART0
+    PINSEL0 =  (PINSEL0 & ~U0_PINMASK) | U0_PINSEL;
+    U0IER = 0x00;                         // disable all interrupts
+    // set the baudrate
+    U0LCR = 1<<7;             // select divisor latches
+    U0DLL = (uint8_t)baud;                // set for baud low byte
+    U0DLM = (uint8_t)(baud >> 8);         // set for baud high byte
+    // set the number of characters and other
+    // user specified operating parameters
+    U0LCR = (mode & ~ULCR_DLAB_ENABLE);
+    U0FCR = mode>>8; /*fifo mode*/
+    // set port pins for UART1
+    PINSEL0 = (PINSEL0 & ~U1_PINMASK) | U1_PINSEL;
+    U1IER = 0x00;              // disable all interrupts
+  }else if(minor==1){
+    U1LCR = ULCR_DLAB_ENABLE;        // select divisor latches
+    U1DLL = (uint8_t)baud;          // set for baud low byte
+    U1DLM = (uint8_t)(baud >> 8);      // set for baud high byte
+    U1LCR = (mode & ~ULCR_DLAB_ENABLE);
+    U1FCR = mode>>8;/*fifo mode*/
 #endif
 /* I'm not sure this is needed for the shared console driver. */
-static void    uart_write_polled(int minor, char c)
+static void uart_write_polled(int minor, char c)
-    uart_write(minor, &c, 1);
+  uart_write(minor, &c, 1);
 /* This is for setting baud rate, bits, etc. */
-static int     uart_set_attributes(int minor, const struct termios *t)
-    return 0;
- * The following functions are not used by TERMIOS, but other RTEMS
- * functions use them instead.
- * Read from UART. This is used in the exit code, and can't
- * rely on interrupts.
+static int uart_set_attributes(int minor, const struct termios *t)
-    return uart_read(minor);
+  return 0;
  * Write a character to the console. This is used by printk() and
  * maybe other low level functions. It should not use interrupts or any
  * RTEMS system calls. It needs to be very simple
-static void _BSP_put_char( char c ) {
-    uart_write_polled(0, c);
-    if (c == '\n') {
-        uart_write_polled(0, '\r');
+static void _BSP_put_char( char c )
+  uart_write_polled(0, c);
+  if (c == '\n') {
+    uart_write_polled(0, '\r');
 BSP_output_char_function_type BSP_output_char = _BSP_put_char;
 static int _BSP_get_char(void)
-  return uart_poll_read(0);
+  return uart_read(0);
 BSP_polling_getchar_function_type BSP_poll_char = _BSP_get_char;
-* init USART 0¡£8 bit, 1 Stop,No checkout, BPS115200
-void  UART0_Ini(void)
-   long Fdiv;
-   int i;
-   PINSEL0 = 0x00000005;		    // I/O to UART0
-   U0LCR = 0x83;		            // DLAB = 1
-   Fdiv = (Fpclk >>4) / UART_BPS;  // configure BPS
-   U0DLM = Fdiv/256;
-   U0DLL = Fdiv%256;
-   U0LCR = 0x03;
-   for(i=0;i<10;i++){
-     U0THR = 67;		//send a C to see if is OK
-     while( (U0LSR&0x40)==0 );
-*Send a Byte
-void  UART0_SendByte(char data)
+ * init USART 0¡£8 bit, 1 Stop,No checkout, BPS115200
+void UART0_Ini(void)
-    U0THR = data;
-*Send a string
-void  UART0_SendStr(char const *str)
-{  while(1)
-   {  if( *str == '\0' ) break;
-      UART0_SendByte(*str++);	    // Send the char
+  long Fdiv;
+  int i;
+  PINSEL0 = 0x00000005;        // I/O to UART0
+  U0LCR = 0x83;                // DLAB = 1
+  Fdiv = (Fpclk >>4) / UART_BPS;  // configure BPS
+  U0DLM = Fdiv/256;
+  U0DLL = Fdiv%256;
+  U0LCR = 0x03;
+  for(i=0;i<10;i++){
+    U0THR = 67;    //send a C to see if is OK
+    while ( (U0LSR&0x40)==0 );
diff --git a/c/src/lib/libbsp/arm/rtl22xx/include/bsp.h b/c/src/lib/libbsp/arm/rtl22xx/include/bsp.h
index bc52e22..f6f8a15 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/include/bsp.h
+++ b/c/src/lib/libbsp/arm/rtl22xx/include/bsp.h
@@ -215,6 +215,11 @@ int cs8900_driver_attach (struct rtems_bsdnet_ifconfig *config,
+ * Prototypes for methods used across file boundaries in the BSP.
+extern void  UART0_Ini(void);
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c b/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c
index 8c4d614..cb764c4 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c
@@ -13,12 +13,6 @@
 #include <lpc22xx.h>
- * Function prototypes
-extern void  UART0_Ini(void);
-extern void printi(unsigned long);
  * bsp_start_default - BSP initialization function
  * This function is called before RTEMS is initialized and used
@@ -28,7 +22,6 @@ extern void printi(unsigned long);
  * RESTRICTIONS/LIMITATIONS:
  *   Since RTEMS is not configured, no RTEMS functions can be called.
 void bsp_start_default( void )
1.9.3
