[PATCH 46/62] arm/csb337/startup/bspstart.c: Ensure bsp_start_default() is static
Wed Oct 15 20:00:36 UTC 2014
 c/src/lib/libbsp/arm/csb337/startup/bspstart.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/csb337/startup/bspstart.c b/c/src/lib/libbsp/arm/csb337/startup/bspstart.c
index 484cbe8..75c8fd7 100644
--- a/c/src/lib/libbsp/arm/csb337/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/csb337/startup/bspstart.c
@@ -37,7 +37,7 @@ void bsp_usart_init(void);
  * RESTRICTIONS/LIMITATIONS:
  *   Since RTEMS is not configured, no RTEMS functions can be called.
-void bsp_start_default( void )
+static void bsp_start_default( void )
   /* disable interrupts */
   AIC_CTL_REG(AIC_IDCR) = 0xffffffff;
1.9.3
