[PATCH 56/62] libcpu/powerpc/mpc6xx: Fix warnings
Wed Oct 15 20:00:46 UTC 2014
 c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c | 29 ++-----------------------
 c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c    | 17 +++++++++------
 2 files changed, 12 insertions(+), 34 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c b/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
index 75ef38b..f14acab 100644
--- a/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
+++ b/c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
@@ -8,7 +8,7 @@
- *  COPYRIGHT (c) 1989-2007.
+ *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may in
@@ -93,7 +93,7 @@ static void clockHandler(void)
     } while (
       _Thread_Heir == _Thread_Executing
         && _Thread_Executing->Start.entry_point
-          == rtems_configuration_get_idle_task()
+          == (Thread_Entry) rtems_configuration_get_idle_task()
   #else
@@ -150,14 +150,6 @@ void clockIsr(void *unused)
  *  for bookE CPUs. For efficiency reasons we
  *  provide a separate handler rather than
  *  checking the CPU type each time.
- *  Input parameters:
- *    vector - vector number
- *  Output parameters:  NONE
- *  Return values:      NONE
 void clockIsrBookE(void *unused)
@@ -195,13 +187,6 @@ int clockIsOn(void* unused)
  *  This routine allows the clock driver to exit by masking the interrupt and
  *  disabling the clock's counter.
- *  Input parameters:   NONE
 void Clock_exit( void )
@@ -228,16 +213,6 @@ static uint32_t Clock_driver_nanoseconds_since_last_tick(void)
  *  Clock_initialize
  *  This routine initializes the clock driver.
- *    major - clock device major number
- *    minor - clock device minor number
- *    parg  - pointer to optional device driver arguments
- *  Return values:
- *    rtems_device_driver status code
 rtems_device_driver Clock_initialize(
   rtems_device_major_number major,
diff --git a/c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c b/c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c
index fe1000a..1e0c665 100644
--- a/c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c
+++ b/c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c
@@ -1,5 +1,6 @@
-/* Trivial page table setup for RTEMS
- * Purpose: allow write protection of text/ro-data
+ * Trivial page table setup for RTEMS
+ * Purpose: allow write protection of text/RO-data
@@ -193,7 +194,8 @@ whatPrintf (void)
 #endif
 #ifdef DEBUG
-unsigned long triv121PgTblConsistency (Triv121PgTbl pt, int pass, int expect);
+static unsigned long triv121PgTblConsistency(
+  Triv121PgTbl pt, int pass, int expect);
 static int consistencyPass = 0;
 #define CONSCHECK(expect) triv121PgTblConsistency(&pgTbl,consistencyPass++,(expect))
@@ -304,12 +306,11 @@ static APte
 slotFor (Triv121PgTbl pt, unsigned long vsid, unsigned long pi)
   int i;
-  unsigned long hash, api;
+  unsigned long hash;
   APte pte;
   /* primary hash */
   hash = PTE_HASH1 (vsid, pi);
-  api = API (pi);
   /* linear search thru all buckets for this hash */
   for (i = 0, pte = ptegOf (pt, hash); i < PTE_PER_PTEG; i++, pte++) {
     if (!pte->v && !pte->marked) {
@@ -707,6 +708,7 @@ myhdl (BSP_Exception_frame * excPtr)
+#ifdef DEBUG
 /* test the consistency of the page table
  * 'pass' is merely a number which will be printed
@@ -725,7 +727,7 @@ myhdl (BSP_Exception_frame * excPtr)
  * RETURNS: total number of valid plus 'marked' slots.
-unsigned long
 triv121PgTblConsistency (Triv121PgTbl pt, int pass, int expected)
   APte pte;
@@ -822,6 +824,7 @@ triv121PgTblConsistency (Triv121PgTbl pt, int pass, int expected)
   return v;
+#endif
 /* Find the PTE for a EA and print its contents
  * RETURNS: pte for EA or NULL if no entry was found.
@@ -1072,6 +1075,7 @@ dumpPte (APte pte)
+#if defined(DEBUG_MAIN)
 /* dump page table entries from index 'from' to 'to'
  * The special values (unsigned)-1 are allowed which
  * cause the routine to dump the entire table.
@@ -1096,7 +1100,6 @@ triv121PgTblDump (Triv121PgTbl pt, unsigned from, unsigned to)
-#if defined(DEBUG_MAIN)
 #define LD_DBG_PT_SIZE	LD_MIN_PT_SIZE
1.9.3
