arm - do_data_abort() warnings
Thu Oct 16 05:59:48 UTC 2014
Hello Joel,
On 14/10/14 23:49, Joel Sherrill wrote:
> Hi
> I have a warning for building it. it is defined in three places:
> libbsp/arm/nds/start/start.S
> libbsp/arm/shared/abort/simple_abort.c
> libbsp/arm/shared/abort/abort.c
> And invoked from cpukit/score/cpu/arm/arm_exc_handler_low.S
> Should this be renamed to arm_do_data_abort()  and prototyped
> in rtems/score/cpu.h?
> What about deleting the nds version and using simple_abort.c?
> Any other thoughts?
the proper way would be to delete these files and use the shared start.S file
for all ARM BSPs.
In the meantime we should add a header file <rtems/score/fix-this-bsp.h> and
add all the prototypes for obsolete functions.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
