[PATCH 05/42] mcf5206 libcpu and mcf5206elite: Fix warnings
Fri Oct 17 15:23:21 UTC 2014
 .../lib/libbsp/m68k/mcf5206elite/console/console.c | 343 ++++----
 c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h   |   5 +
 c/src/lib/libbsp/m68k/mcf5206elite/start/start.S   |   4 +-
 .../libbsp/m68k/mcf5206elite/startup/init5206e.c   | 336 ++++----
 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c    | 256 +++---
 c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c    | 642 +++++++--------
 c/src/lib/libcpu/m68k/mcf5206/include/mcfmbus.h    |   2 +-
 c/src/lib/libcpu/m68k/mcf5206/include/mcfuart.h    |   2 +-
 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c       | 860 ++++++++++-----------
 9 files changed, 1168 insertions(+), 1282 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/mcf5206elite/console/console.c b/c/src/lib/libbsp/m68k/mcf5206elite/console/console.c
index c53b8cb..40df1a5 100644
--- a/c/src/lib/libbsp/m68k/mcf5206elite/console/console.c
+++ b/c/src/lib/libbsp/m68k/mcf5206elite/console/console.c
@@ -1,6 +1,8 @@
  * Console driver for Motorola MCF5206E UART modules
  * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
  * Author: Victor V. Vengerov <vvv at oktet.ru>
@@ -46,7 +48,7 @@ int console_mode = 2;
 static int
 console_poll_read(int minor)
-    return mcfuart_poll_read(&uart[minor]);
+  return mcfuart_poll_read(&uart[minor]);
 /* console_interrupt_write --
@@ -63,7 +65,7 @@ console_poll_read(int minor)
 static ssize_t
 console_interrupt_write(int minor, const char *buf, size_t len)
-    return mcfuart_interrupt_write(&uart[minor], buf, len);
+  return mcfuart_interrupt_write(&uart[minor], buf, len);
 /* console_poll_write --
@@ -80,7 +82,7 @@ console_interrupt_write(int minor, const char *buf, size_t len)
 static ssize_t
 console_poll_write(int minor, const char *buf, size_t len)
-    return mcfuart_poll_write(&uart[minor], buf, len);
+  return mcfuart_poll_write(&uart[minor], buf, len);
 /* console_set_attributes --
@@ -96,7 +98,7 @@ console_poll_write(int minor, const char *buf, size_t len)
 static int
 console_set_attributes(int minor, const struct termios *t)
-    return mcfuart_set_attributes(&uart[minor], t);
+  return mcfuart_set_attributes(&uart[minor], t);
 /* console_stop_remote_tx --
@@ -111,10 +113,10 @@ console_set_attributes(int minor, const struct termios *t)
 static int
 console_stop_remote_tx(int minor)
-    if (minor < sizeof(uart)/sizeof(uart[0]))
-        return mcfuart_stop_remote_tx(&uart[minor]);
-    else
-        return RTEMS_INVALID_NUMBER;
+  if (minor < sizeof(uart)/sizeof(uart[0]))
+    return mcfuart_stop_remote_tx(&uart[minor]);
+  else
+    return RTEMS_INVALID_NUMBER;
 /* console_start_remote_tx --
@@ -127,10 +129,10 @@ console_stop_remote_tx(int minor)
 static int
 console_start_remote_tx(int minor)
-        return mcfuart_start_remote_tx(&uart[minor]);
-    else
+    return mcfuart_start_remote_tx(&uart[minor]);
+  else
 /* console_first_open --
@@ -147,32 +149,31 @@ console_start_remote_tx(int minor)
 static int
 console_first_open(int major, int minor, void *arg)
-    rtems_libio_open_close_args_t *args = arg;
-    rtems_status_code sc;
-    uint8_t         intvec;
-    switch (minor)
-        case 0: intvec = BSP_INTVEC_UART1; break;
-        case 1: intvec = BSP_INTVEC_UART2; break;
-        default:
-    if (console_mode != CONSOLE_MODE_INT)
-        intvec = 0;
-    sc = mcfuart_init(&uart[minor],          /* uart */
-                      args->iop->data1,      /* tty */
-                      intvec,                /* interrupt vector number */
-                      minor+1);
-    if (sc == RTEMS_SUCCESSFUL)
-        sc = mcfuart_reset(&uart[minor]);
-    return sc;
+  rtems_libio_open_close_args_t *args = arg;
+  rtems_status_code sc;
+  uint8_t         intvec;
+  switch (minor) {
+    case 0: intvec = BSP_INTVEC_UART1; break;
+    case 1: intvec = BSP_INTVEC_UART2; break;
+    default:
+  if (console_mode != CONSOLE_MODE_INT) {
+    intvec = 0;
+  sc = mcfuart_init(
+    &uart[minor],          /* uart */
+    args->iop->data1,      /* tty */
+    intvec,                /* interrupt vector number */
+    minor+1);
+  if (sc == RTEMS_SUCCESSFUL)
+    sc = mcfuart_reset(&uart[minor]);
+  return sc;
 /* console_last_close --
@@ -189,7 +190,7 @@ console_first_open(int major, int minor, void *arg)
 static int
 console_last_close(int major, int minor, void *arg)
-    return mcfuart_disable(&uart[minor]);
+  return mcfuart_disable(&uart[minor]);
 /* console_initialize --
@@ -204,51 +205,51 @@ console_last_close(int major, int minor, void *arg)
  * RETURNS:
  *     RTEMS error code (RTEMS_SUCCESSFUL if device initialized successfuly)
-rtems_device_driver
-console_initialize(rtems_device_major_number major,
-                   rtems_device_minor_number minor,
-                   void *arg)
+rtems_device_driver console_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *arg)
-    rtems_status_code status;
-     * Set up TERMIOS
-    if (console_mode != CONSOLE_MODE_RAW)
-        rtems_termios_initialize ();
-     * Register the devices
-    status = rtems_io_register_name ("/dev/console", major, 0);
-    if (status != RTEMS_SUCCESSFUL)
-        rtems_fatal_error_occurred (status);
-    status = rtems_io_register_name ("/dev/aux", major, 1);
-    if (console_mode == CONSOLE_MODE_RAW)
-        sc = mcfuart_init(&uart[0],              /* uart */
-                          NULL,                  /* tty */
-                          0,                     /* interrupt vector number */
-                          1);                    /* UART channel number */
-            sc = mcfuart_reset(&uart[0]);
-        sc = mcfuart_init(&uart[1],              /* uart */
-                          NULL,                  /* tty */
-                          2);                    /* UART channel number */
-            sc = mcfuart_reset(&uart[1]);
-        return sc;
+  rtems_status_code status;
+   * Set up TERMIOS
+  if (console_mode != CONSOLE_MODE_RAW)
+      rtems_termios_initialize ();
+   * Register the devices
+  status = rtems_io_register_name ("/dev/console", major, 0);
+  if (status != RTEMS_SUCCESSFUL)
+    rtems_fatal_error_occurred (status);
+  status = rtems_io_register_name ("/dev/aux", major, 1);
+  if (console_mode == CONSOLE_MODE_RAW) {
+    sc = mcfuart_init(&uart[0],              /* uart */
+                      NULL,                  /* tty */
+                      0,                     /* interrupt vector number */
+                      1);                    /* UART channel number */
-    return RTEMS_SUCCESSFUL;
+        sc = mcfuart_reset(&uart[0]);
+    sc = mcfuart_init(&uart[1],              /* uart */
+                      NULL,                  /* tty */
+                      2);                    /* UART channel number */
+      sc = mcfuart_reset(&uart[1]);
+    return sc;
+  return RTEMS_SUCCESSFUL;
 /* console_open --
@@ -268,42 +269,41 @@ console_open(rtems_device_major_number major,
              void *arg)
-    static const rtems_termios_callbacks intr_callbacks = {
-        console_first_open,        /* firstOpen */
-        console_last_close,        /* lastClose */
-        NULL,                      /* pollRead */
-        console_interrupt_write,   /* write */
-        console_set_attributes,    /* setAttributes */
-        console_stop_remote_tx,    /* stopRemoteTx */
-        console_start_remote_tx,   /* startRemoteTx */
-        1                          /* outputUsesInterrupts */
-    static const rtems_termios_callbacks poll_callbacks = {
-        console_poll_read,         /* pollRead */
-        console_poll_write,        /* write */
-        0                          /* outputUsesInterrupts */
-    switch (console_mode)
-        case CONSOLE_MODE_RAW:
-        case CONSOLE_MODE_INT:
-            return rtems_termios_open(major, minor, arg, &intr_callbacks);
-        case CONSOLE_MODE_POLL:
-            return rtems_termios_open(major, minor, arg, &poll_callbacks);
-        default:
-            rtems_fatal_error_occurred(0xC07A1310);
-    return RTEMS_INTERNAL_ERROR;
+  static const rtems_termios_callbacks intr_callbacks = {
+    console_first_open,        /* firstOpen */
+    console_last_close,        /* lastClose */
+    NULL,                      /* pollRead */
+    console_interrupt_write,   /* write */
+    console_set_attributes,    /* setAttributes */
+    console_stop_remote_tx,    /* stopRemoteTx */
+    console_start_remote_tx,   /* startRemoteTx */
+    1                          /* outputUsesInterrupts */
+  static const rtems_termios_callbacks poll_callbacks = {
+    console_poll_read,         /* pollRead */
+    console_poll_write,        /* write */
+    0                          /* outputUsesInterrupts */
+  switch (console_mode) {
+    case CONSOLE_MODE_RAW:
+    case CONSOLE_MODE_INT:
+      return rtems_termios_open(major, minor, arg, &intr_callbacks);
+      case CONSOLE_MODE_POLL:
+        return rtems_termios_open(major, minor, arg, &poll_callbacks);
+      default:
+        rtems_fatal_error_occurred(0xC07A1310);
+  return RTEMS_INTERNAL_ERROR;
 /* console_close --
@@ -322,10 +322,10 @@ console_close(rtems_device_major_number major,
               void *arg)
-        return rtems_termios_close (arg);
-    else
+    return rtems_termios_close (arg);
+  else
 /* console_read --
@@ -344,32 +344,29 @@ console_read(rtems_device_major_number major,
              void *arg)
-        return rtems_termios_read (arg);
-    else
-        rtems_libio_rw_args_t *argp = arg;
-        char *buf = argp->buffer;
-        int count = argp->count;
-        int n = 0;
-        int c;
-        while (n < count)
-            do {
-                c = mcfuart_poll_read(&uart[minor]);
-            } while (c == -1);
-            if (c == '\r')
-                c = '\n';
-            *(buf++) = c;
-            n++;
-            if (c == '\n')
-                break;
-        argp->bytes_moved = n;
+  if (console_mode != CONSOLE_MODE_RAW) {
+    return rtems_termios_read (arg);
+  } else {
+    rtems_libio_rw_args_t *argp = arg;
+    char *buf = argp->buffer;
+    int count = argp->count;
+    int n = 0;
+    int c;
+    while (n < count) {
+      do {
+        c = mcfuart_poll_read(&uart[minor]);
+      } while (c == -1);
+      if (c == '\r')
+        c = '\n';
+      *(buf++) = c;
+      n++;
+      if (c == '\n')
+        break;
+    argp->bytes_moved = n;
 /* console_write --
@@ -389,27 +386,24 @@ console_write(rtems_device_major_number major,
               void *arg
-        return rtems_termios_write (arg);
-    else
-        char cr = '\r';
-        int i;
-        for (i = 0; i < count; i++)
-            if (*buf == '\n')
-                mcfuart_poll_write(&uart[minor], &cr, 1);
-            mcfuart_poll_write(&uart[minor], buf, 1);
-            buf++;
-        argp->bytes_moved = count;
+    return rtems_termios_write (arg);
+  } else {
+    char cr = '\r';
+    int i;
+    for (i = 0; i < count; i++) {
+        if (*buf == '\n')
+            mcfuart_poll_write(&uart[minor], &cr, 1);
+        mcfuart_poll_write(&uart[minor], buf, 1);
+        buf++;
+    argp->bytes_moved = count;
 /* console_control --
@@ -428,12 +422,9 @@ console_control(rtems_device_major_number major,
                 void *arg)
-        return rtems_termios_ioctl (arg);
-    else
+    return rtems_termios_ioctl (arg);
+  } else {
diff --git a/c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h b/c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h
index 72983a0..d11c34d 100644
--- a/c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h
@@ -173,6 +173,11 @@ rtems_isr_entry set_vector(
   int                 type
+ * Prototypes for BSP methods that cross file boundaries
+void Init5206e(void);
 #ifdef __cplusplus
 #endif
diff --git a/c/src/lib/libbsp/m68k/mcf5206elite/start/start.S b/c/src/lib/libbsp/m68k/mcf5206elite/start/start.S
index 96a5a54..57848ff 100644
--- a/c/src/lib/libbsp/m68k/mcf5206elite/start/start.S
+++ b/c/src/lib/libbsp/m68k/mcf5206elite/start/start.S
@@ -5,7 +5,9 @@
  *  The name of this entry point is compiler dependent.
  *  It jumps to the BSP which is responsible for performing
  *  all initialization.
diff --git a/c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c b/c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c
index fe13ea4..a128b81 100644
--- a/c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c
+++ b/c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c
@@ -8,7 +8,9 @@
  *  This initialization code based on hardware settings of dBUG
  *  monitor. This must be changed if you like to run it immediately
  *  after reset.
@@ -53,180 +55,172 @@ extern void INTERRUPT_VECTOR(void);
                   "nop\n\t" \
                   : : "d" (MCF5206E_CACR_CINV) )
-/* Init5206e --
- *     Initialize MCF5206e on-chip modules
- * PARAMETERS:
- *     none
- * RETURNS:
- *     none
+ * Initialize MCF5206e on-chip modules
-void
-Init5206e(void)
+  /* Set Module Base Address register */
+  m68k_set_mbar((MBAR & MCF5206E_MBAR_BA) | MCF5206E_MBAR_V);
-    /* Set Module Base Address register */
-    m68k_set_mbar((MBAR & MCF5206E_MBAR_BA) | MCF5206E_MBAR_V);
-    /* Set System Protection Control Register (SYPCR):
-     * Bus Monitor Enable, Bus Monitor Timing = 1024 clocks,
-     * Software watchdog disabled
-    *MCF5206E_SYPCR(MBAR) = MCF5206E_SYPCR_BME |
-                            MCF5206E_SYPCR_BMT_1024;
-    /* Set Pin Assignment Register (PAR):
-     *     Output Timer 0 (not DREQ) on *TOUT[0] / *DREQ[1]
-     *     Input Timer 0 (not DREQ) on *TIN[0] / *DREQ[0]
-     *     IRQ, not IPL
-     *     UART2 RTS signal (not \RSTO)
-     *     PST/DDATA (not PPIO)
-     *     *WE (not CS/A)
-    *MCF5206E_PAR(MBAR) = MCF5206E_PAR_PAR9_TOUT |
-                          MCF5206E_PAR_PAR8_TIN0 |
-                          MCF5206E_PAR_PAR7_UART2 |
-                          MCF5206E_PAR_PAR6_IRQ |
-                          MCF5206E_PAR_PAR5_PST |
-                          MCF5206E_PAR_PAR4_DDATA |
-                          MCF5206E_PAR_WE0_WE1_WE2_WE3;
-    /* Set SIM Configuration Register (SIMR):
-     * Disable software watchdog timer and bus timeout monitor when
-     * internal freeze signal is asserted.
-    *MCF5206E_SIMR(MBAR) = MCF5206E_SIMR_FRZ0 | MCF5206E_SIMR_FRZ1;
-    /* Set Interrupt Mask Register: Disable all interrupts */
-    *MCF5206E_IMR(MBAR) = 0xFFFF;
-    /* Assign Interrupt Control Registers as it is defined in bsp.h */
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL1) =
-                            (BSP_INTLVL_AVEC1 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_AVEC1 << MCF5206E_ICR_IP_S) |
-                            MCF5206E_ICR_AVEC;
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL2) =
-                            (BSP_INTLVL_AVEC2 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_AVEC2 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL3) =
-                            (BSP_INTLVL_AVEC3 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_AVEC3 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL4) =
-                            (BSP_INTLVL_AVEC4 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_AVEC4 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL5) =
-                            (BSP_INTLVL_AVEC5 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_AVEC5 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL6) =
-                            (BSP_INTLVL_AVEC6 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_AVEC6 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL7) =
-                            (BSP_INTLVL_AVEC7 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_AVEC7 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_TIMER_1) =
-                            (BSP_INTLVL_TIMER1 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_TIMER1 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_TIMER_2) =
-                            (BSP_INTLVL_TIMER2 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_TIMER2 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_MBUS) =
-                            (BSP_INTLVL_MBUS << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_MBUS << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_UART_1) =
-                            (BSP_INTLVL_UART1 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_UART1 << MCF5206E_ICR_IP_S);
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_UART_2) =
-                            (BSP_INTLVL_UART2 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_UART2 << MCF5206E_ICR_IP_S);
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_DMA_0) =
-                            (BSP_INTLVL_DMA0 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_DMA0 << MCF5206E_ICR_IP_S) |
-    *MCF5206E_ICR(MBAR,MCF5206E_INTR_DMA_1) =
-                            (BSP_INTLVL_DMA1 << MCF5206E_ICR_IL_S) |
-                            (BSP_INTPRIO_DMA1 << MCF5206E_ICR_IP_S) |
-    /* Software Watchdog timer (not used now) */
-    *MCF5206E_SWIVR(MBAR) = 0x0F; /* Uninitialized interrupt */
-    *MCF5206E_SWSR(MBAR) = MCF5206E_SWSR_KEY1;
-    *MCF5206E_SWSR(MBAR) = MCF5206E_SWSR_KEY2;
-    /* Configuring Chip Selects */
-    /* CS2: SRAM memory */
-    *MCF5206E_CSAR(MBAR,2) = BSP_MEM_ADDR_ESRAM >> 16;
-    *MCF5206E_CSMR(MBAR,2) = BSP_MEM_MASK_ESRAM;
-    *MCF5206E_CSCR(MBAR,2) = MCF5206E_CSCR_WS1 |
-                             MCF5206E_CSCR_PS_32 |
-                             MCF5206E_CSCR_AA |
-                             MCF5206E_CSCR_EMAA |
-                             MCF5206E_CSCR_WR |
-                             MCF5206E_CSCR_RD;
-    /* CS3: GPIO on eLITE board */
-    *MCF5206E_CSAR(MBAR,3) = BSP_MEM_ADDR_GPIO >> 16;
-    *MCF5206E_CSMR(MBAR,3) = BSP_MEM_MASK_GPIO;
-    *MCF5206E_CSCR(MBAR,3) = MCF5206E_CSCR_WS15 |
-                             MCF5206E_CSCR_PS_16 |
-                             MCF5206E_CSCR_RD;
-        uint32_t         *inttab = (uint32_t*)&INTERRUPT_VECTOR;
-        uint32_t         *intvec = (uint32_t*)BSP_MEM_ADDR_ESRAM;
-        register int i;
-        for (i = 0; i < 256; i++)
-            *(intvec++) = *(inttab++);
+  /* Set System Protection Control Register (SYPCR):
+   * Bus Monitor Enable, Bus Monitor Timing = 1024 clocks,
+   * Software watchdog disabled
+  *MCF5206E_SYPCR(MBAR) = MCF5206E_SYPCR_BME |
+			  MCF5206E_SYPCR_BMT_1024;
+  /* Set Pin Assignment Register (PAR):
+   *     Output Timer 0 (not DREQ) on *TOUT[0] / *DREQ[1]
+   *     Input Timer 0 (not DREQ) on *TIN[0] / *DREQ[0]
+   *     IRQ, not IPL
+   *     UART2 RTS signal (not \RSTO)
+   *     PST/DDATA (not PPIO)
+   *     *WE (not CS/A)
+  *MCF5206E_PAR(MBAR) = MCF5206E_PAR_PAR9_TOUT |
+			MCF5206E_PAR_PAR8_TIN0 |
+			MCF5206E_PAR_PAR7_UART2 |
+			MCF5206E_PAR_PAR6_IRQ |
+			MCF5206E_PAR_PAR5_PST |
+			MCF5206E_PAR_PAR4_DDATA |
+			MCF5206E_PAR_WE0_WE1_WE2_WE3;
+  /* Set SIM Configuration Register (SIMR):
+   * Disable software watchdog timer and bus timeout monitor when
+   * internal freeze signal is asserted.
+  *MCF5206E_SIMR(MBAR) = MCF5206E_SIMR_FRZ0 | MCF5206E_SIMR_FRZ1;
+  /* Set Interrupt Mask Register: Disable all interrupts */
+  *MCF5206E_IMR(MBAR) = 0xFFFF;
+  /* Assign Interrupt Control Registers as it is defined in bsp.h */
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL1) =
+			  (BSP_INTLVL_AVEC1 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_AVEC1 << MCF5206E_ICR_IP_S) |
+			  MCF5206E_ICR_AVEC;
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL2) =
+			  (BSP_INTLVL_AVEC2 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_AVEC2 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL3) =
+			  (BSP_INTLVL_AVEC3 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_AVEC3 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL4) =
+			  (BSP_INTLVL_AVEC4 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_AVEC4 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL5) =
+			  (BSP_INTLVL_AVEC5 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_AVEC5 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL6) =
+			  (BSP_INTLVL_AVEC6 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_AVEC6 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_EXT_IPL7) =
+			  (BSP_INTLVL_AVEC7 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_AVEC7 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_TIMER_1) =
+			  (BSP_INTLVL_TIMER1 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_TIMER1 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_TIMER_2) =
+			  (BSP_INTLVL_TIMER2 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_TIMER2 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_MBUS) =
+			  (BSP_INTLVL_MBUS << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_MBUS << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_UART_1) =
+			  (BSP_INTLVL_UART1 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_UART1 << MCF5206E_ICR_IP_S);
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_UART_2) =
+			  (BSP_INTLVL_UART2 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_UART2 << MCF5206E_ICR_IP_S);
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_DMA_0) =
+			  (BSP_INTLVL_DMA0 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_DMA0 << MCF5206E_ICR_IP_S) |
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_DMA_1) =
+			  (BSP_INTLVL_DMA1 << MCF5206E_ICR_IL_S) |
+			  (BSP_INTPRIO_DMA1 << MCF5206E_ICR_IP_S) |
+  /* Software Watchdog timer (not used now) */
+  *MCF5206E_SWIVR(MBAR) = 0x0F; /* Uninitialized interrupt */
+  *MCF5206E_SWSR(MBAR) = MCF5206E_SWSR_KEY1;
+  *MCF5206E_SWSR(MBAR) = MCF5206E_SWSR_KEY2;
+  /* Configuring Chip Selects */
+  /* CS2: SRAM memory */
+  *MCF5206E_CSAR(MBAR,2) = BSP_MEM_ADDR_ESRAM >> 16;
+  *MCF5206E_CSMR(MBAR,2) = BSP_MEM_MASK_ESRAM;
+  *MCF5206E_CSCR(MBAR,2) = MCF5206E_CSCR_WS1 |
+			   MCF5206E_CSCR_PS_32 |
+			   MCF5206E_CSCR_AA |
+			   MCF5206E_CSCR_EMAA |
+			   MCF5206E_CSCR_WR |
+			   MCF5206E_CSCR_RD;
+  /* CS3: GPIO on eLITE board */
+  *MCF5206E_CSAR(MBAR,3) = BSP_MEM_ADDR_GPIO >> 16;
+  *MCF5206E_CSMR(MBAR,3) = BSP_MEM_MASK_GPIO;
+  *MCF5206E_CSCR(MBAR,3) = MCF5206E_CSCR_WS15 |
+			   MCF5206E_CSCR_PS_16 |
+			   MCF5206E_CSCR_RD;
+    uint32_t         *inttab = (uint32_t*)&INTERRUPT_VECTOR;
+    uint32_t         *intvec = (uint32_t*)BSP_MEM_ADDR_ESRAM;
+    register int i;
+    for (i = 0; i < 256; i++) {
+      *(intvec++) = *(inttab++);
-    m68k_set_vbr(BSP_MEM_ADDR_ESRAM);
-    /* CS0: Flash EEPROM */
-    *MCF5206E_CSAR(MBAR,0) = BSP_MEM_ADDR_FLASH >> 16;
-    *MCF5206E_CSCR(MBAR,0) = MCF5206E_CSCR_WS3 |
-                             MCF5206E_CSCR_RD;
-    *MCF5206E_CSMR(MBAR,0) = BSP_MEM_MASK_FLASH;
-     * Invalidate the cache and disable it
-    mcf5206e_disable_cache();
-     * Setup ACRs so that if cache turned on, periphal accesses
-     * are not messed up.  (Non-cacheable, serialized)
-    m68k_set_acr0 ( 0
-        | MCF5206E_ACR_BASE(BSP_MEM_ADDR_ESRAM)
-        | MCF5206E_ACR_MASK(BSP_MEM_MASK_ESRAM)
-        | MCF5206E_ACR_EN
-        | MCF5206E_ACR_SM_ANY
-    m68k_set_acr1 ( 0
-        | MCF5206E_ACR_BASE(BSP_MEM_ADDR_FLASH)
-        | MCF5206E_ACR_MASK(BSP_MEM_MASK_FLASH)
-        | MCF5206E_ACR_EN
-    mcf5206e_enable_cache();
+  m68k_set_vbr(BSP_MEM_ADDR_ESRAM);
+  /* CS0: Flash EEPROM */
+  *MCF5206E_CSAR(MBAR,0) = BSP_MEM_ADDR_FLASH >> 16;
+  *MCF5206E_CSCR(MBAR,0) = MCF5206E_CSCR_WS3 |
+			   MCF5206E_CSCR_RD;
+  *MCF5206E_CSMR(MBAR,0) = BSP_MEM_MASK_FLASH;
+   * Invalidate the cache and disable it
+  mcf5206e_disable_cache();
+   * Setup ACRs so that if cache turned on, periphal accesses
+   * are not messed up.  (Non-cacheable, serialized)
+  m68k_set_acr0 ( 0
+      | MCF5206E_ACR_BASE(BSP_MEM_ADDR_ESRAM)
+      | MCF5206E_ACR_MASK(BSP_MEM_MASK_ESRAM)
+      | MCF5206E_ACR_EN
+      | MCF5206E_ACR_SM_ANY
+  m68k_set_acr1 ( 0
+      | MCF5206E_ACR_BASE(BSP_MEM_ADDR_FLASH)
+      | MCF5206E_ACR_MASK(BSP_MEM_MASK_FLASH)
+      | MCF5206E_ACR_EN
+  mcf5206e_enable_cache();
    * Copy data, clear BSS, switch stacks and call boot_card()
diff --git a/c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c b/c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c
index b49f5b6..ab7fc7d 100644
--- a/c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c
+++ b/c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c
@@ -16,13 +16,14 @@
  *    + two digit years 00-87 are mapped to 2000-2087
  *    + two digit years 88-99 are mapped to 1988-1999
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
  * http://www.rtems.org/license/LICENSE.
@@ -43,36 +44,34 @@
  * PARAMETERS:
  *     minor -- minor RTC device number
-void
-ds1307_initialize(int minor)
+static void ds1307_initialize(int minor)
-    i2c_message_status status;
-    int try;
-    uint8_t         sec;
-    i2c_bus_number bus;
-    i2c_address addr;
-    bus = RTC_Table[minor].ulCtrlPort1;
-    addr = RTC_Table[minor].ulDataPort;
-    /* Read SECONDS register */
-    try = 0;
-    do {
-        status = i2c_wbrd(bus, addr, 0, &sec, sizeof(sec));
-        try++;
-    } while ((status != I2C_SUCCESSFUL) && (try < 15));
-    /* If clock is halted, reset and start the clock */
-    if ((sec & DS1307_SECOND_HALT) != 0)
-        uint8_t         start[8];
-        memset(start, 0, sizeof(start));
-        start[0] = DS1307_SECOND;
-        try = 0;
-        do {
-            status = i2c_write(bus, addr, start, 2);
+  i2c_message_status status;
+  int try;
+  uint8_t         sec;
+  i2c_bus_number bus;
+  i2c_address addr;
+  bus = RTC_Table[minor].ulCtrlPort1;
+  addr = RTC_Table[minor].ulDataPort;
+  /* Read SECONDS register */
+  try = 0;
+  do {
+    status = i2c_wbrd(bus, addr, 0, &sec, sizeof(sec));
+    try++;
+  } while ((status != I2C_SUCCESSFUL) && (try < 15));
+  /* If clock is halted, reset and start the clock */
+  if ((sec & DS1307_SECOND_HALT) != 0) {
+      uint8_t         start[8];
+      memset(start, 0, sizeof(start));
+      start[0] = DS1307_SECOND;
+      try = 0;
+      do {
+	  status = i2c_write(bus, addr, start, 2);
 /* ds1307_get_time --
@@ -87,74 +86,66 @@ ds1307_initialize(int minor)
  *     0, if time obtained successfully
  *     -1, if error occured
-int
-ds1307_get_time(int minor, rtems_time_of_day *time)
+static int ds1307_get_time(int minor, rtems_time_of_day *time)
-    i2c_address addr;
-    uint8_t         info[8];
-    uint32_t         v1, v2;
-    int try;
-    if (time == NULL)
-        return -1;
-    memset(time, 0, sizeof(rtems_time_of_day));
-    try = 0;
-    do {
-        status = i2c_wbrd(bus, addr, 0, info, sizeof(info));
-        try++;
-    } while ((status != I2C_SUCCESSFUL) && (try < 10));
-    if (status != I2C_SUCCESSFUL)
-        return -1;
+  i2c_address addr;
+  uint8_t         info[8];
+  uint32_t         v1, v2;
+  int try;
+  if (time == NULL)
+    return -1;
+  memset(time, 0, sizeof(rtems_time_of_day));
+  try = 0;
+  do {
+    status = i2c_wbrd(bus, addr, 0, info, sizeof(info));
+    try++;
+  } while ((status != I2C_SUCCESSFUL) && (try < 10));
+  if (status != I2C_SUCCESSFUL) {
+    return -1;
+  v1 = info[DS1307_YEAR];
+  v2 = From_BCD(v1);
+  if (v2 < 88)
+    time->year = 2000 + v2;
+  else
+    time->year = 1900 + v2;
+  v1 = info[DS1307_MONTH] & ~0xE0;
+  time->month = From_BCD(v1);
+  v1 = info[DS1307_DAY] & ~0xC0;
+  time->day = From_BCD(v1);
+  v1 = info[DS1307_HOUR];
+  if (v1 & DS1307_HOUR_12) {
+    v2 = v1 & ~0xE0;
+    if (v1 & DS1307_HOUR_PM) {
+      time->hour = From_BCD(v2) + 12;
+    } else {
+      time->hour = From_BCD(v2);
+  } else {
+    v2 = v1 & ~0xC0;
-    v1 = info[DS1307_YEAR];
-    v2 = From_BCD(v1);
-    if (v2 < 88)
-        time->year = 2000 + v2;
-    else
-        time->year = 1900 + v2;
-    v1 = info[DS1307_MONTH] & ~0xE0;
-    time->month = From_BCD(v1);
-    v1 = info[DS1307_DAY] & ~0xC0;
-    time->day = From_BCD(v1);
-    v1 = info[DS1307_HOUR];
-    if (v1 & DS1307_HOUR_12)
-        v2 = v1 & ~0xE0;
-        if (v1 & DS1307_HOUR_PM)
-            time->hour = From_BCD(v2) + 12;
-        else
-            time->hour = From_BCD(v2);
-    else
-        v2 = v1 & ~0xC0;
-    v1 = info[DS1307_MINUTE] & ~0x80;
-    time->minute = From_BCD(v1);
+  v1 = info[DS1307_MINUTE] & ~0x80;
+  time->minute = From_BCD(v1);
-    v1 = info[DS1307_SECOND];
-    v2 = v1 & ~0x80;
-    time->second = From_BCD(v2);
+  v1 = info[DS1307_SECOND];
+  v2 = v1 & ~0x80;
+  time->second = From_BCD(v2);
-    return 0;
+  return 0;
 /* ds1307_set_time --
@@ -168,49 +159,48 @@ ds1307_get_time(int minor, rtems_time_of_day *time)
-int
-ds1307_set_time(int minor, const rtems_time_of_day *time)
+static int ds1307_set_time(int minor, const rtems_time_of_day *time)
-    i2c_address addr;
-    uint8_t         info[8];
-    int try;
-    if (time == NULL)
-        return -1;
-    if (time->year >= 2088)
-        rtems_fatal_error_occurred(RTEMS_INVALID_NUMBER);
-    info[0] = DS1307_SECOND;
-    info[1 + DS1307_YEAR] = To_BCD(time->year % 100);
-    info[1 + DS1307_MONTH] = To_BCD(time->month);
-    info[1 + DS1307_DAY] = To_BCD(time->day);
-    info[1 + DS1307_HOUR] = To_BCD(time->hour);
-    info[1 + DS1307_MINUTE] = To_BCD(time->minute);
-    info[1 + DS1307_SECOND] = To_BCD(time->second);
-    info[1 + DS1307_DAY_OF_WEEK] = 1; /* Do not set day of week */
-    try = 0;
-    do {
-        status = i2c_write(bus, addr, info, 8);
-        try++;
-        return -1;
-    else
-        return 0;
+  i2c_address addr;
+  uint8_t         info[8];
+  int try;
+  if (time == NULL)
+    return -1;
+  if (time->year >= 2088)
+      rtems_fatal_error_occurred(RTEMS_INVALID_NUMBER);
+  info[0] = DS1307_SECOND;
+  info[1 + DS1307_YEAR] = To_BCD(time->year % 100);
+  info[1 + DS1307_MONTH] = To_BCD(time->month);
+  info[1 + DS1307_DAY] = To_BCD(time->day);
+  info[1 + DS1307_HOUR] = To_BCD(time->hour);
+  info[1 + DS1307_MINUTE] = To_BCD(time->minute);
+  info[1 + DS1307_SECOND] = To_BCD(time->second);
+  info[1 + DS1307_DAY_OF_WEEK] = 1; /* Do not set day of week */
+  try = 0;
+  do {
+    status = i2c_write(bus, addr, info, 8);
+    try++;
+    return -1;
+  else
+    return 0;
 /* Driver function table */
 rtc_fns ds1307_fns = {
-    ds1307_initialize,
-    ds1307_get_time,
-    ds1307_set_time
+  ds1307_initialize,
+  ds1307_get_time,
+  ds1307_set_time
diff --git a/c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c b/c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c
index ec284c4..fccce85 100644
--- a/c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c
+++ b/c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c
@@ -1,6 +1,8 @@
  * Generic UART Serial driver for Motorola Coldfire processors
  * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russian Fed.
@@ -10,7 +12,6 @@
@@ -23,8 +24,8 @@
  * UART descriptor structures
 static struct {
-    mcfuart *uart;
-    int      vec;
+  mcfuart *uart;
+  int      vec;
 } int_driven_uart[2];
 /* Forward function declarations */
@@ -48,20 +49,24 @@ mcfuart_interrupt_handler(rtems_vector_number vec);
  *     RTEMS_SUCCESSFUL if all parameters are valid, or error code
 rtems_status_code
-mcfuart_init(mcfuart *uart, void *tty, uint8_t   intvec,
-             uint32_t   chn)
+mcfuart_init(
+  mcfuart   *uart,
+  void      *tty,
+  uint8_t    intvec,
+  uint32_t   chn
-    if (uart == NULL)
-        return RTEMS_INVALID_ADDRESS;
+  if (uart == NULL)
+      return RTEMS_INVALID_ADDRESS;
-    if ((chn <= 0) || (chn > MCF5206E_UART_CHANNELS))
+  if ((chn <= 0) || (chn > MCF5206E_UART_CHANNELS))
-    uart->chn = chn;
-    uart->intvec = intvec;
-    uart->tty = tty;
+  uart->chn = chn;
+  uart->intvec = intvec;
+  uart->tty = tty;
 /* mcfuart_set_baudrate --
@@ -77,38 +82,38 @@ mcfuart_init(mcfuart *uart, void *tty, uint8_t   intvec,
 static void
 mcfuart_set_baudrate(mcfuart *uart, speed_t baud)
-    uint32_t   div;
-    uint32_t   rate;
-    switch (baud)
-        case B50:     rate = 50; break;
-        case B75:     rate = 75; break;
-        case B110:    rate = 110; break;
-        case B134:    rate = 134; break;
-        case B150:    rate = 150; break;
-        case B200:    rate = 200; break;
-        case B300:    rate = 300; break;
-        case B600:    rate = 600; break;
-        case B1200:   rate = 1200; break;
-        case B2400:   rate = 2400; break;
-        case B4800:   rate = 4800; break;
-        case B9600:   rate = 9600; break;
-        case B19200:  rate = 19200; break;
-        case B38400:  rate = 38400; break;
-        case B57600:  rate = 57600; break;
+  uint32_t   div;
+  uint32_t   rate;
+    switch (baud) {
+      case B50:     rate = 50; break;
+      case B75:     rate = 75; break;
+      case B110:    rate = 110; break;
+      case B134:    rate = 134; break;
+      case B150:    rate = 150; break;
+      case B200:    rate = 200; break;
+      case B300:    rate = 300; break;
+      case B600:    rate = 600; break;
+      case B1200:   rate = 1200; break;
+      case B2400:   rate = 2400; break;
+      case B4800:   rate = 4800; break;
+      case B9600:   rate = 9600; break;
+      case B19200:  rate = 19200; break;
+      case B38400:  rate = 38400; break;
+      case B57600:  rate = 57600; break;
 #ifdef B115200
-        case B115200: rate = 115200; break;
+      case B115200: rate = 115200; break;
 #endif
 #ifdef B230400
-        case B230400: rate = 230400; break;
+      case B230400: rate = 230400; break;
 #endif
-        default:      rate = 9600; break;
+      default:      rate = 9600; break;
-    div = SYSTEM_CLOCK_FREQUENCY / (rate * 32);
+  div = SYSTEM_CLOCK_FREQUENCY / (rate * 32);
-    *MCF5206E_UBG1(MBAR,uart->chn) = (uint8_t)((div >> 8) & 0xff);
-    *MCF5206E_UBG2(MBAR,uart->chn) = (uint8_t)(div & 0xff);
+  *MCF5206E_UBG1(MBAR,uart->chn) = (uint8_t)((div >> 8) & 0xff);
+  *MCF5206E_UBG2(MBAR,uart->chn) = (uint8_t)(div & 0xff);
@@ -128,69 +133,64 @@ mcfuart_set_baudrate(mcfuart *uart, speed_t baud)
  *     This function in general follows to algorith described in MCF5206e
  *     User's Manual, 12.5 UART Module Initialization Sequence
-rtems_status_code
-mcfuart_reset(mcfuart *uart)
+rtems_status_code mcfuart_reset(mcfuart *uart)
-    register uint32_t   chn;
-    rtems_status_code rc;
-    if (uart == NULL)
-    chn = uart->chn;
-    /* Reset the receiver and transmitter */
-    *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_RX;
-    *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_TX;
-     * Program the vector number for a UART module interrupt, or
-     * disable UART interrupts if polled I/O. Enable the desired
-     * interrupt sources.
-    if (uart->intvec != 0)
-        int_driven_uart[chn - 1].uart = uart;
-        int_driven_uart[chn - 1].vec = uart->intvec;
-        rc = rtems_interrupt_catch(mcfuart_interrupt_handler, uart->intvec,
-                                   &uart->old_handler);
-        if (rc != RTEMS_SUCCESSFUL)
-            return rc;
-        *MCF5206E_UIVR(MBAR,chn) = uart->intvec;
-        *MCF5206E_UIMR(MBAR,chn) = MCF5206E_UIMR_FFULL;
-        *MCF5206E_UACR(MBAR,chn) = MCF5206E_UACR_IEC;
-        *MCF5206E_IMR(MBAR) &= ~MCF5206E_INTR_BIT(uart->chn == 1 ?
-                                                  MCF5206E_INTR_UART_1 :
-                                                  MCF5206E_INTR_UART_2);
-    else
-        *MCF5206E_UIMR(MBAR,chn) = 0;
-    /* Select the receiver and transmitter clock. */
-    mcfuart_set_baudrate(uart, B19200); /* dBUG defaults (unfortunately,
-                                           it is differ to termios default */
-    *MCF5206E_UCSR(MBAR,chn) =
-        MCF5206E_UCSR_RCS_TIMER | MCF5206E_UCSR_TCS_TIMER;
-    /* Mode Registers 1,2 - set termios defaults (8N1) */
-    *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_MR;
-    *MCF5206E_UMR(MBAR,chn) =
+  register uint32_t   chn;
+  rtems_status_code rc;
+  if (uart == NULL)
+  chn = uart->chn;
+  /* Reset the receiver and transmitter */
+  *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_RX;
+  *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_TX;
+   * Program the vector number for a UART module interrupt, or
+   * disable UART interrupts if polled I/O. Enable the desired
+   * interrupt sources.
+  if (uart->intvec != 0) {
+    int_driven_uart[chn - 1].uart = uart;
+    int_driven_uart[chn - 1].vec = uart->intvec;
+    rc = rtems_interrupt_catch(mcfuart_interrupt_handler, uart->intvec,
+			       &uart->old_handler);
+    if (rc != RTEMS_SUCCESSFUL)
+      return rc;
+    *MCF5206E_UIVR(MBAR,chn) = uart->intvec;
+    *MCF5206E_UIMR(MBAR,chn) = MCF5206E_UIMR_FFULL;
+    *MCF5206E_UACR(MBAR,chn) = MCF5206E_UACR_IEC;
+    *MCF5206E_IMR(MBAR) &= ~MCF5206E_INTR_BIT(uart->chn == 1 ?
+					      MCF5206E_INTR_UART_1 :
+					      MCF5206E_INTR_UART_2);
+  } else {
+    *MCF5206E_UIMR(MBAR,chn) = 0;
+  /* Select the receiver and transmitter clock. */
+  mcfuart_set_baudrate(uart, B19200); /* dBUG defaults (unfortunately,
+					 it is differ to termios default */
+  *MCF5206E_UCSR(MBAR,chn) = MCF5206E_UCSR_RCS_TIMER | MCF5206E_UCSR_TCS_TIMER;
+  /* Mode Registers 1,2 - set termios defaults (8N1) */
+  *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_MR;
+  *MCF5206E_UMR(MBAR,chn) =
 /*      MCF5206E_UMR1_RXRTS | */
-        MCF5206E_UMR1_PM_NO_PARITY |
-        MCF5206E_UMR1_BC_8;
-        MCF5206E_UMR2_CM_NORMAL |
+      MCF5206E_UMR1_PM_NO_PARITY |
+      MCF5206E_UMR1_BC_8;
+      MCF5206E_UMR2_CM_NORMAL |
 /*      MCF5206E_UMR2_TXCTS | */
-        MCF5206E_UMR2_SB_1;
+      MCF5206E_UMR2_SB_1;
-    /* Enable Receiver and Transmitter */
-    *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_ERR;
-    *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_TC_ENABLE;
-    *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_RC_ENABLE;
+  /* Enable Receiver and Transmitter */
+  *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_MISC_RESET_ERR;
+  *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_TC_ENABLE;
+  *MCF5206E_UCR(MBAR,chn) = MCF5206E_UCR_RC_ENABLE;
@@ -205,25 +205,24 @@ mcfuart_reset(mcfuart *uart)
  *     RTEMS_SUCCESSFUL if UART closed successfuly, or error code in
  *     other case
-rtems_status_code
-mcfuart_disable(mcfuart *uart)
+rtems_status_code mcfuart_disable(mcfuart *uart)
-    *MCF5206E_UCR(MBAR,uart->chn) =
-        MCF5206E_UCR_TC_DISABLE |
-        MCF5206E_UCR_RC_DISABLE;
-        *MCF5206E_IMR(MBAR) |=  MCF5206E_INTR_BIT(uart->chn == 1 ?
-        rc = rtems_interrupt_catch(uart->old_handler, uart->intvec, NULL);
-        int_driven_uart[uart->chn - 1].uart = NULL;
-        int_driven_uart[uart->chn - 1].vec = 0;
-            return rc;
+  *MCF5206E_UCR(MBAR,uart->chn) =
+      MCF5206E_UCR_TC_DISABLE |
+      MCF5206E_UCR_RC_DISABLE;
+      *MCF5206E_IMR(MBAR) |=  MCF5206E_INTR_BIT(uart->chn == 1 ?
+      rc = rtems_interrupt_catch(uart->old_handler, uart->intvec, NULL);
+      int_driven_uart[uart->chn - 1].uart = NULL;
+      int_driven_uart[uart->chn - 1].vec = 0;
+	  return rc;
@@ -238,93 +237,72 @@ mcfuart_disable(mcfuart *uart)
  * RETURNS:
  *     RTEMS_SUCCESSFUL
-int
-mcfuart_set_attributes(mcfuart *uart, const struct termios *t)
+int mcfuart_set_attributes(mcfuart *uart, const struct termios *t)
-    int level;
-    speed_t baud;
-    uint8_t   umr1, umr2;
-    baud = cfgetospeed(t);
-    umr1 = 0;
-    umr2 = MCF5206E_UMR2_CM_NORMAL;
-    /* Set flow control */
-    if ((t->c_cflag & CRTSCTS) != 0)
-        umr1 |= MCF5206E_UMR1_RXRTS;
-        umr2 |= MCF5206E_UMR2_TXCTS;
-    /* Set character size */
-    switch (t->c_cflag & CSIZE)
-        case CS5: umr1 |= MCF5206E_UMR1_BC_5; break;
-        case CS6: umr1 |= MCF5206E_UMR1_BC_6; break;
-        case CS7: umr1 |= MCF5206E_UMR1_BC_7; break;
-        case CS8: umr1 |= MCF5206E_UMR1_BC_8; break;
-    /* Set number of stop bits */
-    if ((t->c_cflag & CSTOPB) != 0)
-        if ((t->c_cflag & CSIZE) == CS5)
-            umr2 |= MCF5206E_UMR2_SB5_2;
-        else
-            umr2 |= MCF5206E_UMR2_SB_2;
-    else
-            umr2 |= MCF5206E_UMR2_SB5_1;
-        else
-            umr2 |= MCF5206E_UMR2_SB_1;
+  int level;
+  speed_t baud;
+  uint8_t   umr1, umr2;
+  baud = cfgetospeed(t);
+  umr1 = 0;
+  umr2 = MCF5206E_UMR2_CM_NORMAL;
+  /* Set flow control */
+  if ((t->c_cflag & CRTSCTS) != 0) {
+    umr1 |= MCF5206E_UMR1_RXRTS;
+    umr2 |= MCF5206E_UMR2_TXCTS;
+  /* Set character size */
+  switch (t->c_cflag & CSIZE) {
+    case CS5: umr1 |= MCF5206E_UMR1_BC_5; break;
+    case CS6: umr1 |= MCF5206E_UMR1_BC_6; break;
+    case CS7: umr1 |= MCF5206E_UMR1_BC_7; break;
+    case CS8: umr1 |= MCF5206E_UMR1_BC_8; break;
+  /* Set number of stop bits */
+  if ((t->c_cflag & CSTOPB) != 0) {
+    if ((t->c_cflag & CSIZE) == CS5) {
+      umr2 |= MCF5206E_UMR2_SB5_2;
+    } else {
+      umr2 |= MCF5206E_UMR2_SB_2;
-    /* Set parity mode */
-    if ((t->c_cflag & PARENB) != 0)
-        if ((t->c_cflag & PARODD) != 0)
-            umr1 |= MCF5206E_UMR1_PM_ODD;
-        else
-            umr1 |= MCF5206E_UMR1_PM_EVEN;
+  } else {
+      umr2 |= MCF5206E_UMR2_SB5_1;
+    } else {
+      umr2 |= MCF5206E_UMR2_SB_1;
-    else
-        umr1 |= MCF5206E_UMR1_PM_NO_PARITY;
+  /* Set parity mode */
+  if ((t->c_cflag & PARENB) != 0) {
+    if ((t->c_cflag & PARODD) != 0) {
+      umr1 |= MCF5206E_UMR1_PM_ODD;
+    } else {
+      umr1 |= MCF5206E_UMR1_PM_EVEN;
-    rtems_interrupt_disable(level);
+  } else {
+    umr1 |= MCF5206E_UMR1_PM_NO_PARITY;
+  rtems_interrupt_disable(level);
+      MCF5206E_UCR_TC_DISABLE | MCF5206E_UCR_RC_DISABLE;
+  mcfuart_set_baudrate(uart, baud);
+  *MCF5206E_UCR(MBAR,uart->chn) = MCF5206E_UCR_MISC_RESET_MR;
+  *MCF5206E_UMR(MBAR,uart->chn) = umr1;
+  *MCF5206E_UMR(MBAR,uart->chn) = umr2;
+  if ((t->c_cflag & CREAD) != 0) {
-        MCF5206E_UCR_TC_DISABLE | MCF5206E_UCR_RC_DISABLE;
-    mcfuart_set_baudrate(uart, baud);
-    *MCF5206E_UCR(MBAR,uart->chn) = MCF5206E_UCR_MISC_RESET_MR;
-    *MCF5206E_UMR(MBAR,uart->chn) = umr1;
-    *MCF5206E_UMR(MBAR,uart->chn) = umr2;
-    if ((t->c_cflag & CREAD) != 0)
-            MCF5206E_UCR_TC_ENABLE | MCF5206E_UCR_RC_ENABLE;
-    else
-        *MCF5206E_UCR(MBAR,uart->chn) = MCF5206E_UCR_TC_ENABLE;
-    rtems_interrupt_enable(level);
+	MCF5206E_UCR_TC_ENABLE | MCF5206E_UCR_RC_ENABLE;
+  } else {
+    *MCF5206E_UCR(MBAR,uart->chn) = MCF5206E_UCR_TC_ENABLE;
+  rtems_interrupt_enable(level);
@@ -343,41 +321,33 @@ mcfuart_set_attributes(mcfuart *uart, const struct termios *t)
  * RETURNS:
  *     code of received character or -1 if no characters received.
-int
-mcfuart_poll_read(mcfuart *uart)
+int mcfuart_poll_read(mcfuart *uart)
-    uint8_t   usr;
-    int ch;
-    if (uart->parerr_mark_flag == true)
-        uart->parerr_mark_flag = false;
-        return 0;
-    usr = *MCF5206E_USR(MBAR,uart->chn);
-    if ((usr & MCF5206E_USR_RXRDY) != 0)
-        if (((usr & (MCF5206E_USR_FE | MCF5206E_USR_PE)) != 0) &&
-            !(uart->c_iflag & IGNPAR))
-            ch = *MCF5206E_URB(MBAR,uart->chn); /* Clear error bits */
-            if (uart->c_iflag & PARMRK)
-                uart->parerr_mark_flag = true;
-                ch = 0xff;
-            else
-                ch = 0;
-        else
+  uint8_t   usr;
+  int ch;
+  if (uart->parerr_mark_flag == true) {
+    uart->parerr_mark_flag = false;
+    return 0;
+  usr = *MCF5206E_USR(MBAR,uart->chn);
+  if ((usr & MCF5206E_USR_RXRDY) != 0) {
+    if (((usr & (MCF5206E_USR_FE | MCF5206E_USR_PE)) != 0) &&
+	!(uart->c_iflag & IGNPAR)) {
+      ch = *MCF5206E_URB(MBAR,uart->chn); /* Clear error bits */
+      if (uart->c_iflag & PARMRK) {
+	uart->parerr_mark_flag = true;
+	ch = 0xff;
+      } else {
+	ch = 0;
+    } else {
-    else
-        ch = -1;
-    return ch;
+  } else
+    ch = -1;
+  return ch;
@@ -392,17 +362,15 @@ mcfuart_poll_read(mcfuart *uart)
  * RETURNS:
  *     0
-ssize_t
-mcfuart_poll_write(mcfuart *uart, const char *buf, size_t len)
+ssize_t mcfuart_poll_write(mcfuart *uart, const char *buf, size_t len)
   size_t retval = len;
-    while (len--)
-        while ((*MCF5206E_USR(MBAR, uart->chn) & MCF5206E_USR_TXRDY) == 0);
-        *MCF5206E_UTB(MBAR, uart->chn) = *buf++;
-    return retval;
+  while (len--) {
+    while ((*MCF5206E_USR(MBAR, uart->chn) & MCF5206E_USR_TXRDY) == 0);
+    *MCF5206E_UTB(MBAR, uart->chn) = *buf++;
+  return retval;
 /* mcfuart_interrupt_handler --
@@ -414,95 +382,78 @@ mcfuart_poll_write(mcfuart *uart, const char *buf, size_t len)
  * RETURNS:
  *     none
-static rtems_isr
-mcfuart_interrupt_handler(rtems_vector_number vec)
+static rtems_isr mcfuart_interrupt_handler(rtems_vector_number vec)
-    mcfuart *uart;
-    register uint8_t   usr;
-    register uint8_t   uisr;
-    register int chn;
-    register int bp = 0;
-    /* Find UART descriptor from vector number */
-    if (int_driven_uart[0].vec == vec)
-        uart = int_driven_uart[0].uart;
-    else if (int_driven_uart[1].vec == vec)
-        uart = int_driven_uart[1].uart;
-    else
-        return;
-    chn = uart->chn;
-    uisr = *MCF5206E_UISR(MBAR, chn);
-    if (uisr & MCF5206E_UISR_DB)
-        *MCF5206E_UCR(MBAR, chn) = MCF5206E_UCR_MISC_RESET_BRK;
+  mcfuart *uart;
+  register uint8_t   usr;
+  register uint8_t   uisr;
+  register int chn;
+  register int bp = 0;
+  /* Find UART descriptor from vector number */
+  if (int_driven_uart[0].vec == vec)
+    uart = int_driven_uart[0].uart;
+  else if (int_driven_uart[1].vec == vec)
+    uart = int_driven_uart[1].uart;
+  else
+    return;
+  chn = uart->chn;
+  uisr = *MCF5206E_UISR(MBAR, chn);
+  if (uisr & MCF5206E_UISR_DB) {
+    *MCF5206E_UCR(MBAR, chn) = MCF5206E_UCR_MISC_RESET_BRK;
+  /* Receiving */
+  while (1) {
+    char buf[32];
+    usr = *MCF5206E_USR(MBAR,chn);
+    if ((bp < sizeof(buf) - 1) && ((usr & MCF5206E_USR_RXRDY) != 0)) {
+      /* Receive character and handle frame/parity errors */
+	    buf[bp++] = 0xff;
+	    buf[bp++] = 0x00;
+	  } else {
+	    buf[bp++] = 0x00;
+      } else {
+	buf[bp++] = *MCF5206E_URB(MBAR, chn);
+      /* Reset error condition if any errors has been detected */
+      if (usr & (MCF5206E_USR_RB | MCF5206E_USR_FE |
+		 MCF5206E_USR_PE | MCF5206E_USR_OE)) {
+	*MCF5206E_UCR(MBAR, chn) = MCF5206E_UCR_MISC_RESET_ERR;
+    } else {
+      if (bp != 0)
+	rtems_termios_enqueue_raw_characters(uart->tty, buf, bp);
+      break;
-    /* Receiving */
-    while (1)
-        char buf[32];
-        usr = *MCF5206E_USR(MBAR,chn);
-        if ((bp < sizeof(buf) - 1) && ((usr & MCF5206E_USR_RXRDY) != 0))
-            /* Receive character and handle frame/parity errors */
-                    buf[bp++] = 0xff;
-                    buf[bp++] = 0x00;
-                else
-                    buf[bp++] = 0x00;
-            else
-                buf[bp++] = *MCF5206E_URB(MBAR, chn);
-            /* Reset error condition if any errors has been detected */
-            if (usr & (MCF5206E_USR_RB | MCF5206E_USR_FE |
-                       MCF5206E_USR_PE | MCF5206E_USR_OE))
-                *MCF5206E_UCR(MBAR, chn) = MCF5206E_UCR_MISC_RESET_ERR;
-        else
-            if (bp != 0)
-                rtems_termios_enqueue_raw_characters(uart->tty, buf, bp);
-            break;
-    /* Transmitting */
-    while (1)
-        if ((*MCF5206E_USR(MBAR, chn) & MCF5206E_USR_TXRDY) == 0)
-            break;
-        if (uart->tx_buf != NULL)
-            if (uart->tx_ptr >= uart->tx_buf_len)
-                register int dequeue = uart->tx_buf_len;
-                *MCF5206E_UIMR(MBAR, uart->chn) = MCF5206E_UIMR_FFULL;
-                uart->tx_buf = NULL;
-                uart->tx_ptr = uart->tx_buf_len = 0;
-                rtems_termios_dequeue_characters(uart->tty, dequeue);
-            else
-                *MCF5206E_UTB(MBAR, chn) = uart->tx_buf[uart->tx_ptr++];
-        else
-            break;
+  /* Transmitting */
+  while (1) {
+    if ((*MCF5206E_USR(MBAR, chn) & MCF5206E_USR_TXRDY) == 0)
+      break;
+    if (uart->tx_buf != NULL) {
+      if (uart->tx_ptr >= uart->tx_buf_len) {
+	register int dequeue = uart->tx_buf_len;
+	*MCF5206E_UIMR(MBAR, uart->chn) = MCF5206E_UIMR_FFULL;
+	uart->tx_buf = NULL;
+	uart->tx_ptr = uart->tx_buf_len = 0;
+	rtems_termios_dequeue_characters(uart->tty, dequeue);
+      } else {
+	*MCF5206E_UTB(MBAR, chn) = uart->tx_buf[uart->tx_ptr++];
+    else
+      break;
 /* mcfuart_interrupt_write --
@@ -516,24 +467,25 @@ mcfuart_interrupt_handler(rtems_vector_number vec)
  * RETURNS:
  *     0
-ssize_t
-mcfuart_interrupt_write(mcfuart *uart, const char *buf, size_t len)
+ssize_t mcfuart_interrupt_write(
+  mcfuart *uart,
+  const char *buf,
+  size_t len
-    if (len > 0)
-        uart->tx_buf = buf;
-        uart->tx_buf_len = len;
-        uart->tx_ptr = 0;
-                MCF5206E_UIMR_FFULL | MCF5206E_UIMR_TXRDY;
-        while (((*MCF5206E_USR(MBAR,uart->chn) & MCF5206E_USR_TXRDY) != 0) &&
-               (uart->tx_ptr < uart->tx_buf_len))
-            *MCF5206E_UTB(MBAR,uart->chn) = uart->tx_buf[uart->tx_ptr++];
+  if (len > 0) {
+    uart->tx_buf = buf;
+    uart->tx_buf_len = len;
+    uart->tx_ptr = 0;
+	    MCF5206E_UIMR_FFULL | MCF5206E_UIMR_TXRDY;
+    while (((*MCF5206E_USR(MBAR,uart->chn) & MCF5206E_USR_TXRDY) != 0) &&
+	   (uart->tx_ptr < uart->tx_buf_len)) {
+	*MCF5206E_UTB(MBAR,uart->chn) = uart->tx_buf[uart->tx_ptr++];
-    return 0;
+  return 0;
 /* mcfuart_stop_remote_tx --
@@ -545,11 +497,10 @@ mcfuart_interrupt_write(mcfuart *uart, const char *buf, size_t len)
  * RETURNS:
  *     RTEMS_SUCCESSFUL
-int
-mcfuart_stop_remote_tx(mcfuart *uart)
+int mcfuart_stop_remote_tx(mcfuart *uart)
-    *MCF5206E_UOP0(MBAR, uart->chn) = 1;
+  *MCF5206E_UOP0(MBAR, uart->chn) = 1;
 /* mcfuart_start_remote_tx --
@@ -561,9 +512,8 @@ mcfuart_stop_remote_tx(mcfuart *uart)
  * RETURNS:
  *     RTEMS_SUCCESSFUL
-int
-mcfuart_start_remote_tx(mcfuart *uart)
+int mcfuart_start_remote_tx(mcfuart *uart)
-    *MCF5206E_UOP1(MBAR, uart->chn) = 1;
+  *MCF5206E_UOP1(MBAR, uart->chn) = 1;
diff --git a/c/src/lib/libcpu/m68k/mcf5206/include/mcfmbus.h b/c/src/lib/libcpu/m68k/mcf5206/include/mcfmbus.h
index 9c6a5be..f70a70e 100644
--- a/c/src/lib/libcpu/m68k/mcf5206/include/mcfmbus.h
+++ b/c/src/lib/libcpu/m68k/mcf5206/include/mcfmbus.h
@@ -36,7 +36,7 @@ typedef struct mcfmbus {
     rtems_isr_entry        oldisr; /* Old interrupt handler */
     rtems_id               sema; /* MBUS semaphore */
     i2c_transfer_done      done; /* Transfer done function */
-    uint32_t       done_arg_ptr; /* Done function argument ptr */
+    uintptr_t      done_arg_ptr; /* Done function argument ptr */
 } mcfmbus;
 /* mcfmbus_initialize --
diff --git a/c/src/lib/libcpu/m68k/mcf5206/include/mcfuart.h b/c/src/lib/libcpu/m68k/mcf5206/include/mcfuart.h
index e919efa..bd9df5b 100644
--- a/c/src/lib/libcpu/m68k/mcf5206/include/mcfuart.h
+++ b/c/src/lib/libcpu/m68k/mcf5206/include/mcfuart.h
@@ -34,7 +34,7 @@ typedef struct mcfuart {
                                                 0 if polled I/O */
    void               *tty;              /* termios channel descriptor */
-   volatile const uint8_t  *tx_buf;      /* Transmit buffer from termios */
+   volatile const char     *tx_buf;      /* Transmit buffer from termios */
    volatile uint32_t        tx_buf_len;  /* Transmit buffer length */
    volatile uint32_t        tx_ptr;      /* Index of next char to transmit*/
    rtems_isr_entry          old_handler; /* Saved interrupt handler */
diff --git a/c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c b/c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c
index 1df8d95..d9e7008 100644
--- a/c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c
+++ b/c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c
@@ -1,6 +1,8 @@
  *  MCF5206e MBUS module (I2C bus) driver
@@ -15,15 +17,15 @@
 /* Events of I2C machine */
 typedef enum i2c_event {
-    EVENT_NONE,      /* Spurious event */
-    EVENT_TRANSFER,  /* Start new transfer */
-    EVENT_NEXTMSG,   /* Start processing of next message in transfer */
-    EVENT_ACK,       /* Sending finished with ACK */
-    EVENT_NACK,      /* Sending finished with NACK */
-    EVENT_TIMEOUT,   /* Timeout occured */
-    EVENT_DATA_RECV, /* Data received */
-    EVENT_ARB_LOST,  /* Arbitration lost */
-    EVENT_SLAVE      /* Addressed as a slave */
+  EVENT_NONE,      /* Spurious event */
+  EVENT_TRANSFER,  /* Start new transfer */
+  EVENT_NEXTMSG,   /* Start processing of next message in transfer */
+  EVENT_ACK,       /* Sending finished with ACK */
+  EVENT_NACK,      /* Sending finished with NACK */
+  EVENT_TIMEOUT,   /* Timeout occured */
+  EVENT_DATA_RECV, /* Data received */
+  EVENT_ARB_LOST,  /* Arbitration lost */
+  EVENT_SLAVE      /* Addressed as a slave */
 } i2c_event;
 static mcfmbus *mbus;
@@ -109,52 +111,42 @@ static mcfmbus *mbus;
 static i2c_event
 mcfmbus_get_event(mcfmbus *bus)
-    i2c_event event;
-    uint8_t   status, control;
-    rtems_interrupt_level level;
-    status = *MCF5206E_MBSR(bus->base);
-    control = *MCF5206E_MBCR(bus->base);
-    if (status & MCF5206E_MBSR_MIF) /* Interrupt occured */
-        if (status & MCF5206E_MBSR_MAAS)
-            event = EVENT_SLAVE;
-            *MCF5206E_MBCR(bus->base) = control; /* To clear Addressed As Slave
-                                                    condition */
-        else if (status & MCF5206E_MBSR_MAL) /* Arbitration lost */
-            *MCF5206E_MBSR(bus->base) = status & ~MCF5206E_MBSR_MAL;
-            event = EVENT_ARB_LOST;
-        else if (control & MCF5206E_MBCR_MTX) /* Trasmit mode */
-            if (status & MCF5206E_MBSR_RXAK)
-                event = EVENT_NACK;
-            else
-                event = EVENT_ACK;
-        else /* Received */
-            event = EVENT_DATA_RECV;
-        /* Clear interrupt condition */
-        *MCF5206E_MBSR(bus->base) &= ~MCF5206E_MBSR_MIF;
+  i2c_event event;
+  uint8_t   status, control;
+  rtems_interrupt_level level;
+  status = *MCF5206E_MBSR(bus->base);
+  control = *MCF5206E_MBCR(bus->base);
+  if (status & MCF5206E_MBSR_MIF) { /* Interrupt occured */
+    if (status & MCF5206E_MBSR_MAAS) {
+      event = EVENT_SLAVE;
+      *MCF5206E_MBCR(bus->base) = control; /* To clear Addressed As Slave
+                                              condition */
+    } else if (status & MCF5206E_MBSR_MAL) { /* Arbitration lost */
+      *MCF5206E_MBSR(bus->base) = status & ~MCF5206E_MBSR_MAL;
+      event = EVENT_ARB_LOST;
-    else
-        event = EVENT_NONE;
+    else if (control & MCF5206E_MBCR_MTX) { /* Trasmit mode */
+      if (status & MCF5206E_MBSR_RXAK)
+        event = EVENT_NACK;
+      else
+        event = EVENT_ACK;
+    } else { /* Received */
+      event = EVENT_DATA_RECV;
-    return event;
+    /* Clear interrupt condition */
+    *MCF5206E_MBSR(bus->base) &= ~MCF5206E_MBSR_MIF;
+  } else {
+    event = EVENT_NONE;
+  return event;
-static void
-mcfmbus_machine_error(mcfmbus *bus, i2c_event event)
+static void mcfmbus_machine_error(mcfmbus *bus, i2c_event event)
-    return;
 /* mcfmbus_machine --
@@ -167,445 +159,407 @@ mcfmbus_machine_error(mcfmbus *bus, i2c_event event)
  * RETURNS:
  *     none
-static void
-mcfmbus_machine(mcfmbus *bus, i2c_event event)
+static void mcfmbus_machine(mcfmbus *bus, i2c_event event)
-    uint8_t   b;
-    switch (bus->state)
-        case STATE_IDLE:
-            switch (event)
-                case EVENT_NEXTMSG:  /* Start new message processing */
-                    bus->cmsg++;
-                    /* FALLTHRU */
-                case EVENT_TRANSFER: /* Initiate new transfer */
-                    if (bus->cmsg - bus->msg >= bus->nmsg)
-                        mcfmbus_stop(bus);
-                        next_state(bus, STATE_IDLE);
-                        bus->msg = bus->cmsg = NULL;
-                        bus->nmsg = bus->byte = 0;
-                        bus->done(bus->done_arg_ptr);
-                        break;
-                    /* Initiate START or REPEATED START condition on the bus */
-                    if (event == EVENT_TRANSFER)
-                        mcfmbus_start(bus);
-                    else /* (event == EVENT_NEXTMSG) */
-                        mcfmbus_rstart(bus);
-                    bus->byte = 0;
-                    mcfmbus_tx_mode(bus);
-                    /* Initiate slave address sending */
-                    if (bus->cmsg->flags & I2C_MSG_ADDR_10)
-                        i2c_address a = bus->cmsg->addr;
-                        b = 0xf0 | (((a >> 8) & 0x03) << 1);
-                        if (bus->cmsg->flags & I2C_MSG_WR)
-                            mcfmbus_send(bus, b);
-                            next_state(bus, STATE_ADDR_1_W);
-                        else
-                            mcfmbus_send(bus, b | 1);
-                            next_state(bus, STATE_ADDR_1_R);
-                    else
-                        b = (bus->cmsg->addr & ~0x01);
-                            next_state(bus, STATE_SENDING);
-                        else
-                            next_state(bus, STATE_ADDR_7);
-                            b |= 1;
-                    break;
-                default:
-                    mcfmbus_machine_error(bus, event);
-                    break;
+  uint8_t   b;
+  switch (bus->state) {
+    case STATE_IDLE:
+      switch (event) {
+        case EVENT_NEXTMSG:  /* Start new message processing */
+          bus->cmsg++;
+          /* FALLTHRU */
+        case EVENT_TRANSFER: /* Initiate new transfer */
+          if (bus->cmsg - bus->msg >= bus->nmsg) {
+            mcfmbus_stop(bus);
+            next_state(bus, STATE_IDLE);
+            bus->msg = bus->cmsg = NULL;
+            bus->nmsg = bus->byte = 0;
+            bus->done((void *)bus->done_arg_ptr);
             break;
-        case STATE_ADDR_7:
-            switch (event)
-                case EVENT_ACK:
-                    mcfmbus_rx_mode(bus);
-                    if (bus->cmsg->len <= 1)
-                        mcfmbus_send_nack(bus);
-                    else
-                        mcfmbus_send_ack(bus);
-                    next_state(bus, STATE_RECEIVING);
-                    break;
-                case EVENT_NACK:
-                    mcfmbus_error(bus, I2C_NO_DEVICE);
-                    mcfmbus_machine(bus, EVENT_NEXTMSG);
-                    break;
-                case EVENT_ARB_LOST:
-                    mcfmbus_error(bus, I2C_ARBITRATION_LOST);
-                    break;
-                default:
-                    break;
+          /* Initiate START or REPEATED START condition on the bus */
+          if (event == EVENT_TRANSFER) {
+            mcfmbus_start(bus);
+          } else { /* (event == EVENT_NEXTMSG) */
+            mcfmbus_rstart(bus);
+          bus->byte = 0;
+          mcfmbus_tx_mode(bus);
+          /* Initiate slave address sending */
+          if (bus->cmsg->flags & I2C_MSG_ADDR_10) {
+            i2c_address a = bus->cmsg->addr;
+            b = 0xf0 | (((a >> 8) & 0x03) << 1);
+            if (bus->cmsg->flags & I2C_MSG_WR) {
+              mcfmbus_send(bus, b);
+              next_state(bus, STATE_ADDR_1_W);
+            } else {
+              mcfmbus_send(bus, b | 1);
+              next_state(bus, STATE_ADDR_1_R);
-            break;
-        case STATE_ADDR_1_R:
-        case STATE_ADDR_1_W:
-            switch (event)
-                case EVENT_ACK:
-                    uint8_t   b = (bus->cmsg->addr & 0xff);
-                    if (bus->state == STATE_ADDR_1_W)
-                    else
-                        i2c_address a;
-                        a = bus->cmsg->addr;
-                        b = 0xf0 | (((a >> 8) & 0x03) << 1) | 1;
-                    break;
-                case EVENT_NACK:
-                    break;
-                    break;
-                default:
-                    break;
+          } else {
+            b = (bus->cmsg->addr & ~0x01);
+              next_state(bus, STATE_SENDING);
+            } else {
+              next_state(bus, STATE_ADDR_7);
+              b |= 1;
-            break;
-        case STATE_SENDING:
-            switch (event)
-                case EVENT_ACK:
-                    if (bus->byte == bus->cmsg->len)
-                    else
-                        mcfmbus_send(bus, bus->cmsg->buf[bus->byte++]);
-                    break;
-                case EVENT_NACK:
-                    if (bus->byte == 0)
-                    else
-                        mcfmbus_error(bus, I2C_NO_ACKNOWLEDGE);
-                    break;
-                    break;
-                default:
-                    break;
+          break;
+        default:
+          mcfmbus_machine_error(bus, event);
             break;
+      break;
+    case STATE_ADDR_7:
+      switch (event) {
+        case EVENT_ACK:
+          mcfmbus_rx_mode(bus);
+          if (bus->cmsg->len <= 1)
+            mcfmbus_send_nack(bus);
+          else
+            mcfmbus_send_ack(bus);
+          next_state(bus, STATE_RECEIVING);
+          break;
+        case EVENT_NACK:
+          mcfmbus_error(bus, I2C_NO_DEVICE);
+          mcfmbus_machine(bus, EVENT_NEXTMSG);
+          break;
+        case EVENT_ARB_LOST:
+          mcfmbus_error(bus, I2C_ARBITRATION_LOST);
+          break;
+        default:
+          break;
+      break;
+    case STATE_ADDR_1_R:
+    case STATE_ADDR_1_W:
+      switch (event) {
+        case EVENT_ACK: {
+          uint8_t   b = (bus->cmsg->addr & 0xff);
+          if (bus->state == STATE_ADDR_1_W) {
+          } else {
+              i2c_address a;
+              a = bus->cmsg->addr;
+              b = 0xf0 | (((a >> 8) & 0x03) << 1) | 1;
+          break;
-        case STATE_RECEIVING:
-            switch (event)
-                case EVENT_DATA_RECV:
-                    if (bus->cmsg->len - bus->byte <= 2)
-                        if (bus->cmsg->len - bus->byte <= 1)
-                            if (bus->cmsg - bus->msg + 1 == bus->nmsg)
-                            else
-                    else
-                    bus->cmsg->buf[bus->byte++] = *MCF5206E_MBDR(bus->base);
-                    if (bus->cmsg->len == bus->byte)
-                        next_state(bus,STATE_IDLE);
-                    else
-                        next_state(bus,STATE_RECEIVING);
-                    break;
-                    break;
-                default:
-                    break;
-            break;
+        case EVENT_NACK:
+          break;
+          break;
+        default:
+          break;
+      break;
+    case STATE_SENDING:
+      switch (event) {
+        case EVENT_ACK:
+          if (bus->byte == bus->cmsg->len) {
+          } else {
+            mcfmbus_send(bus, bus->cmsg->buf[bus->byte++]);
+          break;
+        case EVENT_NACK:
+          if (bus->byte == 0) {
+          } else {
+            mcfmbus_error(bus, I2C_NO_ACKNOWLEDGE);
+          break;
+          break;
+        default:
+          break;
+      break;
+    case STATE_RECEIVING:
+      switch (event) {
+        case EVENT_DATA_RECV:
+          if (bus->cmsg->len - bus->byte <= 2) {
+            if (bus->cmsg->len - bus->byte <= 1) {
+                if (bus->cmsg - bus->msg + 1 == bus->nmsg)
+                else
+          } else {
+          bus->cmsg->buf[bus->byte++] = *MCF5206E_MBDR(bus->base);
+          if (bus->cmsg->len == bus->byte) {
+            next_state(bus,STATE_IDLE);
+          } else {
+            next_state(bus,STATE_RECEIVING);
+          break;
+          break;
+        default:
+          break;
+      break;
 /* mcfmbus_interrupt_handler --
- *     MBUS module interrupt handler routine
- * PARAMETERS:
- *     vector - interrupt vector number (not used)
- * RETURNS:
- *     none
-rtems_isr
-mcfmbus_interrupt_handler(rtems_vector_number vector)
+*     MBUS module interrupt handler routine
+* PARAMETERS:
+*     vector - interrupt vector number (not used)
+* RETURNS:
+*     none
+static rtems_isr mcfmbus_interrupt_handler(rtems_vector_number vector)
-    i2c_event event;
-    event = mcfmbus_get_event(mbus);
-    mcfmbus_machine(mbus, event);
+  i2c_event event;
+  event = mcfmbus_get_event(mbus);
+  mcfmbus_machine(mbus, event);
 /* mcfmbus_poll --
- *     MBUS module poll routine; used to poll events when I2C driver
- *     operates in poll-driven mode.
- * PARAMETERS:
- *     none
- * RETURNS:
- *     none
+*     MBUS module poll routine; used to poll events when I2C driver
+*     operates in poll-driven mode.
+* PARAMETERS:
+*     none
+* RETURNS:
+*     none
 void
 mcfmbus_poll(mcfmbus *bus)
-    i2c_event event;
-    event = mcfmbus_get_event(bus);
-    if (event != EVENT_NONE)
-        mcfmbus_machine(bus, event);
+  i2c_event event;
+  event = mcfmbus_get_event(bus);
+  if (event != EVENT_NONE)
+      mcfmbus_machine(bus, event);
 /* mcfmbus_select_clock_divider --
- *     Select divider for system clock which is used for I2C bus clock
- *     generation. Not each divider can be selected for I2C bus; this
- *     function select nearest larger or equal divider.
- * PARAMETERS:
- *     i2c_bus - pointer to the bus descriptor structure
- *     divider - system frequency divider for I2C serial clock.
- * RETURNS:
- *     RTEMS_SUCCESSFUL, if operation performed successfully, or
- *     RTEMS error code when failed.
+*     Select divider for system clock which is used for I2C bus clock
+*     generation. Not each divider can be selected for I2C bus; this
+*     function select nearest larger or equal divider.
+* PARAMETERS:
+*     i2c_bus - pointer to the bus descriptor structure
+*     divider - system frequency divider for I2C serial clock.
+* RETURNS:
+*     RTEMS_SUCCESSFUL, if operation performed successfully, or
+*     RTEMS error code when failed.
 rtems_status_code
 mcfmbus_select_clock_divider(mcfmbus *i2c_bus, int divider)
-    int i;
-    int mbc;
-    struct {
-        int divider;
-        int mbc;
-    } dividers[] ={
-        { 20,   0x20 }, { 22,   0x21 }, { 24,   0x22 }, { 26,   0x23 },
-        { 28,   0x00 }, { 30,   0x01 }, { 32,   0x25 }, { 34,   0x02 },
-        { 36,   0x26 }, { 40,   0x03 }, { 44,   0x04 }, { 48,   0x05 },
-        { 56,   0x06 }, { 64,   0x2a }, { 68,   0x07 }, { 72,   0x2B },
-        { 80,   0x08 }, { 88,   0x09 }, { 96,   0x2D }, { 104,  0x0A },
-        { 112,  0x2E }, { 128,  0x0B }, { 144,  0x0C }, { 160,  0x0D },
-        { 192,  0x0E }, { 224,  0x32 }, { 240,  0x0F }, { 256,  0x33 },
-        { 288,  0x10 }, { 320,  0x11 }, { 384,  0x12 }, { 448,  0x36 },
-        { 480,  0x13 }, { 512,  0x37 }, { 576,  0x14 }, { 640,  0x15 },
-        { 768,  0x16 }, { 896,  0x3A }, { 960,  0x17 }, { 1024, 0x3B },
-        { 1152, 0x18 }, { 1280, 0x19 }, { 1536, 0x1A }, { 1792, 0x3E },
-        { 1920, 0x1B }, { 2048, 0x3F }, { 2304, 0x1C }, { 2560, 0x1D },
-        { 3072, 0x1E }, { 3840, 0x1F }
-    if (i2c_bus == NULL)
-    for (i = 0, mbc = -1; i < sizeof(dividers)/sizeof(dividers[0]); i++)
-        mbc = dividers[i].mbc;
-        if (dividers[i].divider >= divider)
-            break;
+  int i;
+  int mbc;
+  struct {
+      int divider;
+      int mbc;
+  } dividers[] ={
+      { 20,   0x20 }, { 22,   0x21 }, { 24,   0x22 }, { 26,   0x23 },
+      { 28,   0x00 }, { 30,   0x01 }, { 32,   0x25 }, { 34,   0x02 },
+      { 36,   0x26 }, { 40,   0x03 }, { 44,   0x04 }, { 48,   0x05 },
+      { 56,   0x06 }, { 64,   0x2a }, { 68,   0x07 }, { 72,   0x2B },
+      { 80,   0x08 }, { 88,   0x09 }, { 96,   0x2D }, { 104,  0x0A },
+      { 112,  0x2E }, { 128,  0x0B }, { 144,  0x0C }, { 160,  0x0D },
+      { 192,  0x0E }, { 224,  0x32 }, { 240,  0x0F }, { 256,  0x33 },
+      { 288,  0x10 }, { 320,  0x11 }, { 384,  0x12 }, { 448,  0x36 },
+      { 480,  0x13 }, { 512,  0x37 }, { 576,  0x14 }, { 640,  0x15 },
+      { 768,  0x16 }, { 896,  0x3A }, { 960,  0x17 }, { 1024, 0x3B },
+      { 1152, 0x18 }, { 1280, 0x19 }, { 1536, 0x1A }, { 1792, 0x3E },
+      { 1920, 0x1B }, { 2048, 0x3F }, { 2304, 0x1C }, { 2560, 0x1D },
+      { 3072, 0x1E }, { 3840, 0x1F }
+  if (i2c_bus == NULL)
+  for (i = 0, mbc = -1; i < sizeof(dividers)/sizeof(dividers[0]); i++) {
+    mbc = dividers[i].mbc;
+    if (dividers[i].divider >= divider) {
+      break;
-    *MCF5206E_MFDR(i2c_bus->base) = mbc;
+  *MCF5206E_MFDR(i2c_bus->base) = mbc;
- *     Initialize ColdFire MBUS I2C bus controller.
- * PARAMETERS:
- *     base    - ColdFire internal peripherial base address
- * RETURNS:
- *     RTEMS_SUCCESSFUL, or RTEMS error code when initialization failed.
-rtems_status_code
-mcfmbus_initialize(mcfmbus *i2c_bus, uint32_t   base)
+*     Initialize ColdFire MBUS I2C bus controller.
+* PARAMETERS:
+*     base    - ColdFire internal peripherial base address
+* RETURNS:
+*     RTEMS_SUCCESSFUL, or RTEMS error code when initialization failed.
+rtems_status_code mcfmbus_initialize(mcfmbus *i2c_bus, uint32_t   base)
-    if (mbus != NULL) /* Check if already initialized */
-        return RTEMS_RESOURCE_IN_USE;
-    i2c_bus->base = base;
-    i2c_bus->state = STATE_IDLE;
-    i2c_bus->msg = NULL;
-    i2c_bus->cmsg = NULL;
-    i2c_bus->nmsg = 0;
-    i2c_bus->byte = 0;
-    sc = rtems_interrupt_catch(
-        mcfmbus_interrupt_handler,
-        24 + ((*MCF5206E_ICR(base, MCF5206E_INTR_MBUS) & MCF5206E_ICR_IL) >>
-                                   MCF5206E_ICR_IL_S),
-        &i2c_bus->oldisr
-    if (sc != RTEMS_SUCCESSFUL)
-        return sc;
-    mbus = i2c_bus;
-    *MCF5206E_IMR(base) &= ~MCF5206E_INTR_BIT(MCF5206E_INTR_MBUS);
-    *MCF5206E_MBCR(base) = 0;
-    *MCF5206E_MBSR(base) = 0;
-    *MCF5206E_MBDR(base) = 0x1F; /* Maximum possible divider is 3840 */
-    *MCF5206E_MBCR(base) = MCF5206E_MBCR_MEN | MCF5206E_MBCR_MIEN;
+  if (mbus != NULL) /* Check if already initialized */
+    return RTEMS_RESOURCE_IN_USE;
+  i2c_bus->base = base;
+  i2c_bus->state = STATE_IDLE;
+  i2c_bus->msg = NULL;
+  i2c_bus->cmsg = NULL;
+  i2c_bus->nmsg = 0;
+  i2c_bus->byte = 0;
+  sc = rtems_interrupt_catch(
+      mcfmbus_interrupt_handler,
+      24 + ((*MCF5206E_ICR(base, MCF5206E_INTR_MBUS) & MCF5206E_ICR_IL) >>
+                                 MCF5206E_ICR_IL_S),
+      &i2c_bus->oldisr
+  if (sc != RTEMS_SUCCESSFUL)
+    return sc;
+  mbus = i2c_bus;
+  *MCF5206E_IMR(base) &= ~MCF5206E_INTR_BIT(MCF5206E_INTR_MBUS);
+  *MCF5206E_MBCR(base) = 0;
+  *MCF5206E_MBSR(base) = 0;
+  *MCF5206E_MBDR(base) = 0x1F; /* Maximum possible divider is 3840 */
+  *MCF5206E_MBCR(base) = MCF5206E_MBCR_MEN | MCF5206E_MBCR_MIEN;
 /* mcfmbus_i2c_transfer --
- *     Initiate multiple-messages transfer over I2C bus via ColdFire MBUS
- *     controller.
- * PARAMETERS:
- *     bus - pointer to MBUS controller descriptor
- *     nmsg - number of messages
- *     msg - pointer to messages array
- *     done - function which is called when transfer is finished
- *     done_arg_ptr - arbitrary argument ptr passed to done funciton
- * RETURNS:
- *     RTEMS_SUCCESSFUL if transfer initiated successfully, or error
- *     code when failed.
-rtems_status_code
-mcfmbus_i2c_transfer(mcfmbus *bus, int nmsg, i2c_message *msg,
-                     i2c_transfer_done done, void *done_arg_ptr)
+*     Initiate multiple-messages transfer over I2C bus via ColdFire MBUS
+*     controller.
+* PARAMETERS:
+*     bus - pointer to MBUS controller descriptor
+*     nmsg - number of messages
+*     msg - pointer to messages array
+*     done - function which is called when transfer is finished
+*     done_arg_ptr - arbitrary argument ptr passed to done funciton
+* RETURNS:
+*     RTEMS_SUCCESSFUL if transfer initiated successfully, or error
+*     code when failed.
+rtems_status_code mcfmbus_i2c_transfer(
+  mcfmbus *bus,
+  int nmsg,
+  i2c_message *msg,
+  i2c_transfer_done done,
+  void *done_arg_ptr
-    if (bus != mbus)
-        return RTEMS_NOT_CONFIGURED;
-    bus->done = done;
-    bus->done_arg_ptr = done_arg_ptr;
-    bus->cmsg = bus->msg = msg;
-    bus->nmsg = nmsg;
-    bus->byte = 0;
-    bus->state = STATE_IDLE;
-    mcfmbus_machine(bus, EVENT_TRANSFER);
+  if (bus != mbus)
+    return RTEMS_NOT_CONFIGURED;
+  bus->done = done;
+  bus->done_arg_ptr = (uintptr_t) done_arg_ptr;
+  bus->cmsg = bus->msg = msg;
+  bus->nmsg = nmsg;
+  bus->byte = 0;
+  bus->state = STATE_IDLE;
+  mcfmbus_machine(bus, EVENT_TRANSFER);
 /* mcfmbus_i2c_done --
- *     Close ColdFire MBUS I2C bus controller and release all resources.
- * PARAMETERS:
- * RETURNS:
- *     RTEMS_SUCCESSFUL, if transfer initiated successfully, or error
-rtems_status_code
-mcfmbus_i2c_done(mcfmbus *i2c_bus)
+*     Close ColdFire MBUS I2C bus controller and release all resources.
+* PARAMETERS:
+* RETURNS:
+*     RTEMS_SUCCESSFUL, if transfer initiated successfully, or error
+rtems_status_code mcfmbus_i2c_done(mcfmbus *i2c_bus)
-    uint32_t   base;
-    if (mbus == NULL)
-    if (mbus != i2c_bus)
-    base = i2c_bus->base;
-    *MCF5206E_IMR(base) |= MCF5206E_INTR_BIT(MCF5206E_INTR_MBUS);
-        i2c_bus->oldisr,
-        NULL
-    return sc;
+  uint32_t   base;
+  if (mbus == NULL)
+  if (mbus != i2c_bus)
+  base = i2c_bus->base;
+  *MCF5206E_IMR(base) |= MCF5206E_INTR_BIT(MCF5206E_INTR_MBUS);
+      i2c_bus->oldisr,
+      NULL
+  return sc;
1.9.3
