[PATCH 08/42] powerpc/mvme5500/pci/pcifinddevice.c: Remove unused variable
Fri Oct 17 15:23:24 UTC 2014
 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c | 15 ++++++---------
 1 file changed, 6 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c b/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
index ac2f050..493388a 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
@@ -1,13 +1,12 @@
-/* pcifinddevice.c
- * Copyright 2001,  Till Straumann <strauman at slac.stanford.edu>
  * find a particular PCI device
  * (we assume, the firmware configured the PCI bus[es] for us)
+ * Copyright 2001,  Till Straumann <strauman at slac.stanford.edu>
  * Kate Feng <feng1 at bnl.gov>, modified it to support the mvme5500 board.
 #include <bsp/pci.h>
@@ -19,10 +18,8 @@ static int BSP_pciDebug=0;
 int BSP_pciFindDevicePrint(unsigned short vendorid, unsigned short deviceid,
                    int instance, int *pbus, int *pdev, int *pfun )
-  int x;
   BSP_pciDebug = 1;
-  x=pci_find_device(vendorid, deviceid, instance, pbus, pdev, pfun );
+  (void) pci_find_device(vendorid, deviceid, instance, pbus, pdev, pfun );
   BSP_pciDebug = 0;
   return 0;
1.9.3
