[PATCH 18/42] powerpc/beatnik: Fix warnings
Fri Oct 17 15:23:34 UTC 2014
 c/src/lib/libbsp/powerpc/beatnik/include/bsp.h     | 140 ++++---
 .../lib/libbsp/powerpc/beatnik/irq/discovery_pic.c |   2 +-
 .../lib/libbsp/powerpc/beatnik/marvell/gt_timer.c  | 406 ++++++++++-----------
 .../lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c  | 260 +++++++------
 .../lib/libbsp/powerpc/beatnik/startup/bspstart.c  |   9 +-
 c/src/lib/libbsp/powerpc/beatnik/vme/VMEConfig.h   |  81 ++--
 6 files changed, 467 insertions(+), 431 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h b/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h
index c7f8cae..9cc9ae0 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/beatnik/include/bsp.h
@@ -1,6 +1,8 @@
  *  bsp.h  -- contain BSP API definition.
  *  Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
  *  The license and distribution terms for this file may be
@@ -11,9 +13,12 @@
  *  Modified for the 'beatnik' BSP by T. Straumann, 2005-2007.
 #ifndef LIBBSP_BEATNIK_BSP_H
 #define LIBBSP_BEATNIK_BSP_H
+#ifndef ASM
 #include <bspopts.h>
 #include <bsp/default-initial-extension.h>
@@ -24,26 +29,25 @@
 #include <bsp/vectors.h>
 #ifdef __cplusplus
-  extern "C" {
+extern "C" {
 #endif
 /* Board type */
 typedef enum {
-	Unknown = 0,
-	MVME5500,
-	MVME6100
+  Unknown = 0,
+  MVME5500,
+  MVME6100
 } BSP_BoardType;
-BSP_BoardType
-BSP_getBoardType();
+BSP_BoardType BSP_getBoardType(void);
 /* Discovery Version */
 typedef enum {
-	unknown    = 0,
-	GT_64260_A,		/* Revision 0x10 */
-	GT_64260_B,	    /* Revision 0x20 */
-	MV_64360,
+  unknown    = 0,
+  GT_64260_A,      /* Revision 0x10 */
+  GT_64260_B,      /* Revision 0x20 */
+  MV_64360,
 } DiscoveryVersion;
 /* Determine the type of discovery chip on this board; info
@@ -52,9 +56,7 @@ typedef enum {
  * If a non-zero argument is passed, the routine panics
  * (BSP_panic) if no recognized bridge is found;
-DiscoveryVersion
-BSP_getDiscoveryVersion(int assertion);
+DiscoveryVersion BSP_getDiscoveryVersion(int assertion);
  *  confdefs.h overrides for this BSP:
@@ -65,18 +67,18 @@ BSP_getDiscoveryVersion(int assertion);
  *  base address definitions for several devices
-#define BSP_MV64x60_BASE    		(0xf1000000)
-#define BSP_MV64x60_DEV1_BASE		(0xf1100000)
-#define BSP_UART_IOBASE_COM1 		((BSP_MV64x60_DEV1_BASE)+0x20000)
-#define BSP_UART_IOBASE_COM2 		((BSP_MV64x60_DEV1_BASE)+0x21000)
+#define BSP_MV64x60_BASE        (0xf1000000)
+#define BSP_MV64x60_DEV1_BASE   (0xf1100000)
+#define BSP_UART_IOBASE_COM1    ((BSP_MV64x60_DEV1_BASE)+0x20000)
+#define BSP_UART_IOBASE_COM2    ((BSP_MV64x60_DEV1_BASE)+0x21000)
 #define BSP_UART_USE_SHARED_IRQS
-#define BSP_NVRAM_BASE_ADDR			(0xf1110000)
-#define BSP_NVRAM_END_ADDR			(0xf1117fff)
-#define BSP_NVRAM_RTC_START			(0xf1117ff8)
+#define BSP_NVRAM_BASE_ADDR      (0xf1110000)
+#define BSP_NVRAM_END_ADDR       (0xf1117fff)
+#define BSP_NVRAM_RTC_START      (0xf1117ff8)
-#define BSP_NVRAM_BOOTPARMS_START	(0xf1111000)
-#define BSP_NVRAM_BOOTPARMS_END		(0xf1111fff)
+#define BSP_NVRAM_BOOTPARMS_START  (0xf1111000)
+#define BSP_NVRAM_BOOTPARMS_END    (0xf1111fff)
 /* This is only active/used during early init. It defines
@@ -85,18 +87,22 @@ BSP_getDiscoveryVersion(int assertion);
  * override the PCI configuration (see gt_pci_init.c:BSP_pci_initialize)
-#define PCI_CONFIG_ADDR				(BSP_MV64x60_BASE + 0xcf8)
-#define PCI_CONFIG_DATA				(BSP_MV64x60_BASE + 0xcfc)
+#define PCI_CONFIG_ADDR        (BSP_MV64x60_BASE + 0xcf8)
+#define PCI_CONFIG_DATA        (BSP_MV64x60_BASE + 0xcfc)
 /* our wonderful PCI initialization remaps everything to CPU addresses
  * - before calling BSP_pci_initialize() this is NOT VALID, however
  * and the deprecated inl()/outl() etc won't work!
-#define _IO_BASE					0x00000000
-/* wonderful MotLoad has the base address as seen from the CPU programmed into config space :-) */
-#define PCI_MEM_BASE				0
-#define PCI_MEM_BASE_ADJUSTMENT		0
-#define PCI_DRAM_OFFSET				0
+#define _IO_BASE          0x00000000
+/* wonderful MotLoad has the base address as seen from the
+ * CPU programmed into config space :-)
+#define PCI_MEM_BASE               0
+#define PCI_MEM_BASE_ADJUSTMENT    0
+#define PCI_DRAM_OFFSET            0
+extern void BSP_motload_pci_fixup(void);
 /* PCI <-> local address mapping - no sophisticated windows
  * (i.e., no support for cached regions etc. you read a BAR
@@ -106,20 +112,20 @@ BSP_getDiscoveryVersion(int assertion);
 #define BSP_PCI2LOCAL_ADDR(a) ((uint32_t)(a))
 #define BSP_LOCAL2PCI_ADDR(a) ((uint32_t)(a))
-#define BSP_CONFIG_NUM_PCI_CACHE_SLOTS	32
+#define BSP_CONFIG_NUM_PCI_CACHE_SLOTS  32
-#define BSP_CONSOLE_PORT			BSP_UART_COM1
-#define BSP_UART_BAUD_BASE			115200
+#define BSP_CONSOLE_PORT      BSP_UART_COM1
+#define BSP_UART_BAUD_BASE    115200
 /* I2C Devices */
 /* Note that the i2c addresses stated in the manual are
  * left-shifted by one bit.
-#define BSP_VPD_I2C_ADDR			(0xA8>>1)		/* the VPD EEPROM  */
-#define BSP_USR_I2C_ADDR			(0xAA>>1)		/* the user EEPROM */
-#define BSP_THM_I2C_ADDR			(0x90>>1)		/* the DS1621 temperature sensor & thermostat */
+#define BSP_VPD_I2C_ADDR      (0xA8>>1)    /* the VPD EEPROM  */
+#define BSP_USR_I2C_ADDR      (0xAA>>1)    /* the user EEPROM */
+#define BSP_THM_I2C_ADDR      (0x90>>1)    /* the DS1621 temperature sensor & thermostat */
-#define BSP_I2C_BUS_DESCRIPTOR		gt64260_i2c_bus_descriptor
+#define BSP_I2C_BUS_DESCRIPTOR    gt64260_i2c_bus_descriptor
 #define BSP_I2C_BUS0_NAME             "/dev/i2c0"
@@ -129,11 +135,11 @@ BSP_getDiscoveryVersion(int assertion);
 #define BSP_I2C_THM_NAME              BSP_I2C_DS1621_NAME
 #define BSP_I2C_DS1621_RAW_NAME       "ds1621-raw"
-#define	BSP_I2C_VPD_EEPROM_DEV_NAME      (BSP_I2C_BUS0_NAME"."BSP_I2C_VPD_EEPROM_NAME)
-#define	BSP_I2C_USR_EEPROM_DEV_NAME      (BSP_I2C_BUS0_NAME"."BSP_I2C_USR_EEPROM_NAME)
-#define	BSP_I2C_DS1621_DEV_NAME          (BSP_I2C_BUS0_NAME"."BSP_I2C_DS1621_NAME)
+#define  BSP_I2C_VPD_EEPROM_DEV_NAME      (BSP_I2C_BUS0_NAME"."BSP_I2C_VPD_EEPROM_NAME)
+#define  BSP_I2C_USR_EEPROM_DEV_NAME      (BSP_I2C_BUS0_NAME"."BSP_I2C_USR_EEPROM_NAME)
+#define  BSP_I2C_DS1621_DEV_NAME          (BSP_I2C_BUS0_NAME"."BSP_I2C_DS1621_NAME)
 #define BSP_I2C_THM_DEV_NAME              BSP_I2C_DS1621_DEV_NAME
-#define	BSP_I2C_DS1621_RAW_DEV_NAME      (BSP_I2C_BUS0_NAME"."BSP_I2C_DS1621_RAW_NAME)
+#define  BSP_I2C_DS1621_RAW_DEV_NAME      (BSP_I2C_BUS0_NAME"."BSP_I2C_DS1621_RAW_NAME)
 /* Initialize the I2C driver and register all devices
@@ -148,8 +154,7 @@ BSP_getDiscoveryVersion(int assertion);
  *   /dev/i2c0.ds1621       (read-only; one byte: board-temp in degC)
  *   /dev/i2c0.ds1621-raw   (read-write; transfer bytes to/from the ds1621)
-int
-BSP_i2c_initialize();
+int BSP_i2c_initialize(void);
 /* Networking; */
 #if defined(RTEMS_NETWORKING)
@@ -157,27 +162,29 @@ BSP_i2c_initialize();
 #endif
 /* NOT FOR PUBLIC USE BELOW HERE */
-#define BSP_PCI_HOSE0_MEM_BASE		0x80000000	/* must be aligned to size */
-#define BSP_PCI_HOSE0_MEM_SIZE		0x20000000
+#define BSP_PCI_HOSE0_MEM_BASE    0x80000000  /* must be aligned to size */
+#define BSP_PCI_HOSE0_MEM_SIZE    0x20000000
-#define BSP_PCI_HOSE1_MEM_BASE		0xe0000000
+#define BSP_PCI_HOSE1_MEM_BASE    0xe0000000
-#define BSP_DEV_AND_PCI_IO_BASE 	0xf0000000
-#define BSP_DEV_AND_PCI_IO_SIZE 	0x10000000
+#define BSP_DEV_AND_PCI_IO_BASE   0xf0000000
+#define BSP_DEV_AND_PCI_IO_SIZE   0x10000000
-/* maintain coherency between CPU and GT64340 ethernet (& possibly other discovery components) */
-#define BSP_RW_PAGE_ATTRIBUTES	TRIV121_ATTR_M
+/* maintain coherency between CPU and GT64340 Ethernet
+ * (andpossibly other Discovery components).
+#define BSP_RW_PAGE_ATTRIBUTES  TRIV121_ATTR_M
 extern unsigned BSP_pci_hose1_bus_base;
-void BSP_pci_initialize();
+void BSP_pci_initialize(void);
 /* Exception Handling */
 /* Use a task notepad to attach user exception handler info;
  * may be changed by application startup code (EPICS uses 11)
-#define BSP_EXCEPTION_NOTEPAD		14
+#define BSP_EXCEPTION_NOTEPAD    14
 #ifndef ASM
@@ -257,14 +264,37 @@ extern unsigned long _BSP_clear_hostbridge_errors(int enableMCP, int quiet);
  *            16-bit error status on error.
-extern unsigned short
-(*_BSP_clear_vmebridge_errors)(int);
+extern unsigned short (*_BSP_clear_vmebridge_errors)(int);
+ * Prototypes for debug helpers
+void discovery_pic_set_debug_irq(int on);
+void discovery_pic_install_debug_irq(void);
+ * Prototypes for methods called only from .S for dependency tracking
+char *save_boot_params(
+  void *r3,
+  void *r4,
+  void *r5,
+  char *cmdline_start,
+  char *cmdline_end
+void zero_bss(void);
+ * Prototypes for methods in the BSP that cross file boundaries
+uint32_t probeMemoryEnd(void);
 #endif
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif
diff --git a/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c b/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c
index de19f31..8efe2ce 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c
@@ -196,7 +196,7 @@ int i;
-void discovery_dump_picregs(void)
+static void discovery_dump_picregs(void)
 		printk("       ..GPP_IRQ. -- ..MAIN_HI. -- ..MAIN_LO.\n");
 		printk("Cause:"); pregs(thePic.causes);
diff --git a/c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c b/c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c
index d70c6a9..e53e8e1 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c
@@ -14,13 +14,13 @@
  * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
  *     created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
- * 	   Stanford Linear Accelerator Center, Stanford University.
+ *      Stanford Linear Accelerator Center, Stanford University.
  * Acknowledgement of sponsorship
  * The 'beatnik' BSP was produced by
  *     the Stanford Linear Accelerator Center, Stanford University,
- * 	   under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ *      under Contract DE-AC03-76SFO0515 with the Department of Energy.
  * Government disclaimer of liability
@@ -53,6 +53,7 @@
  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
 #include <bsp/gtreg.h>
 #include <libcpu/io.h>
@@ -68,199 +69,196 @@
 static inline uint32_t gt_rd(uint32_t off)
-		return in_le32( (volatile unsigned *)(BSP_MV64x60_BASE+off) );
+  return in_le32( (volatile unsigned *)(BSP_MV64x60_BASE+off) );
 static inline void gt_wr(uint32_t off, uint32_t val)
-		out_le32( (volatile unsigned *)(BSP_MV64x60_BASE+off), val);
+  out_le32( (volatile unsigned *)(BSP_MV64x60_BASE+off), val);
 static inline uint32_t gt_timer_bitmod(uint32_t off, uint32_t clr, uint32_t set)
-	unsigned	flags;
-	uint32_t	rval;
-		rtems_interrupt_disable(flags);
-			rval = gt_rd( off );
-			gt_wr( off, (rval & ~clr) | set );
-		rtems_interrupt_enable(flags);
-	return rval;
+  unsigned  flags;
+  uint32_t  rval;
+  rtems_interrupt_disable(flags);
+    rval = gt_rd( off );
+    gt_wr( off, (rval & ~clr) | set );
+  rtems_interrupt_enable(flags);
+  return rval;
-#define GT_TIMER_MAX			3
-#define TIMER_ARGCHECK(t)	do { if ((t)<0 || (t)>GT_TIMER_MAX) return -1; } while (0)
+#define GT_TIMER_MAX      3
+#define TIMER_ARGCHECK(t)  do { if ((t)<0 || (t)>GT_TIMER_MAX) return -1; } while (0)
 static struct {
-	void (*isr)(void *);
-	void  *arg;
+  void (*isr)(void *);
+  void  *arg;
 } gt_timer_isrs[GT_TIMER_MAX+1] = {{0},};
 uint32_t BSP_timer_read(uint32_t timer)
-	TIMER_ARGCHECK(timer);
-	return gt_rd(GT_TIMER_0 + (timer<<2));
+  TIMER_ARGCHECK(timer);
+  return gt_rd(GT_TIMER_0 + (timer<<2));
 int
 BSP_timer_start(uint32_t timer, uint32_t period)
-	gt_wr(GT_TIMER_0 + (timer<<2), period);
-	return 0;
+  gt_wr(GT_TIMER_0 + (timer<<2), period);
+  return 0;
 int
 BSP_timer_stop(uint32_t timer)
-	/* disable, clear period, re-enable */
-	gt_timer_bitmod(GT_TIMER_0_3_Ctl, GT_TIMER_0_Ctl_Enb << (timer<<3), 0);
-	gt_wr(GT_TIMER_0 + (timer<<2), 0);
-	gt_timer_bitmod(GT_TIMER_0_3_Ctl, 0, GT_TIMER_0_Ctl_Enb << (timer<<3));
-	return 0;
+  /* disable, clear period, re-enable */
+  gt_timer_bitmod(GT_TIMER_0_3_Ctl, GT_TIMER_0_Ctl_Enb << (timer<<3), 0);
+  gt_wr(GT_TIMER_0 + (timer<<2), 0);
+  gt_timer_bitmod(GT_TIMER_0_3_Ctl, 0, GT_TIMER_0_Ctl_Enb << (timer<<3));
+  return 0;
 int
 BSP_timer_setup(uint32_t timer, void (*isr)(void *arg), void *arg, int reload)
-	if ( isr && gt_timer_isrs[timer].isr )
-		return -1;
-	BSP_timer_stop(timer);
-	/* mask and clear */
-	gt_timer_bitmod(GT_TIMER_0_3_Intr_Msk, GT_TIMER_0_Intr<<timer, 0);
-	gt_timer_bitmod(GT_TIMER_0_3_Intr_Cse, GT_TIMER_0_Intr<<timer, 0);
-	/* set reload bit */
-	if ( reload )
-		gt_timer_bitmod(GT_TIMER_0_3_Ctl, 0, GT_TIMER_0_Ctl_Rld << (timer<<3));
-	else
-		gt_timer_bitmod(GT_TIMER_0_3_Ctl, GT_TIMER_0_Ctl_Rld << (timer<<3), 0);
-	asm volatile("":::"memory");
-	if ( isr ) {
-		gt_timer_isrs[timer].isr = isr;
-		gt_timer_isrs[timer].arg = arg;
-		gt_timer_bitmod(GT_TIMER_0_3_Intr_Msk, 0, GT_TIMER_0_Intr<<timer);
-	} else {
-		gt_timer_isrs[timer].isr = 0;
-		gt_timer_isrs[timer].arg = 0;
-	return 0;
+  if ( isr && gt_timer_isrs[timer].isr )
+    return -1;
+  BSP_timer_stop(timer);
+  /* mask and clear */
+  gt_timer_bitmod(GT_TIMER_0_3_Intr_Msk, GT_TIMER_0_Intr<<timer, 0);
+  gt_timer_bitmod(GT_TIMER_0_3_Intr_Cse, GT_TIMER_0_Intr<<timer, 0);
+  /* set reload bit */
+  if ( reload )
+    gt_timer_bitmod(GT_TIMER_0_3_Ctl, 0, GT_TIMER_0_Ctl_Rld << (timer<<3));
+  else
+    gt_timer_bitmod(GT_TIMER_0_3_Ctl, GT_TIMER_0_Ctl_Rld << (timer<<3), 0);
+  asm volatile("":::"memory");
+  if ( isr ) {
+    gt_timer_isrs[timer].isr = isr;
+    gt_timer_isrs[timer].arg = arg;
+    gt_timer_bitmod(GT_TIMER_0_3_Intr_Msk, 0, GT_TIMER_0_Intr<<timer);
+  } else {
+    gt_timer_isrs[timer].isr = 0;
+    gt_timer_isrs[timer].arg = 0;
+  return 0;
 static void
 gt_timer_hdl(rtems_irq_hdl_param arg)
-int	  iarg = (int)arg;
-int       timer;
-uint32_t  bit;
-	for ( ; iarg; iarg >>= 4 ) {
-		timer = (iarg & 0xf)-1;
-		bit   = GT_TIMER_0_Intr<<timer;
-		if ( gt_timer_bitmod(GT_TIMER_0_3_Intr_Cse, bit, 0) & bit ) {
-			/* cause was set */
-			if ( ! gt_timer_isrs[timer].isr ) {
-				printk("gt_timer: warning; no ISR connected but and IRQ happened (timer # %i)\n", timer);
-				/* mask */
-				gt_timer_bitmod(GT_TIMER_0_3_Intr_Msk, bit, 0);
-			} else {
-				gt_timer_isrs[timer].isr(gt_timer_isrs[timer].arg);
+  int       iarg = (int)arg;
+  int       timer;
+  uint32_t  bit;
+  for ( ; iarg; iarg >>= 4 ) {
+    timer = (iarg & 0xf)-1;
+    bit   = GT_TIMER_0_Intr<<timer;
+    if ( gt_timer_bitmod(GT_TIMER_0_3_Intr_Cse, bit, 0) & bit ) {
+      /* cause was set */
+      if ( ! gt_timer_isrs[timer].isr ) {
+        printk("gt_timer: warning; no ISR connected but and IRQ happened (timer # %i)\n", timer);
+        /* mask */
+        gt_timer_bitmod(GT_TIMER_0_3_Intr_Msk, bit, 0);
+      } else {
+        gt_timer_isrs[timer].isr(gt_timer_isrs[timer].arg);
 int
 BSP_timers_initialize(void)
-rtems_irq_connect_data xx = {0};
-int                    i, ainc, arg;
-	xx.hdl    = gt_timer_hdl;
-	xx.on     = 0;
-	xx.off    = 0;
-	xx.isOn   = 0;
-	switch (BSP_getDiscoveryVersion(0)) {
-		case MV_64360:
-			i    = 3;
-			ainc = 1;
-			arg  = 4;
-			break;
-		default:
-			i    = 1;
-			ainc = 0x0202;
-			arg  = 0x0403;
-			break;
-	for ( ; i>=0; i--, arg-=ainc ) {
-		xx.name   = BSP_IRQ_TIME0_1 + i;
-		xx.handle = (rtems_irq_hdl_param)arg;
-		if ( !BSP_install_rtems_irq_handler(&xx) )
-			return -1;
-	return 0;
+  rtems_irq_connect_data xx = {0};
+  int                    i, ainc, arg;
+  xx.hdl    = gt_timer_hdl;
+  xx.on     = 0;
+  xx.off    = 0;
+  xx.isOn   = 0;
+  switch (BSP_getDiscoveryVersion(0)) {
+    case MV_64360:
+      i    = 3;
+      ainc = 1;
+      arg  = 4;
+      break;
+    default:
+      i    = 1;
+      ainc = 0x0202;
+      arg  = 0x0403;
+      break;
+  for ( ; i>=0; i--, arg-=ainc ) {
+    xx.name   = BSP_IRQ_TIME0_1 + i;
+    xx.handle = (rtems_irq_hdl_param)arg;
+    if ( !BSP_install_rtems_irq_handler(&xx) )
+      return -1;
+  return 0;
-int
+#ifdef DEBUG_MODULAR
+static int
 BSP_timers_uninstall(void)
-int                    i;
-	xx.on     = 0;
-	xx.off    = 0;
-	xx.isOn   = 0;
-	for ( i=0; i<= GT_TIMER_MAX; i++ ) {
-		if ( BSP_timer_setup(i, 0, 0, 0) )
-			return -1;
-		case MV_64360:
-			i = 3;
-			break;
-		default:
-			i = 1;
-			break;
-	for ( ; i >= 0; i-- ) {
-		BSP_get_current_rtems_irq_handler(&xx);
-		if ( !BSP_remove_rtems_irq_handler(&xx) )
-			return -1;
-	return 0;
+  int                    i;
+  xx.on     = 0;
+  xx.off    = 0;
+  xx.isOn   = 0;
+  for ( i=0; i<= GT_TIMER_MAX; i++ ) {
+    if ( BSP_timer_setup(i, 0, 0, 0) )
+      return -1;
+    case MV_64360:
+      i = 3;
+      break;
+    default:
+      i = 1;
+      break;
+  for ( ; i >= 0; i-- ) {
+    BSP_get_current_rtems_irq_handler(&xx);
+    if ( !BSP_remove_rtems_irq_handler(&xx) )
+      return -1;
+  return 0;
+#endif
 uint32_t
 BSP_timer_clock_get(uint32_t timer)
-	return BSP_bus_frequency;
+  return BSP_bus_frequency;
 int BSP_timer_instances(void)
-	return GT_TIMER_MAX + 1;
+  return GT_TIMER_MAX + 1;
-#ifdef DEBUG
-void BSP_timer_test_isr(void *arg)
-	printk("TIMER IRQ (user arg 0x%x)\n",arg);
-#endif
 /* On a 64260A we can't read the status (on/off), apparently
  * so we maintain it locally and assume the firmware has
  * not enabled the dog initially...
@@ -269,32 +267,33 @@ static uint32_t wdog_on = 0x00ffffff;
 static uint32_t rd_wdcnf(void)
-	uint32_t cnf = gt_rd(GT_WDOG_Config);
-	/* BSD driver says that on the 64260A we always
-	 * read 0xffffffff so we have to maintain the
-	 * status locally (and hope we get the initial
-	 * value right).
-	if ( ~0 == cnf )
-		cnf = wdog_on;
-	return cnf;
+  uint32_t cnf = gt_rd(GT_WDOG_Config);
+  /* BSD driver says that on the 64260A we always
+   * read 0xffffffff so we have to maintain the
+   * status locally (and hope we get the initial
+   * value right).
+  if ( ~0 == cnf )
+    cnf = wdog_on;
+  return cnf;
 /* change on/off state assume caller has IRQs disabled */
 static void dog_toggle(uint32_t ctl)
-	ctl &= ~( GT_WDOG_Config_Ctl1a | GT_WDOG_Config_Ctl1b \
-	        | GT_WDOG_Config_Ctl2a | GT_WDOG_Config_Ctl2b);
-	gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl1a);
-	gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl1b);
+  ctl &= ~( GT_WDOG_Config_Ctl1a | GT_WDOG_Config_Ctl1b \
+          | GT_WDOG_Config_Ctl2a | GT_WDOG_Config_Ctl2b);
+  gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl1a);
+  gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl1b);
 static void dog_pet(uint32_t ctl)
-	gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl2a);
-	gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl2b);
+  gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl2a);
+  gt_wr(GT_WDOG_Config, ctl | GT_WDOG_Config_Ctl2b);
@@ -307,41 +306,41 @@ static void dog_pet(uint32_t ctl)
 int
 BSP_watchdog_enable(uint32_t timeout_us)
-unsigned long long x = timeout_us;
-unsigned flags;
-uint32_t ctl;
+  unsigned long long x = timeout_us;
+  unsigned flags;
+  uint32_t ctl;
-	x *= BSP_bus_frequency;
-	x /= 256;     /* there seems to be a prescaler */
+  x *= BSP_bus_frequency;
+  x /= 256;     /* there seems to be a prescaler */
     x /= 1000000; /* us/s                          */
-	if ( x > (1<<24)-1 )
-		x = (1<<24)-1;
+  if ( x > (1<<24)-1 )
+    x = (1<<24)-1;
-	if ( 0xffffffff != timeout_us )
-		timeout_us = x;
+  if ( 0xffffffff != timeout_us )
+    timeout_us = x;
-	ctl = rd_wdcnf();
+  ctl = rd_wdcnf();
-	/* if enabled, disable first */
-	if ( GT_WDOG_Config_Enb & ctl ) {
-		dog_toggle(ctl);
-	if ( 0xffffffff == timeout_us ) {
-		timeout_us = ctl & ((1<<24)-1);
-		dog_toggle(ctl);
-		dog_pet(ctl);
-	} else {
-		gt_wr(GT_WDOG_Config, timeout_us | GT_WDOG_Config_Ctl1a);
-		gt_wr(GT_WDOG_Config, timeout_us | GT_WDOG_Config_Ctl1b);
+  /* if enabled, disable first */
+  if ( GT_WDOG_Config_Enb & ctl ) {
+    dog_toggle(ctl);
+  if ( 0xffffffff == timeout_us ) {
+    timeout_us = ctl & ((1<<24)-1);
+    dog_toggle(ctl);
+    dog_pet(ctl);
+  } else {
+    gt_wr(GT_WDOG_Config, timeout_us | GT_WDOG_Config_Ctl1a);
+    gt_wr(GT_WDOG_Config, timeout_us | GT_WDOG_Config_Ctl1b);
-	wdog_on = GT_WDOG_Config_Enb | timeout_us;
+  wdog_on = GT_WDOG_Config_Enb | timeout_us;
-	return 0;
+  return 0;
 /* Disable watchdog
@@ -352,17 +351,17 @@ int BSP_watchdog_disable(void)
 unsigned long flags;
 uint32_t      ctl;
-	ctl = rd_wdcnf();
+  ctl = rd_wdcnf();
-	if ( (GT_WDOG_Config_Enb & ctl) ) {
-		dog_toggle(ctl);
-		wdog_on = ctl & ~(GT_WDOG_Config_Enb);
+  if ( (GT_WDOG_Config_Enb & ctl) ) {
+    dog_toggle(ctl);
+    wdog_on = ctl & ~(GT_WDOG_Config_Enb);
-	return 0;
+  return 0;
 /* Check status -- unfortunately there seems to be no way
@@ -372,10 +371,10 @@ uint32_t      ctl;
 int BSP_watchdog_status(void)
-uint32_t ctl = rd_wdcnf();
+  uint32_t ctl = rd_wdcnf();
-	/* report also the current period */
-	return GT_WDOG_Config_Enb & ctl ? ctl : 0;
+  /* report also the current period */
+  return GT_WDOG_Config_Enb & ctl ? ctl : 0;
 /* Pet the watchdog (rearm to configured timeout)
@@ -384,13 +383,14 @@ uint32_t ctl = rd_wdcnf();
 int BSP_watchdog_pet(void)
-unsigned long flags;
-	if ( !wdog_on )
-		return -1;
-		dog_pet(rd_wdcnf());
-	return 0;
+  unsigned long flags;
+  if ( !wdog_on )
+    return -1;
+    dog_pet(rd_wdcnf());
+  return 0;
@@ -398,13 +398,13 @@ unsigned long flags;
 int
 _cexpModuleFinalize(void *unused)
-	BSP_watchdog_disable();
-	return BSP_timers_uninstall();
+  BSP_watchdog_disable();
+  return BSP_timers_uninstall();
 void
 _cexpModuleInitialize(void *unused)
-	BSP_timers_initialize();
+  BSP_timers_initialize();
 #endif
diff --git a/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c b/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c
index 101b86b..79dd297 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c
@@ -5,13 +5,13 @@
@@ -49,6 +49,7 @@
 #include <rtems/bspIo.h>
 #include <bsp/pci.h>
 #include <stdint.h>
+#include "pci_io_remap.h"
 #ifndef PCI_MULTI_FUN
 #define PCI_MULTI_FUN 0x80
@@ -64,142 +65,139 @@
  * of PCI-PCI bridges, too.
  * RESTRICTIONS: 'offset' must be 4k aligned (PCI req.); no argument check
- * 			on the bus numbers is done.
+ *       on the bus numbers is done.
  * RETURNS: 0 on success and a number > 0 indicating the number of
  *          non-32bit bridges found where the offset couldn't be added.
  *          Devices behind such a bridge are not accessible through I/O
  *          and should probably be switched off (not done by this code).
 int
 rtems_pci_io_remap(int bus_from, int bus_to, uint32_t offset)
-int rval = 0;
-int bus, dev, fun, maxf;
-int bar, numBars = 0;
-uint8_t			b;
-uint16_t		s;
-uint32_t        d;
-unsigned int	bas, lim;
-	if ( offset & ((1<<12)-1) ) {
-		BSP_panic("rtems_pci_io_remap(): offset must be 4k aligned");
-		return -1;
-	for ( bus=bus_from; bus < bus_to; bus++ ) {
-		for ( dev = 0; dev<PCI_MAX_DEVICES; dev++ ) {
-			maxf = 1;
-			for ( fun = 0; fun < maxf; fun++ ) {
-				pci_read_config_word( bus, dev, fun, PCI_VENDOR_ID, &s );
-				if ( 0xffff == s )
-					continue;
-				pci_read_config_byte( bus, dev, fun, PCI_HEADER_TYPE, &b );
-				/* readjust the max. function number to scan if this is a multi-function
-				 * device.
-				if ( 0 == fun && (PCI_MULTI_FUN & b) )
-					maxf = PCI_MAX_FUNCTIONS;
-				/* Check the header type; panic if unknown.
-				 * header type 0 has 6 bars, header type 1 (PCI-PCI bridge) has 2
-				b &= PCI_HEADER_TYPE_MSK;
-				switch ( b ) {
-					default:
-						printk("PCI header type %i (@%i/%i/%i)\n", b, bus, dev, fun);
-						BSP_panic("rtems_pci_io_remap(): unknown PCI header type");
-					return -1; /* keep compiler happy */
-					case PCI_HEADER_TYPE_CARDBUS:
-						BSP_panic("rtems_pci_io_remap():  don't know how to deal with Cardbus bridge");
-					return -1;
-					case PCI_HEADER_TYPE_NORMAL:
-						numBars = 6*4;	/* loop below counts reg. offset in bytes */
-					break;
-					case PCI_HEADER_TYPE_BRIDGE:
-						numBars = 2*4;	/* loop below counts reg. offset in bytes */
-					break;
-				for ( bar = 0; bar < numBars; bar+=4 ) {
-					pci_read_config_dword( bus, dev, fun, PCI_BASE_ADDRESS_0 + bar, &d );
-					if ( PCI_BASE_ADDRESS_SPACE_IO & d ) {
-						/* It's an I/O BAR; remap */
-						d &= PCI_BASE_ADDRESS_IO_MASK;
-						if ( d ) {
-							/* IO bar was configured; add offset */
-							d += offset;
-							pci_write_config_dword( bus, dev, fun, PCI_BASE_ADDRESS_0 + bar, d );
-					} else {
-						/* skip upper half of 64-bit window */
-						d &= PCI_BASE_ADDRESS_MEM_TYPE_MASK;
-						if ( PCI_BASE_ADDRESS_MEM_TYPE_64 == d )
-							bar+=4;
-				/* Now it's time to deal with bridges */
-				if ( PCI_HEADER_TYPE_BRIDGE == b ) {
-					/* must adjust the limit registers */
-					pci_read_config_byte( bus, dev, fun, PCI_IO_LIMIT, &b );
-					pci_read_config_word( bus, dev, fun, PCI_IO_LIMIT_UPPER16, &s );
-					lim  = (s<<16) + (( b & PCI_IO_RANGE_MASK ) << 8);
-					lim += offset;
-					pci_read_config_byte( bus, dev, fun, PCI_IO_BASE, &b );
-					pci_read_config_word( bus, dev, fun, PCI_IO_BASE_UPPER16, &s );
-					bas  = (s<<16) + (( b & PCI_IO_RANGE_MASK ) << 8);
-					bas += offset;
-					b &= PCI_IO_RANGE_TYPE_MASK;
-					switch ( b ) {
-						default:
-							printk("Unknown IO range type 0x%x (@%i/%i/%i)\n", b, bus, dev, fun);
-							BSP_panic("rtems_pci_io_remap(): unknown IO range type");
-						return -1;
-						case PCI_IO_RANGE_TYPE_16:
-							if ( bas > 0xffff || lim > 0xffff ) {
-								printk("PCI I/O range type 1 (16bit) bridge (@%i/%i/%i) found:\n", bus, dev, fun);
-								printk("WARNING: base (0x%08x) or limit (0x%08x) exceed 16-bit;\n", bas, lim);
-								printk("         devices behind this bridge are NOT accessible!\n");
-								/* FIXME: should we disable devices behind this bridge ? */
-								bas = lim = 0;
-						break;
-						case PCI_IO_RANGE_TYPE_32:
-						break;
-					b = (uint8_t)((bas>>8) & PCI_IO_RANGE_MASK);
-					pci_write_config_byte( bus, dev, fun, PCI_IO_BASE, b );
-					s = (uint16_t)((bas>>16)&0xffff);
-					pci_write_config_word( bus, dev, fun, PCI_IO_BASE_UPPER16, s);
-					b = (uint8_t)((lim>>8) & PCI_IO_RANGE_MASK);
-					pci_write_config_byte( bus, dev, fun, PCI_IO_LIMIT, b );
-					s = (uint16_t)((lim>>16)&0xffff);
-					pci_write_config_word( bus, dev, fun, PCI_IO_LIMIT_UPPER16, s );
-	return rval;
+  int           rval = 0;
+  int           bus, dev, fun, maxf;
+  int           bar, numBars = 0;
+  uint8_t       b;
+  uint16_t      s;
+  uint32_t      d;
+  unsigned int  bas, lim;
+  if ( offset & ((1<<12)-1) ) {
+    BSP_panic("rtems_pci_io_remap(): offset must be 4k aligned");
+    return -1;
+  for ( bus=bus_from; bus < bus_to; bus++ ) {
+    for ( dev = 0; dev<PCI_MAX_DEVICES; dev++ ) {
+      maxf = 1;
+      for ( fun = 0; fun < maxf; fun++ ) {
+        pci_read_config_word( bus, dev, fun, PCI_VENDOR_ID, &s );
+        if ( 0xffff == s )
+          continue;
+        pci_read_config_byte( bus, dev, fun, PCI_HEADER_TYPE, &b );
+        /* readjust the max. function number to scan if this is a multi-function
+         * device.
+        if ( 0 == fun && (PCI_MULTI_FUN & b) )
+          maxf = PCI_MAX_FUNCTIONS;
+        /* Check the header type; panic if unknown.
+         * header type 0 has 6 bars, header type 1 (PCI-PCI bridge) has 2
+        b &= PCI_HEADER_TYPE_MSK;
+        switch ( b ) {
+          default:
+            printk("PCI header type %i (@%i/%i/%i)\n", b, bus, dev, fun);
+            BSP_panic("rtems_pci_io_remap(): unknown PCI header type");
+          return -1; /* keep compiler happy */
+          case PCI_HEADER_TYPE_CARDBUS:
+            BSP_panic("rtems_pci_io_remap():  don't know how to deal with Cardbus bridge");
+          return -1;
+          case PCI_HEADER_TYPE_NORMAL:
+            numBars = 6*4;  /* loop below counts reg. offset in bytes */
+          break;
+          case PCI_HEADER_TYPE_BRIDGE:
+            numBars = 2*4;  /* loop below counts reg. offset in bytes */
+          break;
+        for ( bar = 0; bar < numBars; bar+=4 ) {
+          pci_read_config_dword( bus, dev, fun, PCI_BASE_ADDRESS_0 + bar, &d );
+          if ( PCI_BASE_ADDRESS_SPACE_IO & d ) {
+            /* It's an I/O BAR; remap */
+            d &= PCI_BASE_ADDRESS_IO_MASK;
+            if ( d ) {
+              /* IO bar was configured; add offset */
+              d += offset;
+              pci_write_config_dword( bus, dev, fun, PCI_BASE_ADDRESS_0 + bar, d );
+          } else {
+            /* skip upper half of 64-bit window */
+            d &= PCI_BASE_ADDRESS_MEM_TYPE_MASK;
+            if ( PCI_BASE_ADDRESS_MEM_TYPE_64 == d )
+              bar+=4;
+        /* Now it's time to deal with bridges */
+        if ( PCI_HEADER_TYPE_BRIDGE == b ) {
+          /* must adjust the limit registers */
+          pci_read_config_byte( bus, dev, fun, PCI_IO_LIMIT, &b );
+          pci_read_config_word( bus, dev, fun, PCI_IO_LIMIT_UPPER16, &s );
+          lim  = (s<<16) + (( b & PCI_IO_RANGE_MASK ) << 8);
+          lim += offset;
+          pci_read_config_byte( bus, dev, fun, PCI_IO_BASE, &b );
+          pci_read_config_word( bus, dev, fun, PCI_IO_BASE_UPPER16, &s );
+          bas  = (s<<16) + (( b & PCI_IO_RANGE_MASK ) << 8);
+          bas += offset;
+          b &= PCI_IO_RANGE_TYPE_MASK;
+          switch ( b ) {
+            default:
+              printk("Unknown IO range type 0x%x (@%i/%i/%i)\n", b, bus, dev, fun);
+              BSP_panic("rtems_pci_io_remap(): unknown IO range type");
+            return -1;
+            case PCI_IO_RANGE_TYPE_16:
+              if ( bas > 0xffff || lim > 0xffff ) {
+                printk("PCI I/O range type 1 (16bit) bridge (@%i/%i/%i) found:\n", bus, dev, fun);
+                printk("WARNING: base (0x%08x) or limit (0x%08x) exceed 16-bit;\n", bas, lim);
+                printk("         devices behind this bridge are NOT accessible!\n");
+                /* FIXME: should we disable devices behind this bridge ? */
+                bas = lim = 0;
+            break;
+            case PCI_IO_RANGE_TYPE_32:
+            break;
+          b = (uint8_t)((bas>>8) & PCI_IO_RANGE_MASK);
+          pci_write_config_byte( bus, dev, fun, PCI_IO_BASE, b );
+          s = (uint16_t)((bas>>16)&0xffff);
+          pci_write_config_word( bus, dev, fun, PCI_IO_BASE_UPPER16, s);
+          b = (uint8_t)((lim>>8) & PCI_IO_RANGE_MASK);
+          pci_write_config_byte( bus, dev, fun, PCI_IO_LIMIT, b );
+          s = (uint16_t)((lim>>16)&0xffff);
+          pci_write_config_word( bus, dev, fun, PCI_IO_LIMIT_UPPER16, s );
+  return rval;
diff --git a/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c b/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c
index d5dcd15..773ac21 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c
@@ -143,8 +143,13 @@ char *BSP_commandline_string = cmdline_buf;
 /* this routine is called early and must be safe with a not properly
  * aligned stack
-char *
-save_boot_params(void *r3, void *r4, void* r5, char *cmdline_start, char *cmdline_end)
+  void *r3,
+  void *r4,
+  void *r5,
+  char *cmdline_end
 int             i=cmdline_end-cmdline_start;
 	if ( i >= CMDLINE_BUF_SIZE )
diff --git a/c/src/lib/libbsp/powerpc/beatnik/vme/VMEConfig.h b/c/src/lib/libbsp/powerpc/beatnik/vme/VMEConfig.h
index b3bccee..986a016 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/vme/VMEConfig.h
+++ b/c/src/lib/libbsp/powerpc/beatnik/vme/VMEConfig.h
@@ -8,13 +8,13 @@
@@ -56,56 +56,59 @@
  * hardcoded window lengths that match this
  * layout when setting BATs:
-#define _VME_A32_WIN0_ON_PCI	0x90000000
+#define _VME_A32_WIN0_ON_PCI  0x90000000
 /* If _VME_CSR_ON_PCI is defined then the A32 window is reduced to accommodate
  * CSR for space.
-#define _VME_CSR_ON_PCI			0x9e000000
-#define _VME_A24_ON_PCI			0x9f000000
-#define _VME_A16_ON_PCI			0x9fff0000
+#define _VME_CSR_ON_PCI      0x9e000000
+#define _VME_A24_ON_PCI      0x9f000000
+#define _VME_A16_ON_PCI      0x9fff0000
 /* start of the A32 window on the VME bus
  * TODO: this should perhaps be a configuration option
-#define _VME_A32_WIN0_ON_VME	0x20000000
+#define _VME_A32_WIN0_ON_VME  0x20000000
 /* if _VME_DRAM_OFFSET is defined, the BSP
  * will map our RAM onto the VME bus, starting
  * at _VME_DRAM_OFFSET
-#define _VME_DRAM_OFFSET		0x90000000
+#define _VME_DRAM_OFFSET    0x90000000
-#define BSP_VME_INSTALL_IRQ_MGR(err)	\
-  do {									\
-  err = -1;								\
-  switch (BSP_getBoardType()) {			\
-	case MVME6100:						\
-		err = theOps->install_irq_mgr(	\
-					VMETSI148_IRQ_MGR_FLAG_SHARED,	\
-					0, BSP_IRQ_GPP_0 + 20,			\
-					1, BSP_IRQ_GPP_0 + 21,			\
-					2, BSP_IRQ_GPP_0 + 22,			\
-					3, BSP_IRQ_GPP_0 + 23,			\
-					-1);				\
-	break;								\
-	case MVME5500:						\
-					VMEUNIVERSE_IRQ_MGR_FLAG_SHARED |			\
-					VMEUNIVERSE_IRQ_MGR_FLAG_PW_WORKAROUND,		\
-					0, BSP_IRQ_GPP_0 + 12,						\
-					1, BSP_IRQ_GPP_0 + 13,						\
-					2, BSP_IRQ_GPP_0 + 14,						\
-					3, BSP_IRQ_GPP_0 + 15,						\
-					-1);										\
-	break;								\
-	default:							\
-		printk("WARNING: unknown board; ");						\
-	break;								\
-  if ( err )							\
-	printk("VME interrupt manager NOT INSTALLED (error: %i)\n", err); \
+extern int BSP_VMEInit(void);
+extern int BSP_VMEIrqMgrInstall(void);
+#define BSP_VME_INSTALL_IRQ_MGR(err)  \
+  do { \
+    err = -1; \
+    switch (BSP_getBoardType()) { \
+      case MVME6100: \
+	err = theOps->install_irq_mgr( \
+	      VMETSI148_IRQ_MGR_FLAG_SHARED, \
+	      0, BSP_IRQ_GPP_0 + 20, \
+	      1, BSP_IRQ_GPP_0 + 21, \
+	      2, BSP_IRQ_GPP_0 + 22, \
+	      3, BSP_IRQ_GPP_0 + 23, \
+	      -1); \
+	break; \
+      case MVME5500: \
+	      VMEUNIVERSE_IRQ_MGR_FLAG_SHARED | \
+	      VMEUNIVERSE_IRQ_MGR_FLAG_PW_WORKAROUND, \
+	      0, BSP_IRQ_GPP_0 + 12, \
+	      1, BSP_IRQ_GPP_0 + 13, \
+	      2, BSP_IRQ_GPP_0 + 14, \
+	      3, BSP_IRQ_GPP_0 + 15, \
+	      -1); \
+	break; \
+      default: \
+	printk("WARNING: unknown board; "); \
+	break; \
+    if ( err ) \
+      printk("VME interrupt manager NOT INSTALLED (error: %i)\n", err); \
   } while (0)
 #endif
1.9.3
