[PATCH 22/42] mips/hurricane: Fix warnings
Fri Oct 17 15:23:38 UTC 2014
 c/src/lib/libbsp/mips/hurricane/console/console.c | 78 +++++------------------
 c/src/lib/libbsp/mips/hurricane/include/bsp.h     | 11 +++-
 c/src/lib/libbsp/mips/hurricane/start/start.S     |  1 +
 c/src/lib/libbsp/mips/hurricane/startup/inittlb.c |  3 +-
 4 files changed, 27 insertions(+), 66 deletions(-)
diff --git a/c/src/lib/libbsp/mips/hurricane/console/console.c b/c/src/lib/libbsp/mips/hurricane/console/console.c
index f2aa3a4..ccc6f93 100644
--- a/c/src/lib/libbsp/mips/hurricane/console/console.c
+++ b/c/src/lib/libbsp/mips/hurricane/console/console.c
@@ -1,6 +1,8 @@
  *  This file contains the IDT 4650 console IO package.
  *  Author:     Craig Lebakken <craigl at transition.com>
  *  COPYRIGHT (c) 1996 by Transition Networks Inc.
@@ -31,8 +33,8 @@
 #include <ctype.h>
 /* PMON entry points */
-int mon_read(int fd, char *buf, int cnt);		/* stdin is fd=0 */
-int mon_write(int fd, char *buf, int cnt);		/* stdout is fd=1 */
+int mon_read(int fd, char *buf, int cnt);    /* stdin is fd=0 */
+int mon_write(int fd, char *buf, int cnt);    /* stdout is fd=1 */
 /*  console_initialize
@@ -44,7 +46,6 @@ int mon_write(int fd, char *buf, int cnt);		/* stdout is fd=1 */
  *  Return values:
 rtems_device_driver console_initialize(
   rtems_device_major_number  major,
   rtems_device_minor_number  minor,
@@ -65,81 +66,42 @@ rtems_device_driver console_initialize(
   return RTEMS_SUCCESSFUL;
-/*  is_character_ready
- *  This routine returns TRUE if a character is available.
- *  Input parameters: NONE
- *  Output parameters:  NONE
- *  Return values:
-bool is_character_ready(
-  char *ch
-  *ch = '\0';   /* return NULL for no particular reason */
-  return true;
 /*  inbyte
  *  This routine reads a character from the SOURCE.
- *  Return values:
- *    character read from SOURCE
-char inbyte( void )
+static char inbyte( void )
-	char buf[10];
+  char buf[10];
    *  If polling, wait until a character is available.
+  mon_read(0, buf, 1);    /* stdin is fd=0, read 1 byte */
-	mon_read(0, buf, 1);		/* stdin is fd=0, read 1 byte */
-	return (buf[0]);
+  return (buf[0]);
 /*  outbyte
  *  This routine transmits a character out the SOURCE.  It may support
  *  XON/XOFF flow control.
- *    ch  - character to be transmitted
-void outbyte(
+static void outbyte(
   char ch
-	char buf[10];
+  char buf[10];
    *  If polling, wait for the transmitter to be ready.
    *  Check for flow control requests and process.
    *  Then output the character.
-	buf[0] = ch;
+  buf[0] = ch;
-	mon_write( 1, buf, 1 );		/* stdout is fd=1, write 1 byte */
+  mon_write( 1, buf, 1 );    /* stdout is fd=1, write 1 byte */
-#if 0
-static int console_fd = -1;
-#endif
  *  Open entry point
@@ -150,9 +112,6 @@ rtems_device_driver console_open(
   void                    * arg
-#if 0
-  int console_fd = open("tty0", 2); /* open for read/write */
-#endif
@@ -166,17 +125,12 @@ rtems_device_driver console_close(
   void                    * arg
-#if 0
-  if ( console_fd )
-    close( console_fd );
-#endif
  * read bytes from the serial port. We only have stdin.
 rtems_device_driver console_read(
@@ -208,7 +162,6 @@ rtems_device_driver console_read(
  * write bytes to the serial port. Stdout and stderr are the same.
 rtems_device_driver console_write(
@@ -239,7 +192,6 @@ rtems_device_driver console_write(
  *  IO Control entry point
 rtems_device_driver console_control(
@@ -251,7 +203,7 @@ rtems_device_driver console_control(
 #include <rtems/bspIo.h>
-void hurricane_output_char(char c) { outbyte( c ); }
+static void hurricane_output_char(char c) { outbyte( c ); }
 BSP_output_char_function_type           BSP_output_char = hurricane_output_char;
 BSP_polling_getchar_function_type       BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/mips/hurricane/include/bsp.h b/c/src/lib/libbsp/mips/hurricane/include/bsp.h
index 92453d5..e297ba8 100644
--- a/c/src/lib/libbsp/mips/hurricane/include/bsp.h
+++ b/c/src/lib/libbsp/mips/hurricane/include/bsp.h
@@ -1,6 +1,5 @@
  *  @file
@@ -15,6 +14,8 @@
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -66,8 +67,16 @@ extern uint32_t mips_get_timer( void );
 #define RAM_START 0
 #define RAM_END   0x100000
+ * Prototypes for methods called from .S for dependency tracking
+void init_tlb(void);
+void resettlb(int i);
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif	/* __HURRICANE_BSP_h */
diff --git a/c/src/lib/libbsp/mips/hurricane/start/start.S b/c/src/lib/libbsp/mips/hurricane/start/start.S
index 0e24995..e3d97cd 100644
--- a/c/src/lib/libbsp/mips/hurricane/start/start.S
+++ b/c/src/lib/libbsp/mips/hurricane/start/start.S
@@ -33,6 +33,7 @@ LICENSED MATERIAL - PROGRAM PROPERTY OF IDT
 #include <rtems/mips/idtcpu.h>
 #include <rtems/asm.h>
+#include <bsp.h>
 #if 0
 	.extern _fdata,4		/* this is defined by the linker */
diff --git a/c/src/lib/libbsp/mips/hurricane/startup/inittlb.c b/c/src/lib/libbsp/mips/hurricane/startup/inittlb.c
index 27518d0..800cf3d 100644
--- a/c/src/lib/libbsp/mips/hurricane/startup/inittlb.c
+++ b/c/src/lib/libbsp/mips/hurricane/startup/inittlb.c
@@ -1,7 +1,6 @@
+#include <bsp.h>
-extern void resettlb( int i );
 void init_tlb(void)
   int i;
1.9.3
