[PATCH 25/42] mips/rbtx4938: Fix warnings
Fri Oct 17 15:23:41 UTC 2014
 .../lib/libbsp/mips/rbtx4938/console/console-io.c  | 101 ++++-----------------
 c/src/lib/libbsp/mips/rbtx4938/include/bsp.h       |  10 ++
 c/src/lib/libbsp/mips/rbtx4938/start/start.S       |   2 +
 c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c   |   1 +
 4 files changed, 29 insertions(+), 85 deletions(-)
diff --git a/c/src/lib/libbsp/mips/rbtx4938/console/console-io.c b/c/src/lib/libbsp/mips/rbtx4938/console/console-io.c
index 32e3dd6..4f5b4f7 100644
--- a/c/src/lib/libbsp/mips/rbtx4938/console/console-io.c
+++ b/c/src/lib/libbsp/mips/rbtx4938/console/console-io.c
@@ -1,6 +1,8 @@
  *  This file contains the RBTX4938 console IO package.
  *  Author:     Craig Lebakken <craigl at transition.com>
  *  COPYRIGHT (c) 1996 by Transition Networks Inc.
@@ -26,16 +28,6 @@
  *  http://www.rtems.org/license/LICENSE.
- *  Rather than deleting this, it is commented out to (hopefully) help
- *  the submitter send updates.
- *  static char _sccsid[] = "@(#)console.c 08/20/96     1.6\n";
 #include <bsp.h>
 #include <rtems/libio.h>
 #include <ctype.h>
@@ -43,21 +35,14 @@
 #include "yamon_api.h"
 /* PMON entry points */
-int mon_read(int fd, char *buf, int cnt);		/* stdin is fd=0 */
-int mon_write(int fd, char *buf, int cnt);		/* stdout is fd=1 */
+int mon_read(int fd, char *buf, int cnt);    /* stdin is fd=0 */
+int mon_write(int fd, char *buf, int cnt);    /* stdout is fd=1 */
 /*  console_initialize
  *  This routine initializes the console IO driver.
- *  Input parameters: NONE
- *  Output parameters:  NONE
- *  Return values:
 rtems_device_driver console_initialize(
   rtems_device_major_number  major,
   rtems_device_minor_number  minor,
@@ -78,85 +63,43 @@ rtems_device_driver console_initialize(
   return RTEMS_SUCCESSFUL;
-/*  is_character_ready
- *  This routine returns TRUE if a character is available.
- *  Return values:
-bool is_character_ready(
-  char *ch
-  *ch = '\0';   /* return NULL for no particular reason */
-  return true;
 /*  inbyte
  *  This routine reads a character from the SOURCE.
- *  Return values:
- *    character read from SOURCE
-char inbyte( void )
+static char inbyte( void )
-	char buf[10];
+  char buf[10];
    *  If polling, wait until a character is available.
+  while (YAMON_FUNC_GETCHAR(buf) == YAMON_FALSE);
-	while (YAMON_FUNC_GETCHAR(buf) == YAMON_FALSE);
-/*	mon_read(0, buf, 1);	*/		/* stdin is fd=0, read 1 byte */
-	return (buf[0]);
+  return (buf[0]);
 /*  outbyte
  *  This routine transmits a character out the SOURCE.  It may support
  *  XON/XOFF flow control.
- *    ch  - character to be transmitted
-void outbyte(
+static void outbyte(
   char ch
-	char buf[10];
+  char buf[10];
    *  If polling, wait for the transmitter to be ready.
    *  Check for flow control requests and process.
    *  Then output the character.
-	buf[0] = ch;
+  buf[0] = ch;
-	YAMON_FUNC_PRINT_COUNT(buf,1);
-/*	mon_write( 1, buf, 1 ); */		/* stdout is fd=1, write 1 byte */
+  YAMON_FUNC_PRINT_COUNT(buf,1);
-#if 0
-static int console_fd = -1;
-#endif
  *  Open entry point
@@ -167,33 +110,24 @@ rtems_device_driver console_open(
   void                    * arg
-#if 0
-  int console_fd = open("tty0", 2); /* open for read/write */
-#endif
  *  Close entry point
 rtems_device_driver console_close(
   void                    * arg
-#if 0
-  if ( console_fd )
-    close( console_fd );
-#endif
  * read bytes from the serial port. We only have stdin.
 rtems_device_driver console_read(
@@ -225,7 +159,6 @@ rtems_device_driver console_read(
  * write bytes to the serial port. Stdout and stderr are the same.
 rtems_device_driver console_write(
@@ -256,7 +189,6 @@ rtems_device_driver console_write(
  *  IO Control entry point
 rtems_device_driver console_control(
@@ -266,10 +198,9 @@ rtems_device_driver console_control(
 #include <rtems/bspIo.h>
-void RBTX4938_output_char(char c) { outbyte( c ); }
+static void RBTX4938_output_char(char c) { outbyte( c ); }
 BSP_output_char_function_type           BSP_output_char = RBTX4938_output_char;
 BSP_polling_getchar_function_type       BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/mips/rbtx4938/include/bsp.h b/c/src/lib/libbsp/mips/rbtx4938/include/bsp.h
index 96aaa64..df029b2 100644
--- a/c/src/lib/libbsp/mips/rbtx4938/include/bsp.h
+++ b/c/src/lib/libbsp/mips/rbtx4938/include/bsp.h
@@ -16,6 +16,8 @@
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -32,8 +34,16 @@ extern "C" {
 #define BSP_FEATURE_IRQ_EXTENSION
 #define BSP_SHARED_HANDLER_SUPPORT      1
+ * Prototypes for methods called from .S for dependency tracking
+void init_tlb(void);
+void resettlb(int i);
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif
diff --git a/c/src/lib/libbsp/mips/rbtx4938/start/start.S b/c/src/lib/libbsp/mips/rbtx4938/start/start.S
index 8ad4a31..406f1b6 100644
--- a/c/src/lib/libbsp/mips/rbtx4938/start/start.S
+++ b/c/src/lib/libbsp/mips/rbtx4938/start/start.S
@@ -33,6 +33,8 @@ LICENSED MATERIAL - PROGRAM PROPERTY OF IDT
 #include <rtems/mips/idtcpu.h>
 #include <rtems/asm.h>
+#include <bsp.h>
 	.extern	mon_flush_cache
 #if 0
diff --git a/c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c b/c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c
index d82eff7..ab09e9c 100644
--- a/c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c
+++ b/c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c
@@ -2,6 +2,7 @@
  *  inittlb.c
+#include <bsp.h>
 extern void resettlb( int i );
1.9.3
