[PATCH 27/42] powerpc/mvme5500: Fix warnings
Fri Oct 17 15:23:43 UTC 2014
 .../libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c  | 144 +++++++++++----------
 .../libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c  |  52 ++++----
 c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h    | 115 +++++++++-------
 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c    | 141 ++++++++++----------
 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c        |   2 -
 .../libbsp/powerpc/mvme5500/pci/pcifinddevice.c    |  71 +++++-----
 .../powerpc/mvme5500/startup/pgtbl_activate.c      |  45 ++++---
 7 files changed, 296 insertions(+), 274 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c b/c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c
index c0f34b3..19cf28f 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c
@@ -1,5 +1,8 @@
-/* GT64260TWSI.c : Two-Wire Serial Interface (TWSI) support for the GT64260
+ * Two-Wire Serial Interface (TWSI) support for the GT64260
  * Copyright (c) 2004, Brookhaven National Laboratory and
  *                 Shuchen Kate Feng <feng1 at bnl.gov>
  * All rights reserved.
@@ -15,11 +18,11 @@
  * We need it to read out I2C devices used for the MVME5500
  * (eg. the memory SPD and VPD).
 #include <libcpu/spr.h>  /*registers.h included here for rtems_bsp_delay()*/
 #include <libcpu/io.h>
-#include <rtems/bspIo.h>	    /* printk */
+#include <rtems/bspIo.h>
 #include "bsp/gtreg.h"
 #include "bsp/GT64260TWSI.h"
@@ -28,44 +31,44 @@
 #define TWSI_DEBUG 0
-static int TWSI_initFlg = 0;	/* TWSI Initialization Flag */
+static int TWSI_initFlg = 0;  /* TWSI Initialization Flag */
 void GT64260TWSIinit(void)
-  if ( !TWSI_initFlg) {
+  if ( !TWSI_initFlg ) {
 #if TWSI_DEBUG
-     printk("GT64260TWSIinit(");
+   printk("GT64260TWSIinit(");
 #endif
-     outl( 0, TWSI_SFT_RST); /* soft reset */
-     rtems_bsp_delay(1000);
-     /* See 24.2.5 : Assume bus speed is 133MHZ
-      * Try to be close to the default frequency : 62.5KHZ
-      * value 0x2c: 69.27 KHz TWSI bus clock
-     outl(0x2c, TWSI_BAUDE_RATE);
-     /* Set Acknowledge and enable TWSI in the Control register */
-     outl(0x44, TWSI_CTRL);
-     rtems_bsp_delay(4000);
-     TWSI_initFlg = 1;
+   outl( 0, TWSI_SFT_RST); /* soft reset */
+   rtems_bsp_delay(1000);
+   /* See 24.2.5 : Assume bus speed is 133MHZ
+    * Try to be close to the default frequency : 62.5KHZ
+    * value 0x2c: 69.27 KHz TWSI bus clock
+   outl(0x2c, TWSI_BAUDE_RATE);
+   /* Set Acknowledge and enable TWSI in the Control register */
+   outl(0x44, TWSI_CTRL);
+   rtems_bsp_delay(4000);
+   TWSI_initFlg = 1;
 #if TWSI_DEBUG
-     printk(")\n");
+   printk(")\n");
 #endif
 /* return the interrupt flag */
-int GT64260TWSIintFlag(void)
+static int GT64260TWSIintFlag(void)
   unsigned int loop;
   for (loop = 0; loop < MAX_LOOP; loop++ ) {
     /* Return 1 if the interrupt flag is set */
-      if (inl(TWSI_CTRL) & TWSI_INTFLG) return(1);
+    if (inl(TWSI_CTRL) & TWSI_INTFLG)
+      return(1);
   return(0);
@@ -111,19 +114,19 @@ int GT64260TWSIstart(void)
   if (GT64260TWSIintFlag()) {
-     /* Check for completion of START sequence */
-     for (loop = 0; loop<MAX_LOOP; loop++ ) {
-         /* if (start condition transmitted) ||
-          *    (repeated start condition transmitted )
-         if (((status= inl( TWSI_STATUS)) == 8) || (status == 0x10)) {
+    /* Check for completion of START sequence */
+    for (loop = 0; loop<MAX_LOOP; loop++ ) {
+      /* if (start condition transmitted) ||
+       *    (repeated start condition transmitted )
+      if (((status= inl( TWSI_STATUS)) == 8) || (status == 0x10)) {
 #if TWSI_DEBUG
-             printk(")");
+        printk(")");
 #endif
-             return(0);
+        return(0);
   /* if loop ends or intFlag ==0 */
   GT64260TWSIstop();
@@ -142,22 +145,23 @@ int GT64260TWSIread(unsigned char * pData, int lastByte)
-     for (loop = 0; loop< MAX_LOOP; loop++) {
-       /* if Master received read data, acknowledge transmitted */
-       if ( (inl( TWSI_STATUS) == 0x50)) {
-	   *pData = (unsigned char) inl( TWSI_DATA);
-   	   rtems_bsp_delay(1500);
-           /* Clear INTFLAG and set Enable bit only */
-	   if (lastByte) outl(TWSI_TWSIEN, TWSI_CTRL);
+    for (loop = 0; loop< MAX_LOOP; loop++) {
+      /* if Master received read data, acknowledge transmitted */
+      if ( (inl( TWSI_STATUS) == 0x50)) {
+        *pData = (unsigned char) inl( TWSI_DATA);
+        rtems_bsp_delay(1500);
+        /* Clear INTFLAG and set Enable bit only */
+        if (lastByte)
+         outl(TWSI_TWSIEN, TWSI_CTRL);
 #if TWSI_DEBUG
-  printk(")\n");
+        printk(")\n");
 #endif
-	   return(0);
-     } /* end for */
+        return(0);
+    } /* end for */
   GT64260TWSIstop();
@@ -182,27 +186,27 @@ int GT64260TWSIwrite(unsigned char Data)
   if (GT64260TWSIintFlag() ) {
-	 /* if address + write bit transmitted, acknowledge not received */
-	 if ( (status = inl( TWSI_STATUS)) == 0x20) {
-            /* No device responding, generate STOP and return -1 */
-	   printk("no device responding\n");
-	    GT64260TWSIstop();
-	    return(-1);
-         /* if (address + write bit transmitted, acknowledge received)
-	  *    (Master transmmitted data byte, acknowledge received)
-          *    (address + read bit transmitted, acknowledge received)
-	 if ((status == 0x18)||(status == 0x28)||(status == 0x40)) {
+      /* if address + write bit transmitted, acknowledge not received */
+      if ( (status = inl( TWSI_STATUS)) == 0x20) {
+        /* No device responding, generate STOP and return -1 */
+        printk("no device responding\n");
+        GT64260TWSIstop();
+        return(-1);
+      /* if (address + write bit transmitted, acknowledge received)
+       * (Master transmmitted data byte, acknowledge received)
+       *    (address + read bit transmitted, acknowledge received)
+      if ((status == 0x18)||(status == 0x28)||(status == 0x40)) {
 #if TWSI_DEBUG
-	      printk(")\n");
+        printk(")\n");
 #endif
-	      return(0);
-     } /* end for */
+        return(0);
+    } /* end for */
   printk("No correct status, timeout\n");
   GT64260TWSIstop();
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c b/c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c
index 382425e..107b8f1 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c
@@ -1,16 +1,18 @@
-/* MVME5500I2C.c
+ * To read information of the EEPROM via the I2C
  * Copyright (c) 2003, 2004 Brookhaven National Laboratory
  * Author:    S. Kate Feng <feng1 at bnl.gov>
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution.
- * To read information of the EEPROM via the I2C
+#include <bsp.h>
+#include <rtems/bspIo.h>      /* printk */
 #include <stdint.h>           /* uint32_t */
@@ -28,28 +30,34 @@ static unsigned char I2cDevByteAddr(uint32_t devA2A1A0, unsigned char byteNum)
 * I2Cread_eeprom - read EEPROM VPD from the I2C
-int I2Cread_eeprom(unsigned char I2cBusAddr,uint32_t devA2A1A0,uint32_t AddrBytes,unsigned char *pBuff,uint32_t numBytes)
+int I2Cread_eeprom(
+  unsigned char  I2cBusAddr,
+  uint32_t       devA2A1A0,
+  uint32_t       AddrBytes,
+  unsigned char *pBuff,
+  uint32_t       numBytes
   int status=0, lastByte=0;
   switch (AddrBytes) {
     case 1:
       if ((status=GT64260TWSIstart()) != -1) {
-	if ((status=GT64260TWSIwrite(I2cAddrPack(I2cBusAddr,devA2A1A0)))!= -1){
-	  if ((status=GT64260TWSIwrite(devA2A1A0))!=-1){
-	    if ((status=GT64260TWSIstart())!=-1)
-	        status=GT64260TWSIwrite(I2cAddrPack((I2cBusAddr|0x01),devA2A1A0));
+        if ((status=GT64260TWSIwrite(I2cAddrPack(I2cBusAddr,devA2A1A0)))!= -1){
+          if ((status=GT64260TWSIwrite(devA2A1A0))!=-1){
+            if ((status=GT64260TWSIstart())!=-1)
+                status=GT64260TWSIwrite(I2cAddrPack((I2cBusAddr|0x01),devA2A1A0));
       break;
     case 2:
       if ((status=GT64260TWSIstart())!=-1) {
-	if ((status=GT64260TWSIwrite(I2cBusAddr))!= -1) {
-	  if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,1)))!=-1) {
-	    if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,0)))!= -1){
-	      if ((status=GT64260TWSIstart()) != -1) {
-		status = GT64260TWSIwrite((I2cBusAddr | 0x01));
+        if ((status=GT64260TWSIwrite(I2cBusAddr))!= -1) {
+          if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,1)))!=-1) {
+            if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,0)))!= -1){
+              if ((status=GT64260TWSIstart()) != -1) {
+                status = GT64260TWSIwrite((I2cBusAddr | 0x01));
@@ -58,12 +66,12 @@ int I2Cread_eeprom(unsigned char I2cBusAddr,uint32_t devA2A1A0,uint32_t AddrByte
       break;
     case 3:
       if ((status = GT64260TWSIstart())!= -1) {
-	if ((status = GT64260TWSIwrite(I2cBusAddr))!= -1) {
-	  if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,2)))!= -1){
-	    if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,1)))!= -1){
-  	        if ((status=GT64260TWSIstart())!= -1) {
-		  status = GT64260TWSIwrite(I2cBusAddr | 0x01);
+        if ((status = GT64260TWSIwrite(I2cBusAddr))!= -1) {
+          if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,2)))!= -1){
+            if ((status=GT64260TWSIwrite(I2cDevByteAddr(devA2A1A0,1)))!= -1){
+                  if ((status=GT64260TWSIstart())!= -1) {
+                  status = GT64260TWSIwrite(I2cBusAddr | 0x01);
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h b/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h
index 972835a..ad22495 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/mvme5500/include/bsp.h
@@ -1,6 +1,4 @@
- *  bsp.h  -- contain BSP API definition.
  *  Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
@@ -8,13 +6,13 @@
  *  http://www.rtems.org/license/LICENSE.
  *  (C) S. Kate Feng 2003-2007 : Modified it to support the mvme5500 BSP.
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #include <bspopts.h>
 #include <bsp/default-initial-extension.h>
@@ -26,42 +24,42 @@
 /* Board type */
 typedef enum {
-	undefined = 0,
-	MVME5500,
-	MVME6100
+  undefined = 0,
+  MVME5500,
+  MVME6100
 } BSP_BoardTypes;
-BSP_BoardTypes BSP_getBoardType();
+BSP_BoardTypes BSP_getBoardType(void);
 /* Board type */
 typedef enum {
-	Undefined,
-	UNIVERSE2,
-	TSI148,
+  Undefined,
+  UNIVERSE2,
+  TSI148,
 } BSP_VMEchipTypes;
-BSP_VMEchipTypes BSP_getVMEchipType();
+BSP_VMEchipTypes BSP_getVMEchipType(void);
 /* The version of Discovery system controller */
 typedef enum {
-	notdefined,
-	GT64260A,
-	GT64260B,
-	MV64360,
+  notdefined,
+  GT64260A,
+  GT64260B,
+  MV64360,
 } DiscoveryChipVersion;
-DiscoveryChipVersion BSP_getDiscoveryChipVersion();
+DiscoveryChipVersion BSP_getDiscoveryChipVersion(void);
 #define _256M           0x10000000
 #define _512M           0x20000000
-#define GT64x60_REG_BASE	0xf1000000  /* Base of GT64260 Reg Space */
-#define GT64x60_REG_SPACE_SIZE	0x10000     /* 64Kb Internal Reg Space */
+#define GT64x60_REG_BASE        0xf1000000  /* Base of GT64260 Reg Space */
+#define GT64x60_REG_SPACE_SIZE  0x10000     /* 64Kb Internal Reg Space */
 #define GT64x60_DEV1_BASE       0xf1100000  /* Device bank1(chip select 1) base
-#define GT64260_DEV1_SIZE 	0x00100000 /* Device bank size */
+#define GT64260_DEV1_SIZE       0x00100000 /* Device bank size */
 /* fundamental addresses for this BSP (PREPxxx are from libcpu/io.h) */
 #define _IO_BASE GT64x60_REG_BASE
@@ -69,10 +67,10 @@ DiscoveryChipVersion BSP_getDiscoveryChipVersion();
 #define BSP_NVRAM_BASE_ADDR     0xf1110000
 #define BSP_RTC_INTA_REG        0x7ff0
-#define BSP_RTC_SECOND	        0x7ff2
-#define BSP_RTC_MINUTE	        0x7ff3
-#define BSP_RTC_HOUR	        0x7ff4
-#define BSP_RTC_DATE	        0x7ff5
+#define BSP_RTC_SECOND          0x7ff2
+#define BSP_RTC_MINUTE          0x7ff3
+#define BSP_RTC_HOUR            0x7ff4
+#define BSP_RTC_DATE            0x7ff5
 #define BSP_RTC_INTERRUPTS      0x7ff6
 #define BSP_RTC_WATCHDOG        0x7ff7
@@ -81,15 +79,15 @@ DiscoveryChipVersion BSP_getDiscoveryChipVersion();
 #define PCI1_IO_BASE            0xf0800000
 /* PCI 0 memory space as seen from the CPU */
-#define PCI0_MEM_BASE		0x80000000
-#define PCI_MEM_BASE            0  /* glue for vmeUniverse */
+#define PCI0_MEM_BASE                  0x80000000
+#define PCI_MEM_BASE                   0  /* glue for vmeUniverse */
 #define PCI_MEM_BASE_ADJUSTMENT        0
 /* address of our ram on the PCI bus */
-#define	PCI_DRAM_OFFSET	        0
+#define  PCI_DRAM_OFFSET          0
 /* PCI 1 memory space as seen from the CPU */
-#define PCI1_MEM_BASE		0xe0000000
+#define PCI1_MEM_BASE           0xe0000000
 #define PCI1_MEM_SIZE           0x10000000
 /* Needed for hot adding via PMCspan on the PCI0 local bus.
@@ -114,11 +112,11 @@ DiscoveryChipVersion BSP_getDiscoveryChipVersion();
 #define BSP_INTERRUPT_STACK_SIZE  (16 * 1024) /* <skf> 2/09 wants it to be adjustable by BSP */
 /* uart.c uses out_8 instead of outb  */
-#define BSP_UART_IOBASE_COM1	GT64x60_DEV1_BASE + 0x20000
-#define BSP_UART_IOBASE_COM2	GT64x60_DEV1_BASE + 0x21000
+#define BSP_UART_IOBASE_COM1  GT64x60_DEV1_BASE + 0x20000
+#define BSP_UART_IOBASE_COM2  GT64x60_DEV1_BASE + 0x21000
-#define BSP_CONSOLE_PORT		BSP_UART_COM1  /* console */
-#define BSP_UART_BAUD_BASE		115200
+#define BSP_CONSOLE_PORT    BSP_UART_COM1  /* console */
+#define BSP_UART_BAUD_BASE    115200
  * Total memory using RESIDUAL DATA
@@ -140,43 +138,72 @@ extern unsigned int BSP_time_base_divisor;
 #define BSP_Convert_decrementer( _value ) \
   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))
-extern rtems_configuration_table  BSP_Configuration;
 extern void BSP_panic(char *s);
 extern void bsp_reset(void);
 /* extern int printk(const char *, ...) __attribute__((format(printf, 1, 2))); */
-extern int BSP_disconnect_clock_handler (void);
-extern int BSP_connect_clock_handler (void);
+extern int BSP_disconnect_clock_handler(void);
+extern int BSP_connect_clock_handler(void);
-extern unsigned long _BSP_clear_hostbridge_errors();
+unsigned long _BSP_clear_hostbridge_errors(int enableMCP, int quiet);
+ * Prototypes for methods called only from .S for dependency tracking
+char *save_boot_params(
+  void *r3,
+  void *r4,
+  void *r5,
+  char *cmdline_start,
+  char *cmdline_end
+void zero_bss(void);
+ * Prototypes for methods in the BSP that cross file boundaries
+uint32_t probeMemoryEnd(void);
+void     pci_interface(void);
+void     BSP_printPicIsrTbl(void);
+  uint32_t       numBytes
 #if 0
-#define RTEMS_BSP_NETWORK_DRIVER_NAME	"gt1"
-#define RTEMS_BSP_NETWORK_DRIVER_ATTACH	rtems_GT64260eth_driver_attach
+#define RTEMS_BSP_NETWORK_DRIVER_NAME  "gt1"
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH  rtems_GT64260eth_driver_attach
 #else
-#define RTEMS_BSP_NETWORK_DRIVER_NAME	"wmG1"
-#define RTEMS_BSP_NETWORK_DRIVER_ATTACH	rtems_i82544EI_driver_attach
+#define RTEMS_BSP_NETWORK_DRIVER_NAME  "wmG1"
+#define RTEMS_BSP_NETWORK_DRIVER_ATTACH  rtems_i82544EI_driver_attach
 #endif
 extern int RTEMS_BSP_NETWORK_DRIVER_ATTACH();
 #define gccMemBar() RTEMS_COMPILER_MEMORY_BARRIER()
-static inline void lwmemBar()
+static inline void lwmemBar(void)
     __asm__ volatile("lwsync":::"memory");
-static inline void io_flush()
+static inline void io_flush(void)
     __asm__ volatile("isync":::"memory");
-static inline void memBar()
+static inline void memBar(void)
     __asm__ volatile("sync":::"memory");
-static inline void ioBar()
+static inline void ioBar(void)
     __asm__ volatile("eieio":::"memory");
 #endif
+#endif /* !ASM */
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c b/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c
index a95425d..0f99dee 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c
@@ -1,7 +1,8 @@
-/*  BSP_irq.c
  *  This file contains the implementation of the function described in irq.h
  *  Copyright (C) 1998, 1999 valette at crf.canon.fr
@@ -319,11 +320,6 @@ void BSP_enable_irq_at_pic(const rtems_irq_number irqNum)
   rtems_interrupt_enable(level);
-void BSP_enable_pic_irq(const rtems_irq_number irqNum)
-	BSP_enable_irq_at_pic(irqNum);
 int BSP_disable_irq_at_pic(const rtems_irq_number irqNum)
   int      rval;
@@ -331,7 +327,7 @@ int BSP_disable_irq_at_pic(const rtems_irq_number irqNum)
   unsigned int level;
   if ( ! is_pic_irq(irqNum) )
-  	return -1;
+    return -1;
   bitNum = (((unsigned int)irqNum) - BSP_MICL_IRQ_LOWEST_OFFSET)%32;
   regNum = (((unsigned int)irqNum) - BSP_MICL_IRQ_LOWEST_OFFSET)>>5;
@@ -354,85 +350,80 @@ int BSP_disable_irq_at_pic(const rtems_irq_number irqNum)
   return rval ? 1 : 0;
-void BSP_disable_pic_irq(const rtems_irq_number irqNum)
-	(void)BSP_disable_irq_at_pic(irqNum);
 /* Use shared/irq : 2008 */
 int BSP_setup_the_pic(rtems_irq_global_settings* config)
-    int i;
-    BSP_config = *config;
-    default_rtems_hdl = config->defaultEntry.hdl;
-    rtems_hdl_tbl     = config->irqHdlTbl;
-    /* Get ready for discovery BSP */
-    BSP_irqMask_reg[0]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_CPU_INT_MASK_LO);
-    BSP_irqMask_reg[1]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_CPU_INT_MASK_HI);
-    BSP_irqCause_reg[0]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_MAIN_INT_CAUSE_LO);
-    BSP_irqCause_reg[1]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_MAIN_INT_CAUSE_HI);
-    BSP_irqMask_reg[2]= (volatile unsigned int *) (GT64x60_REG_BASE + GT_GPP_Interrupt_Mask);
-    BSP_irqCause_reg[2]= (volatile unsigned int *) (GT64x60_REG_BASE + GT_GPP_Value);
-    /* Page 401, Table 598:
-     * Comm Unit Arbiter Control register :
-     * bit 10:GPP interrupts as level sensitive(1) or edge sensitive(0).
-     * MOTload default is set as level sensitive(1). Set it agin to make sure.
-    out_le32((volatile unsigned int *)GT_CommUnitArb_Ctrl,
-	     (in_le32((volatile unsigned int *)GT_CommUnitArb_Ctrl)| (1<<10)));
+  int i;
+  BSP_config = *config;
+  default_rtems_hdl = config->defaultEntry.hdl;
+  rtems_hdl_tbl     = config->irqHdlTbl;
+  /* Get ready for discovery BSP */
+  BSP_irqMask_reg[0]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_CPU_INT_MASK_LO);
+  BSP_irqMask_reg[1]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_CPU_INT_MASK_HI);
+  BSP_irqCause_reg[0]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_MAIN_INT_CAUSE_LO);
+  BSP_irqCause_reg[1]= (volatile unsigned int *) (GT64x60_REG_BASE + GT64260_MAIN_INT_CAUSE_HI);
+  BSP_irqMask_reg[2]= (volatile unsigned int *) (GT64x60_REG_BASE + GT_GPP_Interrupt_Mask);
+  BSP_irqCause_reg[2]= (volatile unsigned int *) (GT64x60_REG_BASE + GT_GPP_Value);
+  /* Page 401, Table 598:
+   * Comm Unit Arbiter Control register :
+   * bit 10:GPP interrupts as level sensitive(1) or edge sensitive(0).
+   * MOTload default is set as level sensitive(1). Set it agin to make sure.
+  out_le32((volatile unsigned int *)GT_CommUnitArb_Ctrl,
+           (in_le32((volatile unsigned int *)GT_CommUnitArb_Ctrl)| (1<<10)));
 #if 0
-    printk("BSP_irqMask_reg[0] = 0x%x, BSP_irqCause_reg[0] 0x%x\n",
-	   in_le32(BSP_irqMask_reg[0]),
-	   in_le32(BSP_irqCause_reg[0]));
-    printk("BSP_irqMask_reg[1] = 0x%x, BSP_irqCause_reg[1] 0x%x\n",
-	   in_le32(BSP_irqMask_reg[1]),
-	   in_le32(BSP_irqCause_reg[1]));
-    printk("BSP_irqMask_reg[2] = 0x%x, BSP_irqCause_reg[2] 0x%x\n",
-	   in_le32(BSP_irqMask_reg[2]),
-	   in_le32(BSP_irqCause_reg[2]));
+  printk("BSP_irqMask_reg[0] = 0x%x, BSP_irqCause_reg[0] 0x%x\n",
+         in_le32(BSP_irqMask_reg[0]),
+         in_le32(BSP_irqCause_reg[0]));
+  printk("BSP_irqMask_reg[1] = 0x%x, BSP_irqCause_reg[1] 0x%x\n",
+         in_le32(BSP_irqMask_reg[1]),
+         in_le32(BSP_irqCause_reg[1]));
+  printk("BSP_irqMask_reg[2] = 0x%x, BSP_irqCause_reg[2] 0x%x\n",
+         in_le32(BSP_irqMask_reg[2]),
+         in_le32(BSP_irqCause_reg[2]));
 #endif
-    /* Initialize the interrupt related  registers */
-    for (i=0; i<3; i++) {
-      out_le32(BSP_irqCause_reg[i], 0);
-      out_le32(BSP_irqMask_reg[i], 0);
-    in_le32(BSP_irqMask_reg[2]);
-    compute_pic_masks_from_prio();
+  /* Initialize the interrupt related  registers */
+  for (i=0; i<3; i++) {
+    out_le32(BSP_irqCause_reg[i], 0);
+    out_le32(BSP_irqMask_reg[i], 0);
+  in_le32(BSP_irqMask_reg[2]);
+  compute_pic_masks_from_prio();
 #if 0
 #endif
-    for (i=BSP_MICL_IRQ_LOWEST_OFFSET; i < BSP_PROCESSOR_IRQ_LOWEST_OFFSET ; i++) {
-      if ( BSP_config.irqHdlTbl[i].hdl != BSP_config.defaultEntry.hdl) {
-	BSP_enable_irq_at_pic(i);
-	BSP_config.irqHdlTbl[i].on(&BSP_config.irqHdlTbl[i]);
-      else {
-	BSP_config.irqHdlTbl[i].off(&BSP_config.irqHdlTbl[i]);
-	BSP_disable_irq_at_pic(i);
-    for (i= BSP_MAIN_GPP7_0_IRQ; i < BSP_MAIN_GPP31_24_IRQ; i++)
+  for (i=BSP_MICL_IRQ_LOWEST_OFFSET; i < BSP_PROCESSOR_IRQ_LOWEST_OFFSET ; i++) {
+    if ( BSP_config.irqHdlTbl[i].hdl != BSP_config.defaultEntry.hdl) {
+      BSP_config.irqHdlTbl[i].on(&BSP_config.irqHdlTbl[i]);
+    else {
+      BSP_config.irqHdlTbl[i].off(&BSP_config.irqHdlTbl[i]);
+      BSP_disable_irq_at_pic(i);
+  for (i= BSP_MAIN_GPP7_0_IRQ; i < BSP_MAIN_GPP31_24_IRQ; i++)
+    BSP_enable_irq_at_pic(i);
-    return(1);
+  return(1);
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c b/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
index 96d9f36..d3ffa1e 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c
@@ -72,8 +72,6 @@ static rtems_pci_config_t BSP_pci[2]={
    0 /* defined at BSP_pci_configuration */}
-extern void pci_interface(void);
 /* Pack RegNum,FuncNum,DevNum,BusNum,and ConfigEnable for
  * PCI Configuration Address Register
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c b/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
index 493388a..9f3acee 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c
@@ -15,16 +15,6 @@
 static int BSP_pciDebug=0;
-int BSP_pciFindDevicePrint(unsigned short vendorid, unsigned short deviceid,
-                   int instance, int *pbus, int *pdev, int *pfun )
-  BSP_pciDebug = 1;
-  (void) pci_find_device(vendorid, deviceid, instance, pbus, pdev, pfun );
-  BSP_pciDebug = 0;
-  return 0;
 int pci_find_device( unsigned short vendorid, unsigned short deviceid,
@@ -33,37 +23,38 @@ int pci_find_device( unsigned short vendorid, unsigned short deviceid,
   unsigned char bus,dev,fun,hd;
   for (bus=0; bus<BSP_MAX_PCI_BUS;  bus++) {
-      for (dev=0; dev<PCI_MAX_DEVICES; dev++) {
-	  pci_read_config_byte(bus, dev, 0, PCI_HEADER_TYPE, &hd);
-	  hd = (hd & PCI_HEADER_TYPE_MULTI_FUNCTION ? PCI_MAX_FUNCTIONS : 1);
-     	  for (fun=0; fun<hd; fun++) {
-	       * The last devfn id/slot is special; must skip it
-	      if (PCI_MAX_DEVICES-1==dev && PCI_MAX_FUNCTIONS-1 == fun)
-		 break;
-	      (void)pci_read_config_dword(bus,dev,fun,PCI_VENDOR_ID,&d);
-     	      if (PCI_INVALID_VENDORDEVICEID == d)
-		 continue;
-              if (BSP_pciDebug) {
-	         printk("pci_find_device: found 0x%08x at %2d/%2d/%2d ",d,bus,dev,fun);
-	         printk("(Physically: PCI%d  %2d/%2d/%2d)\n",
-		     (bus>= BSP_MAX_PCI_BUS_ON_PCI0)? 1:0,
-		     (bus>= BSP_MAX_PCI_BUS_ON_PCI0)? bus-BSP_MAX_PCI_BUS_ON_PCI0:bus,
-		     dev, fun);
-	      (void)pci_read_config_word(bus,dev,fun,PCI_VENDOR_ID,&s);
-      	      if (vendorid != s)
-           	 continue;
-	      (void)pci_read_config_word(bus,dev,fun,PCI_DEVICE_ID,&s);
-	      if (deviceid == s) {
-		 if (instance--) continue;
-		 *pbus=bus; *pdev=dev; *pfun=fun;
-		 return 0;
+    for (dev=0; dev<PCI_MAX_DEVICES; dev++) {
+      pci_read_config_byte(bus, dev, 0, PCI_HEADER_TYPE, &hd);
+      hd = (hd & PCI_HEADER_TYPE_MULTI_FUNCTION ? PCI_MAX_FUNCTIONS : 1);
+      for (fun=0; fun<hd; fun++) {
+         * The last devfn id/slot is special; must skip it
+        if (PCI_MAX_DEVICES-1==dev && PCI_MAX_FUNCTIONS-1 == fun)
+          break;
+        (void)pci_read_config_dword(bus,dev,fun,PCI_VENDOR_ID,&d);
+        if (PCI_INVALID_VENDORDEVICEID == d)
+          continue;
+        if (BSP_pciDebug) {
+           printk(
+             "pci_find_device: found 0x%08x at %2d/%2d/%2d ",d,bus,dev,fun);
+           printk("(Physically: PCI%d  %2d/%2d/%2d)\n",
+             (bus>= BSP_MAX_PCI_BUS_ON_PCI0)? 1:0,
+             (bus>= BSP_MAX_PCI_BUS_ON_PCI0)? bus-BSP_MAX_PCI_BUS_ON_PCI0:bus,
+             dev, fun);
+        (void)pci_read_config_word(bus,dev,fun,PCI_VENDOR_ID,&s);
+        if (vendorid != s)
+          continue;
+      (void)pci_read_config_word(bus,dev,fun,PCI_DEVICE_ID,&s);
+      if (deviceid == s) {
+        if (instance--) continue;
+          *pbus=bus; *pdev=dev; *pfun=fun;
+          return 0;
   }  /* end for bus */
   return -1;
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c b/c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c
index 8145e22..c72b030 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c
@@ -1,8 +1,5 @@
-#include <rtems.h>
-#include <libcpu/pte121.h>
-#include <libcpu/bat.h>
-/* Default activation of the page tables. This is a weak
+ * Default activation of the page tables. This is a weak
  * alias, so applications may easily override this
  * default activation procedure.
@@ -11,25 +8,31 @@
  * Kate Feng <feng1 at bnl.gov> ported it to MVME5500, 4/2004
-void
-BSP_pgtbl_activate(Triv121PgTbl) __attribute__ (( weak, alias("__BSP_default_pgtbl_activate") ));
+#include <rtems.h>
+#include <libcpu/pte121.h>
+#include <libcpu/bat.h>
-void
+static void
 __BSP_default_pgtbl_activate(Triv121PgTbl pt)
-	if (!pt) return;
+  if (!pt)
+    return;
-	/* switch the text/ro sements to RO only after
-	 * initializing the interrupts because the irq_mng
-	 * installs some code...
-	 * activate the page table; it is still masked by the
-	 * DBAT0, however
-	triv121PgTblActivate(pt);
+  /* switch the text/ro sements to RO only after
+   * initializing the interrupts because the irq_mng
+   * installs some code...
+   * activate the page table; it is still masked by the
+   * DBAT0, however
+  triv121PgTblActivate(pt);
-	/* finally, switch off DBAT0 & DBAT1 */
-	setdbat(0,0,0,0,0);
-	setdbat(1,0,0,0,0);  /* <skf> */
-	/* At this point, DBAT0 is available for other use... */
+  /* finally, switch off DBAT0 & DBAT1 */
+  setdbat(0,0,0,0,0);
+  setdbat(1,0,0,0,0);  /* <skf> */
+  /* At this point, DBAT0 is available for other use... */
+void BSP_pgtbl_activate(Triv121PgTbl)
+  __attribute__ (( weak, alias("__BSP_default_pgtbl_activate") ));
1.9.3
