[PATCH 36/42] sparc/leon3/include/bsp.h: Fix warnings
Fri Oct 17 15:23:52 UTC 2014
 c/src/lib/libbsp/sparc/leon3/include/bsp.h | 5 +++++
 1 file changed, 5 insertions(+)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 5cc6e02..dbd3a3d 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -135,6 +135,11 @@ void BSP_fatal_exit(uint32_t error);
 void bsp_spurious_initialize( void );
+ *  Delay for the specified number of microseconds.
+void rtems_bsp_delay(int usecs);
 /* Allocate 8-byte aligned non-freeable pre-malloc() memory. The function
  * can be called at any time. The work-area will shrink when called before
  * bsp_work_area_initialize(). malloc() is called to get memory when this
1.9.3
