[PATCH 37/42] powerpc/gen83xx: Fix warnings
Fri Oct 17 15:23:53 UTC 2014
 c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c |  15 +-
 c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h  |  11 +-
 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c      | 899 ++++++++++++------------
 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c |  30 +-
 4 files changed, 491 insertions(+), 464 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c b/c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c
index 59b9a30..7fdd6bb 100644
--- a/c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c
+++ b/c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c
@@ -117,7 +117,7 @@ rtems_status_code bsp_register_i2c
     i2c_busno[i] = rtems_libi2c_register_bus(device_path, &desc->bus_desc);
-#ifdef RTEMS_BSP_I2C_EEPROM_DEVICE_NAME
+#if defined(RTEMS_BSP_I2C_EEPROM_DEVICE_NAME)
   if (n > 0) {
      * register EEPROM to bus 1, Address 0x50
@@ -126,9 +126,7 @@ rtems_status_code bsp_register_i2c
                  i2c_2b_eeprom_driver_descriptor,
                  i2c_busno[0],0x50);
-#endif /* RTEMS_BSP_I2C_EEPROM_DEVICE_NAME */
-#ifdef MPC83XX_BOARD_BR_UID
+#elif defined(MPC83XX_BOARD_BR_UID)
   if (n > 0) {
     rtems_libi2c_register_drv(
       "sc620",
@@ -137,7 +135,14 @@ rtems_status_code bsp_register_i2c
       0x70
-#endif /* MPC83XX_BOARD_BR_UID */
+#else
+   * We have no i2c configuration for this variant but need to mark
+   * i2c_busno as used.
+   (void) i2c_busno[0]; /* avoid set but not used warning */
+#endif
    * FIXME: register RTC driver, when available
diff --git a/c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h b/c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h
index e23cf61..b9033c1 100644
--- a/c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h
@@ -82,8 +82,10 @@ extern "C" {
 /* misc macros */
 #define BSP_ARRAY_CNT(arr) (sizeof(arr)/sizeof(arr[0]))
-/* functions */
+void *bsp_idle_thread( uintptr_t ignored );
+#define BSP_IDLE_TASK_BODY bsp_idle_thread
+/* functions */
 rtems_status_code bsp_register_i2c(void);
 rtems_status_code bsp_register_spi(void);
@@ -147,6 +149,13 @@ void cpu_init( void);
 void bsp_restart(void *addr);
+#if defined(HAS_UBOOT)
+  /* Routine to obtain U-Boot environment variables */
+  const char *bsp_uboot_getenv(
+    const char *name
+#endif
 #ifdef __cplusplus
 #endif
diff --git a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
index 96ec4d7..2d89cfa 100644
--- a/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
+++ b/c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c
@@ -17,7 +17,6 @@
 | this file integrates the IPIC irq controller                    |
 #include <mpc83xx/mpc83xx.h>
@@ -36,9 +35,9 @@
 #define MPC83XX_IPIC_INVALID_MASK_POSITION 255
 typedef struct {
-	volatile uint32_t *pend_reg;
-	volatile uint32_t *mask_reg;
-	const uint32_t bit_num;
+  volatile uint32_t *pend_reg;
+  volatile uint32_t *mask_reg;
+  const uint32_t bit_num;
 } BSP_isrc_rsc_t;
@@ -51,244 +50,245 @@ typedef struct {
  *   sermr     : 96 .. 127
 typedef struct {
-	uint32_t simsr_mask [2];
-	uint32_t semsr_mask;
-	uint32_t sermr_mask;
+  uint32_t simsr_mask [2];
+  uint32_t semsr_mask;
+  uint32_t sermr_mask;
 } mpc83xx_ipic_mask_t;
 static const BSP_isrc_rsc_t mpc83xx_ipic_isrc_rsc [MPC83XX_IPIC_VECTOR_NUMBER] = {
-	/* vector 0 */
-	{&mpc83xx.ipic.sersr, &mpc83xx.ipic.sermr, 31},
-	{NULL, NULL, 0},
-	{NULL, NULL, 0},
-	{NULL, NULL, 0},
-	{NULL, NULL, 0},
-	{NULL, NULL, 0},
-	{NULL, NULL, 0},
-	{NULL, NULL, 0},
-	/* vector  8 */
-	{NULL, NULL, 0},	/* reserved vector  8 */
-	/* vector  9: UART1 SIxxR_H, Bit 24 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 24},
-	/* vector 10: UART2 SIxxR_H, Bit 25 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 25},
-	/* vector 11: SEC   SIxxR_H, Bit 26 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 26},
-	{NULL, NULL, 0},	/* reserved vector 12 */
-	{NULL, NULL, 0},	/* reserved vector 13 */
-	/* vector 14: I2C1 SIxxR_H, Bit 29 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 29},
-	/* vector 15: I2C2 SIxxR_H, Bit 30 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 30},
-	/* vector 16: SPI  SIxxR_H, Bit 31 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 31},
-	/* vector 17: IRQ1 SExxR  , Bit  1 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 1},
-	/* vector 18: IRQ2 SExxR  , Bit  2 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 2},
-	/* vector 19: IRQ3 SExxR  , Bit  3 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 3},
-	/* vector 20: IRQ4 SExxR  , Bit  4 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 4},
-	/* vector 21: IRQ5 SExxR  , Bit  5 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 5},
-	/* vector 22: IRQ6 SExxR  , Bit  6 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 6},
-	/* vector 23: IRQ7 SExxR  , Bit  7 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 7},
-	{NULL, NULL, 0},	/* reserved vector 24 */
-	{NULL, NULL, 0},	/* reserved vector 25 */
-	{NULL, NULL, 0},	/* reserved vector 26 */
-	{NULL, NULL, 0},	/* reserved vector 27 */
-	{NULL, NULL, 0},	/* reserved vector 28 */
-	{NULL, NULL, 0},	/* reserved vector 29 */
-	{NULL, NULL, 0},	/* reserved vector 30 */
-	{NULL, NULL, 0},	/* reserved vector 31 */
-	/* vector 32: TSEC1 Tx  SIxxR_H  , Bit  0 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 0},
-	/* vector 33: TSEC1 Rx  SIxxR_H  , Bit  1 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 1},
-	/* vector 34: TSEC1 Err SIxxR_H  , Bit  2 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 2},
-	/* vector 35: TSEC2 Tx  SIxxR_H  , Bit  3 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 3},
-	/* vector 36: TSEC2 Rx  SIxxR_H  , Bit  4 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 4},
-	/* vector 37: TSEC2 Err SIxxR_H  , Bit  5 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 5},
-	/* vector 38: USB DR    SIxxR_H  , Bit  6 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 6},
-	/* vector 39: USB MPH   SIxxR_H  , Bit  7 */
-	{&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 7},
-	{NULL, NULL, 0},	/* reserved vector 40 */
-	{NULL, NULL, 0},	/* reserved vector 41 */
-	{NULL, NULL, 0},	/* reserved vector 42 */
-	{NULL, NULL, 0},	/* reserved vector 43 */
-	{NULL, NULL, 0},	/* reserved vector 44 */
-	{NULL, NULL, 0},	/* reserved vector 45 */
-	{NULL, NULL, 0},	/* reserved vector 46 */
-	{NULL, NULL, 0},	/* reserved vector 47 */
-	/* vector 48: IRQ0 SExxR  , Bit  0 */
-	{&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 0},
-	{NULL, NULL, 0},	/* reserved vector 49 */
-	{NULL, NULL, 0},	/* reserved vector 50 */
-	{NULL, NULL, 0},	/* reserved vector 51 */
-	{NULL, NULL, 0},	/* reserved vector 52 */
-	{NULL, NULL, 0},	/* reserved vector 53 */
-	{NULL, NULL, 0},	/* reserved vector 54 */
-	{NULL, NULL, 0},	/* reserved vector 55 */
-	{NULL, NULL, 0},	/* reserved vector 56 */
-	{NULL, NULL, 0},	/* reserved vector 57 */
-	{NULL, NULL, 0},	/* reserved vector 58 */
-	{NULL, NULL, 0},	/* reserved vector 59 */
-	{NULL, NULL, 0},	/* reserved vector 60 */
-	{NULL, NULL, 0},	/* reserved vector 61 */
-	{NULL, NULL, 0},	/* reserved vector 62 */
-	{NULL, NULL, 0},	/* reserved vector 63 */
-	/* vector 64: RTC SEC   SIxxR_L  , Bit  0 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 0},
-	/* vector 65: PIT       SIxxR_L  , Bit  1 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 1},
-	/* vector 66: PCI1      SIxxR_L  , Bit  2 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 2},
-	/* vector 67: PCI2      SIxxR_L  , Bit  3 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 3},
-	/* vector 68: RTC ALR   SIxxR_L  , Bit  4 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 4},
-	/* vector 69: MU        SIxxR_L  , Bit  5 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 5},
-	/* vector 70: SBA       SIxxR_L  , Bit  6 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 6},
-	/* vector 71: DMA       SIxxR_L  , Bit  7 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 7},
-	/* vector 72: GTM4      SIxxR_L  , Bit  8 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 8},
-	/* vector 73: GTM8      SIxxR_L  , Bit  9 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 9},
-	/* vector 74: GPIO1     SIxxR_L  , Bit 10 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 10},
-	/* vector 75: GPIO2     SIxxR_L  , Bit 11 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 11},
-	/* vector 76: DDR       SIxxR_L  , Bit 12 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 12},
-	/* vector 77: LBC       SIxxR_L  , Bit 13 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 13},
-	/* vector 78: GTM2      SIxxR_L  , Bit 14 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 14},
-	/* vector 79: GTM6      SIxxR_L  , Bit 15 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 15},
-	/* vector 80: PMC       SIxxR_L  , Bit 16 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 16},
-	{NULL, NULL, 0},	/* reserved vector 81 */
-	{NULL, NULL, 0},	/* reserved vector 82 */
-	/* vector 84: GTM3      SIxxR_L  , Bit 20 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 20},
-	/* vector 85: GTM7      SIxxR_L  , Bit 21 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 21},
-	/* vector 90: GTM1      SIxxR_L  , Bit 26 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 26},
-	/* vector 91: GTM5      SIxxR_L  , Bit 27 */
-	{&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 27}
+  /* vector 0 */
+  {&mpc83xx.ipic.sersr, &mpc83xx.ipic.sermr, 31},
+  {NULL, NULL, 0},
+  {NULL, NULL, 0},
+  {NULL, NULL, 0},
+  {NULL, NULL, 0},
+  {NULL, NULL, 0},
+  {NULL, NULL, 0},
+  {NULL, NULL, 0},
+  /* vector  8 */
+  {NULL, NULL, 0},  /* reserved vector  8 */
+  /* vector  9: UART1 SIxxR_H, Bit 24 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 24},
+  /* vector 10: UART2 SIxxR_H, Bit 25 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 25},
+  /* vector 11: SEC   SIxxR_H, Bit 26 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 26},
+  {NULL, NULL, 0},  /* reserved vector 12 */
+  {NULL, NULL, 0},  /* reserved vector 13 */
+  /* vector 14: I2C1 SIxxR_H, Bit 29 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 29},
+  /* vector 15: I2C2 SIxxR_H, Bit 30 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 30},
+  /* vector 16: SPI  SIxxR_H, Bit 31 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 31},
+  /* vector 17: IRQ1 SExxR  , Bit  1 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 1},
+  /* vector 18: IRQ2 SExxR  , Bit  2 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 2},
+  /* vector 19: IRQ3 SExxR  , Bit  3 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 3},
+  /* vector 20: IRQ4 SExxR  , Bit  4 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 4},
+  /* vector 21: IRQ5 SExxR  , Bit  5 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 5},
+  /* vector 22: IRQ6 SExxR  , Bit  6 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 6},
+  /* vector 23: IRQ7 SExxR  , Bit  7 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 7},
+  {NULL, NULL, 0},  /* reserved vector 24 */
+  {NULL, NULL, 0},  /* reserved vector 25 */
+  {NULL, NULL, 0},  /* reserved vector 26 */
+  {NULL, NULL, 0},  /* reserved vector 27 */
+  {NULL, NULL, 0},  /* reserved vector 28 */
+  {NULL, NULL, 0},  /* reserved vector 29 */
+  {NULL, NULL, 0},  /* reserved vector 30 */
+  {NULL, NULL, 0},  /* reserved vector 31 */
+  /* vector 32: TSEC1 Tx  SIxxR_H  , Bit  0 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 0},
+  /* vector 33: TSEC1 Rx  SIxxR_H  , Bit  1 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 1},
+  /* vector 34: TSEC1 Err SIxxR_H  , Bit  2 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 2},
+  /* vector 35: TSEC2 Tx  SIxxR_H  , Bit  3 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 3},
+  /* vector 36: TSEC2 Rx  SIxxR_H  , Bit  4 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 4},
+  /* vector 37: TSEC2 Err SIxxR_H  , Bit  5 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 5},
+  /* vector 38: USB DR    SIxxR_H  , Bit  6 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 6},
+  /* vector 39: USB MPH   SIxxR_H  , Bit  7 */
+  {&mpc83xx.ipic.sipnr [0], &mpc83xx.ipic.simsr [0], 7},
+  {NULL, NULL, 0},  /* reserved vector 40 */
+  {NULL, NULL, 0},  /* reserved vector 41 */
+  {NULL, NULL, 0},  /* reserved vector 42 */
+  {NULL, NULL, 0},  /* reserved vector 43 */
+  {NULL, NULL, 0},  /* reserved vector 44 */
+  {NULL, NULL, 0},  /* reserved vector 45 */
+  {NULL, NULL, 0},  /* reserved vector 46 */
+  {NULL, NULL, 0},  /* reserved vector 47 */
+  /* vector 48: IRQ0 SExxR  , Bit  0 */
+  {&mpc83xx.ipic.sepnr, &mpc83xx.ipic.semsr, 0},
+  {NULL, NULL, 0},  /* reserved vector 49 */
+  {NULL, NULL, 0},  /* reserved vector 50 */
+  {NULL, NULL, 0},  /* reserved vector 51 */
+  {NULL, NULL, 0},  /* reserved vector 52 */
+  {NULL, NULL, 0},  /* reserved vector 53 */
+  {NULL, NULL, 0},  /* reserved vector 54 */
+  {NULL, NULL, 0},  /* reserved vector 55 */
+  {NULL, NULL, 0},  /* reserved vector 56 */
+  {NULL, NULL, 0},  /* reserved vector 57 */
+  {NULL, NULL, 0},  /* reserved vector 58 */
+  {NULL, NULL, 0},  /* reserved vector 59 */
+  {NULL, NULL, 0},  /* reserved vector 60 */
+  {NULL, NULL, 0},  /* reserved vector 61 */
+  {NULL, NULL, 0},  /* reserved vector 62 */
+  {NULL, NULL, 0},  /* reserved vector 63 */
+  /* vector 64: RTC SEC   SIxxR_L  , Bit  0 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 0},
+  /* vector 65: PIT       SIxxR_L  , Bit  1 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 1},
+  /* vector 66: PCI1      SIxxR_L  , Bit  2 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 2},
+  /* vector 67: PCI2      SIxxR_L  , Bit  3 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 3},
+  /* vector 68: RTC ALR   SIxxR_L  , Bit  4 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 4},
+  /* vector 69: MU        SIxxR_L  , Bit  5 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 5},
+  /* vector 70: SBA       SIxxR_L  , Bit  6 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 6},
+  /* vector 71: DMA       SIxxR_L  , Bit  7 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 7},
+  /* vector 72: GTM4      SIxxR_L  , Bit  8 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 8},
+  /* vector 73: GTM8      SIxxR_L  , Bit  9 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 9},
+  /* vector 74: GPIO1     SIxxR_L  , Bit 10 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 10},
+  /* vector 75: GPIO2     SIxxR_L  , Bit 11 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 11},
+  /* vector 76: DDR       SIxxR_L  , Bit 12 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 12},
+  /* vector 77: LBC       SIxxR_L  , Bit 13 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 13},
+  /* vector 78: GTM2      SIxxR_L  , Bit 14 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 14},
+  /* vector 79: GTM6      SIxxR_L  , Bit 15 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 15},
+  /* vector 80: PMC       SIxxR_L  , Bit 16 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 16},
+  {NULL, NULL, 0},  /* reserved vector 81 */
+  {NULL, NULL, 0},  /* reserved vector 82 */
+  /* vector 84: GTM3      SIxxR_L  , Bit 20 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 20},
+  /* vector 85: GTM7      SIxxR_L  , Bit 21 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 21},
+  /* vector 90: GTM1      SIxxR_L  , Bit 26 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 26},
+  /* vector 91: GTM5      SIxxR_L  , Bit 27 */
+  {&mpc83xx.ipic.sipnr [1], &mpc83xx.ipic.simsr [1], 27}
-static const uint8_t mpc83xx_ipic_mask_position_table [MPC83XX_IPIC_VECTOR_NUMBER] = {
-	MPC83XX_IPIC_INVALID_MASK_POSITION,
-	7,
-	6,
-	5,
-	2,
-	1,
-	0,
-	94,
-	93,
-	92,
-	91,
-	90,
-	89,
-	88,
-	31,
-	30,
-	29,
-	28,
-	27,
-	26,
-	25,
-	24,
-	95,
-	63,
-	62,
-	61,
-	60,
-	59,
-	58,
-	57,
-	56,
-	55,
-	54,
-	53,
-	52,
-	51,
-	50,
-	49,
-	48,
-	47,
-	43,
-	42,
-	37,
-	36
+static const uint8_t
+    mpc83xx_ipic_mask_position_table [MPC83XX_IPIC_VECTOR_NUMBER] = {
+  MPC83XX_IPIC_INVALID_MASK_POSITION,
+  7,
+  6,
+  5,
+  2,
+  1,
+  0,
+  94,
+  93,
+  92,
+  91,
+  90,
+  89,
+  88,
+  31,
+  30,
+  29,
+  28,
+  27,
+  26,
+  25,
+  24,
+  95,
+  63,
+  62,
+  61,
+  60,
+  59,
+  58,
+  57,
+  56,
+  55,
+  54,
+  53,
+  52,
+  51,
+  50,
+  49,
+  48,
+  47,
+  43,
+  42,
+  37,
+  36
@@ -298,71 +298,79 @@ static const uint8_t mpc83xx_ipic_mask_position_table [MPC83XX_IPIC_VECTOR_NUMBE
 static mpc83xx_ipic_mask_t mpc83xx_ipic_prio2mask [MPC83XX_IPIC_VECTOR_NUMBER];
-rtems_status_code mpc83xx_ipic_set_mask( rtems_vector_number vector, rtems_vector_number mask_vector, bool mask)
+rtems_status_code mpc83xx_ipic_set_mask(
+  rtems_vector_number vector,
+  rtems_vector_number mask_vector,
+  bool mask
-	uint8_t pos = 0;
-	mpc83xx_ipic_mask_t *mask_entry;
-	uint32_t *mask_reg;
-	rtems_interrupt_level level;
-	/* Parameter check */
-	if (!MPC83XX_IPIC_IS_VALID_VECTOR( vector) || !MPC83XX_IPIC_IS_VALID_VECTOR( mask_vector)) {
-		return RTEMS_INVALID_NUMBER;
-	} else if (vector == mask_vector) {
-		return RTEMS_RESOURCE_IN_USE;
-	/* Position and mask entry */
-	pos = mpc83xx_ipic_mask_position_table [mask_vector];
-	mask_entry = &mpc83xx_ipic_prio2mask [vector];
-	/* Mask register and position */
-	if (pos < 32) {
-		mask_reg = &mask_entry->simsr_mask [0];
-	} else if (pos < 64) {
-		pos -= 32;
-		mask_reg = &mask_entry->simsr_mask [1];
-	} else if (pos < 96) {
-		pos -= 64;
-		mask_reg = &mask_entry->semsr_mask;
-	} else if (pos < 128) {
-		pos -= 96;
-		mask_reg = &mask_entry->sermr_mask;
-	} else {
-		return RTEMS_NOT_IMPLEMENTED;
-	/* Mask or unmask */
-	if (mask) {
-		rtems_interrupt_disable( level);
-		*mask_reg &= ~(1 << pos);
-		rtems_interrupt_enable( level);
-	} else {
-		*mask_reg |= 1 << pos;
-	return RTEMS_SUCCESSFUL;
+  uint8_t pos = 0;
+  mpc83xx_ipic_mask_t *mask_entry;
+  uint32_t *mask_reg;
+  rtems_interrupt_level level;
+  /* Parameter check */
+  if (!MPC83XX_IPIC_IS_VALID_VECTOR( vector) ||
+      !MPC83XX_IPIC_IS_VALID_VECTOR( mask_vector)) {
+    return RTEMS_INVALID_NUMBER;
+  } else if (vector == mask_vector) {
+    return RTEMS_RESOURCE_IN_USE;
+  /* Position and mask entry */
+  pos = mpc83xx_ipic_mask_position_table [mask_vector];
+  mask_entry = &mpc83xx_ipic_prio2mask [vector];
+  /* Mask register and position */
+  if (pos < 32) {
+    mask_reg = &mask_entry->simsr_mask [0];
+  } else if (pos < 64) {
+    pos -= 32;
+    mask_reg = &mask_entry->simsr_mask [1];
+  } else if (pos < 96) {
+    pos -= 64;
+    mask_reg = &mask_entry->semsr_mask;
+  } else if (pos < 128) {
+    pos -= 96;
+    mask_reg = &mask_entry->sermr_mask;
+  } else {
+    return RTEMS_NOT_IMPLEMENTED;
+  /* Mask or unmask */
+  if (mask) {
+    rtems_interrupt_disable( level);
+    *mask_reg &= ~(1 << pos);
+    rtems_interrupt_enable( level);
+  } else {
+    *mask_reg |= 1 << pos;
+  return RTEMS_SUCCESSFUL;
-rtems_status_code mpc83xx_ipic_set_highest_priority_interrupt( rtems_vector_number vector, int type)
+rtems_status_code mpc83xx_ipic_set_highest_priority_interrupt(
+  int type
-	uint32_t reg = 0;
+  uint32_t reg = 0;
-	if (!MPC83XX_IPIC_IS_VALID_VECTOR( vector)) {
-	} else if (type < 0 || type > MPC83XX_IPIC_INTERRUPT_CRITICAL) {
+  if (!MPC83XX_IPIC_IS_VALID_VECTOR( vector)) {
+  } else if (type < 0 || type > MPC83XX_IPIC_INTERRUPT_CRITICAL) {
-	reg = mpc83xx.ipic.sicfr;
-	mpc83xx.ipic.sicfr = (reg & ~0x7f000300) | (vector << 24) | (type << 8);
+  reg = mpc83xx.ipic.sicfr;
+  mpc83xx.ipic.sicfr = (reg & ~0x7f000300) | (vector << 24) | (type << 8);
@@ -370,42 +378,42 @@ rtems_status_code mpc83xx_ipic_set_highest_priority_interrupt( rtems_vector_numb
 rtems_status_code bsp_interrupt_vector_enable( rtems_vector_number irqnum)
-	rtems_vector_number vecnum = irqnum - BSP_IPIC_IRQ_LOWEST_OFFSET;
-	const BSP_isrc_rsc_t *rsc_ptr;
-	if (MPC83XX_IPIC_IS_VALID_VECTOR( vecnum)) {
-		rsc_ptr = &mpc83xx_ipic_isrc_rsc [vecnum];
-		if (rsc_ptr->mask_reg != NULL) {
-			uint32_t bit = 1U << (31 - rsc_ptr->bit_num);
-			rtems_interrupt_disable(level);
-			*(rsc_ptr->mask_reg) |= bit;
-			rtems_interrupt_enable(level);
+  rtems_vector_number vecnum = irqnum - BSP_IPIC_IRQ_LOWEST_OFFSET;
+  const BSP_isrc_rsc_t *rsc_ptr;
+  if (MPC83XX_IPIC_IS_VALID_VECTOR( vecnum)) {
+    rsc_ptr = &mpc83xx_ipic_isrc_rsc [vecnum];
+    if (rsc_ptr->mask_reg != NULL) {
+      uint32_t bit = 1U << (31 - rsc_ptr->bit_num);
+      rtems_interrupt_disable(level);
+      *(rsc_ptr->mask_reg) |= bit;
+      rtems_interrupt_enable(level);
 rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
-			*(rsc_ptr->mask_reg) &= ~bit;
+      *(rsc_ptr->mask_reg) &= ~bit;
@@ -413,173 +421,176 @@ rtems_status_code bsp_interrupt_vector_disable( rtems_vector_number irqnum)
 static int BSP_irq_handle_at_ipic( unsigned excNum)
-	int32_t vecnum;
+  int32_t vecnum;
 #ifdef GEN83XX_ENABLE_INTERRUPT_NESTING
-	mpc83xx_ipic_mask_t mask_save;
-	const mpc83xx_ipic_mask_t *mask_ptr;
-	uint32_t msr = 0;
+  mpc83xx_ipic_mask_t mask_save;
+  const mpc83xx_ipic_mask_t *mask_ptr;
+  uint32_t msr = 0;
 #endif
-	/* Get vector number */
-	switch (excNum) {
-		case ASM_EXT_VECTOR:
-			vecnum = MPC83xx_VCR_TO_VEC( mpc83xx.ipic.sivcr);
-			break;
-		case ASM_E300_SYSMGMT_VECTOR:
-			vecnum = MPC83xx_VCR_TO_VEC( mpc83xx.ipic.smvcr);
-			break;
-		case ASM_E300_CRIT_VECTOR:
-			vecnum = MPC83xx_VCR_TO_VEC( mpc83xx.ipic.scvcr);
-			break;
-		default:
-			return 1;
-	 * Check the vector number, mask lower priority interrupts, enable
-	 * exceptions and dispatch the handler.
+  /* Get vector number */
+  switch (excNum) {
+    case ASM_EXT_VECTOR:
+      vecnum = MPC83xx_VCR_TO_VEC( mpc83xx.ipic.sivcr);
+      break;
+    case ASM_E300_SYSMGMT_VECTOR:
+      vecnum = MPC83xx_VCR_TO_VEC( mpc83xx.ipic.smvcr);
+      break;
+    case ASM_E300_CRIT_VECTOR:
+      vecnum = MPC83xx_VCR_TO_VEC( mpc83xx.ipic.scvcr);
+      break;
+    default:
+      return 1;
+   * Check the vector number, mask lower priority interrupts, enable
+   * exceptions and dispatch the handler.
-		mask_ptr = &mpc83xx_ipic_prio2mask [vecnum];
+    mask_ptr = &mpc83xx_ipic_prio2mask [vecnum];
-		/* Save current mask registers */
-		mask_save.simsr_mask [0] = mpc83xx.ipic.simsr [0];
-		mask_save.simsr_mask [1] = mpc83xx.ipic.simsr [1];
-		mask_save.semsr_mask = mpc83xx.ipic.semsr;
-		mask_save.sermr_mask = mpc83xx.ipic.sermr;
+    /* Save current mask registers */
+    mask_save.simsr_mask [0] = mpc83xx.ipic.simsr [0];
+    mask_save.simsr_mask [1] = mpc83xx.ipic.simsr [1];
+    mask_save.semsr_mask = mpc83xx.ipic.semsr;
+    mask_save.sermr_mask = mpc83xx.ipic.sermr;
-		/* Mask all lower priority interrupts */
-		mpc83xx.ipic.simsr [0] &= mask_ptr->simsr_mask [0];
-		mpc83xx.ipic.simsr [1] &= mask_ptr->simsr_mask [1];
-		mpc83xx.ipic.semsr &= mask_ptr->semsr_mask;
-		mpc83xx.ipic.sermr &= mask_ptr->sermr_mask;
+    /* Mask all lower priority interrupts */
+    mpc83xx.ipic.simsr [0] &= mask_ptr->simsr_mask [0];
+    mpc83xx.ipic.simsr [1] &= mask_ptr->simsr_mask [1];
+    mpc83xx.ipic.semsr &= mask_ptr->semsr_mask;
+    mpc83xx.ipic.sermr &= mask_ptr->sermr_mask;
-		/* Enable all interrupts */
-		if (excNum != ASM_E300_CRIT_VECTOR) {
-			msr = ppc_external_exceptions_enable();
+    /* Enable all interrupts */
+    if (excNum != ASM_E300_CRIT_VECTOR) {
+      msr = ppc_external_exceptions_enable();
 #endif /* GEN83XX_ENABLE_INTERRUPT_NESTING */
-		/* Dispatch interrupt handlers */
-		bsp_interrupt_handler_dispatch( vecnum + BSP_IPIC_IRQ_LOWEST_OFFSET);
+    /* Dispatch interrupt handlers */
+    bsp_interrupt_handler_dispatch( vecnum + BSP_IPIC_IRQ_LOWEST_OFFSET);
-		/* Restore machine state */
-			ppc_external_exceptions_disable( msr);
-		/* Restore initial masks */
-		mpc83xx.ipic.simsr [0] = mask_save.simsr_mask [0];
-		mpc83xx.ipic.simsr [1] = mask_save.simsr_mask [1];
-		mpc83xx.ipic.semsr = mask_save.semsr_mask;
-		mpc83xx.ipic.sermr = mask_save.sermr_mask;
+    /* Restore machine state */
+      ppc_external_exceptions_disable( msr);
+    /* Restore initial masks */
+    mpc83xx.ipic.simsr [0] = mask_save.simsr_mask [0];
+    mpc83xx.ipic.simsr [1] = mask_save.simsr_mask [1];
+    mpc83xx.ipic.semsr = mask_save.semsr_mask;
+    mpc83xx.ipic.sermr = mask_save.sermr_mask;
-	} else {
-		bsp_interrupt_handler_default( vecnum);
+  } else {
+    bsp_interrupt_handler_default( vecnum);
-	return 0;
+  return 0;
  * Fill the array mpc83xx_ipic_prio2mask to allow masking of lower prio sources
  * to implement nested interrupts.
-rtems_status_code mpc83xx_ipic_calc_prio2mask( void)
+static rtems_status_code mpc83xx_ipic_calc_prio2mask(void)
-	rtems_status_code rc = RTEMS_SUCCESSFUL;
+  rtems_status_code rc = RTEMS_SUCCESSFUL;
-	 * FIXME: fill the array
-	return rc;
+   * FIXME: fill the array
+  return rc;
  * Activate the interrupt controller
-rtems_status_code mpc83xx_ipic_initialize( void)
+static rtems_status_code mpc83xx_ipic_initialize(void)
-	 * mask off all interrupts
-	mpc83xx.ipic.simsr [0] = 0;
-	mpc83xx.ipic.simsr [1] = 0;
-	mpc83xx.ipic.semsr = 0;
-	mpc83xx.ipic.sermr = 0;
-	 * set desired configuration as defined in bspopts.h
-	 * normally, the default values should be fine
-#if defined( BSP_SICFR_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.sicfr = BSP_SICFR_VAL;
+   * mask off all interrupts
+  mpc83xx.ipic.simsr [0] = 0;
+  mpc83xx.ipic.simsr [1] = 0;
+  mpc83xx.ipic.semsr = 0;
+  mpc83xx.ipic.sermr = 0;
+   * set desired configuration as defined in bspopts.h
+   * normally, the default values should be fine
+#if defined( BSP_SICFR_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.sicfr = BSP_SICFR_VAL;
 #endif
-	 * set desired priorities as defined in bspopts.h
-#if defined( BSP_SIPRR0_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.siprr [0] = BSP_SIPRR0_VAL;
+   * set desired priorities as defined in bspopts.h
+#if defined( BSP_SIPRR0_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.siprr [0] = BSP_SIPRR0_VAL;
 #endif
-#if defined( BSP_SIPRR1_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.siprr [1] = BSP_SIPRR1_VAL;
+#if defined( BSP_SIPRR1_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.siprr [1] = BSP_SIPRR1_VAL;
 #endif
-#if defined( BSP_SIPRR2_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.siprr [2] = BSP_SIPRR2_VAL;
+#if defined( BSP_SIPRR2_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.siprr [2] = BSP_SIPRR2_VAL;
 #endif
-#if defined( BSP_SIPRR3_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.siprr [3] = BSP_SIPRR3_VAL;
+#if defined( BSP_SIPRR3_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.siprr [3] = BSP_SIPRR3_VAL;
 #endif
-#if defined( BSP_SMPRR0_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.smprr [0] = BSP_SMPRR0_VAL;
+#if defined( BSP_SMPRR0_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.smprr [0] = BSP_SMPRR0_VAL;
 #endif
-#if defined( BSP_SMPRR1_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.smprr [1] = BSP_SMPRR1_VAL;
+#if defined( BSP_SMPRR1_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.smprr [1] = BSP_SMPRR1_VAL;
 #endif
-#if defined( BSP_SECNR_VAL)	/* defined in bspopts.h ? */
-	mpc83xx.ipic.secnr = BSP_SECNR_VAL;
+#if defined( BSP_SECNR_VAL)  /* defined in bspopts.h ? */
+  mpc83xx.ipic.secnr = BSP_SECNR_VAL;
 #endif
-	 * calculate priority masks
-	return mpc83xx_ipic_calc_prio2mask();
+   * calculate priority masks
+  return mpc83xx_ipic_calc_prio2mask();
-int mpc83xx_exception_handler( BSP_Exception_frame *frame, unsigned exception_number)
+static int mpc83xx_exception_handler(
+  BSP_Exception_frame *frame,
+  unsigned exception_number
-	return BSP_irq_handle_at_ipic( exception_number);
+  return BSP_irq_handle_at_ipic( exception_number);
 rtems_status_code bsp_interrupt_facility_initialize()
-	/* Install exception handler */
-	if (ppc_exc_set_handler( ASM_EXT_VECTOR, mpc83xx_exception_handler)) {
-		return RTEMS_IO_ERROR;
-	if (ppc_exc_set_handler( ASM_E300_SYSMGMT_VECTOR, mpc83xx_exception_handler)) {
-	if (ppc_exc_set_handler( ASM_E300_CRIT_VECTOR, mpc83xx_exception_handler)) {
-	/* Initialize the interrupt controller */
-	return mpc83xx_ipic_initialize();
+  /* Install exception handler */
+  if (ppc_exc_set_handler( ASM_EXT_VECTOR, mpc83xx_exception_handler)) {
+    return RTEMS_IO_ERROR;
+  if (ppc_exc_set_handler( ASM_E300_SYSMGMT_VECTOR, mpc83xx_exception_handler)) {
+  if (ppc_exc_set_handler( ASM_E300_CRIT_VECTOR, mpc83xx_exception_handler)) {
+  /* Initialize the interrupt controller */
+  return mpc83xx_ipic_initialize();
diff --git a/c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c b/c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c
index 512db03..a2a2683 100644
--- a/c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c
+++ b/c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c
@@ -23,22 +23,18 @@
 #include <bsp/irq.h>
 #include <bsp.h>
-#if defined( MPC83XX_BOARD_MPC8313ERDB)
+#if defined(MPC83XX_BOARD_MPC8313ERDB)
 #include <libchip/spi-sd-card.h>
-#elif defined( MPC83XX_BOARD_MPC8349EAMDS)
+#elif defined(MPC83XX_BOARD_MPC8349EAMDS)
 #include <libchip/spi-flash-m25p40.h>
-#elif defined( MPC83XX_BOARD_HSC_CM01)
+#elif defined(MPC83XX_BOARD_HSC_CM01)
 #include <libchip/spi-fram-fm25l256.h>
-#else
-#warning No SPI configuration available
 #endif
@@ -296,11 +292,11 @@ rtems_status_code bsp_register_spi
 |    0 or error code                                                        |
-#if defined(MPC83XX_BOARD_MPC8313ERDB)
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
-#endif
-  int ret_code;
+  #if defined(MPC83XX_BOARD_MPC8313ERDB)
+    rtems_status_code sc = RTEMS_SUCCESSFUL;
+  #endif
   unsigned spi_busno;
+  int      ret_code;
    * init I2C library (if not already done)
@@ -311,7 +307,7 @@ rtems_status_code bsp_register_spi
    * init port pins used to address/select SPI devices
    * Configured as master (direct connection to SD card)
@@ -335,7 +331,7 @@ rtems_status_code bsp_register_spi
   /* Open Drain */
   /* mpc83xx.gpio [0].gpdr  |= 0x0000000f; */
    * GPIO1[0] is nSEL_SPI for M25P40
@@ -345,7 +341,7 @@ rtems_status_code bsp_register_spi
   mpc83xx.gpio[0].gpdir |=  (1 << (31- 0));
   mpc83xx.gpio[0].gpdr  &= ~(1 << (31- 0));
    * GPIO1[24] is SPI_A0
@@ -358,6 +354,12 @@ rtems_status_code bsp_register_spi
   mpc83xx.gpio[0].gpdir |=  (0xf << (31-27));
   mpc83xx.gpio[0].gpdr  &= ~(0xf << (31-27));
+#else
+   * There is no SPI configuration information for this variant.
+  (void) spi_busno; /* avoid set but not used warning */
 #endif
1.9.3
