[PATCH 39/42] powerpc/psim: Fix warnings
Fri Oct 17 15:23:55 UTC 2014
 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c | 21 +++++++++++++--------
 1 file changed, 13 insertions(+), 8 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
index a6377f7..59f0e1d 100644
--- a/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/psim/irq/irq_init.c
@@ -1,12 +1,13 @@
-/* irq_init.c
  *  This file contains the implementation of rtems initialization
- *  related to interrupt handling.
- *  CopyRight (C) 1999 valette at crf.canon.fr
+ *  related to interrupt handling
+ *  Copyright (C) 1999 valette at crf.canon.fr
- * Enhanced by Jay Kulpinski <jskulpin at eng01.gdds.com>
- * to make it valid for MVME2300 Motorola boards.
+ *  Enhanced by Jay Kulpinski <jskulpin at eng01.gdds.com>
+ *  to make it valid for MVME2300 Motorola boards.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -21,6 +22,7 @@
 #include <bsp/vectors.h>
 #include <rtems/bspIo.h>
 #include <bsp/openpic.h>
+#include <bsp/irq-generic.h>
 static rtems_irq_connect_data      rtemsIrq[BSP_IRQ_NUMBER];
 static rtems_irq_global_settings   initial_config;
@@ -88,7 +90,10 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
   #endif
-int psim_exception_handler( BSP_Exception_frame *frame, unsigned exception_number)
+static int psim_exception_handler(
+  BSP_Exception_frame *frame,
+  unsigned exception_number
   BSP_panic("Unexpected interrupt occured");
   return 0;
1.9.3
