[PATCH 42/42] powerpc/shared/irq/irq_init.c: Fix warnings
Fri Oct 17 15:23:58 UTC 2014
 c/src/lib/libbsp/powerpc/shared/irq/irq_init.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c b/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c
index 11b66c3..a58cd24 100644
--- a/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c
+++ b/c/src/lib/libbsp/powerpc/shared/irq/irq_init.c
@@ -164,7 +164,7 @@ static unsigned char mcp750_openpic_initsenses[] = {
 #endif
 #if BSP_ISA_IRQ_NUMBER > 0 && !defined(qemu)
-static void VIA_isa_bridge_interrupts_setup(void)
+void VIA_isa_bridge_interrupts_setup(void)
   pci_isa_bridge_device pci_dev;
   uint32_t temp;
1.9.3
