Warnings Report 17 October 2014
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Oct 17 15:33:23 UTC 2014
Hi
With the 42 patches I just submitted, the warning count is
even further reduced. The summary is:
Unique Warnings : 188
BSPs : 183
BSPs with Zero : 0
BSPs with only in shared: 114
4 cpp
3 deprecated-declarations
20 format=
1 implicit-function-declaration
4 int-to-pointer-cast
2 maybe-uninitialized
75 missing-prototypes
1 nested-externs
2 overflow
7 pointer-to-int-cast
8 unused-but-set-variable
14 unused-function
Notice that there are now only 188 unique warnings.
Also notice that 114 BSPs now have no warnings in BSP of
libCPU code.
As with the previous status reports, help removing these
is appreciated.
Thanks.
200 c/src/../../cpukit/libmisc/shell/hexdump-conv.c:145:4: warning: format '%lc' expects argument of type 'wint_t', but argument 4 has type 'wchar_t' [-Wformat=]
180 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:21: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:88:5: warning: format '%x' expects argument of type 'unsigned int', but argument 8 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:67:3: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 6 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:36:3: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/capture/capture-cli.c:1424:18: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:61:17: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:55:7: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c:72:13: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
56 c/src/lib/libcpu/powerpc/shared/src/cache_.h:203:2: warning: #warning Most cache functions are not implemented [-Wcpp]
34 c/src/../../cpukit/libfs/src/jffs2/src/os-rtems.h:47:3: warning: right shift count >= width of type [enabled by default]
34 c/src/../../cpukit/libfs/src/jffs2/src/nodelist.h:294:86: warning: integer overflow in expression [-Woverflow]
20 c/src/../../cpukit/libfs/src/jffs2/include/linux/kernel.h:12:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
8 c/src/../../cpukit/score/src/threadloadenv.c:28:8: warning: variable 'is_fp' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:161:6: warning: no previous prototype for '_InitMBX8xx' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:79:5: warning: no previous prototype for 'BSP_irq_disable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:66:5: warning: no previous prototype for 'BSP_irq_enable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:271:1: warning: no previous prototype for 'BSP_CPM_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:252:6: warning: no previous prototype for 'BSP_SIU_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:149:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:42:6: warning: no previous prototype for 'mbx8xx_pcmciaide_probe' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:351:19: warning: no previous prototype for 'mbx8xx_pcmciaide_config_io_speed' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:328:5: warning: no previous prototype for 'mbx8xx_pcmciaide_control' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:270:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:213:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:175:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:137:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:111:6: warning: no previous prototype for 'mbx8xx_pcmciaide_initialize' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:714:1: warning: no previous prototype for 'serial_tstc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:693:1: warning: no previous prototype for 'serial_getc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:529:1: warning: no previous prototype for 'serial_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:1102:5: warning: no previous prototype for 'mbx8xx_console_get_configuration' [-Wmissing-prototypes]
7 c/src/../../cpukit/score/cpu/sh/context.c:171:6: warning: no previous prototype for '__CPU_Context_switch' [-Wmissing-prototypes]
6 c/src/../../cpukit/libfs/src/dosfs/msdos_conv_utf8.c:255:31: warning: variable 'rv' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media-server.c:47:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media.c:80:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
5 c/src/../../cpukit/score/cpu/sparc/sparcv8-atomic.c:111:6: warning: conflicting types for built-in function '__atomic_compare_exchange_4' [enabled by default]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 5 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:105:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 6 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 5 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 3 has type 'uint32_t' [-Wformat=]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:78:3: warning: nested extern declaration of 'BSP_Convert_decrementer' [-Wnested-externs]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:78:3: warning: implicit declaration of function 'BSP_Convert_decrementer' [-Wimplicit-function-declaration]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:220:5: warning: no previous prototype for '_BSP_poll_char' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:201:5: warning: no previous prototype for 'dbgu_poll_read' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/uboot_getenv.c:47:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/startup/bspidle.c:27:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/clock/../../../shared/clockdrv_shell.h:154:21: warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
3 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:43:6: warning: no previous prototype for '_Init68360' [-Wmissing-prototypes]
3 c/src/../../cpukit/libcsupport/src/__assert.c:52:43: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/powerpc-virtex.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex5.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex4.log: #warning Most cache functions are not implemented
2 log/powerpc-t32mppc.log: #warning Most cache functions are not implemented
2 log/powerpc-ss555.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_p1020rdb.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_1.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_0.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep-altivec.log: #warning Most cache functions are not implemented
2 log/powerpc-phycore_mpc5554.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme5500.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme3100.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme2307.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_rsm6.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_boot.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_app.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5668g.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_dpu.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mcp750.log: #warning Most cache functions are not implemented
2 log/powerpc-haleakala.log: #warning Most cache functions are not implemented
2 log/powerpc-gwlcfm.log: #warning Most cache functions are not implemented
2 log/powerpc-beatnik.log: #warning Most cache functions are not implemented
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:125:5: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:51: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:120:49: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:22:6: warning: no previous prototype for '_InitTQM8xx' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:129:6: warning: no previous prototype for 'cpu_init' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:86:13: warning: no previous prototype for 'bsp_tqm_get_cib_string' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:75:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:116:20: warning: no previous prototype for 'bsp_tqm_get_cib_uint32' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:906:19: warning: no previous prototype for 'bsp_register_spi' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/../shared/startup/bspidle.c:27:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:59:19: warning: no previous prototype for 'bsp_irq_enable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:52:19: warning: no previous prototype for 'bsp_irq_disable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:45:19: warning: no previous prototype for 'bsp_irq_enable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:38:19: warning: no previous prototype for 'bsp_irq_disable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:217:5: warning: no previous prototype for 'mpc8xx_exception_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:207:19: warning: no previous prototype for 'mpc8xx_siu_int_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:187:19: warning: no previous prototype for 'mpc8xx_cpic_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:45:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
2 c/src/../../cpukit/score/src/threadloadenv.c:29:12: warning: variable 'isr_level' set but not used [-Wunused-but-set-variable]
2 c/src/../../cpukit/score/cpu/m68k/cpu_asm.S:75:2: warning: #warning "_CPU_Context_Restart_self restoring FPU context not implemented" [-Wcpp]
2 c/src/../../cpukit/score/cpu/lm32/irq.c:32:6: warning: no previous prototype for '__ISR_Handler' [-Wmissing-prototypes]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:80:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:33:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
1 tools/cpu/nios2/ptf.c:92:26: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:77:9: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:166:31: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:156:29: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 log/sh-gensh2.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/sh-gensh1.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/powerpc-ss555.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/powerpc-ep1a.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/or1k-or1ksim.log:/users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/../../../../or1k-rtems4.11/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000000000
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: (near initialization for 'Configuration.idle_task') [enabled by default]
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: initialization from incompatible pointer type [enabled by default]
1 log/m68k-m5484FireEngine.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 log/m68k-COBRA5475.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 c/src/../../testsuites/samples/paranoia/paranoia.c:195:0: warning: "POW" redefined [enabled by default]
1 c/src/../../testsuites/samples/fileio/init.c:420:7: warning: large integer implicitly truncated to unsigned type [-Woverflow]
1 c/src/../../testsuites/samples/fileio/init.c:354:9: warning: left shift count >= width of type [enabled by default]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:304:5: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c:207:5: warning: no previous prototype for 'ffuart_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register_abs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:246:5: warning: no previous prototype for 'cchip1_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh2/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/sh/gensh1/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh1/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:848:26: warning: 'bsp_dummy_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:773:26: warning: 'bsp_pghplus_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:743:26: warning: 'bsp_pghplus_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:694:26: warning: 'bsp_pghplus_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:673:26: warning: 'bsp_dummy_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:629:26: warning: 'bsp_dummy_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:52:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_write.c:36:21: warning: no previous prototype for 'console_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_read.c:36:21: warning: no previous prototype for 'console_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_control.c:37:21: warning: no previous prototype for 'console_control' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:22:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c:40:6: warning: no previous prototype for 'cmain' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:411:26: warning: 'do_poll_write' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:347:26: warning: 'do_poll_read' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:219:16: warning: '_EPPCBug_pollWrite' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:114:12: warning: '_EPPCBug_pollRead' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c:14:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:37:17: warning: 'uart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:32:28: warning: 'uart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:45:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:33:6: warning: no previous prototype for 'timerisr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c:24:6: warning: no previous prototype for 'bsp_start' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/console/console.c:38:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c:31:11: warning: no previous prototype for 'Spurious_Isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c:25:6: warning: no previous prototype for 'Init5329' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5235/startup/init5235.c:29:6: warning: no previous prototype for 'Init5235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c:30:6: warning: no previous prototype for 'Init5225x' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c:25:6: warning: no previous prototype for 'Init52235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/mc68ec.c:12:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:48:27: warning: variable 'RamBase_p' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/csb360/startup/init5272.c:84:1: warning: no previous prototype for 'init5272' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/init5282.c:23:6: warning: no previous prototype for 'Init5282' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c:48:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:61:6: warning: no previous prototype for 'BSP_uart_is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:54:6: warning: no previous prototype for 'BSP_uart_polled_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:44:6: warning: no previous prototype for 'BSP_uart_polled_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../../shared/bspclean.c:14:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:37:17: warning: 'usart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:32:28: warning: 'usart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c:124:20: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/arm/gba/console/conio.c:321:6: warning: no previous prototype for 'gba_initconio' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/edb7312/irq/irq.c:23:6: warning: no previous prototype for 'edb7312_interrupt_dispatch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb337/console/fbcons.c:135:5: warning: no previous prototype for 'fbcons_poll_read' [-Wmissing-prototypes]
1 c/src/../../cpukit/score/src/threadstartmultitasking.c:82:1: warning: 'noreturn' function does return [enabled by default]
1 c/src/../../cpukit/score/src/objectextendinformation.c:159:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/score/src/objectextendinformation.c:154:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/libmisc/utf8proc/utf8proc.c:148:5: warning: left shift count >= width of type [enabled by default]
1 c/src/../../cpukit/libfs/src/dosfs/msdos_conv.c:452:48: warning: 'c' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 c/src/../../cpukit/libcsupport/src/vprintk.c:199:41: warning: 'num' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 arm-altcycv_devkit (only shared)
1 arm-altcycv_devkit_smp (only shared)
1 arm-arm1136jfs (only shared)
1 arm-arm1136js (only shared)
1 arm-arm7tdmi (only shared)
1 arm-arm920 (only shared)
1 arm-armcortexa9 (only shared)
1 arm-csb336 (only shared)
1 arm-gp32 (only shared)
1 arm-lm3s3749 (only shared)
1 arm-lm3s6965 (only shared)
1 arm-lm3s6965_qemu (only shared)
1 arm-lm4f120 (only shared)
1 arm-lpc17xx_ea_ram (only shared)
1 arm-lpc17xx_ea_rom_int (only shared)
1 arm-lpc17xx_plx800_ram (only shared)
1 arm-lpc17xx_plx800_rom_int (only shared)
1 arm-lpc2362 (only shared)
1 arm-lpc23xx_tli800 (only shared)
1 arm-lpc24xx_ea (only shared)
1 arm-lpc24xx_ncs_ram (only shared)
1 arm-lpc24xx_ncs_rom_ext (only shared)
1 arm-lpc24xx_ncs_rom_int (only shared)
1 arm-lpc24xx_plx800_ram (only shared)
1 arm-lpc24xx_plx800_rom_int (only shared)
1 arm-lpc32xx_mzx (only shared)
1 arm-lpc32xx_mzx_stage_1 (only shared)
1 arm-lpc32xx_mzx_stage_2 (only shared)
1 arm-lpc32xx_phycore (only shared)
1 arm-lpc40xx_ea_ram (only shared)
1 arm-lpc40xx_ea_rom_int (only shared)
1 arm-realview_pbx_a9_qemu (only shared)
1 arm-realview_pbx_a9_qemu_smp (only shared)
1 arm-smdk2410 (only shared)
1 arm-stm32f105rc (only shared)
1 arm-stm32f4 (only shared)
1 arm-tms570ls3137_hdk_intram (only shared)
1 arm-tms570ls3137_hdk (only shared)
1 arm-tms570ls3137_hdk_sdram (only shared)
1 arm-xilinx_zynq_a9_qemu (only shared)
1 arm-xilinx_zynq_zc702 (only shared)
1 arm-xilinx_zynq_zc706 (only shared)
1 arm-xilinx_zynq_zedboard (only shared)
1 mips-csb350 (only shared)
1 mips-genmongoosev (only shared)
1 mips-hurricane (only shared)
1 mips-jmr3904 (only shared)
1 mips-malta (only shared)
1 mips-rbtx4925 (only shared)
1 mips-rbtx4938 (only shared)
2 arm-edb7312 (inBSP=1 inLibCPU=0)
2 arm-gba (inBSP=1 inLibCPU=0)
2 arm-gumstix (inBSP=0 inLibCPU=1)
2 arm-nds (inBSP=1 inLibCPU=0)
3 arm-csb337 (inBSP=0 inLibCPU=2)
3 arm-kit637_v6 (inBSP=0 inLibCPU=2)
3 avr-avrtest (only shared)
3 powerpc-brs5l (only shared)
3 powerpc-brs6l (only shared)
3 powerpc-br_uid (only shared)
3 powerpc-dp2 (only shared)
3 powerpc-hsc_cm01 (only shared)
3 powerpc-icecube (only shared)
3 powerpc-mpc8260ads (only shared)
3 powerpc-mpc8309som (only shared)
3 powerpc-mpc8313erdb (only shared)
3 powerpc-mpc8349eamds (only shared)
3 powerpc-mtx603e (only shared)
3 powerpc-mvme2100 (only shared)
3 powerpc-pm520_cr825 (only shared)
3 powerpc-pm520_ze30 (only shared)
3 powerpc-psim (only shared)
3 powerpc-score603e (only shared)
3 v850-v850e1sim (only shared)
3 v850-v850e2sim (only shared)
3 v850-v850e2v3sim (only shared)
3 v850-v850esim (only shared)
3 v850-v850essim (only shared)
3 v850-v850sim (only shared)
4 arm-csb637 (inBSP=1 inLibCPU=2)
4 arm-lpc1768_mbed_ahb_ram_eth (only shared)
4 arm-lpc1768_mbed_ahb_ram (only shared)
4 arm-lpc1768_mbed (only shared)
4 powerpc-ep1a (inBSP=1 inLibCPU=0)
4 powerpc-qemuppc (inBSP=1 inLibCPU=0)
4 sh-gensh4 (only shared)
4 sh-simsh1 (only shared)
4 sh-simsh2e (only shared)
4 sh-simsh2 (only shared)
4 sh-simsh4 (only shared)
4 sparc-leon3 (only shared)
4 sparc-ngmp (only shared)
5 lm32-milkymist (inBSP=1 inLibCPU=0)
5 powerpc-beatnik (inBSP=0 inLibCPU=2)
5 powerpc-gwlcfm (inBSP=0 inLibCPU=2)
5 powerpc-mcp750 (inBSP=0 inLibCPU=2)
5 powerpc-mpc5566evb (inBSP=0 inLibCPU=2)
5 powerpc-mpc5566evb_spe (inBSP=0 inLibCPU=2)
5 powerpc-mpc5643l_dpu (inBSP=0 inLibCPU=2)
5 powerpc-mpc5643l_evb (inBSP=0 inLibCPU=2)
5 powerpc-mpc5668g (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_ecu508_app (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_ecu508_boot (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674fevb (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674fevb_spe (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_rsm6 (inBSP=0 inLibCPU=2)
5 powerpc-mvme2307 (inBSP=0 inLibCPU=2)
5 powerpc-mvme3100 (inBSP=0 inLibCPU=2)
5 powerpc-mvme5500 (inBSP=0 inLibCPU=2)
5 powerpc-phycore_mpc5554 (inBSP=0 inLibCPU=2)
5 powerpc-qemuprep-altivec (inBSP=0 inLibCPU=2)
5 powerpc-qemuprep (inBSP=0 inLibCPU=2)
5 powerpc-virtex4 (inBSP=0 inLibCPU=2)
5 powerpc-virtex5 (inBSP=0 inLibCPU=2)
5 powerpc-virtex (inBSP=0 inLibCPU=2)
5 sparc-erc32 (inBSP=1 inLibCPU=0)
5 sparc-sis (inBSP=1 inLibCPU=0)
6 arm-raspberrypi (inBSP=5 inLibCPU=0)
6 arm-rtl22xx_t (inBSP=2 inLibCPU=0)
6 powerpc-haleakala (inBSP=0 inLibCPU=2)
6 powerpc-ss555 (inBSP=1 inLibCPU=2)
6 sh-gensh1 (inBSP=1 inLibCPU=0)
7 arm-rtl22xx (inBSP=2 inLibCPU=0)
7 lm32-lm32_evr (inBSP=3 inLibCPU=0)
7 sh-gensh2 (inBSP=1 inLibCPU=1)
8 sparc-leon2 (inBSP=4 inLibCPU=0)
9 nios2-nios2_iss (inBSP=4 inLibCPU=0)
9 powerpc-t32mppc (inBSP=4 inLibCPU=2)
10 powerpc-qoriq_core_0 (inBSP=3 inLibCPU=4)
10 powerpc-qoriq_core_1 (inBSP=3 inLibCPU=4)
10 powerpc-qoriq_p1020rdb (inBSP=3 inLibCPU=4)
21 bfin-bf537Stamp (only shared)
21 bfin-eZKit533 (only shared)
21 bfin-TLL6527M (only shared)
21 h8300-h8sim (only shared)
21 m32r-m32rsim (only shared)
21 moxie-moxiesim (only shared)
21 powerpc-mbx821_001 (inBSP=18 inLibCPU=0)
21 powerpc-mbx821_002b (inBSP=18 inLibCPU=0)
21 powerpc-mbx821_002 (inBSP=18 inLibCPU=0)
21 powerpc-mbx860_001b (inBSP=18 inLibCPU=0)
21 powerpc-mbx860_002 (inBSP=18 inLibCPU=0)
21 powerpc-mbx860_1b (inBSP=18 inLibCPU=0)
21 powerpc-pghplus (inBSP=18 inLibCPU=0)
21 powerpc-tqm8xx_stk8xx (inBSP=18 inLibCPU=0)
22 i386-pc386 (only shared)
22 i386-pc486 (only shared)
22 i386-pc586 (only shared)
22 i386-pc586-sse (only shared)
22 i386-pc686 (only shared)
22 i386-pcp4 (only shared)
23 m68k-gen68302 (only shared)
23 m68k-gen68340 (only shared)
23 m68k-mcf5206elite (only shared)
23 m68k-mvme147 (only shared)
23 m68k-mvme147s (only shared)
23 m68k-mvme162lx (only shared)
23 m68k-mvme162 (only shared)
23 m68k-mvme167 (only shared)
23 m68k-ods68302 (only shared)
23 m68k-sim68000 (only shared)
23 m68k-simcpu32 (only shared)
23 m68k-uC5282 (only shared)
24 m68k-av5282 (inBSP=1 inLibCPU=0)
24 m68k-COBRA5475 (only shared)
24 m68k-csb360 (inBSP=1 inLibCPU=0)
24 m68k-gen68360_040 (inBSP=1 inLibCPU=0)
24 m68k-gen68360 (inBSP=1 inLibCPU=0)
24 m68k-idp (inBSP=1 inLibCPU=0)
24 m68k-m5484FireEngine (only shared)
24 m68k-mcf52235 (inBSP=1 inLibCPU=0)
24 m68k-mcf5225x (inBSP=1 inLibCPU=0)
24 m68k-mcf5235 (inBSP=1 inLibCPU=0)
24 m68k-mcf5329 (inBSP=1 inLibCPU=0)
25 m68k-mrm332 (inBSP=1 inLibCPU=0)
25 m68k-pgh360 (inBSP=2 inLibCPU=0)
25 powerpc-mbx860_005b (inBSP=22 inLibCPU=0)
26 m68k-mvme136 (only shared)
26 sparc64-niagara (only shared)
26 sparc64-usiii (only shared)
27 or1k-or1ksim (inBSP=2 inLibCPU=0)
41 h8300-h8sxsim (only shared)
52 m32c-m32csim (only shared)
