STM32F4 register definitions and PLL settings patch
Chris Nott
chrisn at vl.com.au
Sun Oct 19 06:36:13 UTC 2014
Hi,
On 18/10/2014 3:45 AM, Tomasz Gregorek wrote:
> Hi Chris
> - pll_q = ( (long) ( src_clk * pll_n + src_clk * pll_n / 2 ) ) / pll_m
> / 48; + pll_q = ( (long) ( src_clk * pll_n ) ) / pll_m / 48;
> Your fix for the PLL_Q calculation is correct.
> It supposed to be rounding from <=X.5 to X and from >X.5 to (X+1) but
> first I messed up the equation second this clock should not exceed
> 48MHz so rounding up is not necessarily the best idea.
A check for clock <= 48MHz would be good. Even better if we can check if
USB is used and warn if it is not exactly 48MHz..
> -#define FLASH_ACR_LATENCY( val ) BSP_FLD32( val, 0, 3 ) -#define
> FLASH_ACR_LATENCY_MSK BSP_MSK32( 0, 3 )
> +#define STM32F4_FLASH_ACR_LATENCY(val) BSP_FLD32(val, 0, 2) // Flash
> access latency +#define STM32F4_FLASH_ACR_LATENCY_GET(reg)
> BSP_FLD32GET(reg, 0, 2) +#define STM32F4_FLASH_ACR_LATENCY_SET(reg,
> val) BSP_FLD32SET(reg, val, 0, 2)
> I would argue about the STM32F4_FLASH_ACR_LATENCY where you use 3LSB
> of ACR (up to 7 wait states) which is correct for the STM32F405xx/07xx
> and STM32F415xx/17xx while for the STM32F42xxx and STM32F43xxx there
> are 4LSBs in use (up to 15 wait states).
> I am not sure how to deal with it. Do we need to distinguish for which
> chip we are compiling?
I think it should be safe to use 3 bits as it was. It's a pretty low
risk that someone will accidentally set a flash latency > 7 and it is
pretty likely a write to that bit would be ignored in the hardware anyway.
Ideally yes when we support STM42xxx etc. as well we should add a build
option, but there may be more we need to add, like the operating chip
voltage. Honesty my priority so far is first adding register maps and
example projects to make RTEMS more useful out of the box for standard
boards like STM32F4Discovery.
> Thanks and regards
> Tomasz
> 2014-10-18 11:06 GMT+02:00 Chris Nott <chrisn at vl.com.au
> <mailto:chrisn at vl.com.au>>:
> Hi,
> I sent these header file changes previously, they didn't get
> picked up.
> I re-merged with the head, cleaned up formatting and fixed a bug
> with PLL_Q setting not generating the right auxiliary clock
> frequency for USB peripheral - Tomasz this was your change, could
> you please review my fix.
> Regards,
> Chris.
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141018/2791aa29/attachment.html>
