x86 interpreter and NOVA hypervisor - Was: [PATCH] do_it
Pavel Pisa pisa at cmp.felk.cvut.cz
Mon Oct 20 14:55:14 UTC 2014
Hello Gedare and others,
On Sunday 19 of October 2014 15:01:08 Gedare Bloom wrote:
> On Sun, Oct 19, 2014 at 7:48 AM, Pavel Pisa <pisa at control.felk.cvut.cz>
> >    set interpreter in RTEMS which would allow to run BIOS x86
> >    real code sandboxed and with additional memory ranges protection
> >    and with minimal impact on other RT code running in parallel.
> >    This would be nice to do, allows to use x86 PCI VESA BIOS cards
> >    on other PCI enabled architectures but it is above our current
> >    capabilities and time constraints. On the other hand we can provide
> >    example from NOVA microkernel which achieved and uses this goal.
> This last option seems quite interesting. Can you link to the example
> or any doc on how it is done?
The x86 interpreter used for BIOS, VBE and other untrusted HW related
code indirect execution is part of NOVA hypervisor. The source code
of the executor is there
 https://github.com/TUD-OS/seoul/tree/master/executor
The executor is written in C++ and significant part of source
code for x86 instruction decoding is build with use of python
script and GNU binutils.
The code is GPL licensed but there is some chance to negotiate
RTEMS required exception. My colleague - Michal Sojka - has
worked with these people and have contact to them.
As for the related hypervisor and kernel project, it would
be interresting to combine RTEMS and NOVA hypervisor
http://hypervisor.org/ for some kinds of applications.
My colleague looks for some research project which would
allow to cooperate on porting NOVA to ARM/AArch64 and or
to combine NOVA with RTEMS. RTEMS porting to AArch 64
would be interresting for me as well. But these are kinds
of projects which we cannot start from enthusiasm only.
They require funding - i.e. larger research project, consortium,
strong company contract etc. to pay required man years of work.
Best wishes,
               Pavel
