[PATCH 1/2] dosfs: Support ctime and mtime
Mon Oct 20 17:10:15 UTC 2014
What does it mean "as far as possible"?
On Mon, Oct 20, 2014 at 10:24 AM, Sebastian Huber
> Implement ctime and mtime updates according to POSIX as far as possible.
> The ctime is mapped to the FAT create time and date.  The mtime is
> mapped to the FAT last modified time and date.  For the atime use the
> mtime.
>  cpukit/libfs/src/dosfs/fat_file.c            |  34 +++++++++
>  cpukit/libfs/src/dosfs/fat_file.h            |  33 +++++++++
>  cpukit/libfs/src/dosfs/msdos.h               |  22 +-----
>  cpukit/libfs/src/dosfs/msdos_create.c        |  12 ++--
>  cpukit/libfs/src/dosfs/msdos_dir.c           |   2 +
>  cpukit/libfs/src/dosfs/msdos_file.c          |  76 +++-----------------
>  cpukit/libfs/src/dosfs/msdos_handlers_file.c |   2 +-
>  cpukit/libfs/src/dosfs/msdos_init.c          |  18 ++++-
>  cpukit/libfs/src/dosfs/msdos_misc.c          | 100 ++++++++++++++++-----------
>  9 files changed, 166 insertions(+), 133 deletions(-)
> diff --git a/cpukit/libfs/src/dosfs/fat_file.c b/cpukit/libfs/src/dosfs/fat_file.c
> index 2899f1b..a1f77fa 100644
> --- a/cpukit/libfs/src/dosfs/fat_file.c
> +++ b/cpukit/libfs/src/dosfs/fat_file.c
> @@ -165,6 +165,38 @@ fat_file_reopen(fat_file_fd_t *fat_fd)
>      return RC_OK;
> +int
> +fat_file_update(fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd)
> +    int ret_rc = RC_OK;
> +     * if fat-file descriptor is not marked as "removed", synchronize
> +     * size, first cluster number, write time and date fields of the file
> +    if (!FAT_FILE_IS_REMOVED(fat_fd))
> +        int rc;
> +        if (fat_fd->fat_file_type == FAT_FILE)
> +            rc = fat_file_set_first_cluster_num(fs_info, fat_fd);
> +            if (rc != RC_OK)
> +                ret_rc = rc;
> +            rc = fat_file_set_file_size(fs_info, fat_fd);
> +            if (rc != RC_OK)
> +                ret_rc = rc;
> +        rc = fat_file_set_time_and_date(fs_info, fat_fd);
> +        if (rc != RC_OK)
> +            ret_rc = rc;
> +    return ret_rc;
>  /* fat_file_close --
>   *     Close fat-file. If count of links to fat-file
>   *     descriptor is greater than 1 (i.e. somebody esle holds pointer
> @@ -204,6 +236,8 @@ fat_file_close(
>          uint32_t key = fat_construct_key(fs_info, &fat_fd->dir_pos.sname);
> +        fat_file_update(fs_info, fat_fd);
>          if (fat_fd->flags & FAT_FILE_REMOVED)
>              rc = fat_file_truncate(fs_info, fat_fd, 0);
> diff --git a/cpukit/libfs/src/dosfs/fat_file.h b/cpukit/libfs/src/dosfs/fat_file.h
> index 79af62a..fa177f6 100644
> --- a/cpukit/libfs/src/dosfs/fat_file.h
> +++ b/cpukit/libfs/src/dosfs/fat_file.h
> @@ -22,6 +22,7 @@
>  #include <rtems.h>
>  #include <rtems/libio_.h>
> +#include <sys/time.h>
>  #include <time.h>
>  #include "fat.h"
> @@ -88,6 +89,7 @@ typedef struct fat_file_fd_s
>      fat_dir_pos_t    dir_pos;
>      uint8_t          flags;
>      fat_file_map_t   map;
> +    time_t           ctime;
>      time_t           mtime;
>  } fat_file_fd_t;
> @@ -139,6 +141,17 @@ fat_construct_key(
>                ((pos->ofs >> 5) & (FAT_DIRENTRIES_PER_SEC512 - 1)) );
> +static inline void fat_file_update_ctime(fat_file_fd_t *fat_fd, time_t t)
> +  fat_fd->ctime = t;
> +static inline void fat_file_update_ctime_mtime(fat_file_fd_t *fat_fd, time_t t)
> +  fat_fd->mtime = t;
>  /* Prototypes for "fat-file" operations */
>  int
>  fat_file_open(fat_fs_info_t                         *fs_info,
> @@ -192,6 +205,26 @@ void
>  fat_file_mark_removed(fat_fs_info_t                        *fs_info,
>                        fat_file_fd_t                        *fat_fd);
> +int
> +fat_file_size(fat_fs_info_t                        *fs_info,
> +              fat_file_fd_t                        *fat_fd);
> +int
> +fat_file_set_first_cluster_num(fat_fs_info_t *fs_info,
> +int
> +fat_file_set_file_size(fat_fs_info_t *fs_info,
> +int
> +fat_file_set_time_and_date(fat_fs_info_t *fs_info,
> +int
>  #ifdef __cplusplus
>  #endif
> diff --git a/cpukit/libfs/src/dosfs/msdos.h b/cpukit/libfs/src/dosfs/msdos.h
> index bb191fe..baa34d7 100644
> --- a/cpukit/libfs/src/dosfs/msdos.h
> +++ b/cpukit/libfs/src/dosfs/msdos.h
> @@ -134,6 +134,8 @@ typedef rtems_filesystem_node_types_t msdos_node_type_t;
>  #define MSDOS_FILE_WDATE_OFFSET           24
>  #define MSDOS_FILE_WTIME_OFFSET           22
>  #define MSDOS_FILE_ADATE_OFFSET           18
> +#define MSDOS_FILE_CDATE_OFFSET           16
> +#define MSDOS_FILE_CTIME_OFFSET           14
>   * Possible values of DIR_Attr field of 32 bytes long FAT Directory Entry
> @@ -333,8 +335,6 @@ int msdos_initialize_support(
>    rtems_dosfs_convert_control             *converter
> -int msdos_file_close(rtems_libio_t *iop /* IN  */);
>  ssize_t msdos_file_read(
>    rtems_libio_t *iop,              /* IN  */
>    void          *buffer,           /* IN  */
> @@ -360,8 +360,6 @@ msdos_file_ftruncate(
>  int msdos_file_sync(rtems_libio_t *iop);
> -int msdos_file_datasync(rtems_libio_t *iop);
>  ssize_t msdos_dir_read(
> @@ -461,28 +459,12 @@ void msdos_date_unix2dos(
>  unsigned int msdos_date_dos2unix(unsigned int dd, unsigned int dt);
> -int msdos_set_first_cluster_num(
> -  rtems_filesystem_mount_table_entry_t *mt_entry,
> -  fat_file_fd_t                        *fat_fd
> -int msdos_set_file_size(
>  int msdos_set_first_char4file_name(
>    fat_dir_pos_t                        *dir_pos,
>    unsigned char                         first_char
> -int msdos_set_dir_wrt_time_and_date(
>  int msdos_dir_is_empty(
> diff --git a/cpukit/libfs/src/dosfs/msdos_create.c b/cpukit/libfs/src/dosfs/msdos_create.c
> index 735e053..d58fe56 100644
> --- a/cpukit/libfs/src/dosfs/msdos_create.c
> +++ b/cpukit/libfs/src/dosfs/msdos_create.c
> @@ -70,7 +70,7 @@ msdos_creat_node(const rtems_filesystem_location_info_t  *parent_loc,
>      msdos_fs_info_t  *fs_info = parent_loc->mt_entry->fs_info;
>      fat_file_fd_t    *parent_fat_fd = parent_loc->node_access;
>      fat_file_fd_t    *fat_fd = NULL;
> -    time_t            time_ret = 0;
> +    time_t            now;
>      uint16_t          time_val = 0;
>      uint16_t          date = 0;
> @@ -102,11 +102,10 @@ msdos_creat_node(const rtems_filesystem_location_info_t  *parent_loc,
>      *MSDOS_DIR_NT_RES(short_node) = MSDOS_RES_NT_VALUE;
>      /* set up last write date and time */
> -    time_ret = time(NULL);
> -    if ( time_ret == -1 )
> -        return -1;
> +    now = time(NULL);
> +    fat_file_update_ctime_mtime(parent_fat_fd, now);
> -    msdos_date_unix2dos(time_ret, &date, &time_val);
> +    msdos_date_unix2dos(now, &date, &time_val);
>      *MSDOS_DIR_CRT_TIME(short_node) = CT_LE_W(time_val);
>      *MSDOS_DIR_CRT_DATE(short_node) = CT_LE_W(date);
>      *MSDOS_DIR_WRITE_TIME(short_node) = CT_LE_W(time_val);
> @@ -192,6 +191,7 @@ msdos_creat_node(const rtems_filesystem_location_info_t  *parent_loc,
>          fat_fd->fat_file_size = 0;
>          fat_fd->fat_file_type = FAT_DIRECTORY;
>          fat_fd->size_limit = MSDOS_MAX_DIR_LENGHT;
> +        fat_file_update_ctime_mtime(fat_fd, now);
>           * dot and dotdot entries are identical to new node except the
> @@ -260,7 +260,7 @@ msdos_creat_node(const rtems_filesystem_location_info_t  *parent_loc,
>          /* write first cluster num of a new directory to disk */
> -        rc = msdos_set_first_cluster_num(parent_loc->mt_entry, fat_fd);
> +        rc = fat_file_set_first_cluster_num(&fs_info->fat, fat_fd);
>          if (rc != RC_OK)
>              goto error;
> diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c b/cpukit/libfs/src/dosfs/msdos_dir.c
> index f311d89..b10ed9e 100644
> --- a/cpukit/libfs/src/dosfs/msdos_dir.c
> +++ b/cpukit/libfs/src/dosfs/msdos_dir.c
> @@ -403,6 +403,8 @@ msdos_dir_stat(
>      buf->st_size = fat_fd->fat_file_size;
>      buf->st_blocks = fat_fd->fat_file_size >> FAT_SECTOR512_BITS;
>      buf->st_blksize = fs_info->fat.vol.bps;
> +    buf->st_atime = fat_fd->mtime;
> +    buf->st_ctime = fat_fd->ctime;
>      buf->st_mtime = fat_fd->mtime;
>      rtems_semaphore_release(fs_info->vol_sema);
> diff --git a/cpukit/libfs/src/dosfs/msdos_file.c b/cpukit/libfs/src/dosfs/msdos_file.c
> index 33fe525..f575290 100644
> --- a/cpukit/libfs/src/dosfs/msdos_file.c
> +++ b/cpukit/libfs/src/dosfs/msdos_file.c
> @@ -30,70 +30,6 @@
>  #include "msdos.h"
> -static int
> -msdos_file_update(rtems_libio_t *iop)
> -    int              rc = RC_OK;
> -    fat_file_fd_t   *fat_fd = iop->pathinfo.node_access;
> -     * if fat-file descriptor is not marked as "removed", synchronize
> -     * size, first cluster number, write time and date fields of the file
> -    if (!FAT_FILE_IS_REMOVED(fat_fd))
> -        rc = msdos_set_first_cluster_num(iop->pathinfo.mt_entry, fat_fd);
> -        if (rc != RC_OK)
> -            return rc;
> -        rc = msdos_set_file_size(iop->pathinfo.mt_entry, fat_fd);
> -        if (rc != RC_OK)
> -            return rc;
> -        rc = msdos_set_dir_wrt_time_and_date(iop->pathinfo.mt_entry, fat_fd);
> -        if (rc != RC_OK)
> -            return rc;
> -    return rc;
> -/* msdos_file_close --
> - *     Close fat-file which correspondes to the file. If fat-file descriptor
> - *     which correspondes to the file is not marked "removed", synchronize
> - *     size, first cluster number, write time and date fields of the file.
> - * PARAMETERS:
> - *     iop - file control block
> - * RETURNS:
> - *     RC_OK, if file closed successfully, or -1 if error occured (errno set
> - *     appropriately)
> -int
> -msdos_file_close(rtems_libio_t *iop)
> -    int                rc = RC_OK;
> -    rtems_status_code  sc = RTEMS_SUCCESSFUL;
> -    msdos_fs_info_t   *fs_info = iop->pathinfo.mt_entry->fs_info;
> -    sc = rtems_semaphore_obtain(fs_info->vol_sema, RTEMS_WAIT,
> -                                MSDOS_VOLUME_SEMAPHORE_TIMEOUT);
> -    if (sc != RTEMS_SUCCESSFUL)
> -        rtems_set_errno_and_return_minus_one(EIO);
> -    rc = msdos_file_update(iop);
> -    rtems_semaphore_release(fs_info->vol_sema);
> -    return rc;
>  /* msdos_file_read --
>   *     This routine read from file pointed to by file control block into
>   *     the specified data buffer provided by user
> @@ -174,6 +110,9 @@ msdos_file_write(rtems_libio_t *iop,const void *buffer, size_t count)
>      if (iop->offset > fat_fd->fat_file_size)
>          fat_fd->fat_file_size = iop->offset;
> +    if (ret > 0)
> +        fat_file_update_ctime_mtime(fat_fd, time(NULL));
>      return ret;
> @@ -211,6 +150,8 @@ msdos_file_stat(
>      buf->st_blocks = ((fat_fd->fat_file_size + cl_mask) & ~cl_mask)
>        >> FAT_SECTOR512_BITS;
>      buf->st_blksize = fs_info->fat.vol.bpc;
> @@ -259,8 +200,10 @@ msdos_file_ftruncate(rtems_libio_t *iop, off_t length)
> -    if (rc == RC_OK) {
> +    if (rc == RC_OK)
>          fat_fd->fat_file_size = length;
> @@ -284,13 +227,14 @@ msdos_file_sync(rtems_libio_t *iop)
>      int                rc = RC_OK;
> +    fat_file_fd_t     *fat_fd = iop->pathinfo.node_access;
> +    rc = fat_file_update(&fs_info->fat, fat_fd);
>      if (rc != RC_OK)
> diff --git a/cpukit/libfs/src/dosfs/msdos_handlers_file.c b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> index dbc949f..0bea6e1 100644
> --- a/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> +++ b/cpukit/libfs/src/dosfs/msdos_handlers_file.c
> @@ -23,7 +23,7 @@
>  const rtems_filesystem_file_handlers_r msdos_file_handlers = {
>    .open_h = rtems_filesystem_default_open,
> -  .close_h = msdos_file_close,
> +  .close_h = rtems_filesystem_default_close,
>    .read_h = msdos_file_read,
>    .write_h = msdos_file_write,
>    .ioctl_h = rtems_filesystem_default_ioctl,
> diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
> index 2846dbd..a5e52f1 100644
> --- a/cpukit/libfs/src/dosfs/msdos_init.c
> +++ b/cpukit/libfs/src/dosfs/msdos_init.c
> @@ -35,6 +35,22 @@ static int msdos_clone_node_info(rtems_filesystem_location_info_t *loc)
>      return fat_file_reopen(fat_fd);
> +static int msdos_utime(
> +  const rtems_filesystem_location_info_t *loc,
> +  time_t                                  actime,
> +  time_t                                  modtime
> +    fat_file_fd_t *fat_fd = loc->node_access;
> +    if (actime != modtime)
> +        rtems_set_errno_and_return_minus_one( ENOTSUP );
> +    fat_fd->mtime = modtime;
> +    return RC_OK;
>  const rtems_filesystem_operations_table  msdos_ops = {
>    .lock_h         =  msdos_lock,
>    .unlock_h       =  msdos_unlock,
> @@ -52,7 +68,7 @@ const rtems_filesystem_operations_table  msdos_ops = {
>    .fsmount_me_h   =  rtems_dosfs_initialize,
>    .unmount_h      =  rtems_filesystem_default_unmount,
>    .fsunmount_me_h =  msdos_shut_down,
> -  .utime_h        =  rtems_filesystem_default_utime,
> +  .utime_h        =  msdos_utime,
>    .symlink_h      =  rtems_filesystem_default_symlink,
>    .readlink_h     =  rtems_filesystem_default_readlink,
>    .rename_h       =  msdos_rename,
> diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c b/cpukit/libfs/src/dosfs/msdos_misc.c
> index 03ec38f..8223653 100644
> --- a/cpukit/libfs/src/dosfs/msdos_misc.c
> +++ b/cpukit/libfs/src/dosfs/msdos_misc.c
> @@ -380,6 +380,11 @@ msdos_find_name(
>          fat_fd->mtime = msdos_date_dos2unix(CF_LE_W(date), CF_LE_W(time_val));
> +        time_val = *MSDOS_DIR_CRT_TIME(node_entry);
> +        date = *MSDOS_DIR_CRT_DATE(node_entry);
> +        fat_fd->ctime = msdos_date_dos2unix(CF_LE_W(date), CF_LE_W(time_val));
>          if ((*MSDOS_DIR_ATTR(node_entry)) & MSDOS_ATTR_DIRECTORY)
> @@ -670,12 +675,12 @@ msdos_get_dotdot_dir_info_cluster_num_and_offset(
> -/* msdos_set_dir_wrt_time_and_date --
> +/* fat_file_set_time_and_date --
>   *     Write last write date and time for a file to the disk (to corresponded
>   *     32bytes node)
>   * PARAMETERS:
> - *     mt_entry - mount table entry
> + *     fs_info  - fat fs info
>   *     fat_fd   - fat-file descriptor
>   * RETURNS:
> @@ -683,50 +688,69 @@ msdos_get_dotdot_dir_info_cluster_num_and_offset(
>  int
> -msdos_set_dir_wrt_time_and_date(
> +    fat_fs_info_t                        *fs_info,
> -    ssize_t          ret1 = 0, ret2 = 0, ret3 = 0;
> -    msdos_fs_info_t *fs_info = mt_entry->fs_info;
> +    int              rc = RC_OK;
> +    ssize_t          ret;
>      uint16_t         time_val;
>      uint16_t         date;
>      uint32_t         sec = 0;
>      uint32_t         byte = 0;
> -    msdos_date_unix2dos(fat_fd->mtime, &date, &time_val);
>       * calculate input for fat_sector_write: convert (cluster num, offset) to
>       * (sector num, new offset)
> -    sec = fat_cluster_num_to_sector_num(&fs_info->fat, fat_fd->dir_pos.sname.cln);
> -    sec += (fat_fd->dir_pos.sname.ofs >> fs_info->fat.vol.sec_log2);
> +    sec = fat_cluster_num_to_sector_num(fs_info, fat_fd->dir_pos.sname.cln);
> +    sec += (fat_fd->dir_pos.sname.ofs >> fs_info->vol.sec_log2);
>      /* byte points to start of 32bytes structure */
> -    byte = fat_fd->dir_pos.sname.ofs & (fs_info->fat.vol.bps - 1);
> +    byte = fat_fd->dir_pos.sname.ofs & (fs_info->vol.bps - 1);
> +    msdos_date_unix2dos(fat_fd->mtime, &date, &time_val);
>      time_val = CT_LE_W(time_val);
> -    ret1 = fat_sector_write(&fs_info->fat, sec, byte + MSDOS_FILE_WTIME_OFFSET,
> -                            2, (char *)(&time_val));
> +    ret = fat_sector_write(fs_info, sec, byte + MSDOS_FILE_WTIME_OFFSET,
> +                           2, (char *)(&time_val));
> +    if ( ret < 0 )
> +        rc = -1;
>      date = CT_LE_W(date);
> -    ret2 = fat_sector_write(&fs_info->fat, sec, byte + MSDOS_FILE_WDATE_OFFSET,
> -                            2, (char *)(&date));
> -    ret3 = fat_sector_write(&fs_info->fat, sec, byte + MSDOS_FILE_ADATE_OFFSET,
> +    ret = fat_sector_write(fs_info, sec, byte + MSDOS_FILE_WDATE_OFFSET,
> +                           2, (char *)(&date));
> +    if ( ret < 0 )
> +        rc = -1;
> -    if ( (ret1 < 0) || (ret2 < 0) || (ret3 < 0) )
> -        return -1;
> +    ret = fat_sector_write(fs_info, sec, byte + MSDOS_FILE_ADATE_OFFSET,
> +    if ( ret < 0 )
> +        rc = -1;
> -    return RC_OK;
> +    msdos_date_unix2dos(fat_fd->ctime, &date, &time_val);
> +    time_val = CT_LE_W(time_val);
> +    ret = fat_sector_write(fs_info, sec, byte + MSDOS_FILE_CTIME_OFFSET,
> +    if ( ret < 0 )
> +        rc = -1;
> +    date = CT_LE_W(date);
> +    ret = fat_sector_write(fs_info, sec, byte + MSDOS_FILE_CDATE_OFFSET,
> +    if ( ret < 0 )
> +        rc = -1;
> +    return rc;
> -/* msdos_set_first_cluster_num --
> +/* fat_set_first_cluster_num --
>   *     Write number of first cluster of the file to the disk (to corresponded
>   *     32bytes slot)
>   * PARAMETERS:
>   * RETURNS:
> @@ -734,13 +758,12 @@ msdos_set_dir_wrt_time_and_date(
>  int
> -msdos_set_first_cluster_num(
>      ssize_t          ret1 = 0, ret2 = 0;
>      uint32_t         new_cln = fat_fd->cln;
>      uint16_t         le_cl_low = 0;
>      uint16_t         le_cl_hi = 0;
> @@ -751,17 +774,17 @@ msdos_set_first_cluster_num(
>      /* byte from points to start of 32bytes structure */
>      le_cl_low = CT_LE_W((uint16_t  )(new_cln & 0x0000FFFF));
> +    ret1 = fat_sector_write(fs_info, sec,
>                              byte + MSDOS_FIRST_CLUSTER_LOW_OFFSET, 2,
>                              (char *)(&le_cl_low));
>      le_cl_hi = CT_LE_W((uint16_t  )((new_cln & 0xFFFF0000) >> 16));
> +    ret2 = fat_sector_write(fs_info, sec,
>                              byte + MSDOS_FIRST_CLUSTER_HI_OFFSET, 2,
>                              (char *)(&le_cl_hi));
>      if ( (ret1 < 0) || (ret2 < 0) )
> @@ -771,11 +794,11 @@ msdos_set_first_cluster_num(
> -/* msdos_set_file size --
> +/* fat_set_file size --
>   *     Write file size of the file to the disk (to corresponded 32bytes slot)
>   * PARAMETERS:
>   * RETURNS:
> @@ -783,23 +806,22 @@ msdos_set_first_cluster_num(
>  int
> -msdos_set_file_size(
>      ssize_t          ret = 0;
>      uint32_t         le_new_length = 0;
>      uint32_t         sec = 0;
>      uint32_t         byte = 0;
> -    byte = (fat_fd->dir_pos.sname.ofs & (fs_info->fat.vol.bps - 1));
> +    byte = (fat_fd->dir_pos.sname.ofs & (fs_info->vol.bps - 1));
>      le_new_length = CT_LE_L((fat_fd->fat_file_size));
> -    ret = fat_sector_write(&fs_info->fat, sec, byte + MSDOS_FILE_SIZE_OFFSET, 4,
> +    ret = fat_sector_write(fs_info, sec, byte + MSDOS_FILE_SIZE_OFFSET, 4,
>                             (char *)(&le_new_length));
>      if ( ret < 0 )
>          return -1;
> 1.8.4.5
> devel mailing list
> devel at rtems.org
